odd waf error from examples-v2
Joel Sherrill
joel at rtems.org
Fri Apr 27 13:36:16 UTC 2018
OK .. the waf in my git clone is OK but the copy of waf-2.0.7 I downloaded
and dropped in the top directory doesn't work:
[joel at rtbf64c examples-v2]$ ./waf distclean
Traceback (most recent call last):
File "./waf", line 164, in <module>
from waflib import Scripting
ImportError: No module named waflib
[joel at rtbf64c examples-v2]$ ~/waf/waf/waf distclean
'distclean' finished successfully (0.001s)
Any thoughts?
On Thu, Apr 26, 2018 at 8:57 PM, Joel Sherrill <joel at rtems.org> wrote:
> On Thu, Apr 26, 2018, 8:23 PM Chris Johns <chrisj at rtems.org> wrote:
>> On 26/04/2018 23:42, Joel Sherrill wrote:
>> > Hi
>> > I am getting this on rtbf64c which is running this version of CentOS:
>> > CentOS Linux release 7.4.1708 (Core)
>> > It doesn't occur on my VM which has the same version:
>> > $ cat /etc/redhat-release
>> > Any ideas?
>> Please try the latest version of waf.
> I tried the latest release from waf.io and it worked for me on a single
> BSP. I left a build of all going overnight and will review results as soon
> as I can.
>> If successful please update the version in the repo.
> Ok. Will push in the morning.
> I have typo fixes for incorrect BSP names in the tester. I will push them
> if ok. That will leave epiphany network issue.
>> Thank you.
>> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180427/2024a10f/attachment.html>
