[PATCH] covoar: Add symbol set reader and ELF data parser to covoar.
Cillian O'Donnell
cpodonnell8 at gmail.com
Sat Apr 28 18:34:28 UTC 2018
On 28 April 2018 at 17:29, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
wrote:
> I'm getting the following error after applying the patch:
Did you apply it to the current rtems-tools master? It's building fine for
me.
> ./waf build install
> Waf: Entering directory `/home/lunatic/development/
> rtems/test/rtems-tools/build'
> Traceback (most recent call last):
> File "/home/lunatic/development/rtems/test/rtems-tools/.waf-1.9.9-
> 75529a659e4f06cb4254801e52405e0a/waflib/Scripting.py", line 120, in
> waf_entry_point
> run_commands()
> 75529a659e4f06cb4254801e52405e0a/waflib/Scripting.py", line 181, in
> run_commands
> ctx=run_command(cmd_name)
> 75529a659e4f06cb4254801e52405e0a/waflib/Scripting.py", line 172, in
> run_command
> ctx.execute()
> 75529a659e4f06cb4254801e52405e0a/waflib/Scripting.py", line 362, in
> execute
> return execute_method(self)
> 75529a659e4f06cb4254801e52405e0a/waflib/Build.py", line 99, in execute
> self.execute_build()
> 75529a659e4f06cb4254801e52405e0a/waflib/Build.py", line 102, in
> execute_build
> self.recurse([self.run_dir])
> 75529a659e4f06cb4254801e52405e0a/waflib/Context.py", line 129, in recurse
> user_function(self)
> File "/home/lunatic/development/rtems/test/rtems-tools/wscript", line
> 134, in build
> recurse(ctx)
> 81, in recurse
> ctx.recurse(sd)
> user_function(self)
> File "/home/lunatic/development/rtems/test/rtems-tools/tester/wscript",
> line 48, in build
> recurse(bld)
> line 35, in recurse
> ctx.recurse(sd)
> user_function(self)
> File "/home/lunatic/development/rtems/test/rtems-tools/tester/covoar/wscript",
> line 115, in build
> use = ['ccovoar'] + modules,
> NameError: global name 'modules' is not defined
> -- vijay
> On 28 April 2018 at 21:54, Cillian O'Donnell <cpodonnell8 at gmail.com>
> wrote:
>> On 28 April 2018 at 08:08, Chris Johns <chrisj at rtems.org> wrote:
>>> From: Cillian O'Donnell <cpodonnell8 at gmail.com>
>>> Add ability to organize symbol sets of libraries in INI file
>>> and then read them with covoar and load the symbols directly from the
>>> libraries.
>>> rtems-tools/../testing: Add configuration files for coverage analysis.
>>> A number of covoar options are not required and are defaulted.
>>> Co-author: Krzysztof Miesowicz <krzysztof.miesowicz at gmail.com>
>>> Co-author: Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
>>> Cp-author: Chris Johns <chrisj at rtems.org>
>>> tester/covoar/DesiredSymbols.cc | 144 +++++-----
>>> tester/covoar/DesiredSymbols.h | 14 +-
>>> tester/covoar/ExecutableInfo.cc | 4 +-
>>> tester/covoar/ExecutableInfo.h | 6 +-
>>> tester/covoar/ObjdumpProcessor.cc | 6 +-
>>> tester/covoar/app_common.h | 9 +-
>>> tester/covoar/covoar.cc | 300
>>> tester/covoar/wscript | 2 +
>>> tester/rtems/testing/bsps/leon3-qemu-cov.ini | 39 +++
>>> tester/rtems/testing/bsps/leon3-qemu.ini | 38 +++
>>> tester/rtems/testing/coverage/Categories.txt | 19 ++
>>> tester/rtems/testing/coverage/Explanations.txt | 35 +++
>>> .../coverage/SPARC-Annul-Slot-Explanation.txt | 56 ++++
>>> tester/rtems/testing/coverage/score-symbols.ini | 35 +++
>>> tester/rtems/testing/coverage/style.css | 197 ++++++++++++++
>>> tester/rtems/testing/qemu.cfg | 11 +-
>>> tester/rtems/testing/testing.mc | 8 +
>>> 17 files changed, 737 insertions(+), 186 deletions(-)
>>> create mode 100644 tester/rtems/testing/bsps/leon3-qemu-cov.ini
>>> create mode 100644 tester/rtems/testing/bsps/leon3-qemu.ini
>>> create mode 100644 tester/rtems/testing/coverage/Categories.txt
>>> create mode 100644 tester/rtems/testing/coverage/Explanations.txt
>>> create mode 100644 tester/rtems/testing/coverage/score-symbols.ini
>>> create mode 100644 tester/rtems/testing/coverage/style.css
>>> diff --git a/tester/covoar/DesiredSymbols.cc
>>> b/tester/covoar/DesiredSymbols.cc
>>> index 00d1984..9957b28 100644
>>> --- a/tester/covoar/DesiredSymbols.cc
>>> +++ b/tester/covoar/DesiredSymbols.cc
>>> @@ -16,6 +16,13 @@
>>> #include <string.h>
>>> #include <unistd.h>
>>> +#include <iostream>
>>> +#include "rld.h"
>>> +#include <rld-config.h>
>>> +#include "rld-symbols.h"
>>> +#include "rld-files.h"
>>> #include "DesiredSymbols.h"
>>> #include "app_common.h"
>>> #include "CoverageMap.h"
>>> @@ -31,75 +38,90 @@ namespace Coverage {
>>> - void DesiredSymbols::load(
>>> - const char* const symbolsFile
>>> + bool DesiredSymbols::load(
>>> + const std::string& symbolsSet,
>>> + const std::string& buildTarget,
>>> + const std::string& buildBSP,
>>> + bool verbose
>>> - int cStatus;
>>> - bool done = false;
>>> - FILE* sFile;
>>> - SymbolInformation* symInfo;
>>> - int line = 1;
>>> - std::string symbol;
>>> - // Ensure that symbols file name is given.
>>> - if ( !symbolsFile ) {
>>> - fprintf(
>>> - stderr,
>>> - "ERROR: DesiredSymbols::load - no symbols file specified\n"
>>> - exit(-1);
>>> - // Open symbols file.
>>> - sFile = fopen( symbolsFile, "r" );
>>> - if ( !sFile ) {
>>> - fprintf(
>>> - stderr,
>>> - "ERROR: DesiredSymbols::load - unable to open symbols file
>>> %s\n",
>>> - symbolsFile
>>> - exit(-1);
>>> - // Process symbols file.
>>> - while ( !done ) {
>>> - symInfo = new SymbolInformation;
>>> - // Skip blank lines between symbols
>>> - do {
>>> - inputBuffer[0] = '\0';
>>> - inputBuffer2[0] = '\0';
>>> - cStatus = fscanf( sFile, "%s %s", inputBuffer, inputBuffer2 );
>>> - if ( cStatus == EOF ) {
>>> - done = true;
>>> + rld::files::cache cache;
>>> + bool r = true;
>>> + // Load the INI file looking for a top level:
>>> + // [symbols-sets]
>>> + // sets = A, B, C
>>> + // For each set read the libraries from the configuration file and
>>> load.
>>> + // [A]
>>> + // libraries = @BUILD-PREFIX@/c/@BSP@/A/libA.a
>>> + // [B]
>>> + // libraries = @BUILD-PREFIX@/c/@BSP@/B/libB.a
>>> + try {
>>> + cache.open();
>>> + rld::config::config config;
>>> + if (verbose)
>>> + std::cerr << "Loading symbol sets: " << symbolsSet << std::endl;
>>> + config.load (symbolsSet);
>>> + const rld::config::section& sym_section =
>>> config.get_section("symbol-sets");
>>> + rld::strings sets;
>>> + rld::config::parse_items (sym_section, "sets", sets, true);
>>> + for (const std::string set : sets) {
>>> + if (verbose)
>>> + std::cerr << " Symbol set: " << set << std::endl;
>>> + const rld::config::section& set_section =
>>> config.get_section(set);
>>> + rld::strings libs;
>>> + rld::config::parse_items (set_section, "libraries", libs, true);
>>> + for (std::string lib : libs) {
>>> + lib = rld::find_replace(lib, "@BUILD-TARGET@", buildTarget);
>>> + lib = rld::find_replace(lib, "@BSP@", buildBSP);
>>> + if (verbose)
>>> + std::cerr << " Loading library: " << lib << std::endl;
>>> + cache.add(lib);
>>> - else {
>>> - //inputBuffer[ strlen(inputBuffer) - 1] = '\0';
>>> - line++;
>>> - } while ( !done && (inputBuffer[0] == '\0') );
>>> - // Have we already seen this one?
>>> - if ( !done ) {
>>> - if (set.find( inputBuffer ) != set.end()) {
>>> - fprintf(
>>> - stderr,
>>> - "File: %s, Line %d: Duplicate symbol: %s\n",
>>> - symbolsFile,
>>> - line,
>>> - inputBuffer
>>> + rld::symbols::table symbols;
>>> - delete symInfo;
>>> + cache.load_symbols (symbols, true);
>>> - // Add this to the set of symbols.
>>> - else
>>> - set[ inputBuffer ] = *symInfo;
>>> + for (auto& kv : symbols.globals()) {
>>> + const rld::symbols::symbol& sym = *(kv.second);
>>> + set[sym.name()] = *(new SymbolInformation);
>>> + for (auto& kv : symbols.weaks()) {
>>> + for (auto& kv : symbols.locals()) {
>>> + } catch (rld::error re) {
>>> + std::cerr << "error: "
>>> + << re.where << ": " << re.what
>>> + << std::endl;
>>> + r = false;
>>> + } catch (...) {
>>> + cache.close();
>>> + throw;
>>> + cache.close();
>>> + return r;
>>> void DesiredSymbols::preprocess( void )
>>> diff --git a/tester/covoar/DesiredSymbols.h
>>> b/tester/covoar/DesiredSymbols.h
>>> index 9524c64..21c5602 100644
>>> --- a/tester/covoar/DesiredSymbols.h
>>> +++ b/tester/covoar/DesiredSymbols.h
>>> @@ -293,9 +293,17 @@ namespace Coverage {
>>> * This method creates the set of symbols to analyze from the
>>> symbols
>>> * listed in the specified file.
>>> - void load(
>>> + * @param[in] symbolsSet An INI format file of the symbols to be
>>> loaded.
>>> + * @param[in] buildTarget The build target
>>> + * @param[in] buildBSP The BSP
>>> + * @return Returns false if the load fails.
>>> + bool load(
>>> + bool verbose
>>> diff --git a/tester/covoar/ExecutableInfo.cc
>>> b/tester/covoar/ExecutableInfo.cc
>>> index d71c435..c41d931 100644
>>> --- a/tester/covoar/ExecutableInfo.cc
>>> +++ b/tester/covoar/ExecutableInfo.cc
>>> @@ -67,12 +67,12 @@ namespace Coverage {
>>> return aCoverageMap;
>>> - std::string ExecutableInfo::getFileName ( void ) const
>>> + const std::string& ExecutableInfo::getFileName ( void ) const
>>> return executableName;
>>> - std::string ExecutableInfo::getLibraryName( void ) const
>>> + const std::string& ExecutableInfo::getLibraryName( void ) const
>>> return libraryName;
>>> diff --git a/tester/covoar/ExecutableInfo.h
>>> b/tester/covoar/ExecutableInfo.h
>>> index 7242715..20ea9bf 100644
>>> --- a/tester/covoar/ExecutableInfo.h
>>> +++ b/tester/covoar/ExecutableInfo.h
>>> @@ -67,14 +67,14 @@ namespace Coverage {
>>> * @return Returns the executable's file name
>>> - std::string getFileName( void ) const;
>>> + const std::string& getFileName( void ) const;
>>> * This method returns the library name associated with the
>>> executable.
>>> * @return Returns the executable's library name
>>> - std::string getLibraryName( void ) const;
>>> + const std::string& getLibraryName( void ) const;
>>> * This method returns the load address of the dynamic library
>>> @@ -111,7 +111,7 @@ namespace Coverage {
>>> * This method indicates whether a dynamic library has been
>>> * associated with the executable.
>>> - * @return Returns TRUE if
>>> + * @return Returns TRUE if
>>> bool hasDynamicLibrary( void );
>>> diff --git a/tester/covoar/ObjdumpProcessor.cc
>>> b/tester/covoar/ObjdumpProcessor.cc
>>> index b916984..d41906c 100644
>>> --- a/tester/covoar/ObjdumpProcessor.cc
>>> +++ b/tester/covoar/ObjdumpProcessor.cc
>>> @@ -247,15 +247,15 @@ namespace Coverage {
>>> try
>>> status = rld::process::execute( TargetInfo->getObjdump(),
>>> - args, objdumpFile.name(), err.name() );
>>> + args, objdumpFile.name(),
>>> err.name() );
>>> if ( (status.type != rld::process::status::normal)
>>> || (status.code != 0) ) {
>>> throw rld::error( "Objdump error", "generating objdump" );
>>> } catch( rld::error& err )
>>> - std::cout << "Error while running" << TargetInfo->getObjdump()
>>> - << "for" << fileName << std::endl;
>>> + std::cout << "Error while running " << TargetInfo->getObjdump()
>>> + << " on " << fileName << std::endl;
>>> std::cout << err.what << " in " << err.where << std::endl;
>>> return;
>>> diff --git a/tester/covoar/app_common.h b/tester/covoar/app_common.h
>>> index d28bfd0..ac32bbd 100644
>>> --- a/tester/covoar/app_common.h
>>> +++ b/tester/covoar/app_common.h
>>> @@ -1,6 +1,11 @@
>>> #ifndef __APP_COMMON_h
>>> #define __APP_COMMON_h
>>> + * This file needs to be removed and these globals removed from the
>>> + * global scope. For example SymbolsToAnalyze is never destructed.
>>> #include <list>
>>> @@ -22,8 +27,8 @@ extern char
>>> inputBuffer[MAX_LINE_LENGTH];
>>> extern char inputBuffer2[MAX_LINE_LENGTH];
>>> -bool FileIsNewer( const char *f1, const char *f2 );
>>> -bool FileIsReadable( const char *f1 );
>>> +bool FileIsNewer( const char *f1, const char *f2 );
>>> +bool FileIsReadable( const char *f1 );
>>> bool ReadUntilFound( FILE *file, const char *line );
>>> #endif
>>> diff --git a/tester/covoar/covoar.cc b/tester/covoar/covoar.cc
>>> index c36b00a..81c90d2 100644
>>> --- a/tester/covoar/covoar.cc
>>> +++ b/tester/covoar/covoar.cc
>>> @@ -29,34 +29,92 @@
>>> #define kill(p,s) raise(s)
>>> #endif
>>> +typedef std::list<std::string> CoverageNames;
>>> +typedef std::list<Coverage::ExecutableInfo*> Executables;
>>> - * Variables to control general behavior
>>> + * Create a build path from the executable paths. Also extract the
>>> build prefix
>>> + * and BSP names.
>>> -const char* coverageFileExtension = NULL;
>>> -std::list<std::string> coverageFileNames;
>>> -int coverageExtensionLength = 0;
>>> -Coverage::CoverageFormats_t coverageFormat;
>>> -Coverage::CoverageReaderBase* coverageReader = NULL;
>>> -char* executable = NULL;
>>> -const char* executableExtension = NULL;
>>> -int executableExtensionLength = 0;
>>> -std::list<Coverage::ExecutableInfo*> executablesToAnalyze;
>>> -const char* explanations = NULL;
>>> -char* progname;
>>> -const char* symbolsFile = NULL;
>>> -const char* gcnosFileName = NULL;
>>> -char gcnoFileName[FILE_NAME_LENGTH];
>>> -char gcdaFileName[FILE_NAME_LENGTH];
>>> -char gcovBashCommand[256];
>>> -const char* target = NULL;
>>> -const char* format = NULL;
>>> -FILE* gcnosFile = NULL;
>>> -Gcov::GcovData* gcovFile;
>>> +static void createBuildPath(Executables& executablesToAnalyze,
>>> + std::string& buildPath,
>>> + std::string& buildPrefix,
>>> + std::string& buildBSP)
>>> + for (const auto& exe : executablesToAnalyze) {
>>> + rld::strings eparts;
>>> + rld::split(eparts, rld::path::path_abs(exe->getFileName()),
>>> RLD_PATH_SEPARATOR);
>>> + std::string fail; // empty means all is OK else an error string
>>> + for (rld::path::paths::reverse_iterator pri = eparts.rbegin();
>>> + pri != eparts.rend();
>>> + ++pri) {
>>> + if (*pri == "testsuites") {
>>> + ++pri;
>>> + if (pri == eparts.rend()) {
>>> + fail = "invalid executable path, no BSP";
>>> + break;
>>> + if (buildBSP.empty()) {
>>> + buildBSP = *pri;
>>> + } else {
>>> + if (buildBSP != *pri) {
>>> + fail = "executable BSP does not match: " + buildBSP;
>>> + break;
>>> + ++pri;
>>> + if (pri == eparts.rend() || *pri != "c") {
>>> + fail = "invalid executable path, no 'c'";
>>> + break;
>>> + ++pri;
>>> + fail = "invalid executable path, no arch prefix";
>>> + break;
>>> + if (buildPrefix.empty()) {
>>> + buildPrefix = *pri;
>>> + } else {
>>> + fail = "executable build prefix does not match: " +
>>> buildPrefix;
>>> + break;
>>> + ++pri;
>>> + fail = "invalid executable path, no build top";
>>> + break;
>>> + // The remaining parts of the path is the build path. Iterator
>>> over them
>>> + // and collect into a new paths variable to join to make a path.
>>> + rld::path::paths bparts;
>>> + for (; pri != eparts.rend(); ++pri)
>>> + bparts.insert(bparts.begin(), *pri);
>>> + std::string thisBuildPath;
>>> + rld::path::path_join(thisBuildPath, bparts, thisBuildPath);
>>> + if (buildPath.empty()) {
>>> + buildPath = thisBuildPath;
>>> + } else {
>>> + fail = "executable build path does not match: " + buildPath;
>>> + break;
>>> + if (!fail.empty()) {
>>> + std::cerr << "ERROR: " << fail << std::endl;
>>> + exit(EXIT_FAILURE);
>>> * Print program usage message
>>> -void usage()
>>> +void usage(const std::string& progname)
>>> fprintf(
>>> stderr,
>>> @@ -69,17 +127,18 @@ void usage()
>>> " -f FORMAT - coverage file format "
>>> "(RTEMS, QEMU, TSIM or Skyeye)\n"
>>> " -E EXPLANATIONS - name of file with explanations\n"
>>> - " -s SYMBOLS_FILE - name of file with symbols of
>>> interest\n"
>>> + " -s SYMBOL_SET_FILE - path to the INI format symbol sets\n"
>>> " -1 EXECUTABLE - name of executable to get symbols
>>> from\n"
>>> " -e EXE_EXTENSION - extension of the executables to
>>> analyze\n"
>>> " -c COVERAGEFILE_EXTENSION - extension of the coverage files to
>>> analyze\n"
>>> " -g GCNOS_LIST - name of file with list of *.gcno
>>> files\n"
>>> " -p PROJECT_NAME - name of the project\n"
>>> " -C ConfigurationFileName - name of configuration file\n"
>>> - " -O Output_Directory - name of output directory (default=."
>>> + " -O Output_Directory - name of output directory
>>> (default=.\n"
>>> + " -d debug - disable cleaning of tempfiles."
>>> "\n",
>>> - progname,
>>> - progname
>>> + progname.c_str(),
>>> + progname.c_str()
>>> @@ -125,42 +184,58 @@ int main(
>>> char** argv
>>> - std::list<std::string>::iterator citr;
>>> - std::string coverageFileName;
>>> - std::list<Coverage::ExecutableInfo*>::iterator eitr;
>>> - Coverage::ExecutableInfo* executableInfo = NULL;
>>> - int i;
>>> - int opt;
>>> - const char* singleExecutable =
>>> NULL;
>>> - rld::process::tempfile objdumpFile( ".dmp" );
>>> - rld::process::tempfile err( ".err" );
>>> - bool debug = false;
>>> - std::string option;
>>> + CoverageNames coverageFileNames;
>>> + std::string coverageFileName;
>>> + Executables executablesToAnalyze;
>>> + Coverage::ExecutableInfo* executableInfo = NULL;
>>> + std::string executableExtension = "exe";
>>> + std::string coverageExtension = "cov";
>>> + Coverage::CoverageFormats_t coverageFormat;
>>> + Coverage::CoverageReaderBase* coverageReader = NULL;
>>> + char* executable = NULL;
>>> + const char* explanations = NULL;
>>> + const char* gcnosFileName = NULL;
>>> + char gcnoFileName[FILE_NAME_LENGTH];
>>> + char gcdaFileName[FILE_NAME_LENGTH];
>>> + char gcovBashCommand[256];
>>> + std::string target;
>>> + const char* format = "html";
>>> + FILE* gcnosFile = NULL;
>>> + Gcov::GcovData* gcovFile;
>>> + const char* singleExecutable = NULL;
>>> + rld::process::tempfile objdumpFile( ".dmp" );
>>> + rld::process::tempfile err( ".err" );
>>> + rld::process::tempfile syms( ".syms" );
>>> + bool debug = false;
>>> + std::string symbolSet;
>>> + std::string progname;
>>> + std::string option;
>>> + int opt;
>>> setup_signals();
>>> // Process command line options.
>>> - progname = argv[0];
>>> + progname = rld::path::basename(argv[0]);
>>> - while ((opt = getopt(argc, argv, "1:L:e:c:g:E:f:s:T:O:p:v:d")) != -1)
>>> + while ((opt = getopt(argc, argv, "1:L:e:c:g:E:f:s:S:T:O:p:vd")) !=
>>> -1) {
>>> switch (opt) {
>>> - case '1': singleExecutable = optarg; break;
>>> - case 'L': dynamicLibrary = optarg; break;
>>> - case 'e': executableExtension = optarg; break;
>>> - case 'c': coverageFileExtension = optarg; break;
>>> - case 'g': gcnosFileName = optarg; break;
>>> - case 'E': explanations = optarg; break;
>>> - case 'f': format = optarg; break;
>>> - case 's': symbolsFile = optarg; break;
>>> - case 'T': target = optarg; break;
>>> - case 'O': outputDirectory = optarg; break;
>>> - case 'v': Verbose = true; break;
>>> - case 'p': projectName = optarg; break;
>>> - case 'd': debug = true; break;
>>> + case '1': singleExecutable = optarg; break;
>>> + case 'L': dynamicLibrary = optarg; break;
>>> + case 'e': executableExtension = optarg; break;
>>> + case 'c': coverageExtension = optarg; break;
>>> + case 'g': gcnosFileName = optarg; break;
>>> + case 'E': explanations = optarg; break;
>>> + case 'f': format = optarg; break;
>>> + case 'S': symbolSet = optarg; break;
>>> + case 'T': target = optarg; break;
>>> + case 'O': outputDirectory = optarg; break;
>>> + case 'v': Verbose = true; break;
>>> + case 'p': projectName = optarg; break;
>>> + case 'd': debug = true; break;
>>> default: /* '?' */
>>> - usage();
>>> + usage(progname);
>>> exit(EXIT_FAILURE);
>>> @@ -171,18 +246,10 @@ int main(
>>> - * Target name must be set.
>>> + * Validate that we have a symbols of interest file.
>>> - if ( !target ) {
>>> - option = "target -T";
>>> - throw option;
>>> - * Validate simulator format.
>>> - if ( !format ) {
>>> - option = "format -f";
>>> + if ( symbolSet.empty() ) {
>>> + option = "symbol set file -S";
>>> throw option;
>>> @@ -194,22 +261,6 @@ int main(
>>> throw option;
>>> - * Has coverage file extension been specified.
>>> - if ( !coverageFileExtension ) {
>>> - option = "coverage extension -c";
>>> - throw option;
>>> - * Has executable extension been specified.
>>> - if ( !executableExtension ) {
>>> - option = "executable extension -e";
>>> - throw option;
>>> * Check for project name.
>>> @@ -220,8 +271,8 @@ int main(
>>> catch( std::string option )
>>> - std::cout << "error missing option: " + option << std::endl;
>>> - usage();
>>> + std::cerr << "error missing option: " + option << std::endl;
>>> + usage(progname);
>>> exit(EXIT_FAILURE);
>>> @@ -238,7 +289,7 @@ int main(
>>> } else {
>>> - for (i=optind; i < argc; i++) {
>>> + for (int i = optind; i < argc; i++) {
>>> // Ensure that the coverage file is readable.
>>> if (!FileIsReadable( argv[i] )) {
>>> fprintf(
>>> @@ -266,11 +317,10 @@ int main(
>>> - // If not invoked with a single executable, process the remaining
>>> - // arguments as executables and derive the coverage file names.
>>> else {
>>> - for (i = optind; i < argc; i++) {
>>> + // If not invoked with a single executable, process the remaining
>>> + // arguments as executables and derive the coverage file names.
>>> // Ensure that the executable is readable.
>>> @@ -282,9 +332,9 @@ int main(
>>> } else {
>>> coverageFileName = argv[i];
>>> coverageFileName.replace(
>>> - coverageFileName.length() - executableExtensionLength,
>>> - coverageFileExtension
>>> + coverageFileName.length() - executableExtension.size(),
>>> + executableExtension.size(),
>>> + coverageExtension
>>> if (!FileIsReadable( coverageFileName.c_str() )) {
>>> @@ -310,6 +360,33 @@ int main(
>>> exit(EXIT_FAILURE);
>>> + // The executablesToAnalyze and coverageFileNames containers need
>>> + // to be the name size of some of the code below breaks. Lets
>>> + // check and make sure.
>>> + if (executablesToAnalyze.size() != coverageFileNames.size()) {
>>> + std::cerr << "ERROR: executables and coverage name size mismatch"
>>> << std::endl;
>>> + // Find the top of the BSP's build tree and if we have found the top
>>> + // check the executable is under the same path and BSP.
>>> + std::string buildPath;
>>> + std::string buildTarget;
>>> + std::string buildBSP;
>>> + createBuildPath(executablesToAnalyze,
>>> + buildPath,
>>> + buildTarget,
>>> + buildBSP);
>>> + // Use a command line target if provided.
>>> + if (!target.empty()) {
>>> + buildTarget = target;
>>> if (Verbose) {
>>> if (singleExecutable) {
>>> fprintf(
>>> @@ -323,12 +400,12 @@ int main(
>>> fprintf( stderr, "Coverage Format : %s\n", format );
>>> - fprintf( stderr, "Target : %s\n", PrintableString(target)
>>> + fprintf( stderr, "Target : %s\n", buildTarget.c_str() );
>>> fprintf( stderr, "\n" );
>>> -#if 1
>>> // Process each executable/coverage file pair.
>>> - eitr = executablesToAnalyze.begin();
>>> - for (citr = coverageFileNames.begin();
>>> + Executables::iterator eitr = executablesToAnalyze.begin();
>>> + for (CoverageNames::iterator citr = coverageFileNames.begin();
>>> citr != coverageFileNames.end();
>>> citr++) {
>>> @@ -342,7 +419,6 @@ int main(
>>> if (!singleExecutable)
>>> eitr++;
>>> -#endif
>>> @@ -350,19 +426,22 @@ int main(
>>> // Create data based on target.
>>> - TargetInfo = Target::TargetFactory( target );
>>> + TargetInfo = Target::TargetFactory( buildTarget );
>>> // Create the set of desired symbols.
>>> SymbolsToAnalyze = new Coverage::DesiredSymbols();
>>> - SymbolsToAnalyze->load( symbolsFile );
>>> - if (Verbose) {
>>> - fprintf(
>>> - stderr,
>>> - "Analyzing %u symbols\n",
>>> - (unsigned int) SymbolsToAnalyze->set.size()
>>> + // Read symbol configuration file and load needed symbols.
>>> + if (!SymbolsToAnalyze->load( symbolSet, buildTarget, buildBSP,
>>> Verbose )) {
>>> + if ( Verbose )
>>> + std::cout << "Analyzing " << SymbolsToAnalyze->set.size()
>>> + << " symbols" << std::endl;
>>> // Create explanations.
>>> AllExplanations = new Coverage::Explanations();
>>> if ( explanations )
>>> @@ -379,7 +458,7 @@ int main(
>>> objdumpProcessor = new Coverage::ObjdumpProcessor();
>>> // Prepare each executable for analysis.
>>> - for (eitr = executablesToAnalyze.begin();
>>> + for (Executables::iterator eitr = executablesToAnalyze.begin();
>>> eitr != executablesToAnalyze.end();
>>> eitr++) {
>>> @@ -407,22 +486,19 @@ int main(
>>> - citr != coverageFileNames.end();
>>> - citr++) {
>>> + for (const auto& cname : coverageFileNames) {
>>> if (Verbose) {
>>> fprintf(
>>> stderr,
>>> "Processing coverage file %s for executable %s\n",
>>> - (*citr).c_str(),
>>> + cname.c_str(),
>>> ((*eitr)->getFileName()).c_str()
>>> // Process its coverage file.
>>> - coverageReader->processFile( (*citr).c_str(), *eitr );
>>> + coverageReader->processFile( cname.c_str(), *eitr );
>>> // Merge each symbols coverage map into a unified coverage map.
>>> (*eitr)->mergeCoverage();
>>> @@ -524,6 +600,8 @@ int main(
>>> objdumpFile.keep();
>>> err.override( "objdump_exec_log" );
>>> err.keep();
>>> + syms.override( "symbols_list" );
>>> + syms.keep();
>>> return 0;
>>> diff --git a/tester/covoar/wscript b/tester/covoar/wscript
>>> index 9db4815..c0270d8 100644
>>> --- a/tester/covoar/wscript
>>> +++ b/tester/covoar/wscript
>>> @@ -118,10 +118,12 @@ def build(bld):
>>> 'TraceWriterQEMU.cc'],
>>> cflags = ['-O2', '-g'],
>>> + cxxflags = ['-std=c++11', '-O2', '-g'],
>>> includes = ['.'] + rtl_includes)
>>> bld.program(target = 'covoar',
>>> source = ['covoar.cc'],
>>> diff --git a/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>>> b/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>>> new file mode 100644
>>> index 0000000..6b5e7e6
>>> --- /dev/null
>>> +++ b/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>>> @@ -0,0 +1,39 @@
>>> +# RTEMS Tools Project (http://www.rtems.org/)
>>> +# Copyright 2010-2018 Chris Johns (chrisj at rtems.org)
>>> +# All rights reserved.
>>> +# This file is part of the RTEMS Tools package in 'rtems-tools'.
>>> +# Redistribution and use in source and binary forms, with or without
>>> +# modification, are permitted provided that the following conditions
>>> are met:
>>> +# 1. Redistributions of source code must retain the above copyright
>>> notice,
>>> +# this list of conditions and the following disclaimer.
>>> +# 2. Redistributions in binary form must reproduce the above copyright
>>> notice,
>>> +# this list of conditions and the following disclaimer in the
>>> documentation
>>> +# and/or other materials provided with the distribution.
>>> +# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
>>> "AS IS"
>>> +# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
>>> THE
>>> +# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
>>> PURPOSE
>>> +# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR
>>> CONTRIBUTORS BE
>>> +# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
>>> +# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
>>> +# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
>>> BUSINESS
>>> +# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER
>>> IN
>>> +# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
>>> OTHERWISE)
>>> +# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED
>>> OF THE
>>> +# POSSIBILITY OF SUCH DAMAGE.
>>> +# The Leon 3 QEMU BSP
>>> +[leon3-qemu]
>>> +bsp = leon3-qemu
>>> +arch = sparc
>>> +tester = %{_rtscripts}/qemu.cfg
>>> +bsp_qemu_opts = %{qemu_opts_base} -M leon3_generic
>>> +bsp_qemu_cov_opts = -exec-trace %{test_executable}.cov
>>> diff --git a/tester/rtems/testing/bsps/leon3-qemu.ini
>>> b/tester/rtems/testing/bsps/leon3-qemu.ini
>>> index 0000000..9e8854c
>>> --- /dev/null
>>> +++ b/tester/rtems/testing/bsps/leon3-qemu.ini
>>> @@ -0,0 +1,38 @@
>>> +# Copyright 2010-2014 Chris Johns (chrisj at rtems.org)
>>> are met:
>>> notice,
>>> notice,
>>> documentation
>>> "AS IS"
>>> THE
>>> PURPOSE
>>> CONTRIBUTORS BE
>>> BUSINESS
>>> IN
>>> OTHERWISE)
>>> OF THE
>>> +[leon3-qemu]
>>> +bsp = leon3-qemu
>>> +arch = sparc
>>> diff --git a/tester/rtems/testing/coverage/Categories.txt
>>> b/tester/rtems/testing/coverage/Categories.txt
>>> index 0000000..e19a456
>>> --- /dev/null
>>> +++ b/tester/rtems/testing/coverage/Categories.txt
>>> @@ -0,0 +1,19 @@
>>> +This is the list of Explanation Categories used when analyzing RTEMS
>>> +Coverage report. By using standard categories, the table filter on
>>> +the web site works better.
>>> +Simple Test Case
>>> +Hard Test Tase
>>> +Uncalled Routine
>>> +Interrupt Critical Section
>>> +Simple Error Case
>>> +Hard Error Case
>>> +Allocation Error
>>> +Bharath Suri
>>> diff --git a/tester/rtems/testing/coverage/Explanations.txt
>>> b/tester/rtems/testing/coverage/Explanations.txt
>>> index 0000000..a5917f6
>>> --- /dev/null
>>> +++ b/tester/rtems/testing/coverage/Explanations.txt
>>> @@ -0,0 +1,35 @@
>>> +schedulerpriorityyield.c:47
>>> +Simple Test Case
>>> +Branch Never Taken
>>> +New test where there is more than one thread at a priority with the
>>> +executing thread being non-preemptive. Create a higher priority thread
>>> +and then yield.
>>> + init task at priority 2, non-preemptive
>>> + create task at priority 2
>>> + create task at priority 1
>>> + yield
>>> +schedulerpriorityyield.c:51
>>> +Simple Test Case
>>> +Branch Always Taken
>>> +New test where only one thread at a priority (non-preemptive), create a
>>> +thread at higher priority, then yield.
>>> + yield
>>> +schedulerpriorityyield.c:52
>>> +Simple Test Case
>>> +Not Executed
>>> +Same test case as schedulerpriorityyield.c:51
>>> +coremsg.c:86
>>> +Simple Test Case
>>> +We need to request enough messages of a certain size that the math
>>> +overflows to less than a single message.
>>> diff --git a/tester/rtems/testing/coverage/SPARC-Annul-Slot-Explanation.txt
>>> b/tester/rtems/testing/coverage/SPARC-Annul-Slot-Explanation.txt
>>> index 0000000..ef740d3
>>> --- /dev/null
>>> +++ b/tester/rtems/testing/coverage/SPARC-Annul-Slot-Explanation.txt
>>> @@ -0,0 +1,56 @@
>>> +The SPARC assembly is often hard to understand because a single
>>> +instruction will show up as not executed. The instructions before
>>> +and after it will be marked as executed. The instruction before
>>> +the one not executed should be a "bxx,a" instruction which means
>>> +that the instruction following the branch instruction is executed
>>> +ONLY if the branch is taken. Otherwise it is "annulled" or skipped.
>>> +So when you see these cases, it means the branch was NOT taken.
>>> +Subject: <offlist> annul slot explanation
>>> +From: Jiri Gaisler <jiri at gaisler.com>
>>> +Date: Wed, 3 Jun 2009 14:57:48 -0500
>>> +To: Joel Sherrill <Joel.Sherrill at OARcorp.com>
>>> +Joel Sherrill wrote:
>>> +> > Hi,
>>> +> > I am trying to look at more coverage cases and
>>> +> > wanted to make sure I am reading things correctly.
>>> +> > The code in question is:
>>> +> > if ( the_thread->current_priority > interested_priority )
>>> +> > 200fd00: d8 00 e0 14 ld [ %g3 + 0x14 ], %o4
>>> +> > 200fd04: 80 a3 00 04 cmp %o4, %g4
>>> +> > 200fd08: 38 80 00 1c bgu,a 200fd78 <killinfo+0x224>
>>> +> > 200fd0c: 98 10 00 04 mov %g4,
>>> +> > %o4 <== NOT EXECUTED
>>> +> > * If this thread is not interested, then go on to the next
>>> thread.
>>> +> > api = the_thread->API_Extensions[ THREAD_API_POSIX ];
>>> +> > 200fd10: d4 00 e1 6c ld [ %g3 + 0x16c ], %o2
>>> +> > Am I correct in interpreting this as meaning 0x200fd0c
>>> +> > is not executed because the bgu,a is never taken. And it
>>> +> > is not executed as part of falling through.
>>> +Yes, this is correct. The branch delay slot is only executed
>>> +when the branch is taken.
>>> +Jiri.
>>> +> > So in this case we need a test where the "if" condition
>>> +> > is true if I am reading things correctly.
>>> +> > Thanks. There are a number of these 4 byte cases which
>>> +> > are probably easy to hit if I read the code correctly.
>>> diff --git a/tester/rtems/testing/coverage/score-symbols.ini
>>> b/tester/rtems/testing/coverage/score-symbols.ini
>>> index 0000000..b3c8b18
>>> --- /dev/null
>>> +++ b/tester/rtems/testing/coverage/score-symbols.ini
>>> @@ -0,0 +1,35 @@
>>> +# Copyright 2018 Chris Johns (chrisj at rtems.org)
>>> are met:
>>> notice,
>>> notice,
>>> documentation
>>> "AS IS"
>>> THE
>>> PURPOSE
>>> CONTRIBUTORS BE
>>> BUSINESS
>>> IN
>>> OTHERWISE)
>>> OF THE
>>> +[symbol-sets]
>>> +sets = score
>>> +[score]
>>> +libraries=@BUILD-TARGET@/c/@BSP@/cpukit/score/libscore.a
>>> diff --git a/tester/rtems/testing/coverage/style.css
>>> b/tester/rtems/testing/coverage/style.css
>>> index 0000000..c715518
>>> --- /dev/null
>>> +++ b/tester/rtems/testing/coverage/style.css
>>> @@ -0,0 +1,197 @@
>>> +body {
>>> + background: rgb(253,253,253);
>>> + color: rgb(0,0,0);
>>> + font-family: helvetica, sans-serif;
>>> + font-size: 1em;
>>> + line-height: 1.4;
>>> + margin: 5px, 5px, 5px, 5px;
>>> + padding: 0;
>>> +a:link {
>>> + color: rgb(180, 50, 50);
>>> + font-size: 1.0em;
>>> +a:visited {
>>> + color: purple;
>>> + font-size: 1.0em;
>>> +a:hover {
>>> + color: rgb(0, 0, 0);
>>> + font-size: 1.0em;
>>> +a:active {
>>> + color: red;
>>> + font-size: 1.0em;
>>> +.heading {
>>> + background: rgb(250,250,250);
>>> + background-image: url("http://www.rtems.org/logos/rtems_logo.jpg");
>>> + background-repeat: no-repeat;
>>> + color: rgb(55,55,55);
>>> + font-size: 1.5em;
>>> + height: 140px;
>>> + padding-top: 20px;
>>> + padding-left: 300px;
>>> +.heading-title {
>>> + text-align: center;
>>> + font-size: 0.9em;
>>> + font-weight: bold;
>>> + padding-top: 5px;
>>> + padding-left: 0px;
>>> + width: 100%;
>>> +.datetime {
>>> + font-size: 0.8em;
>>> + padding-top: 5px;
>>> + width: 100%;
>>> +.info {
>>> + font-size: 0.6em;
>>> + padding-top: 5px;
>>> + padding-left: 00px;
>>> + width: 100%;
>>> +.stats-table {
>>> + background: rgb(225,225,225);
>>> + font-size: 0.9em;
>>> + border: 1px solid rgb(200, 200, 200);
>>> + padding: 0;
>>> + margin-top: 3px;
>>> + margin-left: 10px;
>>> + width: 70%;
>>> +.stats-table-target {
>>> + background: rgb(243,243,243);
>>> + font-size: 1.2em;
>>> + padding-left: 10px;
>>> + text-align: left;
>>> +.stats-target-results {
>>> + font-size: 0.9em;
>>> + text-align: right;
>>> + padding-right: 10px;
>>> +.stats-target-good {
>>> + background: rgb(30,230,30);
>>> + font-size: 0.9em;
>>> + background: rgb(50,180,50);
>>> + color: rgb(230,230,230);
>>> + font-size: 0.9em;
>>> +.stats-target-bad {
>>> + background: rgb(180,50,50);
>>> + font-size: 0.9em;
>>> +.stats-table-top {
>>> + font-size: 0.9em;
>>> + padding-left: 2px;
>>> +.stats-table-row {
>>> + font-size: 0.9em;
>>> + padding: 1px;
>>> +.error-table {
>>> + font-size: 0.9em;
>>> + padding: 0;
>>> + width: 96%;
>>> +.error-table-top {
>>> + font-size: 0.9em;
>>> +.error-table-on {
>>> + font-size: 0.9em;
>>> +.error-table-off {
>>> + font-size: 0.9em;
>>> +.error-table-dups {
>>> + padding-right: 2px;
>>> +.error-table-error {
>>> + background: rgb(255,150,150);
>>> + font-size: 0.9em;
>>> +.error-table-warning {
>>> + font-size: 0.9em;
>>> +.navbar {
>>> + margin-left: auto;
>>> + margin-right: auto;
>>> + margin-top: 10px;
>>> + width: 40%;
>>> +th.table-sortable {
>>> + background-image:url("unsorted.gif");
>>> + cursor: pointer;
>>> + background-position: center left;
>>> + padding-left: 15px;
>>> +th.table-sorted-asc {
>>> + background-image:url("descending.gif");
>>> +th.table-sorted-desc {
>>> + background-image:url("ascending.gif");
>>> \ No newline at end of file
>>> diff --git a/tester/rtems/testing/qemu.cfg b/tester/rtems/testing/
>>> qemu.cfg
>>> index db5b6b2..858cac8 100644
>>> --- a/tester/rtems/testing/qemu.cfg
>>> +++ b/tester/rtems/testing/qemu.cfg
>>> @@ -54,14 +54,23 @@
>>> #%define qemu_opts_base -no-reboot -monitor none -serial stdio
>>> -nographic
>>> %define qemu_opts_base -no-reboot -serial null -serial mon:stdio
>>> -nographic
>>> %define qemu_opts_no_net -net none
>>> +# Converage, some builds of qemu support coverage.
>> Typo Converage. That's the only mistake I can see from reading through.
>> Still have to apply the patches and test.
>> I'll let you know how that goes.
>>> +%ifn %{defined bsp_qemu_ocv_opts}
>>> + %define bsp_qemu_cov_opts %{nil}
>>> +%endif
>>> # Qemu executable
>>> %ifn %{defined bsp_qemu_opts}
>>> %define bsp_qemu_opts %{nil}
>>> %endif
>>> %define qemu_cmd qemu-system-%{bsp_arch}
>>> -%define qemu_opts %{bsp_qemu_opts}
>>> +%define qemu_opts %{bsp_qemu_opts} %{bsp_qemu_cov_opts}
>>> # Executable
>>> diff --git a/tester/rtems/testing/testing.mc b/tester/rtems/testing/
>>> testing.mc
>>> index 77f8419..662b352 100644
>>> --- a/tester/rtems/testing/testing.mc
>>> +++ b/tester/rtems/testing/testing.mc
>>> @@ -55,3 +55,11 @@ timeout: none, none, '180'
>>> # Tests detected as invalid that are valid
>>> invalid_tests: none, none, '''minimum.exe'''
>>> +# Coverage defaults
>>> +cov_format: none, none, 'QEMU'
>>> +cov_explanations: none, none, '%{_rtscripts}/coverage/Expla
>>> nations.txt'
>>> +cov_extension: none, none, 'cov'
>>> +cov_gcnos_file: none, none, '%{_rtscripts}/coverage/rtems
>>> .gcnos'
>>> +cov_exe_ext: none, none, 'exe'
>>> +cov_report_format: none, none, 'html'
>>> 2.15.1
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180428/10a047aa/attachment-0001.html>
