[PATCH v2 0/4] libbsd: Create some basic buildsets.
Christian Mauderer christian.mauderer at embedded-brains.de
Fri Apr 27 11:17:47 UTC 2018
An updated patch set for this toppic: The last patch should now cleanly
disable all INET6 in the minimal configuration. That reduced the code
size of the media01 test in the minimal configuration for another 60k:
   > arm-rtems5-size build/arm-rtems5-atsamv-*/media01.exe
   text    data     bss     dec     hex filename
   2430820  211448 30922152        33564420        2002704 build/arm-rtems5-atsamv-default/media01.exe
   3068860  211816 30283752        33564428        200270c build/arm-rtems5-atsamv-everything/media01.exe
   2225180  199324 31139880        33564384        20026e0 build/arm-rtems5-atsamv-minimal/media01.exe
If no one objects, I would like to push these patches somewhere arround
Wednesday next week and close ticket #3351 (as soon as I found out how
to change the title so that it reflects that the compiler flags are now
not based on the build sets).
Best regards
Christian
