[PATCH] covoar: Add symbol set reader and ELF data parser to covoar.
Cillian O'Donnell cpodonnell8 at gmail.com
Mon Apr 30 05:38:40 UTC 2018
On Sun, 29 Apr 2018, 23:30 Chris Johns, <chrisj at rtems.org> wrote:
> On 29/04/2018 20:50, Cillian O'Donnell wrote:
> > On 28 April 2018 at 08:08, Chris Johns <chrisj at rtems.org
> > <mailto:chrisj at rtems.org>> wrote:
> >     +      for (const std::string set : sets) {
> >     +        if (verbose)
> >     +          std::cerr << " Symbol set: " << set << std::endl;
> >     +        const rld::config::section& set_section =
> config.get_section(set);
> >     +        rld::strings libs;
> >     +        rld::config::parse_items (set_section, "libraries", libs,
> true);
> >     +        for (std::string lib : libs) {
> >     +          lib = rld::find_replace(lib, "@BUILD-TARGET@",
> buildTarget);
> >     +          lib = rld::find_replace(lib, "@BSP@", buildBSP);
> > Problem here. It tries to find the find the library but doesn't have the
> top
> > build directory.
> Yes, this is correct. I have detected the build path in `main` but I
> decided to
> not use it yet and I have not decided if it gets used at all.
Ah ok, you were expecting this.
> I have not looked at or worked on the qemu side of things, that is next. I
> am
> not sure how this effects things so at this point in time you need to be
> at the
> top of the build tree to work. This is not a bad thing, I think covoar is
> leaving temporary files about the place.
Yes the .cov files could be left lying around in the event of a crash. They
are generated while the tests are run, so before covoar starts and then
need to hang around for covoar's use later on. They probably need to be
handled by the tester.
> >     -  while ((opt = getopt(argc, argv, "1:L:e:c:g:E:f:s:T:O:p:v:d")) !=
> -1) {
> >     +  while ((opt = getopt(argc, argv, "1:L:e:c:g:E:f:s:S:T:O:p:vd"))
> != -1) {
> > Missing semicolon between v and d option.
> There is no argument to the -v option. With the ':' the option parsing get
> stuffed up.
Ok, my mistake.
> >          switch (opt) {
> >     -      case '1': singleExecutable      = optarg; break;
> >     -      case 'L': dynamicLibrary        = optarg; break;
> >     -      case 'e': executableExtension   = optarg; break;
> >     -      case 'c': coverageFileExtension = optarg; break;
> >     -      case 'g': gcnosFileName         = optarg; break;
> >     -      case 'E': explanations          = optarg; break;
> >     -      case 'f': format                = optarg; break;
> >     -      case 's': symbolsFile           = optarg; break;
> >     -      case 'T': target                = optarg; break;
> >     -      case 'O': outputDirectory       = optarg; break;
> >     -      case 'v': Verbose               = true;   break;
> See here and also `usage(..)`.
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180430/fac5f926/attachment.html>
