[PATCH 2/3] tests: Remove difftest and sorttimes tools
Mon Apr 30 06:15:51 UTC 2018
Close #3418.
 configure.ac                          |   6 --
 testsuites/tools/Makefile.am          |   6 --
 testsuites/tools/configure.ac         |  21 ----
 testsuites/tools/generic/Makefile.am  |   5 -
 testsuites/tools/generic/configure.ac |  24 -----
 testsuites/tools/generic/difftest.in  | 113 --------------------
 testsuites/tools/generic/sorttimes.in | 189 ----------------------------------
 7 files changed, 364 deletions(-)
 delete mode 100644 testsuites/tools/Makefile.am
 delete mode 100644 testsuites/tools/configure.ac
 delete mode 100644 testsuites/tools/generic/Makefile.am
 delete mode 100644 testsuites/tools/generic/configure.ac
 delete mode 100644 testsuites/tools/generic/difftest.in
 delete mode 100644 testsuites/tools/generic/sorttimes.in
diff --git a/configure.ac b/configure.ac
index 2d0a2056b3..c245c5ab74 100644
--- a/configure.ac
+++ b/configure.ac
@@ -43,12 +43,6 @@ test -z "$RTEMS_CC" && AC_MSG_ERROR([no acceptable cc found in \$PATH])
 RTEMS_BUILD_CONFIG_SUBDIRS([tools/build])
 RTEMS_BUILD_CONFIG_SUBDIRS([tools/cpu])
-case $enable_tests in
-yes | samples )
-  RTEMS_BUILD_CONFIG_SUBDIRS([testsuites/tools])
-esac
 # Some BSPs carelessly apply these tools as build-tools
 AS_IF([test $host != $build],[
 RTEMS_HOST_CONFIG_SUBDIRS([tools/build])
diff --git a/testsuites/tools/Makefile.am b/testsuites/tools/Makefile.am
deleted file mode 100644
index 6033081ace..0000000000
--- a/testsuites/tools/Makefile.am
+++ /dev/null
@@ -1,6 +0,0 @@
-ACLOCAL_AMFLAGS = -I ../../aclocal
-SUBDIRS = @subdirs@
-include $(top_srcdir)/../../automake/subdirs.am
-include $(top_srcdir)/../../automake/host.am
diff --git a/testsuites/tools/configure.ac b/testsuites/tools/configure.ac
index e7ec106608..0000000000
--- a/testsuites/tools/configure.ac
+++ /dev/null
@@ -1,21 +0,0 @@
-## Process this file with autoconf to produce a configure script.
-AC_PREREQ([2.69])
-AC_INIT([rtems-c-src-tests-tools],[_RTEMS_VERSION],[https://devel.rtems.org/newticket])
-AC_CONFIG_SRCDIR([generic])
-RTEMS_TOP([../..],[..])
-RTEMS_SOURCE_TOP
-RTEMS_BUILD_TOP
-RTEMS_CANONICAL_TARGET_CPU
-AM_INIT_AUTOMAKE([no-define foreign subdir-objects 1.12.2])
-AM_MAINTAINER_MODE
-RTEMS_TOOLPATHS
-AC_SUBST(program_prefix)
-AC_CONFIG_SUBDIRS(generic)
-# Explicitly list all Makefiles here
-AC_CONFIG_FILES([Makefile])
-AC_OUTPUT
diff --git a/testsuites/tools/generic/Makefile.am b/testsuites/tools/generic/Makefile.am
index 2b4a6fcef3..0000000000
--- a/testsuites/tools/generic/Makefile.am
+++ /dev/null
@@ -1,5 +0,0 @@
-ACLOCAL_AMFLAGS = -I ../../../aclocal
-bin_SCRIPTS = difftest sorttimes
-include $(top_srcdir)/../../../automake/host.am
diff --git a/testsuites/tools/generic/configure.ac b/testsuites/tools/generic/configure.ac
index 0f775f3631..0000000000
--- a/testsuites/tools/generic/configure.ac
+++ /dev/null
@@ -1,24 +0,0 @@
-AC_PREREQ([2.69])
-AC_INIT([rtems-c-src-tests-tools-generic],[_RTEMS_VERSION],[https://devel.rtems.org/newticket])
-AC_CONFIG_SRCDIR([sorttimes.in])
-RTEMS_TOP(../../..)
-RTEMS_SOURCE_TOP
-RTEMS_BUILD_TOP
-AM_MAINTAINER_MODE
-RTEMS_PATH_KSH
-RTEMS_TOOLPATHS
-difftest
-sorttimes])
-AC_OUTPUT
diff --git a/testsuites/tools/generic/difftest.in b/testsuites/tools/generic/difftest.in
index 246ff663f8..0000000000
--- a/testsuites/tools/generic/difftest.in
+++ /dev/null
@@ -1,113 +0,0 @@
-#!@KSH@ -p
-#  Check test results against official output from the src tree
-# XXX: do not run size.exe with this; it asks questions we don't answer
-# how to do arith in bash
-#    i=$((i * 2))
-#    b=$((b + 1))
-# progname=`basename $0`
-progname=${0##*/}        # fast basename hack for ksh, bash
-USAGE=\
-"usage: $progname [ -opts ] test [ test ... ]
-	-v	    -- verbose
-        -l logdir   -- specify log directory (default is 'logdir')
-#   log an error to stderr
-prerr()
-    echo "$*" >&2
-fatal() {
-    [ "$1" ] && prerr $*
-    prerr "$USAGE"
-    exit 1
-warn() {
-# process the options
-# defaults for getopt vars
-verbose=""
-logdir=log
-while getopts v12o:l: OPT
-do
-    case "$OPT" in
-	v)
-	    verbose="yes";;
-        l)
-            logdir="$OPTARG";;
-            fatal;;
-    esac
-done
-shiftcount=`expr $OPTIND - 1`
-shift $shiftcount
-args=$*
-# Run the tests
-test -d $logdir || fatal "No log directory: ./$logdir"
-tests="$args"
-if [ ! "$tests" ]
-then
-     cd $logdir
-     set -- `ls -1 sp* mp??_? psx* mp*_?_g 2>/dev/null | grep -v info`
-     cd ..
-     tests="$*"
-fi
-for t in $tests
-do
-   logfile=$t
-   if [ ! -f $logdir/$logfile ]
-   then
-        continue
-   fi
-   echo $logfile
-   echo
-   case $t in
-       mp*)
-           mptest=`echo $t | sed 's/_.//'`
-           node=`echo $t | sed 's/...._//'`
-           tmp_scn_file=mptests/node$node/$mptest.scn;;
-       sp*)
-           tmp_scn_file=sptests/$t.scn;;
-       psx*)
-           tmp_scn_file=psxtests/$t.scn;;
-           fatal "unknown test $t";;
-   esac
-   scn_file=`echo $tmp_scn_file | sed -e s/_g//`
-   sed -e '/^$/d' < $logdir/$logfile | diff -b screens/$scn_file -
-   echo
-   echo
-done
-exit 0
-# Local Variables: ***
-# mode:ksh ***
-# End: ***
diff --git a/testsuites/tools/generic/sorttimes.in b/testsuites/tools/generic/sorttimes.in
index 3fe4fb6a62..0000000000
--- a/testsuites/tools/generic/sorttimes.in
+++ /dev/null
@@ -1,189 +0,0 @@
-#!@KSH@ -p
-#  This script takes the output from the Timing Test Suite, reorders
-#  it, and adds headers so it is in the same order as is printed in
-#  the supplement.
-usage()
-  echo "${progname} file [more files]"
-header()
-  echo
-  echo $*
-  echo
-lookup()
-  grep "$*" $files
-progname=$0
-if [ $# -eq 0 ] ; then
-  usage
-  exit 0
-fi
-files=$*
-header Context Switch
-lookup context switch: self
-lookup context switch: to another task
-lookup context switch: no floating point contexts
-lookup fp context switch: restore 1st FP task
-lookup fp context switch: save initialized, restore initialized
-lookup fp context switch: save idle, restore initialized
-lookup fp context switch: save idle, restore idle
-header Task Manager
-lookup rtems_task_create
-lookup rtems_task_ident
-lookup rtems_task_start
-lookup rtems_task_restart: calling task
-lookup rtems_task_restart: suspended task -- returns to caller
-lookup rtems_task_restart: blocked task -- returns to caller
-lookup rtems_task_restart: ready task -- returns to caller
-lookup rtems_task_restart: suspended task -- preempts caller
-lookup rtems_task_restart: blocked task -- preempts caller
-lookup rtems_task_restart: ready task -- preempts caller
-lookup rtems_task_delete: calling task
-lookup rtems_task_delete: suspended task
-lookup rtems_task_delete: blocked task
-lookup rtems_task_delete: ready task
-lookup rtems_task_suspend: calling task
-lookup rtems_task_suspend: returns to caller
-lookup rtems_task_resume: task readied -- returns to caller
-lookup rtems_task_resume: task readied -- preempts caller
-lookup rtems_task_set_priority: obtain current priority
-lookup rtems_task_set_priority: returns to caller
-lookup rtems_task_set_priority: preempts caller
-lookup rtems_task_mode: obtain current mode
-lookup rtems_task_mode: no reschedule
-lookup rtems_task_mode: reschedule -- returns to caller
-lookup rtems_task_mode: reschedule -- preempts caller
-lookup rtems_task_wake_after: yield -- returns to caller
-lookup rtems_task_wake_after: yields -- preempts caller
-lookup rtems_task_wake_when
-header Interrupt Manager
-lookup interrupt entry overhead: returns to nested interrupt
-lookup interrupt entry overhead: returns to interrupted task
-lookup interrupt entry overhead: returns to preempting task
-lookup interrupt exit overhead: returns to nested interrupt
-lookup interrupt exit overhead: returns to interrupted task
-lookup interrupt exit overhead: returns to preempting task
-header Clock Manager
-lookup rtems_clock_set
-lookup rtems_clock_get
-lookup rtems_clock_tick
-header Timer Manager
-lookup rtems_timer_create
-lookup rtems_timer_ident
-lookup rtems_timer_delete: inactive
-lookup rtems_timer_delete: active
-lookup rtems_timer_fire_after: inactive
-lookup rtems_timer_fire_after: active
-lookup rtems_timer_fire_when: inactive
-lookup rtems_timer_fire_when: active
-lookup rtems_timer_reset: inactive
-lookup rtems_timer_reset: active
-lookup rtems_timer_cancel: inactive
-lookup rtems_timer_cancel: active
-header Semaphore Manager
-lookup rtems_semaphore_create
-lookup rtems_semaphore_ident
-lookup rtems_semaphore_delete
-lookup rtems_semaphore_obtain: available
-lookup rtems_semaphore_obtain: not available -- NO_WAIT
-lookup rtems_semaphore_obtain: not available -- caller blocks
-lookup rtems_semaphore_release: no waiting tasks
-lookup rtems_semaphore_release: task readied -- returns to caller
-lookup rtems_semaphore_release: task readied -- preempts caller
-header Message Queue Manager
-lookup rtems_message_queue_create
-lookup rtems_message_queue_ident
-lookup rtems_message_queue_delete
-lookup rtems_message_queue_send: no waiting tasks
-lookup rtems_message_queue_send: task readied -- returns to caller
-lookup rtems_message_queue_send: task readied -- preempts caller
-lookup rtems_message_queue_urgent: no waiting tasks
-lookup rtems_message_queue_urgent: task readied -- returns to caller
-lookup rtems_message_queue_urgent: task readied -- preempts caller
-lookup rtems_message_queue_broadcast: no waiting tasks
-lookup rtems_message_queue_broadcast: task readied -- returns to caller
-lookup rtems_message_queue_broadcast: task readied -- preempts caller
-lookup rtems_message_queue_receive: available
-lookup rtems_message_queue_receive: not available -- NO_WAIT
-lookup rtems_message_queue_receive: not available -- caller blocks
-lookup rtems_message_queue_flush: no messages flushed
-lookup rtems_message_queue_flush: messages flushed
-header Event Manager
-lookup rtems_event_send: no task readied
-lookup rtems_event_send: task readied -- returns to caller
-lookup rtems_event_send: task readied -- preempts caller
-lookup rtems_event_receive: obtain current events
-lookup rtems_event_receive: available
-lookup rtems_event_receive: not available -- NO_WAIT
-lookup rtems_event_receive: not available -- caller blocks
-header Signal Manager
-lookup rtems_signal_catch
-lookup rtems_signal_send: returns to caller
-lookup rtems_signal_send: signal to self
-lookup exit ASR overhead: returns to calling task
-lookup exit ASR overhead: returns to preempting task
-header Partition Manager
-lookup rtems_partition_create
-lookup rtems_partition_ident
-lookup rtems_partition_delete
-lookup rtems_partition_get_buffer: available
-lookup rtems_partition_get_buffer: not available
-lookup rtems_partition_return_buffer
-header Region Manager
-lookup rtems_region_create
-lookup rtems_region_ident
-lookup rtems_region_delete
-lookup rtems_region_get_segment: available
-lookup rtems_region_get_segment: not available -- NO_WAIT
-lookup rtems_region_get_segment: not available -- caller blocks
-lookup rtems_region_return_segment: no waiting tasks
-lookup rtems_region_return_segment: task readied -- returns to caller
-lookup rtems_region_return_segment: task readied -- preempts caller
-header Dual-Ported Memory Manager
-lookup rtems_port_create
-lookup rtems_port_ident
-lookup rtems_port_delete
-lookup rtems_port_internal_to_external
-lookup rtems_port_external_to_internal
-header IO Manager
-lookup rtems_io_initialize
-lookup rtems_io_open
-lookup rtems_io_close
-lookup rtems_io_read
-lookup rtems_io_write
-lookup rtems_io_control
-header Rate Monotonic Manager
-lookup rtems_rate_monotonic_create
-lookup rtems_rate_monotonic_ident
-lookup rtems_rate_monotonic_cancel
-lookup rtems_rate_monotonic_delete: active
-lookup rtems_rate_monotonic_delete: inactive
-lookup rtems_rate_monotonic_period: obtain status
-lookup rtems_rate_monotonic_period: initiate period -- returns to caller
-lookup rtems_rate_monotonic_period: conclude periods -- caller blocks
-exit 0
2.12.3
