[PATCH 7/9] ftpd: Always build FTP daemon
Mon Apr 30 09:48:15 UTC 2018
Add support for libbsd initialization.
Update #3419.
 cpukit/ftpd/Makefile.am     |  4 +--
 cpukit/ftpd/ftpd-init.c     | 19 ++++++++++++
 cpukit/ftpd/ftpd.c          | 72 +++++++++++++++++++++++++--------------------
 cpukit/include/rtems/ftpd.h |  7 ++++-
 4 files changed, 66 insertions(+), 36 deletions(-)
 create mode 100644 cpukit/ftpd/ftpd-init.c
diff --git a/cpukit/ftpd/Makefile.am b/cpukit/ftpd/Makefile.am
index fbb78650d6..dddf91935e 100644
--- a/cpukit/ftpd/Makefile.am
+++ b/cpukit/ftpd/Makefile.am
@@ -1,13 +1,11 @@
 include $(top_srcdir)/automake/compile.am
-if LIBNETWORKING
 project_lib_LIBRARIES = libftpd.a
 $(PROJECT_LIB)/libftpd.a: libftpd.a
 	$(INSTALL_DATA) $< $(PROJECT_LIB)/libftpd.a
 TMPINSTALL_FILES = $(PROJECT_LIB)/libftpd.a
-libftpd_a_SOURCES = ftpd.c ftpd.h
-endif
+libftpd_a_SOURCES = ftpd.c ftpd-init.c
 include $(top_srcdir)/automake/local.am
diff --git a/cpukit/ftpd/ftpd-init.c b/cpukit/ftpd/ftpd-init.c
new file mode 100644
index 0000000000..35546ff553
--- /dev/null
+++ b/cpukit/ftpd/ftpd-init.c
@@ -0,0 +1,19 @@
+ * Copyright (c) 2018 embedded brains GmbH.  All rights reserved.
+#if HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/ftpd.h>
+int rtems_initialize_ftpd( void )
+  rtems_ftpd_configuration.verbose = true;
+  return rtems_ftpd_start( &rtems_ftpd_configuration );
diff --git a/cpukit/ftpd/ftpd.c b/cpukit/ftpd/ftpd.c
index 098dd63652..2747268329 100644
--- a/cpukit/ftpd/ftpd.c
+++ b/cpukit/ftpd/ftpd.c
@@ -202,7 +202,6 @@
 #include <sched.h>
-#include <rtems/rtems_bsdnet.h>
 #include <rtems/error.h>
 #include <rtems/libio.h>
@@ -243,7 +242,7 @@ enum
 /* Configuration table */
-extern struct rtems_ftpd_configuration rtems_ftpd_configuration;
+static struct rtems_ftpd_configuration *ftpd_config;
 /* this is not prototyped in strict ansi mode */
 FILE *fdopen (int fildes, const char *mode);
@@ -934,7 +933,7 @@ command_store(FTPD_SessionInfo_t *info, char const *filename)
     wrt = &discard;
-  if (!null && rtems_ftpd_configuration.hooks != NULL)
+  if (!null && ftpd_config->hooks != NULL)
     /* Search our list of hooks to see if we need to do something special. */
@@ -942,7 +941,7 @@ command_store(FTPD_SessionInfo_t *info, char const *filename)
     int i;
     i = 0;
-    hook = &rtems_ftpd_configuration.hooks[i++];
+    hook = &ftpd_config->hooks[i++];
     while (hook->filename != NULL)
       if (!strcmp(hook->filename, filename))
@@ -950,7 +949,7 @@ command_store(FTPD_SessionInfo_t *info, char const *filename)
         usehook = hook;
         break;
@@ -963,8 +962,8 @@ command_store(FTPD_SessionInfo_t *info, char const *filename)
      * given name.
-    char                *bigBufr;
-    size_t filesize = rtems_ftpd_configuration.max_hook_filesize + 1;
+    char   *bigBufr;
+    size_t  filesize = ftpd_config->max_hook_filesize + 1;
      * Allocate space for our "file".
@@ -1747,8 +1746,8 @@ exec_command(FTPD_SessionInfo_t *info, char* cmd, char* args)
       free(info->pass);
     info->pass = NULL;
     info->user = strdup(fname);
-    if (rtems_ftpd_configuration.login &&
-      !rtems_ftpd_configuration.login(info->user, NULL)) {
+    if (ftpd_config->login &&
+      !ftpd_config->login(info->user, NULL)) {
       info->auth = false;
       send_reply(info, 331, "User name okay, need password.");
     } else {
@@ -1765,8 +1764,8 @@ exec_command(FTPD_SessionInfo_t *info, char* cmd, char* args)
     if (!info->user) {
       send_reply(info, 332, "Need account to log in");
     } else {
-        !rtems_ftpd_configuration.login(info->user, info->pass)) {
+        !ftpd_config->login(info->user, info->pass)) {
         info->auth = false;
         send_reply(info, 530, "Not logged in.");
       } else {
@@ -1990,7 +1989,7 @@ ftpd_daemon(rtems_task_argument args RTEMS_UNUSED)
     syslog(LOG_ERR, "ftpd: Error creating socket: %s", serr());
   addr.sin_family      = AF_INET;
-  addr.sin_port        = htons(rtems_ftpd_configuration.port);
+  addr.sin_port        = htons(ftpd_config->port);
   addr.sin_addr.s_addr = htonl(INADDR_ANY);
   memset(addr.sin_zero, 0, sizeof(addr.sin_zero));
@@ -2045,7 +2044,7 @@ ftpd_daemon(rtems_task_argument args RTEMS_UNUSED)
             info->idle = ftpd_timeout;
             info->user = NULL;
             info->pass = NULL;
-            if (rtems_ftpd_configuration.login)
+            if (ftpd_config->login)
               info->auth = false;
             else
               info->auth = true;
@@ -2069,46 +2068,54 @@ ftpd_daemon(rtems_task_argument args RTEMS_UNUSED)
  * Input parameters:
+ *    config: constant initial setup.
  * Output parameters:
  *    returns RTEMS_SUCCESSFUL on successful start of the daemon.
 int
-rtems_initialize_ftpd(void)
+rtems_ftpd_start(const struct rtems_ftpd_configuration* config)
   rtems_status_code   sc;
   rtems_id            tid;
   rtems_task_priority priority;
   int count;
-  if (rtems_ftpd_configuration.port == 0)
+  if (ftpd_config != NULL)
+    return RTEMS_RESOURCE_IN_USE;
+  ftpd_config = malloc(sizeof(*ftpd_config));
+  if (ftpd_config == NULL)
+    return RTEMS_NO_MEMORY;
+  *ftpd_config = *config;
+  if (ftpd_config->port == 0)
-    rtems_ftpd_configuration.port = FTPD_CONTROL_PORT;
+    ftpd_config->port = FTPD_CONTROL_PORT;
-  if (rtems_ftpd_configuration.priority == 0)
+  if (ftpd_config->priority == 0)
-    rtems_ftpd_configuration.priority = 40;
+    ftpd_config->priority = 40;
-  priority = rtems_ftpd_configuration.priority;
+  priority = ftpd_config->priority;
-  ftpd_timeout = rtems_ftpd_configuration.idle;
+  ftpd_timeout = ftpd_config->idle;
   if (ftpd_timeout < 0)
     ftpd_timeout = 0;
-  rtems_ftpd_configuration.idle = ftpd_timeout;
+  ftpd_config->idle = ftpd_timeout;
-  ftpd_access = rtems_ftpd_configuration.access;
+  ftpd_access = ftpd_config->access;
   ftpd_root = "/";
-  if ( rtems_ftpd_configuration.root &&
-       rtems_ftpd_configuration.root[0] == '/' )
-    ftpd_root = rtems_ftpd_configuration.root;
+  if (ftpd_config->root && ftpd_config->root[0] == '/' )
+    ftpd_root = ftpd_config->root;
-  rtems_ftpd_configuration.root = ftpd_root;
+  ftpd_config->root = ftpd_root;
-  if (rtems_ftpd_configuration.tasks_count <= 0)
-    rtems_ftpd_configuration.tasks_count = 1;
-  count = rtems_ftpd_configuration.tasks_count;
+  if (ftpd_config->tasks_count <= 0)
+    ftpd_config->tasks_count = 1;
+  count = ftpd_config->tasks_count;
   if (!task_pool_init(count, priority))
@@ -2138,8 +2145,9 @@ rtems_initialize_ftpd(void)
     return RTEMS_UNSATISFIED;
-  syslog(LOG_INFO, "ftpd: FTP daemon started (%d session%s max)",
-    count, ((count > 1) ? "s" : ""));
+  if (ftpd_config->verbose)
+    syslog(LOG_INFO, "ftpd: FTP daemon started (%d session%s max)",
+           count, ((count > 1) ? "s" : ""));
   return RTEMS_SUCCESSFUL;
diff --git a/cpukit/include/rtems/ftpd.h b/cpukit/include/rtems/ftpd.h
index f33ca59d3a..b8d5e779f3 100644
--- a/cpukit/include/rtems/ftpd.h
+++ b/cpukit/include/rtems/ftpd.h
@@ -5,7 +5,7 @@
 #ifndef _RTEMS_FTPD_H
 #define _RTEMS_FTPD_H
-#include <rtems/rtems/tasks.h>
+#include <rtems.h>
 #ifdef __cplusplus
 extern "C" {
@@ -54,6 +54,7 @@ struct rtems_ftpd_configuration
                                                   3 - browse-only */
    rtems_shell_login_check_t login;            /* Login check or 0 to ignore
                                                   user/passwd. */
+   bool                    verbose;            /* Say hello! */
@@ -65,6 +66,10 @@ struct rtems_ftpd_configuration
 #define TRANSIENT       4       /* transient negative completion */
 #define ERROR           5       /* permanent negative completion */
+int rtems_ftpd_start(const struct rtems_ftpd_configuration *config);
+extern struct rtems_ftpd_configuration rtems_ftpd_configuration;
 int rtems_initialize_ftpd(void);
 #ifdef __cplusplus
2.12.3
