[PATCH] Use network services from RTEMS
Mon Apr 30 09:48:34 UTC 2018
Close #3419.
 freebsd/include/arpa/ftp.h       |  107 --
 libbsd.py                        |   15 -
 rtemsbsd/ftpd/ftpd-init.c        |   39 -
 rtemsbsd/ftpd/ftpd.c             | 2171 --------------------------------------
 rtemsbsd/ftpfs/ftpfs.c           | 1428 -------------------------
 rtemsbsd/include/rtems/ftpd.h    |   80 --
 rtemsbsd/include/rtems/ftpfs.h   |  159 ---
 rtemsbsd/include/rtems/telnetd.h |  115 --
 rtemsbsd/telnetd/check_passwd.c  |  107 --
 rtemsbsd/telnetd/des.c           |  879 ---------------
 rtemsbsd/telnetd/passwd.h        |   25 -
 rtemsbsd/telnetd/pty.c           |  660 ------------
 rtemsbsd/telnetd/telnetd-init.c  |   33 -
 rtemsbsd/telnetd/telnetd.c       |  517 ---------
 waf_libbsd.py                    |    2 +-
 15 files changed, 1 insertion(+), 6336 deletions(-)
 delete mode 100644 freebsd/include/arpa/ftp.h
 delete mode 100644 rtemsbsd/ftpd/ftpd-init.c
 delete mode 100644 rtemsbsd/ftpd/ftpd.c
 delete mode 100644 rtemsbsd/ftpfs/ftpfs.c
 delete mode 100644 rtemsbsd/include/rtems/ftpd.h
 delete mode 100644 rtemsbsd/include/rtems/ftpfs.h
 delete mode 100644 rtemsbsd/include/rtems/telnetd.h
 delete mode 100644 rtemsbsd/telnetd/check_passwd.c
 delete mode 100644 rtemsbsd/telnetd/des.c
 delete mode 100644 rtemsbsd/telnetd/passwd.h
 delete mode 100644 rtemsbsd/telnetd/pty.c
 delete mode 100644 rtemsbsd/telnetd/telnetd-init.c
 delete mode 100644 rtemsbsd/telnetd/telnetd.c
diff --git a/freebsd/include/arpa/ftp.h b/freebsd/include/arpa/ftp.h
deleted file mode 100644
index 081c037ec..000000000
--- a/freebsd/include/arpa/ftp.h
+++ /dev/null
@@ -1,107 +0,0 @@
- * Copyright (c) 1983, 1989, 1993
- *	The Regents of the University of California.  All rights reserved.
- * Redistribution and use in source and binary forms, with or without
- * modification, are permitted provided that the following conditions
- * are met:
- * 1. Redistributions of source code must retain the above copyright
- *    notice, this list of conditions and the following disclaimer.
- * 2. Redistributions in binary form must reproduce the above copyright
- *    notice, this list of conditions and the following disclaimer in the
- *    documentation and/or other materials provided with the distribution.
- * 3. Neither the name of the University nor the names of its contributors
- *    may be used to endorse or promote products derived from this software
- *    without specific prior written permission.
- * THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
- * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
- * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
- * ARE DISCLAIMED.  IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
- * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
- * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
- * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
- * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
- * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
- * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
- * SUCH DAMAGE.
- *	@(#)ftp.h	8.1 (Berkeley) 6/2/93
- * $FreeBSD$
-#ifndef _ARPA_FTP_H_
-#define	_ARPA_FTP_H_
-/* Definitions for FTP; see RFC-765. */
- * Reply codes.
-#define PRELIM		1	/* positive preliminary */
-#define COMPLETE	2	/* positive completion */
-#define CONTINUE	3	/* positive intermediate */
-#define TRANSIENT	4	/* transient negative completion */
-#define ERROR		5	/* permanent negative completion */
- * Type codes
-#define	TYPE_A		1	/* ASCII */
-#define	TYPE_E		2	/* EBCDIC */
-#define	TYPE_I		3	/* image */
-#define	TYPE_L		4	/* local byte size */
-#ifdef FTP_NAMES
-char *typenames[] =  {"0", "ASCII", "EBCDIC", "Image", "Local" };
-#endif
- * Form codes
-#define	FORM_N		1	/* non-print */
-#define	FORM_T		2	/* telnet format effectors */
-#define	FORM_C		3	/* carriage control (ASA) */
-#ifdef FTP_NAMES
-char *formnames[] =  {"0", "Nonprint", "Telnet", "Carriage-control" };
-#endif
- * Structure codes
-#define	STRU_F		1	/* file (no record structure) */
-#define	STRU_R		2	/* record structure */
-#define	STRU_P		3	/* page structure */
-#ifdef FTP_NAMES
-char *strunames[] =  {"0", "File", "Record", "Page" };
-#endif
- * Mode types
-#define	MODE_S		1	/* stream */
-#define	MODE_B		2	/* block */
-#define	MODE_C		3	/* compressed */
-#ifdef FTP_NAMES
-char *modenames[] =  {"0", "Stream", "Block", "Compressed" };
-#endif
- * Record Tokens
-#define	REC_ESC		'\377'	/* Record-mode Escape */
-#define	REC_EOR		'\001'	/* Record-mode End-of-Record */
-#define REC_EOF		'\002'	/* Record-mode End-of-File */
- * Block Header
-#define	BLK_EOR		0x80	/* Block is End-of-Record */
-#define	BLK_EOF		0x40	/* Block is End-of-File */
-#define BLK_ERRORS	0x20	/* Block is suspected of containing errors */
-#define	BLK_RESTART	0x10	/* Block is Restart Marker */
-#define	BLK_BYTECOUNT	2	/* Bytes in this block */
-#endif /* !_FTP_H_ */
diff --git a/libbsd.py b/libbsd.py
index a256594e2..586703fdd 100644
--- a/libbsd.py
+++ b/libbsd.py
@@ -278,10 +278,7 @@ class rtems(builder.Module):
                 'rtems/rtems-program-socket.c',
                 'rtems/rtems-routes.c',
                 'rtems/syslog.c',
-                'ftpd/ftpd.c',
-                'ftpd/ftpd-init.c',
                 'ftpd/ftpd-service.c',
-                'ftpfs/ftpfs.c',
                 'mdns/mdns.c',
                 'mdns/mdns-hostname-default.c',
                 'nfsclient/mount_prot_xdr.c',
@@ -318,22 +315,11 @@ class rtems(builder.Module):
                 'sys/fs/devfs/devfs_devs.c',
                 'sys/net/if_ppp.c',
                 'sys/net/ppp_tty.c',
-                'telnetd/check_passwd.c',
-                'telnetd/des.c',
-                'telnetd/pty.c',
-                'telnetd/telnetd.c',
-                'telnetd/telnetd-init.c',
                 'telnetd/telnetd-service.c',
                 'sys/dev/tsec/if_tsec_nexus.c',
             mm.generator['source']()
-        self.addRTEMSSourceFiles(
-                'debugger/rtems-debugger-remote-tcp.c',
-            mm.generator['source-if-header']('rtems/rtems-debugger.h')
         self.addFile(mm.generator['file']('rtems/rtems-kernel-kvm-symbols.c',
                                           mm.generator['rtems-path'](),
                                           mm.generator['no-convert'](),
@@ -2440,7 +2426,6 @@ class user_space(builder.Module):
                 'contrib/libxo/libxo/xo_wcwidth.h',
                 'sbin/pfctl/pfctl.h',
                 'sbin/pfctl/pfctl_parser.h',
-                'include/arpa/ftp.h',
                 'include/arpa/nameser_compat.h',
                 'include/arpa/nameser.h',
                 'include/db.h',
diff --git a/rtemsbsd/ftpd/ftpd-init.c b/rtemsbsd/ftpd/ftpd-init.c
index 2741a6336..000000000
--- a/rtemsbsd/ftpd/ftpd-init.c
+++ /dev/null
@@ -1,39 +0,0 @@
- *  FTP Server Daemon
- *  Submitted by: Jake Janovetz <janovetz at tempest.ece.uiuc.edu>
- *  Changed by:   Sergei Organov <osv at javad.ru> (OSV)
- *                Arnout Vandecappelle <arnout at mind.be> (AV)
- *                Sebastien Bourdeauducq <sebastien at milkymist.org> (MM)
- *                                 ftpd-init.c
- * Description:
- *    This file contains the legacy daemon initialisation.
-#if HAVE_CONFIG_H
-#include "config.h"
-#endif
-#include <rtems/ftpd.h>
-/* Configuration table */
-extern struct rtems_ftpd_configuration rtems_ftpd_configuration;
- * rtems_initialize_ftpd
- * Call the FTPD start function.
-int
-rtems_initialize_ftpd(void)
-  rtems_ftpd_configuration.verbose = true;
-  return rtems_ftpd_start(&rtems_ftpd_configuration);
diff --git a/rtemsbsd/ftpd/ftpd.c b/rtemsbsd/ftpd/ftpd.c
index 77e9d5351..000000000
--- a/rtemsbsd/ftpd/ftpd.c
+++ /dev/null
@@ -1,2171 +0,0 @@
-/* FIXME: 1. Parse command is a hack.  We can do better.
- *        2. OSV: hooks support seems to be bad, as it requires storing of
- *           entire input file in memory.  Seem to be better to change it to
- *           something more reasonable, like having
- *           'hook_write(void const *buf, int count)' routine that will be
- *           called multiple times while file is being received.
- *        3. OSV: Remove hack with "/dev/null"?
- *  Changes:
- *    2010-12-02        Sebastien Bourdeauducq <sebastien at milkymist.org>
- *      * Support spaces in filenames
- *    2010-04-29        Arnout Vandecappelle (Essensium/Mind) <arnout at mind.be>
- *      * Added USER/PASS authentication.
- *    2001-01-31        Sergei Organov <osv at javad.ru>
- *      * Hacks with current dir and root dir removed in favor of new libio
- *        support for task-local current and root directories.
- *    2001-01-30        Sergei Organov <osv at javad.ru>
- *      * Bug in `close_data_socket()' introduced by previous change fixed.
- *      * `command_pasv()' changed to set timeout on socket we are listening on
- *        and code fixed to don't close socket twice on error.
- *      * `serr()' changed to clear `errno'.
- *      * `data_socket()' changed to clear `errno' before `bind()'.
- *      * `session()' changed to clear `errno' before processing session.
- *    2001-01-29        Sergei Organov <osv at javad.ru>
- *      * `close_data_socket()' fixed to close both active and passive sockets
- *      * Initialize info->data_socket to -1 in `daemon()'
- *      * Initialize `fname' to empty string  in `exec_command()'
- *    2001-01-22        Sergei Organov <osv at javad.ru>
- *      * Timeouts on sockets implemented. 'idle' field added to
- *        configuration. No timeout by default to keep backward compatibility.
- *        Note: SITE IDLE command not implemented yet.
- *      * Basic global access control implemented. 'access' field added to
- *        configuration. No access limitations by default to keep backward
- *        compatibility.
- *    2001-01-17        Sergei Organov <osv at javad.ru>
- *      * Anchor data socket for active mode (using self IP and port 20.)
- *      * Fixed default data port support (still not tested).
- *      * Don't allow IP address different from originating host in
- *        PORT command to improve security.
- *      * Fixed bug in MDTM command.
- *      * Check for correctness of parsing of argument in command_port().
- *      * Fixed squeeze_path() to don't allow names like 'NAME/smth' where
- *        'NAME' is not a directory.
- *      * Command parsing a little bit improved: command names are now
- *        converted to upper-case to be more compatible with RFC (command
- *        names are not case-sensitive.)
- *      * Reformat comments so that they have RTEMS look-and-feel.
- *    2001-01-16        Sergei Organov <osv at javad.ru>
- *      * Fixed DELE, SITE CHMOD, RMD, MKD broken by previous changes
- *      * True ASCII mode implemented (doesn't work for hooks and /dev/null)
- *      * Passive mode implemented, PASV command added.
- *      * Default port for data connection could be used (untested, can't find
- *        ftp client that doesn't send PORT command)
- *      * SYST reply changed to UNIX, as former RTEMS isn't registered name.
- *      * Reply codes reviewed and fixed.
- *    2001-01-08        Sergei Organov <osv at javad.ru>
- *      * use pool of pre-created threads to handle sessions
- *      * LIST output now similar to what "/bin/ls -al" would output, thus
- *        FTP clients could parse it.
- *      * LIST NAME now works (both for files and directories)
- *      * keep track of CWD for every session separately
- *      * ability to specify root directory name in configuration table
- *      * options sent in commands are ignored, thus LIST -al FILE works
- *      * added support for NLST, CDUP and MDTM commands
- *      * buffers are allocated on stack instead of heap where possible
- *      * drop using of task notepad to pass parameters - use function
- *        arguments instead
- *      * various bug-fixes, e.g., use of PF_INET in socket() instead of
- *        AF_INET, use snprintf() instead of sprintf() everywhere for safety,
- *        etc.
- *                                 ftpd.c
- * Description:
- *    This file contains the daemon which services requests that appear
- *    on the FTP port.  This server is compatible with FTP, but it
- *    also provides 'hooks' to make it usable in situations where files
- *    are not used/necessary.  Once the server is started, it runs
- *    forever.
- *    Organization:
- *       The FTP daemon is started upon boot along with a (configurable)
- *       number of tasks to handle sessions.  It runs all the time and
- *       waits for connections on the known FTP port (21).  When
- *       a connection is made, it wakes-up a 'session' task.  That
- *       session then interacts with the remote host.  When the session
- *       is complete, the session task goes to sleep.  The daemon still
- *       runs, however.
- * Supported commands are:
- * RETR xxx     - Sends a file from the client.
- * STOR xxx     - Receives a file from the client.  xxx = filename.
- * LIST xxx     - Sends a file list to the client.
- * NLST xxx     - Sends a file list to the client.
- * USER         - Does nothing.
- * PASS         - Does nothing.
- * SYST         - Replies with the system type (`RTEMS').
- * DELE xxx     - Delete file xxx.
- * MKD xxx      - Create directory xxx.
- * RMD xxx      - Remove directory xxx.
- * PWD          - Print working directory.
- * CWD xxx      - Change working directory.
- * CDUP         - Change to upper directory.
- * SITE CHMOD xxx yyy - Change permissions on file yyy to xxx.
- * PORT a,b,c,d,x,y   - Setup for a data port to IP address a.b.c.d
- *                      and port (x*256 + y).
- * MDTM xxx     - Send file modification date/time to the client.
- *                xxx = filename.
- * PASV         - Use passive mode data connection.
- * The public routines contained in this file are:
- *    rtems_initialize_ftpd - Initializes and starts the server daemon,
- *                            then returns to its caller.
- * Jake Janovetz
- * University of Illinois
- * 1406 West Green Street
- * Urbana IL  61801
- * Change History:
- *  12/01/97   - Creation (JWJ)
- *  2001-01-08 - Changes by OSV
- *  2010-04-29 - Authentication added by AV
- * Meanings of first and second digits of reply codes:
- * Reply:  Description:
- *  1yz    Positive preliminary reply.  The action is being started but
- *         expect another reply before sending another command.
- *  2yz    Positive completion reply.  A new command can be sent.
- *  3yz    Positive intermediate reply.  The command has been accepted
- *         but another command must be sent.
- *  4yz    Transient negative completion reply.  The requested action did
- *         not take place, but the error condition is temporary so the
- *         command can be reissued later.
- *  5yz    Permanent negative completion reply.  The command was not
- *         accepted and should not be retried.
- *  x0z    Syntax errors.
- *  x1z    Information.
- *  x2z    Connections.  Replies referring to the control or data
- *         connections.
- *  x3z    Authentication and accounting.  Replies for the login or
- *         accounting commands.
- *  x4z    Unspecified.
- *  x5z    Filesystem status.
-#if HAVE_CONFIG_H
-#endif
-#include <stdio.h>
-#include <stdlib.h>
-#include <string.h>
-#include <unistd.h>
-#include <fcntl.h>
-#include <dirent.h>
-#include <errno.h>
-#include <ctype.h>
-#include <inttypes.h>
-#include <sched.h>
-#include <rtems.h>
-#include <rtems/rtems_bsdnet.h>
-#include <rtems/error.h>
-#include <rtems/libio.h>
-#include <rtems/userenv.h>
-#include <syslog.h>
-#include <sys/types.h>
-#include <sys/socket.h>
-#include <arpa/ftp.h>
-#include <netinet/in.h>
-#ifdef __GNUC__
-/* change to #if 1 to disable syslog entirely */
-#if 0
-#undef  syslog
-#define syslog(a, b, ...) while(0){}
-#endif
-#endif
-#define FTPD_SERVER_MESSAGE  "RTEMS FTP server (Version 1.1-JWJ) ready."
-#define FTPD_SYSTYPE "UNIX Type: L8"
-/* Seem to be unused */
-#if 0
-#define FTPD_WELCOME_MESSAGE \
-   "Welcome to the RTEMS FTP server.\n" \
-   "\n" \
-   "Login accepted.\n"
-#endif
-/* Event to be used by session tasks for waiting */
-enum
-  FTPD_RTEMS_EVENT = RTEMS_EVENT_1
-static struct rtems_ftpd_configuration* ftpd_config;
-/* this is not prototyped in strict ansi mode */
-FILE *fdopen (int fildes, const char *mode);
-/*SessionInfo structure.
- * The following structure is allocated for each session.
-typedef struct
-  struct sockaddr_in  ctrl_addr;   /* Control connection self address */
-  struct sockaddr_in  data_addr;   /* Data address set by PORT command */
-  struct sockaddr_in  def_addr;    /* Default address for data */
-  int                 use_default; /* 1 - use default address for data */
-  FILE                *ctrl_fp;    /* File pointer for control connection */
-  int                 ctrl_socket; /* Socket for ctrl connection */
-  int                 pasv_socket; /* Socket for PASV connection */
-  int                 data_socket; /* Socket for data connection */
-  int                 idle;        /* Timeout in seconds */
-  int                 xfer_mode;   /* Transfer mode (ASCII/binary) */
-  rtems_id            tid;         /* Task id */
-  char                *user;       /* user name (0 if not supplied) */
-  char                *pass;       /* password (0 if not supplied) */
-  bool                auth;        /* true if user/pass was valid, false if not or not supplied */
-} FTPD_SessionInfo_t;
- * TaskPool structure.
-typedef struct
-  FTPD_SessionInfo_t    *info;
-  FTPD_SessionInfo_t    **queue;
-  int                   count;
-  int                   head;
-  int                   tail;
-  rtems_id              mutex;
-  rtems_id              sem;
-} FTPD_TaskPool_t;
- * Task pool instance.
-static FTPD_TaskPool_t task_pool;
- * Root directory
-static char const* ftpd_root = "/";
- * Default idle timeout for sockets in seconds.
-static int ftpd_timeout = 0;
- * Global access flags.
-static int ftpd_access = 0;
- * serr
- * Return error string corresponding to current 'errno'.
-static char const*
-serr(void)
-  int err = errno;
-  errno = 0;
-  return strerror(err);
- * Utility routines for access control.
-static int
-can_read(void)
-  return (ftpd_access & FTPD_NO_READ) == 0;
-static int
-can_write(void)
-  return (ftpd_access & FTPD_NO_WRITE) == 0;
- * Task pool management routines
- * task_pool_done
- * Cleanup task pool.
- * Input parameters:
- *   count - number of entries in task pool to cleanup
- * Output parameters:
- *   NONE
-static void
-task_pool_done(int count)
-  int i;
-  for(i = 0; i < count; ++i)
-    rtems_task_delete(task_pool.info[i].tid);
-  if(task_pool.info)
-    free(task_pool.info);
-  if(task_pool.queue)
-    free(task_pool.queue);
-  if(task_pool.mutex != (rtems_id)-1)
-    rtems_semaphore_delete(task_pool.mutex);
-  if(task_pool.sem != (rtems_id)-1)
-    rtems_semaphore_delete(task_pool.sem);
-  task_pool.info = 0;
-  task_pool.queue = 0;
-  task_pool.count = 0;
-  task_pool.sem = -1;
-  task_pool.mutex = -1;
- * task_pool_init
- * Initialize task pool.
- *   count    - number of entries in task pool to create
- *   priority - priority tasks are started with
- *   returns 1 on success, 0 on failure.
-static void session(rtems_task_argument arg); /* Forward declare */
-static int
-task_pool_init(int count, rtems_task_priority priority)
-  int i;
-  rtems_status_code sc;
-  char id = 'a';
-  task_pool.head = task_pool.tail = 0;
-  task_pool.mutex = (rtems_id)-1;
-  task_pool.sem   = (rtems_id)-1;
-  sc = rtems_semaphore_create(
-    rtems_build_name('F', 'T', 'P', 'M'),
-    1,
-    RTEMS_DEFAULT_ATTRIBUTES
-    | RTEMS_BINARY_SEMAPHORE
-    | RTEMS_INHERIT_PRIORITY
-    | RTEMS_PRIORITY,
-    RTEMS_NO_PRIORITY,
-    &task_pool.mutex);
-  if(sc == RTEMS_SUCCESSFUL)
-      rtems_build_name('F', 'T', 'P', 'S'),
-      count,
-      RTEMS_DEFAULT_ATTRIBUTES,
-      &task_pool.sem);
-  if(sc != RTEMS_SUCCESSFUL) {
-    task_pool_done(0);
-    syslog(LOG_ERR, "ftpd: Can not create semaphores");
-    return 0;
-  task_pool.info = (FTPD_SessionInfo_t*)
-    malloc(sizeof(FTPD_SessionInfo_t) * count);
-  task_pool.queue = (FTPD_SessionInfo_t**)
-    malloc(sizeof(FTPD_SessionInfo_t*) * count);
-  if (NULL == task_pool.info || NULL == task_pool.queue)
-    syslog(LOG_ERR, "ftpd: Not enough memory");
-    return 0;
-    FTPD_SessionInfo_t *info = &task_pool.info[i];
-    sc = rtems_task_create(rtems_build_name('F', 'T', 'P', id),
-      priority, FTPD_STACKSIZE,
-      RTEMS_PREEMPT | RTEMS_NO_TIMESLICE |
-      RTEMS_NO_ASR | RTEMS_INTERRUPT_LEVEL(0),
-      RTEMS_FLOATING_POINT | RTEMS_LOCAL,
-      &info->tid);
-    if (sc == RTEMS_SUCCESSFUL)
-      sc = rtems_task_start(
-        info->tid, session, (rtems_task_argument)info);
-      if (sc != RTEMS_SUCCESSFUL)
-        task_pool_done(i);
-    else
-      task_pool_done(i + 1);
-      syslog(LOG_ERR, "ftpd: Could not create/start FTPD session: %s",
-        rtems_status_text(sc));
-      return 0;
-    task_pool.queue[i] = task_pool.info + i;
-    if (++id > 'z')
-      id = 'a';
-  task_pool.count = count;
-  return 1;
- * task_pool_obtain
- * Obtain free task from task pool.
- *   NONE
- *   returns pointer to the corresponding SessionInfo structure on success,
- *           NULL if there are no free tasks in the pool.
-static FTPD_SessionInfo_t*
-task_pool_obtain(void)
-  FTPD_SessionInfo_t* info = 0;
-  sc = rtems_semaphore_obtain(task_pool.sem, RTEMS_NO_WAIT, RTEMS_NO_TIMEOUT);
-    rtems_semaphore_obtain(task_pool.mutex, RTEMS_WAIT, RTEMS_NO_TIMEOUT);
-    info = task_pool.queue[task_pool.head];
-    if(++task_pool.head >= task_pool.count)
-      task_pool.head = 0;
-    rtems_semaphore_release(task_pool.mutex);
-  return info;
- * task_pool_release
- * Return task obtained by 'obtain()' back to the task pool.
- *   info  - pointer to corresponding SessionInfo structure.
- *   NONE
-static void
-task_pool_release(FTPD_SessionInfo_t* info)
-  task_pool.queue[task_pool.tail] = info;
-  if(++task_pool.tail >= task_pool.count)
-    task_pool.tail = 0;
-  rtems_semaphore_release(task_pool.sem);
- * End of task pool routines
- * Function: send_reply
- *    This procedure sends a reply to the client via the control
- *    connection.
- *   code  - 3-digit reply code.
- *   text  - Reply text.
- *   NONE
-static void
-send_reply(FTPD_SessionInfo_t  *info, int code, char *text)
-  text = text != NULL ? text : "";
-  fprintf(info->ctrl_fp, "%d %.70s\r\n", code, text);
-  fflush(info->ctrl_fp);
- * close_socket
- * Close socket.
- *   s - socket descriptor.
- *   seconds - number of seconds the timeout should be,
- *             if >= 0 - infinite timeout (no timeout).
-static int
-set_socket_timeout(int s, int seconds)
-  int res = 0;
-  struct timeval tv;
-  int len = sizeof(tv);
-  if(seconds < 0)
-    seconds = 0;
-  tv.tv_usec = 0;
-  tv.tv_sec  = seconds;
-  if(0 != setsockopt(s, SOL_SOCKET, SO_SNDTIMEO, &tv, len))
-    syslog(LOG_ERR, "ftpd: Can't set send timeout on socket: %s.", serr());
-  else if(0 != setsockopt(s, SOL_SOCKET, SO_RCVTIMEO, &tv, len))
-    syslog(LOG_ERR, "ftpd: Can't set receive timeout on socket: %s.", serr());
-  else
-    res = 1;
-  return res;
- * close_socket
- * Close socket.
- *   s - socket descriptor to be closed.
-static int
-close_socket(int s)
-  if (0 <= s)
-    if (0 != close(s))
-      shutdown(s, 2);
-        return 0;
-  return 1;
- * data_socket
- * Create data socket for session.
- *   info - corresponding SessionInfo structure
- *   returns socket descriptor, or -1 if failure
-static int
-data_socket(FTPD_SessionInfo_t *info)
-  int s = info->pasv_socket;
-  if(0 > s)
-    int on = 1;
-    s = socket(PF_INET, SOCK_STREAM, 0);
-    if(0 > s)
-      send_reply(info, 425, "Can't create data socket.");
-    else if(0 > setsockopt(s, SOL_SOCKET, SO_REUSEADDR, &on, sizeof(on)))
-      close_socket(s);
-      s = -1;
-    else
-      struct sockaddr_in data_source;
-      int tries;
-      /* anchor socket to avoid multi-homing problems */
-      data_source = info->ctrl_addr;
-      data_source.sin_port = htons(20); /* ftp-data port */
-      for(tries = 1; tries < 10; ++tries)
-        errno = 0;
-        if(bind(s, (struct sockaddr *)&data_source, sizeof(data_source)) >= 0)
-          break;
-        if (errno != EADDRINUSE)
-          tries = 10;
-        else
-          rtems_task_wake_after(tries * 10);
-      if(tries >= 10)
-        send_reply(info, 425, "Can't bind data socket.");
-        close_socket(s);
-        s = -1;
-      else
-        struct sockaddr_in *data_dest =
-          (info->use_default) ? &info->def_addr : &info->data_addr;
-        if(0 > connect(s, (struct sockaddr *)data_dest, sizeof(*data_dest)))
-          send_reply(info, 425, "Can't connect data socket.");
-          close_socket(s);
-          s = -1;
-  info->data_socket = s;
-  info->use_default = 1;
-  if(s >= 0)
-    set_socket_timeout(s, info->idle);
-  return s;
- * close_data_socket
- * Close data socket for session.
- *   NONE
-static void
-close_data_socket(FTPD_SessionInfo_t *info)
-  /* As at most one data socket could be open simultaneously and in some cases
-     data_socket == pasv_socket, we select socket to close, then close it. */
-  int s = info->data_socket;
-  if(0 > s)
-    s = info->pasv_socket;
-  if(!close_socket(s))
-    syslog(LOG_ERR, "ftpd: Error closing data socket.");
-  info->data_socket = -1;
-  info->pasv_socket = -1;
- * close_stream
- * Close control stream of session.
- *   NONE
-static void
-close_stream(FTPD_SessionInfo_t* info)
-  if (NULL != info->ctrl_fp)
-    if (0 != fclose(info->ctrl_fp))
-      syslog(LOG_ERR, "ftpd: Could not close control stream: %s", serr());
-    else
-      info->ctrl_socket = -1;
-  if (!close_socket(info->ctrl_socket))
-    syslog(LOG_ERR, "ftpd: Could not close control socket: %s", serr());
-  info->ctrl_fp = NULL;
- * send_mode_reply
- * Sends BINARY/ASCII reply string depending on current transfer mode.
- *   NONE
-static void
-send_mode_reply(FTPD_SessionInfo_t *info)
-  if(info->xfer_mode == TYPE_I)
-    send_reply(info, 150, "Opening BINARY mode data connection.");
-  else
-    send_reply(info, 150, "Opening ASCII mode data connection.");
- * command_retrieve
- * Perform the "RETR" command (send file to client).
- *   char *filename  - source filename.
- *   NONE
-static void
-command_retrieve(FTPD_SessionInfo_t  *info, char const *filename)
-  int                 s = -1;
-  int                 fd = -1;
-  char                buf[FTPD_DATASIZE];
-  struct stat         stat_buf;
-  int                 res = 0;
-  if(!can_read() || !info->auth)
-    send_reply(info, 550, "Access denied.");
-    return;
-  if (0 > (fd = open(filename, O_RDONLY)))
-    send_reply(info, 550, "Error opening file.");
-    return;
-  if (fstat(fd, &stat_buf) == 0 && S_ISDIR(stat_buf.st_mode))
-    if (-1 != fd)
-      close(fd);
-    send_reply(info, 550, "Is a directory.");
-    return;
-  send_mode_reply(info);
-  s = data_socket(info);
-  if (0 <= s)
-    int n = -1;
-      while ((n = read(fd, buf, FTPD_DATASIZE)) > 0)
-        if(send(s, buf, n, 0) != n)
-          break;
-        sched_yield();
-    else if (info->xfer_mode == TYPE_A)
-      int rest = 0;
-      while (rest == 0 && (n = read(fd, buf, FTPD_DATASIZE)) > 0)
-        char const* e = buf;
-        char const* b;
-        int i;
-        rest = n;
-        do
-          char lf = '\0';
-          b = e;
-          for(i = 0; i < rest; ++i, ++e)
-            if(*e == '\n')
-              lf = '\n';
-              break;
-          if(send(s, b, i, 0) != i)
-            break;
-          if(lf == '\n')
-            if(send(s, "\r\n", 2, 0) != 2)
-              break;
-            ++e;
-            ++i;
-        while((rest -= i) > 0);
-        sched_yield();
-    if (0 == n)
-      if (0 == close(fd))
-        fd = -1;
-        res = 1;
-  if (-1 != fd)
-    close(fd);
-  if (0 == res)
-    send_reply(info, 451, "File read error.");
-  else
-    send_reply(info, 226, "Transfer complete.");
-  close_data_socket(info);
-  return;
- * discard
- * Analog of `write' routine that just discards passed data
- *   fd    - file descriptor (ignored)
- *   buf   - data to write (ignored)
- *   count - number of bytes in `buf'
- *   returns `count'
-static ssize_t
-discard(int fd, void const* buf, size_t count)
-  (void)fd;
-  (void)buf;
-  return count;
- * command_store
- * Performs the "STOR" command (receive data from client).
- *   char *filename   - Destination filename.
- *   NONE
-static void
-command_store(FTPD_SessionInfo_t *info, char const *filename)
-  int                    s;
-  int                    n;
-  unsigned long          size = 0;
-  struct rtems_ftpd_hook *usehook = NULL;
-  int                    res = 1;
-  int                    bare_lfs = 0;
-  int                    null = 0;
-  typedef ssize_t (*WriteProc)(int, void const*, size_t);
-  WriteProc              wrt = &write;
-  if(!can_write() || !info->auth)
-    return;
-  if(0 > s)
-    return;
-  null = !strcmp("/dev/null", filename);
-  if (null)
-    /* File "/dev/null" just throws data away.
-     *  FIXME: this is hack.  Using `/dev/null' filesystem entry would be
-     *  better.
-    wrt = &discard;
-  if (!null && ftpd_config->hooks != NULL)
-    /* Search our list of hooks to see if we need to do something special. */
-    struct rtems_ftpd_hook *hook;
-    int i;
-    i = 0;
-    hook = &ftpd_config->hooks[i++];
-    while (hook->filename != NULL)
-      if (!strcmp(hook->filename, filename))
-        usehook = hook;
-        break;
-  if (usehook != NULL)
-     * OSV: FIXME: Small buffer could be used and hook routine
-     * called multiple times instead.  Alternatively, the support could be
-     * removed entirely in favor of configuring RTEMS pseudo-device with
-     * given name.
-    char   *bigBufr;
-    size_t  filesize = ftpd_config->max_hook_filesize + 1;
-     * Allocate space for our "file".
-    bigBufr = (char *)malloc(filesize);
-    if (bigBufr == NULL)
-      send_reply(info, 451, "Local resource failure: malloc.");
-      return;
-     * Retrieve the file into our buffer space.
-    size = 0;
-    while ((n = recv(s, bigBufr + size, filesize - size, 0)) > 0)
-      size += n;
-    if (size >= filesize)
-      send_reply(info, 451, "File too long: buffer size exceeded.");
-      free(bigBufr);
-      return;
-     * Call our hook.
-    res = (usehook->hook_function)(bigBufr, size) == 0;
-    free(bigBufr);
-    if(!res)
-      send_reply(info, 451, "File processing failed.");
-      return;
-  else
-    /* Data transfer to regular file or /dev/null. */
-    int fd = 0;
-    if(!null)
-      fd = creat(filename,
-        S_IRUSR | S_IWUSR | S_IRGRP | S_IWGRP | S_IROTH | S_IWOTH);
-    if (0 > fd)
-      send_reply(info, 550, "Error creating file.");
-      return;
-      while ((n = recv(s, buf, FTPD_DATASIZE, 0)) > 0)
-        if (wrt(fd, buf, n) != n)
-          res = 0;
-          break;
-        sched_yield();
-    else if(info->xfer_mode == TYPE_A)
-      int rest = 0;
-      int pended_cr = 0;
-      while (res && rest == 0 && (n = recv(s, buf, FTPD_DATASIZE, 0)) > 0)
-        char const* b;
-        int i;
-        rest = n;
-        if(pended_cr && *e != '\n')
-          char const lf = '\r';
-          pended_cr = 0;
-          if(wrt(fd, &lf, 1) != 1)
-            res = 0;
-            break;
-        do
-          int count;
-          int sub = 0;
-          b = e;
-            int pcr = pended_cr;
-            pended_cr = 0;
-            if(*e == '\r')
-              pended_cr = 1;
-            else if(*e == '\n')
-              if(pcr)
-                sub = 2;
-                ++i;
-                ++e;
-                break;
-              ++bare_lfs;
-          if(res == 0)
-            break;
-          count = i - sub - pended_cr;
-          if(count > 0 && wrt(fd, b, count) != count)
-            res = 0;
-            break;
-          if(sub == 2 && wrt(fd, e - 1, 1) != 1)
-            res = 0;
-        sched_yield();
-    if (0 > close(fd) || res == 0)
-      send_reply(info, 452, "Error writing file.");
-      return;
-  if (bare_lfs > 0)
-    snprintf(buf, FTPD_BUFSIZE,
-      "Transfer complete. WARNING! %d bare linefeeds received in ASCII mode.",
-      bare_lfs);
-    send_reply(info, 226, buf);
-  else
- * send_dirline
- * Sends one line of LIST command reply corresponding to single file.
- *   s - socket descriptor to send data to
- *   wide - if 0, send only file name.  If not 0, send 'stat' info as well in
- *          "ls -l" format.
- *   curTime - current time
- *   path - path to be prepended to what is given by 'add'
- *   add  - path to be appended to what is given by 'path', the resulting path
- *          is then passed to 'stat()' routine
- *   name - file name to be reported in output
- *   buf  - buffer for temporary data
- *   returns 0 on failure, 1 on success
-static int
-send_dirline(int s, int wide, time_t curTime, char const* path,
-  char const* add, char const* fname, char* buf)
-  if(wide)
-    int plen = strlen(path);
-    int alen = strlen(add);
-    if(plen == 0)
-      buf[plen++] = '/';
-      buf[plen] = '\0';
-    else
-      strcpy(buf, path);
-      if(alen > 0 && buf[plen - 1] != '/')
-        if(plen >= FTPD_BUFSIZE)
-          return 0;
-        buf[plen] = '\0';
-    if(plen + alen >= FTPD_BUFSIZE)
-      return 0;
-    strcpy(buf + plen, add);
-    if (stat(buf, &stat_buf) == 0)
-      int len;
-      struct tm bt;
-      time_t tf = stat_buf.st_mtime;
-      enum { SIZE = 80 };
-      time_t SIX_MONTHS = (365L*24L*60L*60L)/2L;
-      char timeBuf[SIZE];
-      gmtime_r(&tf, &bt);
-      if(curTime > tf + SIX_MONTHS || tf > curTime + SIX_MONTHS)
-        strftime (timeBuf, SIZE, "%b %d  %Y", &bt);
-      else
-        strftime (timeBuf, SIZE, "%b %d %H:%M", &bt);
-      len = snprintf(buf, FTPD_BUFSIZE,
-        "%c%c%c%c%c%c%c%c%c%c  1 %5d %5d %11u %s %s\r\n",
-        (S_ISLNK(stat_buf.st_mode)?('l'):
-          (S_ISDIR(stat_buf.st_mode)?('d'):('-'))),
-        (stat_buf.st_mode & S_IRUSR)?('r'):('-'),
-        (stat_buf.st_mode & S_IWUSR)?('w'):('-'),
-        (stat_buf.st_mode & S_IXUSR)?('x'):('-'),
-        (stat_buf.st_mode & S_IRGRP)?('r'):('-'),
-        (stat_buf.st_mode & S_IWGRP)?('w'):('-'),
-        (stat_buf.st_mode & S_IXGRP)?('x'):('-'),
-        (stat_buf.st_mode & S_IROTH)?('r'):('-'),
-        (stat_buf.st_mode & S_IWOTH)?('w'):('-'),
-        (stat_buf.st_mode & S_IXOTH)?('x'):('-'),
-        (int)stat_buf.st_uid,
-        (int)stat_buf.st_gid,
-        (int)stat_buf.st_size,
-        timeBuf,
-        fname
-      if(send(s, buf, len, 0) != len)
-        return 0;
-  else
-    int len = snprintf(buf, FTPD_BUFSIZE, "%s\r\n", fname);
-      return 0;
-  return 1;
- * command_list
- * Send file list to client.
- *   char *fname  - File (or directory) to list.
- *   NONE
-static void
-command_list(FTPD_SessionInfo_t *info, char const *fname, int wide)
-  int                 s;
-  DIR                 *dirp = 0;
-  struct dirent       *dp = 0;
-  char                buf[FTPD_BUFSIZE];
-  time_t curTime;
-  int sc = 1;
-  if(!info->auth)
-    return;
-  send_reply(info, 150, "Opening ASCII mode data connection for LIST.");
-  if(0 > s)
-    syslog(LOG_ERR, "ftpd: Error connecting to data socket.");
-    return;
-  if(fname[0] == '\0')
-    fname = ".";
-  if (0 > stat(fname, &stat_buf))
-      "%s: No such file or directory.\r\n", fname);
-    send(s, buf, strlen(buf), 0);
-  else if (S_ISDIR(stat_buf.st_mode) && (NULL == (dirp = opendir(fname))))
-      "%s: Can not open directory.\r\n", fname);
-  else
-    time(&curTime);
-    if(!dirp && *fname)
-      sc = sc && send_dirline(s, wide, curTime, fname, "", fname, buf);
-    else {
-      /* FIXME: need "." and ".." only when '-a' option is given */
-      sc = sc && send_dirline(s, wide, curTime, fname, "", ".", buf);
-        (strcmp(fname, ftpd_root) ? ".." : ""), "..", buf);
-      while (sc && (dp = readdir(dirp)) != NULL)
-        sc = sc &&
-          send_dirline(s, wide, curTime, fname, dp->d_name, dp->d_name, buf);
-  if(dirp)
-    closedir(dirp);
-  if(sc)
-  else
-    send_reply(info, 426, "Connection aborted.");
- * command_cwd
- * Change current working directory.
- *   dir  - directory name passed in CWD command
- *   NONE
-static void
-command_cwd(FTPD_SessionInfo_t  *info, char *dir)
-  if(!info->auth)
-    return;
-  if(chdir(dir) == 0)
-    send_reply(info, 250, "CWD command successful.");
-  else
-    send_reply(info, 550, "CWD command failed.");
- * command_pwd
- * Send current working directory to client.
- *   NONE
-static void
-command_pwd(FTPD_SessionInfo_t  *info)
-  char const* cwd;
-  errno = 0;
-  buf[0] = '"';
-  if(!info->auth)
-    return;
-  cwd = getcwd(buf + 1, FTPD_BUFSIZE - 4);
-  if(cwd)
-    int len = strlen(cwd);
-    static char const txt[] = "\" is the current directory.";
-    int size = sizeof(txt);
-    if(len + size + 1 >= FTPD_BUFSIZE)
-      size = FTPD_BUFSIZE - len - 2;
-    memcpy(buf + len + 1, txt, size);
-    buf[len + size] = '\0';
-    send_reply(info, 250, buf);
-  else {
-    snprintf(buf, FTPD_BUFSIZE, "Error: %s.", serr());
-    send_reply(info, 452, buf);
- * command_mdtm
- * Handle FTP MDTM command (send file modification time to client)/
- *   fname - file name passed in MDTM command
- *   info->cwd is set to new CWD value.
-static void
-command_mdtm(FTPD_SessionInfo_t  *info, char const* fname)
-  struct stat stbuf;
-  if(!info->auth)
-    return;
-  if (0 > stat(fname, &stbuf))
-    snprintf(buf, FTPD_BUFSIZE, "%s: %s.", fname, serr());
-    send_reply(info, 550, buf);
-  else
-    struct tm *t = gmtime(&stbuf.st_mtime);
-    snprintf(buf, FTPD_BUFSIZE, "%04d%02d%02d%02d%02d%02d",
-      1900 + t->tm_year,
-      t->tm_mon+1, t->tm_mday,
-      t->tm_hour, t->tm_min, t->tm_sec);
-    send_reply(info, 213, buf);
-static void
-command_size(FTPD_SessionInfo_t *info, char const* fname)
-  if(!info->auth)
-    return;
-  if (info->xfer_mode != TYPE_I || 0 > stat(fname, &stbuf) || stbuf.st_size < 0)
-    send_reply(info, 550, "Could not get file size.");
-  else
-    snprintf(buf, FTPD_BUFSIZE, "%" PRIuMAX, (uintmax_t) stbuf.st_size);
- * command_port
- * This procedure fills address for data connection given the IP address and
- * port of the remote machine.
- *   args - arguments to the "PORT" command.
- *   info->data_addr is set according to arguments of the PORT command.
- *   info->use_default is set to 0 on success, 1 on failure.
-static void
-command_port(FTPD_SessionInfo_t *info, char const *args)
-  enum { NUM_FIELDS = 6 };
-  unsigned int a[NUM_FIELDS];
-  int n;
-  n = sscanf(args, "%u,%u,%u,%u,%u,%u", a+0, a+1, a+2, a+3, a+4, a+5);
-  if(NUM_FIELDS == n)
-    int i;
-    union {
-      uint8_t b[NUM_FIELDS];
-      struct {
-        uint32_t ip;
-        uint16_t port;
-      } u ;
-    } ip_info;
-    for(i = 0; i < NUM_FIELDS; ++i)
-      if(a[i] > 255)
-        break;
-      ip_info.b[i] = (uint8_t)a[i];
-    if(i == NUM_FIELDS)
-      /* Note: while it contradicts with RFC959, we don't allow PORT command
-       * to specify IP address different than those of the originating client
-       * for the sake of safety. */
-      if (ip_info.u.ip == info->def_addr.sin_addr.s_addr)
-        info->data_addr.sin_addr.s_addr = ip_info.u.ip;
-        info->data_addr.sin_port        = ip_info.u.port;
-        info->data_addr.sin_family      = AF_INET;
-        memset(info->data_addr.sin_zero, 0, sizeof(info->data_addr.sin_zero));
-        info->use_default = 0;
-        send_reply(info, 200, "PORT command successful.");
-        return; /* success */
-      else
-        send_reply(info, 425, "Address doesn't match peer's IP.");
-        return;
-  send_reply(info, 501, "Syntax error.");
- * command_pasv
- * Handle FTP PASV command.
- * Open socket, listen for and accept connection on it.
- *   info->pasv_socket is set to the descriptor of the data socket
-static void
-command_pasv(FTPD_SessionInfo_t *info)
-  int s = -1;
-  int err = 1;
-  if (s < 0)
-    syslog(LOG_ERR, "ftpd: Error creating PASV socket: %s", serr());
-  else
-    struct sockaddr_in addr;
-    socklen_t addrLen = sizeof(addr);
-    addr = info->ctrl_addr;
-    addr.sin_port = htons(0);
-    if (0 > bind(s, (struct sockaddr *)&addr, addrLen))
-      syslog(LOG_ERR, "ftpd: Error binding PASV socket: %s", serr());
-    else if (0 > listen(s, 1))
-      syslog(LOG_ERR, "ftpd: Error listening on PASV socket: %s", serr());
-    else if(set_socket_timeout(s, info->idle))
-      unsigned char const *ip, *p;
-      getsockname(s, (struct sockaddr *)&addr, &addrLen);
-      ip = (unsigned char const*)&(addr.sin_addr);
-      p  = (unsigned char const*)&(addr.sin_port);
-      snprintf(buf, FTPD_BUFSIZE, "Entering passive mode (%u,%u,%u,%u,%u,%u).",
-        ip[0], ip[1], ip[2], ip[3], p[0], p[1]);
-      send_reply(info, 227, buf);
-      info->pasv_socket = accept(s, (struct sockaddr *)&addr, &addrLen);
-      if (0 > info->pasv_socket)
-        syslog(LOG_ERR, "ftpd: Error accepting PASV connection: %s", serr());
-      else
-        close_socket(s);
-        s = -1;
-        err = 0;
-  if(err)
-    /* (OSV) The note is from FreeBSD FTPD.
-     * Note: a response of 425 is not mentioned as a possible response to
-     * the PASV command in RFC959.  However, it has been blessed as a
-     * legitimate response by Jon Postel in a telephone conversation
-     * with Rick Adams on 25 Jan 89. */
-    send_reply(info, 425, "Can't open passive connection.");
-    close_socket(s);
- * skip_options
- * Utility routine to skip options (if any) from input command.
- *   p  - pointer to pointer to command
- *   p  - is changed to point to first non-option argument
-static void
-skip_options(char **p)
-  char* buf = *p;
-  char* last = NULL;
-  while(1) {
-    while(isspace((unsigned char)*buf))
-      ++buf;
-    if(*buf == '-') {
-      if(*++buf == '-') { /* `--' should terminate options */
-        if(isspace((unsigned char)*++buf)) {
-          last = buf;
-          do ++buf;
-          while(isspace((unsigned char)*buf));
-          break;
-      while(*buf && !isspace((unsigned char)*buf))
-        ++buf;
-      last = buf;
-    else
-      break;
-  if(last)
-    *last = '\0';
-  *p = buf;
- * split_command
- * Split command into command itself, options, and arguments. Command itself
- * is converted to upper case.
- *   buf - initial command string
- * Output parameter:
- *   buf  - is modified by inserting '\0' at ends of split entities
- *   cmd  - upper-cased command code
- *   opts - string containing all the options
- *   args - string containing all the arguments
-static void
-split_command(char *buf, char **cmd, char **opts, char **args)
-  char* eoc;
-  char* p = buf;
-  while(isspace((unsigned char)*p))
-    ++p;
-  *cmd = p;
-  while(*p && !isspace((unsigned char)*p))
-    *p = toupper((unsigned char)*p);
-    ++p;
-  eoc = p;
-  if(*p)
-    *p++ = '\0';
-    ++p;
-  *opts = p;
-  skip_options(&p);
-  *args = p;
-  if(*opts == p)
-    *opts = eoc;
-  while(*p && *p != '\r' && *p != '\n')
-    ++p;
-  if(*p)
-    *p++ = '\0';
- * exec_command
- * Parse and execute FTP command.
- * FIXME: This section is somewhat of a hack.  We should have a better
- *        way to parse commands.
- *   cmd  - command to be executed (upper-case)
- *   args - arguments of the command
- *    NONE
-static void
-exec_command(FTPD_SessionInfo_t *info, char* cmd, char* args)
-  char fname[FTPD_BUFSIZE];
-  int wrong_command = 0;
-  fname[0] = '\0';
-  if (!strcmp("PORT", cmd))
-    command_port(info, args);
-  else if (!strcmp("PASV", cmd))
-    command_pasv(info);
-  else if (!strcmp("RETR", cmd))
-    strncpy(fname, args, 254);
-    command_retrieve(info, fname);
-  else if (!strcmp("STOR", cmd))
-    command_store(info, fname);
-  else if (!strcmp("LIST", cmd))
-    command_list(info, fname, 1);
-  else if (!strcmp("NLST", cmd))
-    command_list(info, fname, 0);
-  else if (!strcmp("MDTM", cmd))
-    command_mdtm(info, fname);
-  else if (!strcmp("SIZE", cmd))
-    command_size(info, fname);
-  else if (!strcmp("SYST", cmd))
-    send_reply(info, 215, FTPD_SYSTYPE);
-  else if (!strcmp("TYPE", cmd))
-    if (args[0] == 'I')
-      info->xfer_mode = TYPE_I;
-      send_reply(info, 200, "Type set to I.");
-    else if (args[0] == 'A')
-      info->xfer_mode = TYPE_A;
-      send_reply(info, 200, "Type set to A.");
-    else
-      send_reply(info, 504, "Type not implemented.  Set to I.");
-  else if (!strcmp("USER", cmd))
-    sscanf(args, "%254s", fname);
-    if (info->user)
-      free(info->user);
-    if (info->pass)
-      free(info->pass);
-    info->pass = NULL;
-    info->user = strdup(fname);
-    if (ftpd_config->login &&
-      !ftpd_config->login(info->user, NULL)) {
-      info->auth = false;
-      send_reply(info, 331, "User name okay, need password.");
-    } else {
-      info->auth = true;
-      send_reply(info, 230, "User logged in.");
-  else if (!strcmp("PASS", cmd))
-    if (info->pass)
-      free(info->pass);
-    info->pass = strdup(fname);
-    if (!info->user) {
-      send_reply(info, 332, "Need account to log in");
-    } else {
-        !ftpd_config->login(info->user, info->pass)) {
-        send_reply(info, 530, "Not logged in.");
-      } else {
-  else if (!strcmp("DELE", cmd))
-    else if (
-      strncpy(fname, args, 254) &&
-      unlink(fname) == 0)
-      send_reply(info, 257, "DELE successful.");
-    else
-      send_reply(info, 550, "DELE failed.");
-  else if (!strcmp("SITE", cmd))
-    char* opts;
-    split_command(args, &cmd, &opts, &args);
-    if(!strcmp("CHMOD", cmd))
-      int mask;
-      else {
-        char *c;
-        c = strchr(args, ' ');
-        if((c != NULL) && (sscanf(args, "%o", &mask) == 1) && strncpy(fname, c+1, 254)
-          && (chmod(fname, (mode_t)mask) == 0))
-          send_reply(info, 257, "CHMOD successful.");
-        else
-          send_reply(info, 550, "CHMOD failed.");
-    else
-      wrong_command = 1;
-  else if (!strcmp("RMD", cmd))
-    else if (
-      rmdir(fname) == 0)
-      send_reply(info, 257, "RMD successful.");
-    else
-      send_reply(info, 550, "RMD failed.");
-  else if (!strcmp("MKD", cmd))
-    else if (
-      mkdir(fname, S_IRWXU | S_IRWXG | S_IRWXO) == 0)
-      send_reply(info, 257, "MKD successful.");
-    else
-      send_reply(info, 550, "MKD failed.");
-  else if (!strcmp("CWD", cmd))
-    command_cwd(info, fname);
-  else if (!strcmp("CDUP", cmd))
-    command_cwd(info, "..");
-  else if (!strcmp("PWD", cmd))
-    command_pwd(info);
-  else
-  if(wrong_command)
-    send_reply(info, 500, "Command not understood.");
- * session
- * This task handles single session.  It is waked up when the FTP daemon gets a
- * service request from a remote machine.  Here, we watch for commands that
- * will come through the control connection.  These commands are then parsed
- * and executed until the connection is closed, either unintentionally or
- * intentionally with the "QUIT" command.
- *   arg - pointer to corresponding SessionInfo.
- *   NONE
-static void
-session(rtems_task_argument arg)
-  FTPD_SessionInfo_t  *const info = (FTPD_SessionInfo_t  *)arg;
-  int chroot_made = 0;
-  rtems_libio_set_private_env();
-  /* chroot() can fail here because the directory may not exist yet. */
-  chroot_made = chroot(ftpd_root) == 0;
-  while(1)
-    rtems_event_set set;
-    int rv;
-    rtems_event_receive(FTPD_RTEMS_EVENT, RTEMS_EVENT_ANY, RTEMS_NO_TIMEOUT,
-      &set);
-    chroot_made = chroot_made || chroot(ftpd_root) == 0;
-    rv = chroot_made ? chdir("/") : -1;
-    errno = 0;
-    if (rv == 0)
-      send_reply(info, 220, FTPD_SERVER_MESSAGE);
-      while (1)
-        char *cmd, *opts, *args;
-        if (fgets(buf, FTPD_BUFSIZE, info->ctrl_fp) == NULL)
-          syslog(LOG_INFO, "ftpd: Connection aborted.");
-          break;
-        split_command(buf, &cmd, &opts, &args);
-        if (!strcmp("QUIT", cmd))
-          send_reply(info, 221, "Goodbye.");
-          break;
-        else
-          exec_command(info, cmd, args);
-    else
-      send_reply(info, 421, "Service not available, closing control connection.");
-     * Go back to the root directory.  A use case is to release a current
-     * directory in a mounted file system on dynamic media, e.g. USB stick.
-     * The return value can be ignored since the next session will try do the
-     * operation again and an error check is performed in this case.
-    chdir("/");
-    /* Close connection and put ourselves back into the task pool. */
-    close_stream(info);
-    free(info->user);
-    free(info->pass);
-    task_pool_release(info);
- * ftpd_daemon
- * This task runs forever.  It waits for service requests on the FTP port
- * (port 21 by default).  When a request is received, it opens a new session
- * to handle those requests until the connection is closed.
- *   NONE
- *   NONE
-static void
-ftpd_daemon(rtems_task_argument args __attribute__((unused)))
-  int                 s;
-  socklen_t	      addrLen;
-  FTPD_SessionInfo_t  *info = NULL;
-  if (s < 0)
-    syslog(LOG_ERR, "ftpd: Error creating socket: %s", serr());
-  addr.sin_family      = AF_INET;
-  addr.sin_port        = htons(ftpd_config->port);
-  addr.sin_addr.s_addr = htonl(INADDR_ANY);
-  memset(addr.sin_zero, 0, sizeof(addr.sin_zero));
-  if (0 > bind(s, (struct sockaddr *)&addr, sizeof(addr)))
-    syslog(LOG_ERR, "ftpd: Error binding control socket: %s", serr());
-    syslog(LOG_ERR, "ftpd: Error listening on control socket: %s", serr());
-  else while (1)
-    int ss;
-    addrLen = sizeof(addr);
-    ss = accept(s, (struct sockaddr *)&addr, &addrLen);
-    if (0 > ss)
-      syslog(LOG_ERR, "ftpd: Error accepting control connection: %s", serr());
-    else if(!set_socket_timeout(ss, ftpd_timeout))
-      close_socket(ss);
-    else
-      info = task_pool_obtain();
-      if (NULL == info)
-        close_socket(ss);
-      else
-        info->ctrl_socket = ss;
-        if ((info->ctrl_fp = fdopen(info->ctrl_socket, "r+")) == NULL)
-          syslog(LOG_ERR, "ftpd: fdopen() on socket failed: %s", serr());
-        else
-          /* Initialize corresponding SessionInfo structure */
-          info->def_addr = addr;
-          if(0 > getsockname(ss, (struct sockaddr *)&addr, &addrLen))
-            syslog(LOG_ERR, "ftpd: getsockname(): %s", serr());
-          else
-            info->ctrl_addr  = addr;
-              htons(ntohs(info->ctrl_addr.sin_port) - 1);
-            info->idle = ftpd_timeout;
-            info->user = NULL;
-            if (ftpd_config->login)
-            else
-            /* Wakeup the session task.  The task will call task_pool_release
-               after it closes connection. */
-            rtems_event_send(info->tid, FTPD_RTEMS_EVENT);
-  rtems_task_delete(RTEMS_SELF);
- * rtems_ftpd_start
- * Here, we start the FTPD task which waits for FTP requests and services
- * them.  This procedure returns to its caller once the task is started.
- *    config: constant initial setup.
- *    returns RTEMS_SUCCESSFUL on successful start of the daemon.
-int
-rtems_ftpd_start(const struct rtems_ftpd_configuration* config)
-  rtems_id            tid;
-  rtems_task_priority priority;
-  int count;
-  if (ftpd_config != NULL)
-    return RTEMS_RESOURCE_IN_USE;
-  ftpd_config = malloc(sizeof(*ftpd_config));
-  if (ftpd_config == NULL)
-    return RTEMS_NO_MEMORY;
-  *ftpd_config = *config;
-  if (ftpd_config->port == 0)
-    ftpd_config->port = FTPD_CONTROL_PORT;
-  if (ftpd_config->priority == 0)
-    ftpd_config->priority = 40;
-  priority = ftpd_config->priority;
-  ftpd_timeout = ftpd_config->idle;
-  if (ftpd_timeout < 0)
-    ftpd_timeout = 0;
-  ftpd_config->idle = ftpd_timeout;
-  ftpd_access = ftpd_config->access;
-  ftpd_root = "/";
-  if (ftpd_config->root && ftpd_config->root[0] == '/' )
-    ftpd_root = ftpd_config->root;
-  ftpd_config->root = ftpd_root;
-  if (ftpd_config->tasks_count <= 0)
-    ftpd_config->tasks_count = 1;
-  count = ftpd_config->tasks_count;
-  if (!task_pool_init(count, priority))
-    syslog(LOG_ERR, "ftpd: Could not initialize task pool.");
-    return RTEMS_UNSATISFIED;
-  sc = rtems_task_create(rtems_build_name('F', 'T', 'P', 'D'),
-    priority, RTEMS_MINIMUM_STACK_SIZE,
-    RTEMS_PREEMPT | RTEMS_NO_TIMESLICE | RTEMS_NO_ASR |
-    RTEMS_INTERRUPT_LEVEL(0),
-    &tid);
-    sc = rtems_task_start(tid, ftpd_daemon, 0);
-      rtems_task_delete(tid);
-    task_pool_done(count);
-    syslog(LOG_ERR, "ftpd: Could not create/start FTP daemon: %s",
-  if (ftpd_config->verbose)
-    syslog(LOG_INFO, "ftpd: FTP daemon started (%d session%s max)",
-           count, ((count > 1) ? "s" : ""));
-  return RTEMS_SUCCESSFUL;
diff --git a/rtemsbsd/ftpfs/ftpfs.c b/rtemsbsd/ftpfs/ftpfs.c
index e016caeb2..000000000
--- a/rtemsbsd/ftpfs/ftpfs.c
+++ /dev/null
@@ -1,1428 +0,0 @@
- * @file
- * File Transfer Protocol file system (FTP client).
- * Copyright (c) 2009-2012 embedded brains GmbH.
- *  embedded brains GmbH
- *  Obere Lagerstr. 30
- *  82178 Puchheim
- *  Germany
- *  <rtems at embedded-brains.de>
- * (c) Copyright 2002
- * Thomas Doerfler
- * IMD Ingenieurbuero fuer Microcomputertechnik
- * Herbststr. 8
- * 82178 Puchheim, Germany
- * <Thomas.Doerfler at imd-systems.de>
- * This code has been created after closly inspecting "tftpdriver.c" from Eric
- * Norum.
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
-#ifdef HAVE_CONFIG_H
-#endif
-#include <ctype.h>
-#include <errno.h>
-#include <fcntl.h>
-#include <malloc.h>
-#include <netdb.h>
-#include <stdarg.h>
-#include <stdio.h>
-#include <arpa/inet.h>
-#include <sys/select.h>
-#include <rtems.h>
-#include <rtems/ftpfs.h>
-#include <rtems/libio_.h>
-#include <rtems/seterr.h>
-#ifdef DEBUG
-  #define DEBUG_PRINTF(...) printf(__VA_ARGS__)
-#else
-#endif
- * Connection entry for each open file stream.
-typedef struct {
-  off_t file_size;
-   * Control connection socket.
-  int ctrl_socket;
-  uint32_t client_address;
-   * Data transfer socket.
-  int data_socket;
-   * Current index into the reply buffer.
-  size_t reply_current;
-   * End index of the reply buffer.
-  size_t reply_end;
-   * Buffer for relpy data.
-  char reply_buffer [128];
-   * End of file flag.
-  bool eof;
-  bool write;
-   * Indicates if we should do a SIZE command.
-   * The first call to the rtems_ftpfs_fstat() handler is issued by the path
-   * evaluation to check for access permission.  For this case we avoid the
-   * SIZE command.
-  bool do_size_command;
-  ino_t ino;
-  const char *user;
-  const char *password;
-  const char *hostname;
-  const char *filename;
-  char buffer [];
-} rtems_ftpfs_entry;
- * Mount entry for each file system instance.
-typedef struct {
-   * Verbose mode enabled or disabled.
-  bool verbose;
-   * Timeout value
-  struct timeval timeout;
-   * Inode counter.
-  ino_t ino;
-} rtems_ftpfs_mount_entry;
-static const rtems_filesystem_operations_table rtems_ftpfs_ops;
-static const rtems_filesystem_file_handlers_r rtems_ftpfs_handlers;
-static const rtems_filesystem_file_handlers_r rtems_ftpfs_root_handlers;
-static bool rtems_ftpfs_use_timeout(const struct timeval *to)
-  return to->tv_sec != 0 || to->tv_usec != 0;
-static int rtems_ftpfs_set_connection_timeout(
-  int socket,
-  const struct timeval *to
-  if (rtems_ftpfs_use_timeout(to)) {
-    int rv = 0;
-    rv = setsockopt(socket, SOL_SOCKET, SO_SNDTIMEO, to, sizeof(*to));
-    if (rv != 0) {
-      return EIO;
-    rv = setsockopt(socket, SOL_SOCKET, SO_RCVTIMEO, to, sizeof(*to));
-    if (rv != 0) {
-      return EIO;
-  return 0;
-static rtems_status_code rtems_ftpfs_do_ioctl(
-  const char *mount_point,
-  ioctl_command_t req,
-  rtems_status_code sc = RTEMS_SUCCESSFUL;
-  int rv = 0;
-  int fd = 0;
-  va_list ap;
-  if (mount_point == NULL) {
-    mount_point = RTEMS_FTPFS_MOUNT_POINT_DEFAULT;
-  fd = open(mount_point, O_RDWR);
-  if (fd < 0) {
-    return RTEMS_INVALID_NAME;
-  va_start(ap, req);
-  rv = ioctl(fd, req, va_arg(ap, void *));
-  va_end(ap);
-  if (rv != 0) {
-    sc = RTEMS_INVALID_NUMBER;
-  rv = close(fd);
-  if (rv != 0 && sc == RTEMS_SUCCESSFUL) {
-    sc = RTEMS_IO_ERROR;
-  return sc;
-rtems_status_code rtems_ftpfs_get_verbose(const char *mount_point, bool *verbose)
-  return rtems_ftpfs_do_ioctl(
-    mount_point,
-    RTEMS_FTPFS_IOCTL_GET_VERBOSE,
-    verbose
-rtems_status_code rtems_ftpfs_set_verbose(const char *mount_point, bool verbose)
-    mount_point,
-    RTEMS_FTPFS_IOCTL_SET_VERBOSE,
-    &verbose
-rtems_status_code rtems_ftpfs_get_timeout(
-  struct timeval *timeout
-    mount_point,
-    RTEMS_FTPFS_IOCTL_GET_TIMEOUT,
-    timeout
-rtems_status_code rtems_ftpfs_set_timeout(
-  const struct timeval *timeout
-    mount_point,
-    RTEMS_FTPFS_IOCTL_SET_TIMEOUT,
-    timeout
-typedef void (*rtems_ftpfs_reply_parser)(
-  const char * /* reply fragment */,
-  size_t /* reply fragment length */,
-  void * /* parser argument */
-typedef enum {
-  RTEMS_FTPFS_REPLY_START,
-  RTEMS_FTPFS_REPLY_SINGLE_LINE,
-  RTEMS_FTPFS_REPLY_DONE,
-  RTEMS_FTPFS_REPLY_MULTI_LINE,
-  RTEMS_FTPFS_REPLY_MULTI_LINE_START
-} rtems_ftpfs_reply_state;
-typedef enum {
-  RTEMS_FTPFS_REPLY_ERROR = 0,
-  RTEMS_FTPFS_REPLY_1 = '1',
-  RTEMS_FTPFS_REPLY_2 = '2',
-  RTEMS_FTPFS_REPLY_3 = '3',
-  RTEMS_FTPFS_REPLY_4 = '4',
-  RTEMS_FTPFS_REPLY_5 = '5'
-} rtems_ftpfs_reply;
-#define RTEMS_FTPFS_REPLY_SIZE 3
-static bool rtems_ftpfs_is_reply_code_valid(unsigned char *reply)
-  return isdigit(reply [0]) && isdigit(reply [1]) && isdigit(reply [2]);
-static rtems_ftpfs_reply rtems_ftpfs_get_reply(
-  rtems_ftpfs_entry *e,
-  rtems_ftpfs_reply_parser parser,
-  void *parser_arg,
-  bool verbose
-  rtems_ftpfs_reply_state state = RTEMS_FTPFS_REPLY_START;
-  unsigned char reply_code [RTEMS_FTPFS_REPLY_SIZE] = { 'a', 'a', 'a' };
-  size_t reply_code_index = 0;
-  while (state != RTEMS_FTPFS_REPLY_DONE) {
-    char *buf = NULL;
-    size_t i = 0;
-    size_t n = 0;
-    /* Receive reply fragment from socket */
-    if (e->reply_current == e->reply_end) {
-      ssize_t rv = 0;
-      e->reply_current = 0;
-      e->reply_end = 0;
-      rv = recv(
-        e->ctrl_socket,
-        &e->reply_buffer [0],
-        sizeof(e->reply_buffer),
-        0
-      if (rv > 0) {
-        e->reply_end = (size_t) rv;
-      } else {
-        return RTEMS_FTPFS_REPLY_ERROR;
-    buf = &e->reply_buffer [e->reply_current];
-    n = e->reply_end - e->reply_current;
-    /* Invoke parser if necessary */
-    if (parser != NULL) {
-      parser(buf, n, parser_arg);
-    /* Parse reply fragment */
-    for (i = 0; i < n && state != RTEMS_FTPFS_REPLY_DONE; ++i) {
-      char c = buf [i];
-      switch (state) {
-        case RTEMS_FTPFS_REPLY_START:
-          if (reply_code_index < RTEMS_FTPFS_REPLY_SIZE) {
-            reply_code [reply_code_index] = c;
-            ++reply_code_index;
-          } else if (rtems_ftpfs_is_reply_code_valid(reply_code)) {
-            if (c == '-') {
-              state = RTEMS_FTPFS_REPLY_MULTI_LINE;
-            } else {
-              state = RTEMS_FTPFS_REPLY_SINGLE_LINE;
-          } else {
-          break;
-        case RTEMS_FTPFS_REPLY_SINGLE_LINE:
-          if (c == '\n') {
-            state = RTEMS_FTPFS_REPLY_DONE;
-          break;
-        case RTEMS_FTPFS_REPLY_MULTI_LINE:
-          if (c == '\n') {
-            state = RTEMS_FTPFS_REPLY_MULTI_LINE_START;
-            reply_code_index = 0;
-          break;
-        case RTEMS_FTPFS_REPLY_MULTI_LINE_START:
-            if (reply_code [reply_code_index] == c) {
-            } else {
-          } else {
-            if (c == ' ') {
-            } else {
-          break;
-        default:
-    /* Be verbose if necessary */
-    if (verbose) {
-      write(STDERR_FILENO, buf, i);
-    /* Update reply index */
-    e->reply_current += i;
-  return reply_code [0];
-static rtems_ftpfs_reply rtems_ftpfs_send_command_with_parser(
-  const char *cmd,
-  const char *arg,
-  void *parser_arg,
-  bool verbose
-  rtems_ftpfs_reply reply = RTEMS_FTPFS_REPLY_ERROR;
-  size_t cmd_len = strlen(cmd);
-  size_t arg_len = arg != NULL ? strlen(arg) : 0;
-  size_t len = cmd_len + arg_len + 2;
-  char *buf = malloc(len);
-  if (buf != NULL) {
-    ssize_t n = 0;
-    char *buf_arg = buf + cmd_len;
-    char *buf_eol = buf_arg + arg_len;
-    memcpy(buf, cmd, cmd_len);
-    memcpy(buf_arg, arg, arg_len);
-    buf_eol [0] = '\r';
-    buf_eol [1] = '\n';
-    /* Send */
-    n = send(e->ctrl_socket, buf, len, 0);
-    if (n == (ssize_t) len) {
-      if (verbose) {
-        write(STDERR_FILENO, buf, len);
-      /* Reply */
-      reply = rtems_ftpfs_get_reply(e, parser, parser_arg, verbose);
-    free(buf);
-  return reply;
-static rtems_ftpfs_reply rtems_ftpfs_send_command(
-  const char *cmd,
-  const char *arg,
-  bool verbose
-  return rtems_ftpfs_send_command_with_parser(
-    e,
-    cmd,
-    arg,
-    NULL,
-    NULL,
-    verbose
-typedef enum {
-  STATE_USER_NAME,
-  STATE_START_PASSWORD,
-  STATE_START_HOST_NAME,
-  STATE_START_HOST_NAME_OR_PATH,
-  STATE_START_PATH,
-  STATE_PASSWORD,
-  STATE_HOST_NAME,
-  STATE_DONE,
-  STATE_INVALID
-} split_state;
-static int rtems_ftpfs_split_names (
-  char *s,
-  const char **user,
-  const char **password,
-  const char **hostname,
-  const char **path
-  split_state state = STATE_USER_NAME;
-  size_t len = strlen(s);
-  size_t i = 0;
-  *user = s;
-  for (i = 0; i < len; ++i) {
-    char c = s [i];
-    switch (state) {
-      case STATE_USER_NAME:
-        if (c == ':') {
-          state = STATE_START_PASSWORD;
-          s [i] = '\0';
-        } else if (c == '@') {
-          state = STATE_START_HOST_NAME;
-          s [i] = '\0';
-        } else if (c == '/') {
-          state = STATE_START_HOST_NAME_OR_PATH;
-          s [i] = '\0';
-        break;
-      case STATE_START_PASSWORD:
-        state = STATE_PASSWORD;
-        *password = &s [i];
-        --i;
-        break;
-      case STATE_START_HOST_NAME:
-        state = STATE_HOST_NAME;
-        *hostname = &s [i];
-        --i;
-        break;
-      case STATE_START_HOST_NAME_OR_PATH:
-        if (c == '@') {
-        } else {
-          state = STATE_DONE;
-          *path = &s [i];
-          goto done;
-        break;
-      case STATE_START_PATH:
-        *path = &s [i];
-        goto done;
-      case STATE_PASSWORD:
-        if (c == '@') {
-          s [i] = '\0';
-          s [i] = '\0';
-        break;
-      case STATE_HOST_NAME:
-        if (c == '/') {
-          state = STATE_START_PATH;
-          s [i] = '\0';
-        break;
-      default:
-        state = STATE_INVALID;
-        goto done;
-done:
-  /* This is a special case with no username and password */
-  if (*hostname == NULL) {
-    *hostname = &s [0];
-    *user = "anonymous";
-    *password = *user;
-  /* If we have no password use the user name */
-  if (*password == NULL) {
-  return state == STATE_DONE ? 0 : ENOENT;
-static socklen_t rtems_ftpfs_create_address(
-  struct sockaddr_in *sa,
-  unsigned long address,
-  unsigned short port
-  memset(sa, 0, sizeof(*sa));
-  sa->sin_family = AF_INET;
-  sa->sin_addr.s_addr = address;
-  sa->sin_port = port;
-  sa->sin_len = sizeof(*sa);
-  return sizeof(*sa);
-static int rtems_ftpfs_close_data_connection(
-  bool verbose,
-  bool error
-  int eno = 0;
-  /* Close data connection if necessary */
-  if (e->data_socket >= 0) {
-    int rv = close(e->data_socket);
-    e->data_socket = -1;
-    if (rv != 0) {
-      eno = EIO;
-    /* For write connections we have to obtain the transfer reply  */
-    if (e->write && !error) {
-        rtems_ftpfs_get_reply(e, NULL, NULL, verbose);
-      if (reply != RTEMS_FTPFS_REPLY_2) {
-        eno = EIO;
-  return eno;
-static int rtems_ftpfs_open_ctrl_connection(
-  bool verbose,
-  int rv = 0;
-  int eno = 0;
-  struct in_addr address = { .s_addr = 0 };
-  struct sockaddr_in sa;
-  socklen_t size = 0;
-  /* Create the socket for the control connection */
-  e->ctrl_socket = socket(AF_INET, SOCK_STREAM, 0);
-  if (e->ctrl_socket < 0) {
-    return ENOMEM;
-  /* Set up the server address from the hostname */
-  if (inet_aton(e->hostname, &address) == 0) {
-    /* Try to get the address by name */
-    struct hostent *he = gethostbyname(e->hostname);
-    if (he != NULL) {
-      memcpy(&address, he->h_addr, sizeof(address));
-    } else {
-      return ENOENT;
-  rtems_ftpfs_create_address(&sa, address.s_addr, htons(RTEMS_FTPFS_CTRL_PORT));
-  DEBUG_PRINTF("server = %s\n", inet_ntoa(sa.sin_addr));
-  /* Open control connection */
-  rv = connect(
-    e->ctrl_socket,
-    (struct sockaddr *) &sa,
-    sizeof(sa)
-  if (rv != 0) {
-    return ENOENT;
-  /* Set control connection timeout */
-  eno = rtems_ftpfs_set_connection_timeout(e->ctrl_socket, timeout);
-  if (eno != 0) {
-    return eno;
-  /* Get client address */
-  size = rtems_ftpfs_create_address(&sa, INADDR_ANY, 0);
-  rv = getsockname(
-    e->ctrl_socket,
-    &size
-  if (rv != 0) {
-    return ENOMEM;
-  e->client_address = ntohl(sa.sin_addr.s_addr);
-  DEBUG_PRINTF("client = %s\n", inet_ntoa(sa.sin_addr));
-  /* Now we should get a welcome message from the server */
-  reply = rtems_ftpfs_get_reply(e, NULL, NULL, verbose);
-    return ENOENT;
-  /* Send USER command */
-  reply = rtems_ftpfs_send_command(e, "USER ", e->user, verbose);
-  if (reply == RTEMS_FTPFS_REPLY_3) {
-    /* Send PASS command */
-    reply = rtems_ftpfs_send_command(e, "PASS ", e->password, verbose);
-      return EACCES;
-    /* TODO: Some server may require an account */
-  } else if (reply != RTEMS_FTPFS_REPLY_2) {
-    return EACCES;
-  /* Send TYPE command to set binary mode for all data transfers */
-  reply = rtems_ftpfs_send_command(e, "TYPE I", NULL, verbose);
-    return EIO;
-  return 0;
-static int rtems_ftpfs_open_data_connection_active(
-  const char *file_command,
-  bool verbose,
-  int rv = 0;
-  int eno = 0;
-  int port_socket = -1;
-  char port_command [] = "PORT 000,000,000,000,000,000";
-  uint16_t data_port = 0;
-  /* Create port socket to establish a data data connection */
-  port_socket = socket(AF_INET, SOCK_STREAM, 0);
-  if (port_socket < 0) {
-    eno = ENOMEM;
-    goto cleanup;
-  /* Bind port socket */
-  rtems_ftpfs_create_address(&sa, INADDR_ANY, 0);
-  rv = bind(
-    port_socket,
-    sizeof(sa)
-  if (rv != 0) {
-    eno = EBUSY;
-    goto cleanup;
-  /* Get port number for data socket */
-  rv = getsockname(
-    port_socket,
-    &size
-  if (rv != 0) {
-    eno = ENOMEM;
-    goto cleanup;
-  data_port = ntohs(sa.sin_port);
-  /* Send PORT command to set data connection port for server */
-  snprintf(
-    port_command,
-    sizeof(port_command),
-    "PORT %lu,%lu,%lu,%lu,%lu,%lu",
-    (e->client_address >> 24) & 0xffUL,
-    (e->client_address >> 16) & 0xffUL,
-    (e->client_address >> 8) & 0xffUL,
-    (e->client_address >> 0) & 0xffUL,
-    (data_port >> 8) & 0xffUL,
-    (data_port >> 0) & 0xffUL
-  reply = rtems_ftpfs_send_command(e, port_command, NULL, verbose);
-    eno = ENOTSUP;
-    goto cleanup;
-  /* Listen on port socket for incoming data connections */
-  rv = listen(port_socket, 1);
-  if (rv != 0) {
-    eno = EBUSY;
-    goto cleanup;
-  /* Send RETR or STOR command with filename */
-  reply = rtems_ftpfs_send_command(e, file_command, e->filename, verbose);
-  if (reply != RTEMS_FTPFS_REPLY_1) {
-    eno = EIO;
-    goto cleanup;
-  /* Wait for connect on data connection if necessary */
-  if (rtems_ftpfs_use_timeout(timeout)) {
-    struct timeval to = *timeout;
-    fd_set fds;
-    FD_ZERO(&fds);
-    FD_SET(port_socket, &fds);
-    rv = select(port_socket + 1, &fds, NULL, NULL, &to);
-    if (rv <= 0) {
-      eno = EIO;
-      goto cleanup;
-  /* Accept data connection  */
-  size = sizeof(sa);
-  e->data_socket = accept(
-    port_socket,
-    &size
-  if (e->data_socket < 0) {
-    eno = EIO;
-    goto cleanup;
-cleanup:
-  /* Close port socket if necessary */
-  if (port_socket >= 0) {
-    rv = close(port_socket);
-    if (rv != 0) {
-      eno = EIO;
-  return eno;
-typedef enum {
-  RTEMS_FTPFS_PASV_START = 0,
-  RTEMS_FTPFS_PASV_JUNK,
-  RTEMS_FTPFS_PASV_DATA,
-  RTEMS_FTPFS_PASV_DONE
-} rtems_ftpfs_pasv_state;
-typedef struct {
-  rtems_ftpfs_pasv_state state;
-  size_t index;
-  uint8_t data [6];
-} rtems_ftpfs_pasv_entry;
-static void rtems_ftpfs_pasv_parser(
-  const char* buf,
-  size_t len,
-  void *arg
-  rtems_ftpfs_pasv_entry *pe = arg;
-  size_t i = 0;
-    int c = buf [i];
-    switch (pe->state) {
-      case RTEMS_FTPFS_PASV_START:
-        if (!isdigit(c)) {
-          pe->state = RTEMS_FTPFS_PASV_JUNK;
-          pe->index = 0;
-        break;
-      case RTEMS_FTPFS_PASV_JUNK:
-        if (isdigit(c)) {
-          pe->state = RTEMS_FTPFS_PASV_DATA;
-          pe->data [pe->index] = (uint8_t) (c - '0');
-        break;
-      case RTEMS_FTPFS_PASV_DATA:
-        if (isdigit(c)) {
-            (uint8_t) (pe->data [pe->index] * 10 + c - '0');
-        } else if (c == ',') {
-          ++pe->index;
-          if (pe->index < sizeof(pe->data)) {
-            pe->data [pe->index] = 0;
-          } else {
-            pe->state = RTEMS_FTPFS_PASV_DONE;
-        } else {
-        break;
-      default:
-        return;
-static int rtems_ftpfs_open_data_connection_passive(
-  bool verbose,
-  int rv = 0;
-  uint32_t data_address = 0;
-  rtems_ftpfs_pasv_entry pe;
-  memset(&pe, 0, sizeof(pe));
-  /* Send PASV command */
-  reply = rtems_ftpfs_send_command_with_parser(
-    e,
-    "PASV",
-    NULL,
-    rtems_ftpfs_pasv_parser,
-    &pe,
-    verbose
-    return ENOTSUP;
-  data_address = ((uint32_t)(pe.data [0]) << 24)
-    + ((uint32_t)(pe.data [1]) << 16)
-    + ((uint32_t)(pe.data [2]) << 8)
-    + ((uint32_t)(pe.data [3]));
-  data_port = (uint16_t) ((pe.data [4] << 8) + pe.data [5]);
-  rtems_ftpfs_create_address(&sa, htonl(data_address), htons(data_port));
-  DEBUG_PRINTF(
-    "server data = %s:%u\n",
-    inet_ntoa(sa.sin_addr),
-    (unsigned) ntohs(sa.sin_port)
-  /* Create data socket */
-  e->data_socket = socket(AF_INET, SOCK_STREAM, 0);
-    return ENOMEM;
-  /* Open data connection */
-  rv = connect(
-    e->data_socket,
-    sizeof(sa)
-  if (rv != 0) {
-    return EIO;
-    return EIO;
-  return 0;
-typedef enum {
-  RTEMS_FTPFS_SIZE_START = 0,
-  RTEMS_FTPFS_SIZE_SPACE,
-  RTEMS_FTPFS_SIZE_NUMBER,
-  RTEMS_FTPFS_SIZE_NL
-} rtems_ftpfs_size_state;
-typedef struct {
-  rtems_ftpfs_size_state state;
-  size_t index;
-  off_t size;
-} rtems_ftpfs_size_entry;
-static void rtems_ftpfs_size_parser(
-  const char* buf,
-  size_t len,
-  void *arg
-  rtems_ftpfs_size_entry *se = arg;
-  size_t i = 0;
-  for (i = 0; se->size >= 0 && i < len; ++i, ++se->index) {
-    int c = buf [i];
-    switch (se->state) {
-      case RTEMS_FTPFS_SIZE_START:
-        if (se->index == 2) {
-          se->state = RTEMS_FTPFS_SIZE_SPACE;
-        break;
-      case RTEMS_FTPFS_SIZE_SPACE:
-        if (c == ' ') {
-          se->state = RTEMS_FTPFS_SIZE_NUMBER;
-        } else {
-          se->size = -1;
-        break;
-      case RTEMS_FTPFS_SIZE_NUMBER:
-        if (isdigit(c)) {
-          se->size = 10 * se->size + c - '0';
-        } else if (c == '\r') {
-          se->state = RTEMS_FTPFS_SIZE_NL;
-        } else {
-          se->size = -1;
-        break;
-      case RTEMS_FTPFS_SIZE_NL:
-        if (c != '\n') {
-          se->size = -1;
-        break;
-      default:
-        se->size = -1;
-        break;
-static void rtems_ftpfs_get_file_size(rtems_ftpfs_entry *e, bool verbose)
-  if (e->file_size < 0) {
-    if (e->write) {
-      e->file_size = 0;
-    } else {
-      rtems_ftpfs_size_entry se;
-      memset(&se, 0, sizeof(se));
-        e,
-        "SIZE ",
-        e->filename,
-        rtems_ftpfs_size_parser,
-        &se,
-        verbose
-      if (reply == RTEMS_FTPFS_REPLY_2 && se.size >= 0) {
-        e->file_size = se.size;
-      } else {
-        e->file_size = 0;
-static int rtems_ftpfs_open(
-  rtems_libio_t *iop,
-  const char *path,
-  int oflag,
-  mode_t mode
-  int eno = 0;
-  rtems_ftpfs_entry *e = iop->pathinfo.node_access;
-  rtems_ftpfs_mount_entry *me = iop->pathinfo.mt_entry->fs_info;
-  bool verbose = me->verbose;
-  const struct timeval *timeout = &me->timeout;
-  e->write = (iop->flags & LIBIO_FLAGS_WRITE) != 0;
-  /* Check for either read-only or write-only flags */
-  if (
-    (iop->flags & LIBIO_FLAGS_WRITE) != 0
-      && (iop->flags & LIBIO_FLAGS_READ) != 0
-    eno = ENOTSUP;
-  if (eno == 0) {
-    rtems_ftpfs_get_file_size(e, verbose);
-  if (eno == 0) {
-    const char *file_command = e->write ? "STOR " : "RETR ";
-    /* Open passive data connection */
-    eno = rtems_ftpfs_open_data_connection_passive(
-      e,
-      file_command,
-      verbose,
-      timeout
-    if (eno == ENOTSUP) {
-      /* Open active data connection */
-      eno = rtems_ftpfs_open_data_connection_active(
-        e,
-        file_command,
-        verbose,
-        timeout
-  /* Set data connection timeout */
-  if (eno == 0) {
-    eno = rtems_ftpfs_set_connection_timeout(e->data_socket, timeout);
-  if (eno == 0) {
-    return 0;
-  } else {
-    rtems_ftpfs_close_data_connection(e, verbose, true);
-    rtems_set_errno_and_return_minus_one(eno);
-static ssize_t rtems_ftpfs_read(
-  void *buffer,
-  size_t count
-  const rtems_ftpfs_mount_entry *me = iop->pathinfo.mt_entry->fs_info;
-  char *in = buffer;
-  size_t todo = count;
-  if (e->eof) {
-    return 0;
-  while (todo > 0) {
-    ssize_t rv = recv(e->data_socket, in, todo, 0);
-    if (rv <= 0) {
-      if (rv == 0) {
-        if (reply == RTEMS_FTPFS_REPLY_2) {
-          e->eof = true;
-          break;
-      rtems_set_errno_and_return_minus_one(EIO);
-    in += rv;
-    todo -= (size_t) rv;
-  return (ssize_t) (count - todo);
-static ssize_t rtems_ftpfs_write(
-  const void *buffer,
-  size_t count
-  const char *out = buffer;
-    ssize_t rv = send(e->data_socket, out, todo, 0);
-    if (rv <= 0) {
-      if (rv == 0) {
-        break;
-      } else {
-    out += rv;
-    e->file_size += rv;
-static int rtems_ftpfs_close(rtems_libio_t *iop)
-  int eno = rtems_ftpfs_close_data_connection(e, me->verbose, false);
-  if (eno == 0) {
-    return 0;
-  } else {
-/* Dummy version to let fopen(*,"w") work properly */
-static int rtems_ftpfs_ftruncate(rtems_libio_t *iop, off_t count)
-  return 0;
-static void rtems_ftpfs_eval_path(
-  rtems_filesystem_eval_path_context_t *self
-  int eno = 0;
-  rtems_filesystem_eval_path_eat_delimiter(self);
-  if (rtems_filesystem_eval_path_has_path(self)) {
-    const char *path = rtems_filesystem_eval_path_get_path(self);
-    size_t pathlen = rtems_filesystem_eval_path_get_pathlen(self);
-    rtems_ftpfs_entry *e = calloc(1, sizeof(*e) + pathlen + 1);
-    rtems_filesystem_eval_path_clear_path(self);
-    if (e != NULL) {
-      memcpy(e->buffer, path, pathlen);
-      eno = rtems_ftpfs_split_names(
-          e->buffer,
-          &e->user,
-          &e->password,
-          &e->hostname,
-          &e->filename
-      DEBUG_PRINTF(
-        "user = '%s', password = '%s', filename = '%s'\n",
-        e->user,
-        e->password,
-        e->filename
-      if (eno == 0) {
-        rtems_filesystem_location_info_t *currentloc =
-          rtems_filesystem_eval_path_get_currentloc(self);
-        rtems_ftpfs_mount_entry *me = currentloc->mt_entry->fs_info;
-        rtems_libio_lock();
-        ++me->ino;
-        e->ino = me->ino;
-        rtems_libio_unlock();
-        e->file_size = -1;
-        e->ctrl_socket = -1;
-        eno = rtems_ftpfs_open_ctrl_connection(
-          e,
-          me->verbose,
-          &me->timeout
-        if (eno == 0) {
-          currentloc->node_access = e;
-          currentloc->handlers = &rtems_ftpfs_handlers;
-      if (eno != 0) {
-        free(e);
-    } else {
-      eno = ENOMEM;
-  if (eno != 0) {
-    rtems_filesystem_eval_path_error(self, eno);
-static void rtems_ftpfs_free_node(const rtems_filesystem_location_info_t *loc)
-  rtems_ftpfs_entry *e = loc->node_access;
-  /* The root node handler has no entry */
-  if (e != NULL) {
-    const rtems_ftpfs_mount_entry *me = loc->mt_entry->fs_info;
-    /* Close control connection if necessary */
-    if (e->ctrl_socket >= 0) {
-      rtems_ftpfs_send_command(e, "QUIT", NULL, me->verbose);
-      close(e->ctrl_socket);
-    free(e);
-int rtems_ftpfs_initialize(
-  rtems_filesystem_mount_table_entry_t *e,
-  const void                           *d
-  rtems_ftpfs_mount_entry *me = calloc(1, sizeof(*me));
-  /* Mount entry for FTP file system instance */
-  e->fs_info = me;
-  if (e->fs_info == NULL) {
-    rtems_set_errno_and_return_minus_one(ENOMEM);
-  me->verbose = false;
-  me->timeout.tv_sec = 0;
-  me->timeout.tv_usec = 0;
-  /* Set handler and oparations table */
-  e->mt_fs_root->location.handlers = &rtems_ftpfs_root_handlers;
-  e->ops = &rtems_ftpfs_ops;
-  /* We maintain no real file system nodes, so there is no real root */
-  e->mt_fs_root->location.node_access = NULL;
-  return 0;
-static void rtems_ftpfs_unmount_me(
-  free(e->fs_info);
-static int rtems_ftpfs_ioctl(
-  uint32_t command,
-  void *arg
-  bool *verbose = arg;
-  struct timeval *timeout = arg;
-  if (arg == NULL) {
-    rtems_set_errno_and_return_minus_one(EINVAL);
-  switch (command) {
-    case RTEMS_FTPFS_IOCTL_GET_VERBOSE:
-      *verbose = me->verbose;
-      break;
-    case RTEMS_FTPFS_IOCTL_SET_VERBOSE:
-      me->verbose = *verbose;
-      break;
-    case RTEMS_FTPFS_IOCTL_GET_TIMEOUT:
-      *timeout = me->timeout;
-      break;
-    case RTEMS_FTPFS_IOCTL_SET_TIMEOUT:
-      me->timeout = *timeout;
-      break;
-    default:
-  return 0;
- * The stat() support is intended only for the cp shell command.  Each request
- * will return that we have a regular file with read, write and execute
- * permissions for every one.  The node index uses a global counter to support
- * a remote to remote copy.  This is not a very sophisticated method.
-static int rtems_ftpfs_fstat(
-  const rtems_filesystem_location_info_t *loc,
-  struct stat *st
-  int eno = 0;
-  /* FIXME */
-  st->st_ino = e->ino;
-  st->st_dev = rtems_filesystem_make_dev_t(0xcc494cd6U, 0x1d970b4dU);
-  st->st_mode = S_IFREG | S_IRWXU | S_IRWXG | S_IRWXO;
-  if (e->do_size_command) {
-    rtems_ftpfs_get_file_size(e, me->verbose);
-    st->st_size = e->file_size;
-  } else {
-    e->do_size_command = true;
-  if (eno == 0) {
-    return 0;
-  } else {
-static void rtems_ftpfs_lock_or_unlock(
-  const rtems_filesystem_mount_table_entry_t *mt_entry
-  /* Do nothing */
-static const rtems_filesystem_operations_table rtems_ftpfs_ops = {
-  .lock_h = rtems_ftpfs_lock_or_unlock,
-  .unlock_h = rtems_ftpfs_lock_or_unlock,
-  .eval_path_h = rtems_ftpfs_eval_path,
-  .link_h = rtems_filesystem_default_link,
-  .are_nodes_equal_h = rtems_filesystem_default_are_nodes_equal,
-  .mknod_h = rtems_filesystem_default_mknod,
-  .rmnod_h = rtems_filesystem_default_rmnod,
-  .fchmod_h = rtems_filesystem_default_fchmod,
-  .chown_h = rtems_filesystem_default_chown,
-  .clonenod_h = rtems_filesystem_default_clonenode,
-  .freenod_h = rtems_ftpfs_free_node,
-  .mount_h = rtems_filesystem_default_mount,
-  .unmount_h = rtems_filesystem_default_unmount,
-  .fsunmount_me_h = rtems_ftpfs_unmount_me,
-  .utime_h = rtems_filesystem_default_utime,
-  .symlink_h = rtems_filesystem_default_symlink,
-  .readlink_h = rtems_filesystem_default_readlink,
-  .rename_h = rtems_filesystem_default_rename,
-  .statvfs_h = rtems_filesystem_default_statvfs
-static const rtems_filesystem_file_handlers_r rtems_ftpfs_handlers = {
-  .open_h = rtems_ftpfs_open,
-  .close_h = rtems_ftpfs_close,
-  .read_h = rtems_ftpfs_read,
-  .write_h = rtems_ftpfs_write,
-  .ioctl_h = rtems_filesystem_default_ioctl,
-  .lseek_h = rtems_filesystem_default_lseek,
-  .fstat_h = rtems_ftpfs_fstat,
-  .ftruncate_h = rtems_ftpfs_ftruncate,
-  .fsync_h = rtems_filesystem_default_fsync_or_fdatasync,
-  .fdatasync_h = rtems_filesystem_default_fsync_or_fdatasync,
-  .fcntl_h = rtems_filesystem_default_fcntl,
-  .kqfilter_h = rtems_filesystem_default_kqfilter,
-  .poll_h = rtems_filesystem_default_poll,
-  .readv_h = rtems_filesystem_default_readv,
-  .writev_h = rtems_filesystem_default_writev
-static const rtems_filesystem_file_handlers_r rtems_ftpfs_root_handlers = {
-  .open_h = rtems_filesystem_default_open,
-  .close_h = rtems_filesystem_default_close,
-  .read_h = rtems_filesystem_default_read,
-  .write_h = rtems_filesystem_default_write,
-  .ioctl_h = rtems_ftpfs_ioctl,
-  .fstat_h = rtems_filesystem_default_fstat,
-  .ftruncate_h = rtems_filesystem_default_ftruncate,
diff --git a/rtemsbsd/include/rtems/ftpd.h b/rtemsbsd/include/rtems/ftpd.h
deleted file mode 100644
index b57880d19..000000000
--- a/rtemsbsd/include/rtems/ftpd.h
+++ /dev/null
@@ -1,80 +0,0 @@
- *  FTP Server Information
-#ifndef _RTEMS_FTPD_H
-#define _RTEMS_FTPD_H
-#include <rtems.h>
-#ifdef __cplusplus
-extern "C" {
-#endif
-#define FTPD_CONTROL_PORT   21
-/* Various buffer sizes */
-enum {
-  FTPD_BUFSIZE  = 256,       /* Size for temporary buffers */
-  FTPD_DATASIZE = 4 * 1024,      /* Size for file transfer buffers */
-  FTPD_STACKSIZE = RTEMS_MINIMUM_STACK_SIZE + FTPD_DATASIZE /* Tasks stack size */
-/* FTPD access control flags */
-enum
-  FTPD_NO_WRITE = 0x1,
-  FTPD_NO_READ  = 0x2,
-  FTPD_NO_RW    = FTPD_NO_WRITE | FTPD_NO_READ
-typedef int (*rtems_ftpd_hookfunction)(char *, size_t);
-#include <rtems/shell.h>
-struct rtems_ftpd_hook
-   char                    *filename;
-   rtems_ftpd_hookfunction hook_function;
-struct rtems_ftpd_configuration
-   rtems_task_priority     priority;           /* FTPD task priority  */
-   unsigned long           max_hook_filesize;  /* Maximum buffersize  */
-                                               /*    for hooks        */
-   int                     port;               /* Well-known port     */
-   struct rtems_ftpd_hook  *hooks;             /* List of hooks       */
-   char const              *root;              /* Root for FTPD or 0 for / */
-   int                     tasks_count;        /* Max. connections    */
-   int                     idle;               /* Idle timeout in seoconds
-                                                  or 0 for no (inf) timeout */
-   int                     access;             /* 0 - r/w, 1 - read-only,
-                                                  2 - write-only,
-                                                  3 - browse-only */
-   rtems_shell_login_check_t login;            /* Login check or 0 to ignore
-                                                  user/passwd. */
-   bool                      verbose;          /* Say hello! */
- * Reply codes.
-#define PRELIM          1       /* positive preliminary */
-#define COMPLETE        2       /* positive completion */
-#define CONTINUE        3       /* positive intermediate */
-#define TRANSIENT       4       /* transient negative completion */
-#define ERROR           5       /* permanent negative completion */
- * Initialise with the global table.
- * Note, use rc.conf, this function will be removed at some point.
-int rtems_initialize_ftpd(void);
-#ifdef __cplusplus
-#endif
-#endif  /* _RTEMS_FTPD_H */
diff --git a/rtemsbsd/include/rtems/ftpfs.h b/rtemsbsd/include/rtems/ftpfs.h
index c1f615b85..000000000
--- a/rtemsbsd/include/rtems/ftpfs.h
+++ /dev/null
@@ -1,159 +0,0 @@
- * @file
- * @brief File Transfer Protocol file system (FTP client).
- * D-82178 Puchheim
- * Germany
- * Thomas Doerfler
- * Herbststr. 8
- * Modified by Sebastian Huber <sebastian.huber at embedded-brains.de>.
- * Norum.
-#ifndef _RTEMS_FTPFS_H
-#define _RTEMS_FTPFS_H
-#include <sys/time.h>
-#include <sys/ioctl.h>
-#include <rtems/libio.h>
-#ifdef __cplusplus
-extern "C" {
-#endif
- * @defgroup rtems_ftpfs File Transfer Protocol File System
- * @brief The FTP file system (FTP client) can be used to transfer files from
- * or to remote hosts.
- * You can mount the FTP file system with a call to mount() or
- * mount_and_make_target_path() with the @ref RTEMS_FILESYSTEM_TYPE_FTPFS file
- * system type.
- * You have to add @ref CONFIGURE_FILESYSTEM_FTPFS to your application
- * configuration.
- * You can open files either read-only or write-only.  A seek is not allowed.
- * A close terminates the control and data connections.
- * To open a file @c file.txt in the directory @c dir (relative to home
- * directory of the server) on a server named @c host using the user name
- * @c user and the password @c pw you must specify the following path:
- * <tt>/FTP/user:pw@@host/dir/file.txt</tt>.
- * If the server is the default server specified in BOOTP, it can be ommitted:
- * <tt>/FTP/user:pw/dir/file.txt</tt>.
- * The user name will be used for the password if it is ommitted:
- * <tt>/FTP/user@@host/dir/file.txt</tt>.
- * For the data transfer passive (= default) and active (= fallback) mode are
- * supported.
- * @brief Well-known port number for FTP control connection.
-#define RTEMS_FTPFS_CTRL_PORT 21
- * @brief Default mount point for FTP file system.
-#define RTEMS_FTPFS_MOUNT_POINT_DEFAULT "/FTP"
- * @brief FTP file system IO control requests.
-typedef enum {
-  RTEMS_FTPFS_IOCTL_GET_VERBOSE = _IOR( 'd', 1, bool *),
-  RTEMS_FTPFS_IOCTL_SET_VERBOSE = _IOW( 'd', 1, bool *),
-  RTEMS_FTPFS_IOCTL_GET_TIMEOUT = _IOR( 'd', 2, struct timeval *),
-  RTEMS_FTPFS_IOCTL_SET_TIMEOUT = _IOW( 'd', 2, struct timeval *)
-} rtems_ftpfs_ioctl_numbers;
- * @brief Returns in @a verbose if the verbose mode is enabled or disabled for
- * the file system at @a mount_point.
- * If @a mount_point is @c NULL the default mount point
- * @ref RTEMS_FTPFS_MOUNT_POINT_DEFAULT will be used.
-rtems_status_code rtems_ftpfs_get_verbose( const char *mount_point, bool *verbose);
- * @brief Enables or disables the verbose mode if @a verbose is @c true or
- * @c false respectively for the file system at @a mount_point.
- * In the enabled verbose mode the commands and replies of the FTP control
- * connections will be printed to standard error.
-rtems_status_code rtems_ftpfs_set_verbose( const char *mount_point, bool verbose);
- * @brief Returns the current timeout value in @a timeout for the file system
- * at @a mount_point.
- * @brief Sets the timeout value to @a timeout for the file system at
- * @a mount_point.
- * The timeout value will be used during connection establishment of active
- * data connections.  It will be also used for send and receive operations on
- * data and control connections.
- * @brief Do not call directly, use mount().
-  rtems_filesystem_mount_table_entry_t *mt_entry,
-  const void *data
-#ifdef __cplusplus
-#endif
-#endif
diff --git a/rtemsbsd/include/rtems/telnetd.h b/rtemsbsd/include/rtems/telnetd.h
index 3919d80f7..000000000
--- a/rtemsbsd/include/rtems/telnetd.h
+++ /dev/null
@@ -1,115 +0,0 @@
- *  Original Author: Fernando RUIZ CASAS (fernando.ruiz at ctv.es)
- *  May 2001
- *  Reworked by Till Straumann and .h overhauled by Joel Sherrill.
- * Copyright (c) 2009 embedded brains GmbH and others.
- * Germany
-#ifndef _RTEMS_TELNETD_H
-#define _RTEMS_TELNETD_H
-#include <rtems.h>
-#ifdef __cplusplus
-extern "C" {
-#endif
-bool rtems_telnetd_login_check(
-  const char *user,
-  const char *passphrase
- * @brief Telnet command type.
-typedef void (*rtems_telnetd_command)(
-  char * /* device name */,
-  void * /* arg */
- * @brief Telnet configuration structure.
-typedef struct {
-   * @brief Function invoked for each Telnet connection.
-   * The first parameter contains the device name.  The second parameter
-   * contains the argument pointer of this configuration table.
-  rtems_telnetd_command command;
-   * @brief Argument for command function.
-  void *arg;
-   * @brief Task priority.
-   * If this parameter is equal to zero, then the priority of network task is
-   * used or 100 if this priority is less than two.
-   * @brief Task stack size.
-  size_t stack_size;
-   * @brief Login check function.
-   * Method used for login checks.  Use @c NULL to disable a login check.
-  rtems_shell_login_check_t login_check;
-   * @brief Keep standard IO of the caller.
-   * Telnet takes over the standard input, output and error associated with
-   * task, if this parameter is set to @c true.  In this case, it will @b not
-   * listen on any sockets.  When this parameter is @c false, Telnet will
-   * create other tasks for the shell which listen on sockets.
-  bool keep_stdio;
-} rtems_telnetd_config_table;
- * @brief Start the Telnet subsystem with the provided configuration.
-rtems_status_code rtems_telnetd_start(const rtems_telnetd_config_table* config);
- * @brief Telnet configuration.
- * The application must provide this configuration table.  It is used by
- * rtems_telnetd_initialize() to configure the Telnet subsystem.  Do not modify
- * the entries after the intialization since it is used internally.
-extern rtems_telnetd_config_table rtems_telnetd_config;
- * @brief Initializes the Telnet subsystem.
- * Uses the application provided @ref rtems_telnetd_config configuration table.
-rtems_status_code rtems_telnetd_initialize(void);
-#ifdef __cplusplus
-#endif
-#endif
diff --git a/rtemsbsd/telnetd/check_passwd.c b/rtemsbsd/telnetd/check_passwd.c
index 9e3f2c983..000000000
--- a/rtemsbsd/telnetd/check_passwd.c
+++ /dev/null
@@ -1,107 +0,0 @@
- * Authorship
- * This software was created by
- *     Till Straumann <strauman at slac.stanford.edu>, 2003-2007
- * 	   Stanford Linear Accelerator Center, Stanford University.
- * Acknowledgement of sponsorship
- * This software was produced by
- *     the Stanford Linear Accelerator Center, Stanford University,
- * 	   under Contract DE-AC03-76SFO0515 with the Department of Energy.
- * Government disclaimer of liability
- * Neither the United States nor the United States Department of Energy,
- * nor any of their employees, makes any warranty, express or implied, or
- * assumes any legal liability or responsibility for the accuracy,
- * completeness, or usefulness of any data, apparatus, product, or process
- * disclosed, or represents that its use would not infringe privately owned
- * rights.
- * Stanford disclaimer of liability
- * Stanford University makes no representations or warranties, express or
- * implied, nor assumes any liability for the use of this software.
- * Stanford disclaimer of copyright
- * Stanford University, owner of the copyright, hereby disclaims its
- * copyright and all other rights in this software.  Hence, anyone may
- * freely use it for any purpose without restriction.
- * Maintenance of notices
- * In the interest of clarity regarding the origin and status of this
- * SLAC software, this and all the preceding Stanford University notices
- * are to remain affixed to any copy or derivative of this software made
- * or distributed by the recipient and are to be affixed to any copy of
- * software made or distributed by the recipient that contains a copy or
- * derivative of this software.
- * ------------------ SLAC Software Notices, Set 4 OTT.002a, 2004 FEB 03
- * Germany
-#include "config.h"
-#endif
-#include <termios.h>
-#include <errno.h>
-#include <stdio.h>
-#include <unistd.h>
-#include <stdlib.h>
-#include <string.h>
-#include <syslog.h>
-#include <rtems/telnetd.h>
-#include "passwd.h"
-char *__des_crypt_r( const char *, const char *, char *, int);
- * @brief Standard Telnet login check that uses DES to encrypt the passphrase.
- * Takes a @a passphrase, encrypts it and compares it to the encrypted
- * passphrase in the @c TELNETD_PASSWD environment variable.  No password is
- * required if @c TELNETD_PASSWD is unset.  The argument @a user is ignored.
-  const char *user,
-  char *pw = getenv( "TELNETD_PASSWD");
-  char cryptbuf [21];
-  char salt [3];
-  if (pw == NULL || strlen( pw) == 0) {
-    #ifdef TELNETD_DEFAULT_PASSWD
-      pw = TELNETD_DEFAULT_PASSWD;
-    #else
-      return true;
-    #endif
-  strncpy( salt, pw, 2);
-  salt [2] = '\0';
-  return strcmp(
-    __des_crypt_r( passphrase, salt, cryptbuf, sizeof( cryptbuf)),
-    pw
-  ) == 0;
diff --git a/rtemsbsd/telnetd/des.c b/rtemsbsd/telnetd/des.c
index 542e89681..000000000
--- a/rtemsbsd/telnetd/des.c
+++ /dev/null
@@ -1,879 +0,0 @@
- * FreeSec: libcrypt for NetBSD
- * Copyright (c) 1994 David Burren
- * All rights reserved.
- * Ported to RTEMS and made reentrant by Till Straumann, 9/2003
- * Adapted for FreeBSD-2.0 by Geoffrey M. Rehmet
- *	this file should now *only* export crypt(), in order to make
- *	binaries of libcrypt exportable from the USA
- * Adapted for FreeBSD-4.0 by Mark R V Murray
- *	this file should now *only* export crypt_des(), in order to make
- *	a module that can be optionally included in libcrypt.
- * Redistribution and use in source and binary forms, with or without
- * modification, are permitted provided that the following conditions
- * are met:
- * 1. Redistributions of source code must retain the above copyright
- *    notice, this list of conditions and the following disclaimer.
- * 2. Redistributions in binary form must reproduce the above copyright
- *    notice, this list of conditions and the following disclaimer in the
- *    documentation and/or other materials provided with the distribution.
- * 3. Neither the name of the author nor the names of other contributors
- *    may be used to endorse or promote products derived from this software
- *    without specific prior written permission.
- * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
- * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
- * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
- * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
- * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
- * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
- * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
- * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
- * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
- * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
- * SUCH DAMAGE.
- * This is an original implementation of the DES and the crypt(3) interfaces
- * by David Burren <davidb at werj.com.au>.
- * An excellent reference on the underlying algorithm (and related
- * algorithms) is:
- *	B. Schneier, Applied Cryptography: protocols, algorithms,
- *	and source code in C, John Wiley & Sons, 1994.
- * Note that in that book's description of DES the lookups for the initial,
- * pbox, and final permutations are inverted (this has been brought to the
- * attention of the author).  A list of errata for this book has been
- * posted to the sci.crypt newsgroup by the author and is available for FTP.
- * ARCHITECTURE ASSUMPTIONS:
- *	It is assumed that the 8-byte arrays passed by reference can be
- *	addressed as arrays of u_int32_t's (ie. the CPU is not picky about
- *	alignment).
-#endif
-#define __FORCE_GLIBC
-#include <sys/cdefs.h>
-#include <sys/types.h>
-#include <sys/param.h>
-#include <netinet/in.h>
-#ifndef __rtems__
-#include <pwd.h>
-#include <crypt.h>
-#endif
-#define REENTRANT
-/* Re-entrantify me -- all this junk needs to be in
- * struct crypt_data to make this really reentrant... */
-/* TS; not really - only the stuff in Des_Context */
-static struct fixed1 {
-u_char	inv_key_perm[64];
-u_char	inv_comp_perm[56];
-u_char	u_sbox[8][64];
-u_char	un_pbox[32];
-} des1_f;
-static struct fixed2 {
-u_int32_t ip_maskl[8][256], ip_maskr[8][256];
-} des2_f;
-static struct fixed3 {
-u_int32_t fp_maskl[8][256], fp_maskr[8][256];
-} des3_f;
-static struct fixed4 {
-u_int32_t key_perm_maskl[8][128], key_perm_maskr[8][128];
-u_int32_t comp_maskl[8][128], comp_maskr[8][128];
-} des4_f;
-#define	inv_key_perm des1_f.inv_key_perm
-#define	inv_comp_perm des1_f.inv_comp_perm
-#define	u_sbox des1_f.u_sbox
-#define	un_pbox des1_f.un_pbox
-#define ip_maskl des2_f.ip_maskl
-#define ip_maskr des2_f.ip_maskr
-#define fp_maskl des3_f.fp_maskl
-#define fp_maskr des3_f.fp_maskr
-#define key_perm_maskl des4_f.key_perm_maskl
-#define key_perm_maskr des4_f.key_perm_maskr
-#define comp_maskl des4_f.comp_maskl
-#define comp_maskr des4_f.comp_maskr
-/* These need to be maintained per-process */
-struct Des_Context {
-u_int32_t en_keysl[16], en_keysr[16];
-u_int32_t de_keysl[16], de_keysr[16];
-u_int32_t saltbits;
-u_int32_t old_salt;
-u_int32_t old_rawkey0, old_rawkey1;
-#ifndef REENTRANT
-static struct Des_Context single;
-#endif
-#define en_keysl des_ctx->en_keysl
-#define en_keysr des_ctx->en_keysr
-#define de_keysl des_ctx->de_keysl
-#define de_keysr des_ctx->de_keysr
-#define saltbits des_ctx->saltbits
-#define old_salt des_ctx->old_salt
-#define old_rawkey0 des_ctx->old_rawkey0
-#define old_rawkey1 des_ctx->old_rawkey1
-/* Static stuff that stays resident and doesn't change after
- * being initialized, and therefore doesn't need to be made
- * reentrant. */
-static u_char	init_perm[64], final_perm[64];
-static u_char	m_sbox[4][4096];
-static u_int32_t psbox[4][256];
-/* A pile of data */
-static const u_char	ascii64[] = "./0123456789ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz";
-static const u_char	IP[64] = {
-  58, 50, 42, 34, 26, 18, 10,  2, 60, 52, 44, 36, 28, 20, 12,  4,
-  62, 54, 46, 38, 30, 22, 14,  6, 64, 56, 48, 40, 32, 24, 16,  8,
-  57, 49, 41, 33, 25, 17,  9,  1, 59, 51, 43, 35, 27, 19, 11,  3,
-  61, 53, 45, 37, 29, 21, 13,  5, 63, 55, 47, 39, 31, 23, 15,  7
-static const u_char	key_perm[56] = {
-  57, 49, 41, 33, 25, 17,  9,  1, 58, 50, 42, 34, 26, 18,
-  10,  2, 59, 51, 43, 35, 27, 19, 11,  3, 60, 52, 44, 36,
-  63, 55, 47, 39, 31, 23, 15,  7, 62, 54, 46, 38, 30, 22,
-  14,  6, 61, 53, 45, 37, 29, 21, 13,  5, 28, 20, 12,  4
-static const u_char	key_shifts[16] = {
-  1, 1, 2, 2, 2, 2, 2, 2, 1, 2, 2, 2, 2, 2, 2, 1
-static const u_char	comp_perm[48] = {
-  14, 17, 11, 24,  1,  5,  3, 28, 15,  6, 21, 10,
-  23, 19, 12,  4, 26,  8, 16,  7, 27, 20, 13,  2,
-  41, 52, 31, 37, 47, 55, 30, 40, 51, 45, 33, 48,
-  44, 49, 39, 56, 34, 53, 46, 42, 50, 36, 29, 32
- *	No E box is used, as it's replaced by some ANDs, shifts, and ORs.
-static const u_char	sbox[8][64] = {
-    14,  4, 13,  1,  2, 15, 11,  8,  3, 10,  6, 12,  5,  9,  0,  7,
-     0, 15,  7,  4, 14,  2, 13,  1, 10,  6, 12, 11,  9,  5,  3,  8,
-     4,  1, 14,  8, 13,  6,  2, 11, 15, 12,  9,  7,  3, 10,  5,  0,
-    15, 12,  8,  2,  4,  9,  1,  7,  5, 11,  3, 14, 10,  0,  6, 13
-    15,  1,  8, 14,  6, 11,  3,  4,  9,  7,  2, 13, 12,  0,  5, 10,
-     3, 13,  4,  7, 15,  2,  8, 14, 12,  0,  1, 10,  6,  9, 11,  5,
-     0, 14,  7, 11, 10,  4, 13,  1,  5,  8, 12,  6,  9,  3,  2, 15,
-    13,  8, 10,  1,  3, 15,  4,  2, 11,  6,  7, 12,  0,  5, 14,  9
-    10,  0,  9, 14,  6,  3, 15,  5,  1, 13, 12,  7, 11,  4,  2,  8,
-    13,  7,  0,  9,  3,  4,  6, 10,  2,  8,  5, 14, 12, 11, 15,  1,
-    13,  6,  4,  9,  8, 15,  3,  0, 11,  1,  2, 12,  5, 10, 14,  7,
-     1, 10, 13,  0,  6,  9,  8,  7,  4, 15, 14,  3, 11,  5,  2, 12
-     7, 13, 14,  3,  0,  6,  9, 10,  1,  2,  8,  5, 11, 12,  4, 15,
-    13,  8, 11,  5,  6, 15,  0,  3,  4,  7,  2, 12,  1, 10, 14,  9,
-    10,  6,  9,  0, 12, 11,  7, 13, 15,  1,  3, 14,  5,  2,  8,  4,
-     3, 15,  0,  6, 10,  1, 13,  8,  9,  4,  5, 11, 12,  7,  2, 14
-     2, 12,  4,  1,  7, 10, 11,  6,  8,  5,  3, 15, 13,  0, 14,  9,
-    14, 11,  2, 12,  4,  7, 13,  1,  5,  0, 15, 10,  3,  9,  8,  6,
-     4,  2,  1, 11, 10, 13,  7,  8, 15,  9, 12,  5,  6,  3,  0, 14,
-    11,  8, 12,  7,  1, 14,  2, 13,  6, 15,  0,  9, 10,  4,  5,  3
-    12,  1, 10, 15,  9,  2,  6,  8,  0, 13,  3,  4, 14,  7,  5, 11,
-    10, 15,  4,  2,  7, 12,  9,  5,  6,  1, 13, 14,  0, 11,  3,  8,
-     9, 14, 15,  5,  2,  8, 12,  3,  7,  0,  4, 10,  1, 13, 11,  6,
-     4,  3,  2, 12,  9,  5, 15, 10, 11, 14,  1,  7,  6,  0,  8, 13
-     4, 11,  2, 14, 15,  0,  8, 13,  3, 12,  9,  7,  5, 10,  6,  1,
-    13,  0, 11,  7,  4,  9,  1, 10, 14,  3,  5, 12,  2, 15,  8,  6,
-     1,  4, 11, 13, 12,  3,  7, 14, 10, 15,  6,  8,  0,  5,  9,  2,
-     6, 11, 13,  8,  1,  4, 10,  7,  9,  5,  0, 15, 14,  2,  3, 12
-    13,  2,  8,  4,  6, 15, 11,  1, 10,  9,  3, 14,  5,  0, 12,  7,
-     1, 15, 13,  8, 10,  3,  7,  4, 12,  5,  6, 11,  0, 14,  9,  2,
-     7, 11,  4,  1,  9, 12, 14,  2,  0,  6, 10, 13, 15,  3,  5,  8,
-     2,  1, 14,  7,  4, 10,  8, 13, 15, 12,  9,  0,  3,  5,  6, 11
-static const u_char	pbox[32] = {
-  16,  7, 20, 21, 29, 12, 28, 17,  1, 15, 23, 26,  5, 18, 31, 10,
-   2,  8, 24, 14, 32, 27,  3,  9, 19, 13, 30,  6, 22, 11,  4, 25
-static const u_int32_t bits32[32] =
-  0x80000000, 0x40000000, 0x20000000, 0x10000000,
-  0x08000000, 0x04000000, 0x02000000, 0x01000000,
-  0x00800000, 0x00400000, 0x00200000, 0x00100000,
-  0x00080000, 0x00040000, 0x00020000, 0x00010000,
-  0x00008000, 0x00004000, 0x00002000, 0x00001000,
-  0x00000800, 0x00000400, 0x00000200, 0x00000100,
-  0x00000080, 0x00000040, 0x00000020, 0x00000010,
-  0x00000008, 0x00000004, 0x00000002, 0x00000001
-static const u_char	bits8[8] = { 0x80, 0x40, 0x20, 0x10, 0x08, 0x04, 0x02, 0x01 };
-static const u_int32_t *bits28, *bits24;
-static int
-ascii_to_bin(char ch)
-  if (ch > 'z')
-    return(0);
-  if (ch >= 'a')
-    return(ch - 'a' + 38);
-  if (ch > 'Z')
-    return(0);
-  if (ch >= 'A')
-    return(ch - 'A' + 12);
-  if (ch > '9')
-    return(0);
-  if (ch >= '.')
-    return(ch - '.');
-  return(0);
-struct Des_Context *
-des_ctx_init(void)
-struct Des_Context *des_ctx;
-#ifdef REENTRANT
-  des_ctx = malloc(sizeof(*des_ctx));
-#else
-  des_ctx = &single;
-#endif
-  old_rawkey0 = old_rawkey1 = 0L;
-  saltbits = 0L;
-  old_salt = 0L;
-  return des_ctx;
-static void
-des_init(void)
-  int	i, j, b, k, inbit, obit;
-  u_int32_t	*p, *il, *ir, *fl, *fr;
-  static int des_initialised = 0;
-  if (des_initialised==1)
-      return;
-#ifndef REENTRANT
-  des_ctx_init();
-#endif
-  bits24 = (bits28 = bits32 + 4) + 4;
-   * Invert the S-boxes, reordering the input bits.
-  for (i = 0; i < 8; i++)
-    for (j = 0; j < 64; j++) {
-      b = (j & 0x20) | ((j & 1) << 4) | ((j >> 1) & 0xf);
-      u_sbox[i][j] = sbox[i][b];
-   * Convert the inverted S-boxes into 4 arrays of 8 bits.
-   * Each will handle 12 bits of the S-box input.
-  for (b = 0; b < 4; b++)
-    for (i = 0; i < 64; i++)
-        m_sbox[b][(i << 6) | j] =
-          (u_char)((u_sbox[(b << 1)][i] << 4) |
-          u_sbox[(b << 1) + 1][j]);
-   * Set up the initial & final permutations into a useful form, and
-   * initialise the inverted key permutation.
-  for (i = 0; i < 64; i++) {
-    init_perm[final_perm[i] = IP[i] - 1] = (u_char)i;
-    inv_key_perm[i] = 255;
-   * Invert the key permutation and initialise the inverted key
-   * compression permutation.
-  for (i = 0; i < 56; i++) {
-    inv_key_perm[key_perm[i] - 1] = (u_char)i;
-    inv_comp_perm[i] = 255;
-   * Invert the key compression permutation.
-  for (i = 0; i < 48; i++) {
-    inv_comp_perm[comp_perm[i] - 1] = (u_char)i;
-   * Set up the OR-mask arrays for the initial and final permutations,
-   * and for the key initial and compression permutations.
-  for (k = 0; k < 8; k++) {
-    for (i = 0; i < 256; i++) {
-      *(il = &ip_maskl[k][i]) = 0L;
-      *(ir = &ip_maskr[k][i]) = 0L;
-      *(fl = &fp_maskl[k][i]) = 0L;
-      *(fr = &fp_maskr[k][i]) = 0L;
-      for (j = 0; j < 8; j++) {
-        inbit = 8 * k + j;
-        if (i & bits8[j]) {
-          if ((obit = init_perm[inbit]) < 32)
-            *il |= bits32[obit];
-          else
-            *ir |= bits32[obit-32];
-          if ((obit = final_perm[inbit]) < 32)
-            *fl |= bits32[obit];
-          else
-            *fr |= bits32[obit - 32];
-    for (i = 0; i < 128; i++) {
-      *(il = &key_perm_maskl[k][i]) = 0L;
-      *(ir = &key_perm_maskr[k][i]) = 0L;
-      for (j = 0; j < 7; j++) {
-        if (i & bits8[j + 1]) {
-          if ((obit = inv_key_perm[inbit]) == 255)
-            continue;
-          if (obit < 28)
-            *il |= bits28[obit];
-          else
-            *ir |= bits28[obit - 28];
-      *(il = &comp_maskl[k][i]) = 0L;
-      *(ir = &comp_maskr[k][i]) = 0L;
-        inbit = 7 * k + j;
-          if ((obit=inv_comp_perm[inbit]) == 255)
-            continue;
-          if (obit < 24)
-            *il |= bits24[obit];
-          else
-            *ir |= bits24[obit - 24];
-   * Invert the P-box permutation, and convert into OR-masks for
-   * handling the output of the S-box arrays setup above.
-  for (i = 0; i < 32; i++)
-    un_pbox[pbox[i] - 1] = (u_char)i;
-      *(p = &psbox[b][i]) = 0L;
-        if (i & bits8[j])
-          *p |= bits32[un_pbox[8 * b + j]];
-  des_initialised = 1;
-static void
-setup_salt(long salt, struct Des_Context *des_ctx)
-  u_int32_t	obit, saltbit;
-  int	i;
-  if (salt == old_salt)
-    return;
-  old_salt = salt;
-  saltbits = 0L;
-  saltbit = 1;
-  obit = 0x800000;
-  for (i = 0; i < 24; i++) {
-    if (salt & saltbit)
-      saltbits |= obit;
-    saltbit <<= 1;
-    obit >>= 1;
-static int
-des_setkey(const char *key, struct Des_Context *des_ctx)
-  u_int32_t	k0, k1, rawkey0, rawkey1;
-  int		shifts, round;
-  des_init();
-  rawkey0 = ntohl(*(const u_int32_t *) key);
-  rawkey1 = ntohl(*(const u_int32_t *) (key + 4));
-  if ((rawkey0 | rawkey1)
-      && rawkey0 == old_rawkey0
-      && rawkey1 == old_rawkey1) {
-     * Already setup for this key.
-     * This optimisation fails on a zero key (which is weak and
-     * has bad parity anyway) in order to simplify the starting
-     * conditions.
-    return(0);
-  old_rawkey0 = rawkey0;
-  old_rawkey1 = rawkey1;
-   *	Do key permutation and split into two 28-bit subkeys.
-  k0 = key_perm_maskl[0][rawkey0 >> 25]
-     | key_perm_maskl[1][(rawkey0 >> 17) & 0x7f]
-     | key_perm_maskl[2][(rawkey0 >> 9) & 0x7f]
-     | key_perm_maskl[3][(rawkey0 >> 1) & 0x7f]
-     | key_perm_maskl[4][rawkey1 >> 25]
-     | key_perm_maskl[5][(rawkey1 >> 17) & 0x7f]
-     | key_perm_maskl[6][(rawkey1 >> 9) & 0x7f]
-     | key_perm_maskl[7][(rawkey1 >> 1) & 0x7f];
-  k1 = key_perm_maskr[0][rawkey0 >> 25]
-     | key_perm_maskr[1][(rawkey0 >> 17) & 0x7f]
-     | key_perm_maskr[2][(rawkey0 >> 9) & 0x7f]
-     | key_perm_maskr[3][(rawkey0 >> 1) & 0x7f]
-     | key_perm_maskr[4][rawkey1 >> 25]
-     | key_perm_maskr[5][(rawkey1 >> 17) & 0x7f]
-     | key_perm_maskr[6][(rawkey1 >> 9) & 0x7f]
-     | key_perm_maskr[7][(rawkey1 >> 1) & 0x7f];
-   *	Rotate subkeys and do compression permutation.
-  shifts = 0;
-  for (round = 0; round < 16; round++) {
-    u_int32_t	t0, t1;
-    shifts += key_shifts[round];
-    t0 = (k0 << shifts) | (k0 >> (28 - shifts));
-    t1 = (k1 << shifts) | (k1 >> (28 - shifts));
-    de_keysl[15 - round] =
-    en_keysl[round] = comp_maskl[0][(t0 >> 21) & 0x7f]
-        | comp_maskl[1][(t0 >> 14) & 0x7f]
-        | comp_maskl[2][(t0 >> 7) & 0x7f]
-        | comp_maskl[3][t0 & 0x7f]
-        | comp_maskl[4][(t1 >> 21) & 0x7f]
-        | comp_maskl[5][(t1 >> 14) & 0x7f]
-        | comp_maskl[6][(t1 >> 7) & 0x7f]
-        | comp_maskl[7][t1 & 0x7f];
-    de_keysr[15 - round] =
-    en_keysr[round] = comp_maskr[0][(t0 >> 21) & 0x7f]
-        | comp_maskr[1][(t0 >> 14) & 0x7f]
-        | comp_maskr[2][(t0 >> 7) & 0x7f]
-        | comp_maskr[3][t0 & 0x7f]
-        | comp_maskr[4][(t1 >> 21) & 0x7f]
-        | comp_maskr[5][(t1 >> 14) & 0x7f]
-        | comp_maskr[6][(t1 >> 7) & 0x7f]
-        | comp_maskr[7][t1 & 0x7f];
-  return(0);
-static int
-do_des(	u_int32_t l_in, u_int32_t r_in, u_int32_t *l_out, u_int32_t *r_out, int count, struct Des_Context *des_ctx)
-   *	l_in, r_in, l_out, and r_out are in pseudo-"big-endian" format.
-  u_int32_t	l, r, *kl, *kr, *kl1, *kr1;
-  u_int32_t	f, r48l, r48r;
-  int		round;
-  if (count == 0) {
-    return(1);
-  } else if (count > 0) {
-     * Encrypting
-    kl1 = en_keysl;
-    kr1 = en_keysr;
-  } else {
-     * Decrypting
-    count = -count;
-    kl1 = de_keysl;
-    kr1 = de_keysr;
-   *	Do initial permutation (IP).
-  l = ip_maskl[0][l_in >> 24]
-    | ip_maskl[1][(l_in >> 16) & 0xff]
-    | ip_maskl[2][(l_in >> 8) & 0xff]
-    | ip_maskl[3][l_in & 0xff]
-    | ip_maskl[4][r_in >> 24]
-    | ip_maskl[5][(r_in >> 16) & 0xff]
-    | ip_maskl[6][(r_in >> 8) & 0xff]
-    | ip_maskl[7][r_in & 0xff];
-  r = ip_maskr[0][l_in >> 24]
-    | ip_maskr[1][(l_in >> 16) & 0xff]
-    | ip_maskr[2][(l_in >> 8) & 0xff]
-    | ip_maskr[3][l_in & 0xff]
-    | ip_maskr[4][r_in >> 24]
-    | ip_maskr[5][(r_in >> 16) & 0xff]
-    | ip_maskr[6][(r_in >> 8) & 0xff]
-    | ip_maskr[7][r_in & 0xff];
-  while (count--) {
-     * Do each round.
-    kl = kl1;
-    kr = kr1;
-    round = 16;
-    while (round--) {
-       * Expand R to 48 bits (simulate the E-box).
-      r48l	= ((r & 0x00000001) << 23)
-        | ((r & 0xf8000000) >> 9)
-        | ((r & 0x1f800000) >> 11)
-        | ((r & 0x01f80000) >> 13)
-        | ((r & 0x001f8000) >> 15);
-      r48r	= ((r & 0x0001f800) << 7)
-        | ((r & 0x00001f80) << 5)
-        | ((r & 0x000001f8) << 3)
-        | ((r & 0x0000001f) << 1)
-        | ((r & 0x80000000) >> 31);
-       * Do salting for crypt() and friends, and
-       * XOR with the permuted key.
-      f = (r48l ^ r48r) & saltbits;
-      r48l ^= f ^ *kl++;
-      r48r ^= f ^ *kr++;
-       * Do sbox lookups (which shrink it back to 32 bits)
-       * and do the pbox permutation at the same time.
-      f = psbox[0][m_sbox[0][r48l >> 12]]
-        | psbox[1][m_sbox[1][r48l & 0xfff]]
-        | psbox[2][m_sbox[2][r48r >> 12]]
-        | psbox[3][m_sbox[3][r48r & 0xfff]];
-       * Now that we've permuted things, complete f().
-      f ^= l;
-      l = r;
-      r = f;
-    r = l;
-    l = f;
-   * Do final permutation (inverse of IP).
-  *l_out	= fp_maskl[0][l >> 24]
-    | fp_maskl[1][(l >> 16) & 0xff]
-    | fp_maskl[2][(l >> 8) & 0xff]
-    | fp_maskl[3][l & 0xff]
-    | fp_maskl[4][r >> 24]
-    | fp_maskl[5][(r >> 16) & 0xff]
-    | fp_maskl[6][(r >> 8) & 0xff]
-    | fp_maskl[7][r & 0xff];
-  *r_out	= fp_maskr[0][l >> 24]
-    | fp_maskr[1][(l >> 16) & 0xff]
-    | fp_maskr[2][(l >> 8) & 0xff]
-    | fp_maskr[3][l & 0xff]
-    | fp_maskr[4][r >> 24]
-    | fp_maskr[5][(r >> 16) & 0xff]
-    | fp_maskr[6][(r >> 8) & 0xff]
-    | fp_maskr[7][r & 0xff];
-  return(0);
-#if 0
-static int
-des_cipher(const char *in, char *out, u_int32_t salt, int count)
-  u_int32_t	l_out, r_out, rawl, rawr;
-  int		retval;
-  union {
-    u_int32_t	*ui32;
-    const char	*c;
-  } trans;
-  des_init();
-  setup_salt(salt);
-  trans.c = in;
-  rawl = ntohl(*trans.ui32++);
-  rawr = ntohl(*trans.ui32);
-  retval = do_des(rawl, rawr, &l_out, &r_out, count);
-  trans.c = out;
-  *trans.ui32++ = htonl(l_out);
-  *trans.ui32 = htonl(r_out);
-  return(retval);
-#endif
-#ifndef REENTRANT
-void
-setkey(const char *key)
-  int	i, j;
-  u_int32_t	packed_keys[2];
-  u_char	*p;
-  p = (u_char *) packed_keys;
-  for (i = 0; i < 8; i++) {
-    p[i] = 0;
-      if (*key++ & 1)
-        p[i] |= bits8[j];
-  des_setkey(p, &single);
-#endif
-#ifndef REENTRANT
-void
-encrypt(char *block, int flag)
-  u_int32_t	io[2];
-  u_char	*p;
-  int	i, j;
-  des_init();
-  setup_salt(0L, &single);
-  p = block;
-  for (i = 0; i < 2; i++) {
-    io[i] = 0L;
-    for (j = 0; j < 32; j++)
-      if (*p++ & 1)
-        io[i] |= bits32[j];
-  do_des(io[0], io[1], io, io + 1, flag ? -1 : 1, &single);
-      block[(i << 5) | j] = (io[i] & bits32[j]) ? 1 : 0;
-#endif
-char *
-__des_crypt_r(const char *key, const char *setting, char *output, int sz)
-  char *rval = 0;
-  struct Des_Context *des_ctx;
-  u_int32_t	count, salt, l, r0, r1, keybuf[2];
-  u_char		*p, *q;
-  if (sz < 21)
-    return NULL;
-  des_init();
-  des_ctx = des_ctx_init();
-   * Copy the key, shifting each character up by one bit
-   * and padding with zeros.
-  q = (u_char *)keybuf;
-  while (q - (u_char *)keybuf - 8) {
-    *q++ = *key << 1;
-    if (*(q - 1))
-      key++;
-  if (des_setkey((char *)keybuf, des_ctx))
-    goto bailout;
-#if 0
-  if (*setting == _PASSWORD_EFMT1) {
-    int		i;
-     * "new"-style:
-     *	setting - underscore, 4 bytes of count, 4 bytes of salt
-     *	key - unlimited characters
-    for (i = 1, count = 0L; i < 5; i++)
-      count |= ascii_to_bin(setting[i]) << ((i - 1) * 6);
-    for (i = 5, salt = 0L; i < 9; i++)
-      salt |= ascii_to_bin(setting[i]) << ((i - 5) * 6);
-    while (*key) {
-       * Encrypt the key with itself.
-      if (des_cipher((char *)keybuf, (char *)keybuf, 0L, 1))
-        goto bailout;
-       * And XOR with the next 8 characters of the key.
-      while (q - (u_char *)keybuf - 8 && *key)
-        *q++ ^= *key++ << 1;
-      if (des_setkey((char *)keybuf))
-        goto bailout;
-    strncpy(output, setting, 9);
-     * Double check that we weren't given a short setting.
-     * If we were, the above code will probably have created
-     * wierd values for count and salt, but we don't really care.
-     * Just make sure the output string doesn't have an extra
-     * NUL in it.
-    output[9] = '\0';
-    p = (u_char *)output + strlen(output);
-  } else
-#endif
-     * "old"-style:
-     *	setting - 2 bytes of salt
-     *	key - up to 8 characters
-    count = 25;
-    salt = (ascii_to_bin(setting[1]) << 6)
-         |  ascii_to_bin(setting[0]);
-    output[0] = setting[0];
-     * If the encrypted password that the salt was extracted from
-     * is only 1 character long, the salt will be corrupted.  We
-     * need to ensure that the output string doesn't have an extra
-     * NUL in it!
-    output[1] = setting[1] ? setting[1] : output[0];
-    p = (u_char *)output + 2;
-  setup_salt(salt, des_ctx);
-   * Do it.
-  if (do_des(0L, 0L, &r0, &r1, (int)count, des_ctx))
-    goto bailout;
-   * Now encode the result...
-  l = (r0 >> 8);
-  *p++ = ascii64[(l >> 18) & 0x3f];
-  *p++ = ascii64[(l >> 12) & 0x3f];
-  *p++ = ascii64[(l >> 6) & 0x3f];
-  *p++ = ascii64[l & 0x3f];
-  l = (r0 << 16) | ((r1 >> 16) & 0xffff);
-  l = r1 << 2;
-  *p = 0;
-  rval = output;
-bailout:
-  free(des_ctx);
-  return rval;
-char *
-__des_crypt(const char *key, const char *setting)
-  static char	output[21];
-  return __des_crypt_r(key, setting, output, sizeof(output));
-#ifdef DEBUG
-void
-des_snap(void **pf, void **pd)
-  uint8* pfc;
-  *pf = malloc(sizeof(struct fixed1) + sizeof(struct fixed2) + sizeof(struct fixed3) + sizeof(struct fixed4));
-  pfc = *pf;
-  memcpy(pfc, &des1_f, sizeof(des1_f));
-  pfc += sizeof(des1_f);
-  memcpy(pfc, &des2_f, sizeof(des2_f));
-  pfc += sizeof(des2_f);
-  memcpy(pfc, &des3_f, sizeof(des3_f));
-  pfc += sizeof(des3_f);
-  memcpy(pfc, &des4_f, sizeof(des4_f));
-//	*pd = malloc(sizeof(struct Des_Context));
-//	memcpy(*pd, &des_ctx, sizeof(des_ctx));
-void
-des_check(void *pf, void *pd)
-  uint8* pfc1, pfc2, pfc3, pfc4;
-  pfc1 = pf;
-  pfc2 = pfc1 + sizeof(des1_f);
-  pfc3 = pfc2 + sizeof(des2_f);
-  pfc4 = pfc3 + sizeof(des3_f);
-  printf("Fixed: do%s differ"/*", Context: do%s differ"*/"\n",
-         (memcmp(pfc1, &des1_f, sizeof(des1_f)) ||
-          memcmp(pfc2, &des2_f, sizeof(des2_f)) ||
-          memcmp(pfc3, &des4_f, sizeof(des3_f)) ||
-          memcmp(pfc4, &des4_f, sizeof(des4_f))) ? "" : "nt");
-#endif
diff --git a/rtemsbsd/telnetd/passwd.h b/rtemsbsd/telnetd/passwd.h
index 8d5c299a5..000000000
--- a/rtemsbsd/telnetd/passwd.h
+++ /dev/null
@@ -1,25 +0,0 @@
-/* Define a default password for telnetd here.
- * NOTES:
- *  - this can be overridden at run-time by setting
- *    the "TELNETD_PASSWD" environment variable.
- *    As soon as that variable is set, the new password
- *    is effective - no need to restart telnetd.
- *  - this must be set to an _encrypted_ password, NOT
- *    the cleartext. Use the 'genpw' utility to generate
- *    a password string:
- *    1) Compile 'genpw.c' for the HOST, i.e.
- *         cc -o genpw genpw.c -lcrypt
- *    1) delete an old password definition from this file.
- *    2) run './genpw >> passwd.h'. This will append
- *       a new definition to this file.
- *  - if no password is defined here, no authentication
- *    is needed, i.e. telnet is open to the world.
- *    T. Straumann <strauman at slac.stanford.edu>
-/* #undef TELNETD_DEFAULT_PASSWD */
-/* Default password: 'rtems' */
-#define TELNETD_DEFAULT_PASSWD "tduDcyLX12owo"
diff --git a/rtemsbsd/telnetd/pty.c b/rtemsbsd/telnetd/pty.c
index 727e5ebf5..000000000
--- a/rtemsbsd/telnetd/pty.c
+++ /dev/null
@@ -1,660 +0,0 @@
- * /dev/ptyXX  (Support for pseudo-terminals)
- *  May 2001
- *  This program is distributed in the hope that it will be useful,
- *  but WITHOUT ANY WARRANTY; without even the implied warranty of
- *  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
- *   - converted into a loadable module
- *   - NAWS support / ioctls for querying/setting the window
- *     size added.
- *   - don't delete the running task when the connection
- *     is closed. Rather let 'read()' return a 0 count so
- *     they may cleanup. Some magic hack works around termios
- *     limitation.
-#endif
-#define DEBUG_WH    (1<<0)
-#define DEBUG_DETAIL  (1<<1)
-/* #define DEBUG DEBUG_WH */
-#include <rtems/termiostypes.h>
-#include <sys/ttycom.h>
-#include <rtems.h>
-#include <rtems/bspIo.h>
-#include <errno.h>
-#include <sys/socket.h>
-#include <stdio.h>
-#define IAC_ESC    255
-#define IAC_DONT   254
-#define IAC_DO     253
-#define IAC_WONT   252
-#define IAC_WILL   251
-#define IAC_SB     250
-#define IAC_GA     249
-#define IAC_EL     248
-#define IAC_EC     247
-#define IAC_AYT    246
-#define IAC_AO     245
-#define IAC_IP     244
-#define IAC_BRK    243
-#define IAC_DMARK  242
-#define IAC_NOP    241
-#define IAC_SE     240
-#define IAC_EOR    239
-#define SB_MAX    16
-extern int rtems_telnetd_maximum_ptys;
-struct pty_tt;
-typedef struct pty_tt pty_t;
-struct pty_tt {
- char                     *devname;
- struct rtems_termios_tty *ttyp;
- tcflag_t                  c_cflag;
- int                       opened;
- int                       socket;
- int                       last_cr;
- unsigned                  iac_mode;
- unsigned char             sb_buf[SB_MAX];
- int                       sb_ind;
- int                       width;
- int                       height;
-static int    telnet_pty_inited=FALSE;
-static pty_t *telnet_ptys;
-static rtems_device_major_number pty_major;
-static
-int send_iac(int minor,unsigned char mode,unsigned char option)
-  unsigned char buf[3];
-  buf[0]=IAC_ESC;
-  buf[1]=mode;
-  buf[2]=option;
-  return write(telnet_ptys[minor].socket,buf,sizeof(buf));
-/* This procedure returns the devname for a pty slot free.
- * If not slot availiable (field socket>=0)
- *  then the socket argument is closed
-char *  telnet_get_pty(int socket)
-  int ndx;
-  if (telnet_pty_inited) {
-#if 0
-    if ( rtems_telnetd_maximum_ptys < 5 )
-      rtems_telnetd_maximum_ptys = 5;
-    telnet_ptys = malloc( rtems_telnetd_maximum_ptys * sizeof (pty_t) );
-#endif
-    if ( !telnet_ptys ) {
-      return NULL;
-    for (ndx=0;ndx<rtems_telnetd_maximum_ptys;ndx++) {
-      if (telnet_ptys[ndx].socket<0) {
-        struct timeval t;
-        /* set a long polling interval to save CPU time */
-        t.tv_sec=2;
-        t.tv_usec=00000;
-        setsockopt(socket, SOL_SOCKET, SO_RCVTIMEO, &t, sizeof(t));
-        telnet_ptys[ndx].socket=socket;
-        /* inform the client that we will echo */
-        send_iac(ndx, IAC_WILL, 1);
-        return telnet_ptys[ndx].devname;
-  close(socket);
-  return NULL;
- * The NVT terminal is negociated in PollRead and PollWrite
- * with every BYTE sendded or received.
- * A litle status machine in the pty_read_byte(int minor)
-static const char IAC_AYT_RSP[]="\r\nAYT? Yes, RTEMS-SHELL is here\r\n";
-static const char IAC_BRK_RSP[]="<*Break*>";
-static const char IAC_IP_RSP []="<*Interrupt*>";
-static int
-handleSB(pty_t *pty)
-  switch (pty->sb_buf[0]) {
-    case 31:  /* NAWS */
-      pty->width  = (pty->sb_buf[1]<<8) + pty->sb_buf[2];
-      pty->height = (pty->sb_buf[3]<<8) + pty->sb_buf[4];
-#if DEBUG & DEBUG_WH
-      fprintf(stderr,
-          "Setting width/height to %ix%i\n",
-          pty->width,
-          pty->height);
-#endif
-      break;
-    default:
-      break;
-  return 0;
-static int read_pty(int minor)
-{ /* Characters written to the client side*/
-   unsigned char  value;
-   unsigned int  omod;
-   int      count;
-   int      result;
-   pty_t      *pty=telnet_ptys+minor;
-   count=read(pty->socket,&value,sizeof(value));
-   if (count<0)
-    return -1;
-   if (count<1) {
-      /* Unfortunately, there is no way of passing an EOF
-       * condition through the termios driver. Hence, we
-       * resort to an ugly hack. Setting cindex>ccount
-       * causes the termios driver to return a read count
-       * of '0' which is what we want here. We leave
-       * 'errno' untouched.
-      pty->ttyp->cindex=pty->ttyp->ccount+1;
-      return pty->ttyp->termios.c_cc[VEOF];
-   omod=pty->iac_mode;
-   pty->iac_mode=0;
-   switch(omod & 0xff) {
-       case IAC_ESC:
-           switch(value) {
-               case IAC_ESC :
-                   /* in case this is an ESC ESC sequence in SB mode */
-                   pty->iac_mode = omod>>8;
-                   return IAC_ESC;
-               case IAC_DONT:
-               case IAC_DO  :
-               case IAC_WONT:
-               case IAC_WILL:
-                   pty->iac_mode=value;
-                   return -1;
-               case IAC_SB  :
-#if DEBUG & DEBUG_DETAIL
-                   printk("SB\n");
-#endif
-                   pty->sb_ind=0;
-                   return -100;
-               case IAC_GA  :
-                   return -1;
-               case IAC_EL  :
-                   return 0x03; /* Ctrl-C*/
-               case IAC_EC  :
-                   return '\b';
-               case IAC_AYT :
-                   write(pty->socket,IAC_AYT_RSP,strlen(IAC_AYT_RSP));
-                   return -1;
-               case IAC_AO  :
-                   return -1;
-               case IAC_IP  :
-                   write(pty->socket,IAC_IP_RSP,strlen(IAC_IP_RSP));
-                   return -1;
-               case IAC_BRK :
-                   write(pty->socket,IAC_BRK_RSP,strlen(IAC_BRK_RSP));
-                   return -1;
-               case IAC_DMARK:
-                   return -2;
-               case IAC_NOP :
-                   return -1;
-               case IAC_SE  :
-                  int i;
-                  printk("SE");
-                  for (i=0; i<pty->sb_ind; i++)
-                    printk(" %02x",pty->sb_buf[i]);
-                  printk("\n");
-#endif
-                  handleSB(pty);
-               return -101;
-               case IAC_EOR :
-                   return -102;
-               default      :
-                   return -1;
-           break;
-       case IAC_SB:
-           pty->iac_mode=omod;
-           if (IAC_ESC==value) {
-             pty->iac_mode=(omod<<8)|value;
-           } else {
-             if (pty->sb_ind < SB_MAX)
-               pty->sb_buf[pty->sb_ind++]=value;
-           return -1;
-       case IAC_WILL:
-           if (value==34){
-              send_iac(minor,IAC_DONT,   34);  /*LINEMODE*/
-              send_iac(minor,IAC_DO  ,    1);  /*ECHO    */
-           } else if (value==31) {
-              send_iac(minor,IAC_DO  ,   31);  /*NAWS    */
-              printk("replied DO NAWS\n");
-#endif
-           } else {
-              send_iac(minor,IAC_DONT,value);
-           return -1;
-       case IAC_DONT:
-           return -1;
-       case IAC_DO  :
-           if (value==3) {
-              send_iac(minor,IAC_WILL,    3);  /* GO AHEAD*/
-           } else  if (value==1) {
-              send_iac(minor,IAC_WILL,    1);  /* ECHO */
-           } else {
-              send_iac(minor,IAC_WONT,value);
-           return -1;
-       case IAC_WONT:
-           if (value==1) {
-           } else { /* ECHO */
-           return -1;
-       default:
-           if (value==IAC_ESC) {
-              return -1;
-           } else {
-              result=value;
-              if ( 0
-                /* map CRLF to CR for symmetry */
-                 || ((value=='\n') && pty->last_cr)
-                /* map telnet CRNUL to CR down here */
-                 || ((value==0) && pty->last_cr)
-                ) result=-1;
-               pty->last_cr=(value=='\r');
-               return result;
-  /* should never get here but keep compiler happy */
-  return -1;
-static int ptySetAttributes(int minor,const struct termios *t);
-static int ptyPollInitialize(int major,int minor,void * arg) ;
-static int ptyShutdown(int major,int minor,void * arg) ;
-static ssize_t ptyPollWrite(int minor, const char * buf, size_t len) ;
-static int ptyPollRead(int minor) ;
-static const rtems_termios_callbacks * pty_get_termios_handlers(int polled) ;
-/* Set the 'Hardware'                                        */
-static int
-ptySetAttributes(int minor,const struct termios *t) {
-  if (minor<rtems_telnetd_maximum_ptys) {
-   telnet_ptys[minor].c_cflag=t->c_cflag;
-  } else {
-   return -1;
-  return 0;
-static int
-ptyPollInitialize(int major,int minor,void * arg) {
-  rtems_libio_open_close_args_t * args = (rtems_libio_open_close_args_t*)arg;
-  struct termios t;
-         if (telnet_ptys[minor].socket<0) return -1;
-   telnet_ptys[minor].opened=TRUE;
-   telnet_ptys[minor].ttyp= (struct rtems_termios_tty *) args->iop->data1;
-   telnet_ptys[minor].iac_mode=0;
-   telnet_ptys[minor].sb_ind=0;
-   telnet_ptys[minor].width=0;
-   telnet_ptys[minor].height=0;
-   t.c_cflag=B9600|CS8;/* termios default */
-   return ptySetAttributes(minor,&t);
-  } else {
-   return -1;
-static int
-ptyShutdown(int major,int minor,void * arg) {
-    telnet_ptys[minor].opened=FALSE;
-    if (telnet_ptys[minor].socket>=0) close(telnet_ptys[minor].socket);
-      telnet_ptys[minor].socket=-1;
-    chown(telnet_ptys[minor].devname,2,0);
-  } else {
-    return -1;
-  return 0;
-/* Write Characters into pty device                          */
-static ssize_t
-ptyPollWrite(int minor, const char * buf, size_t len) {
-  size_t count;
-      return -1;
-    count=write(telnet_ptys[minor].socket,buf,len);
-  } else {
-   count=-1;
-  return count;
-static int
-ptyPollRead(int minor) {
-  int result;
-      return -1;
-    result=read_pty(minor);
-    return result;
-  return -1;
-/*  pty_initialize
- *  This routine initializes the pty IO driver.
- *  Input parameters: NONE
- *  Output parameters:  NONE
- *  Return values:
-static
-rtems_device_driver my_pty_initialize(
-  rtems_device_major_number  major,
-  rtems_device_minor_number  minor,
-  void                      *arg
-  int ndx;
-  rtems_status_code status;
-   * Set up ptys
-    telnet_ptys[ndx].devname = (char*)malloc(strlen("/dev/ptyXX")+1);
-    sprintf(telnet_ptys[ndx].devname,"/dev/pty%X",ndx);
-    telnet_ptys[ndx].ttyp    =  NULL;
-    telnet_ptys[ndx].c_cflag = CS8|B9600;
-    telnet_ptys[ndx].socket  = -1;
-    telnet_ptys[ndx].opened  = FALSE;
-    telnet_ptys[ndx].sb_ind  = 0;
-    telnet_ptys[ndx].width   = 0;
-    telnet_ptys[ndx].height  = 0;
-   * Register the devices
-    status = rtems_io_register_name(telnet_ptys[ndx].devname, major, ndx);
-    if (status != RTEMS_SUCCESSFUL)
-        rtems_fatal_error_occurred(status);
-    chmod(telnet_ptys[ndx].devname,0660);
-    chown(telnet_ptys[ndx].devname,2,0); /* tty,root*/
-  syslog(
-    LOG_KERN | LOG_INFO,
-    "/dev/pty%X../dev/pty%X (%d) pseudo-terminals registered.\n",
-    0,
-    rtems_telnetd_maximum_ptys - 1,
-  return RTEMS_SUCCESSFUL;
-static int pty_do_finalize(void)
-    int ndx;
-    if ( !telnet_pty_inited )
-      return 0;
-      if (telnet_ptys[ndx].opened) {
-          fprintf(stderr,
-            "There are still opened PTY devices, unable to proceed\n");
-          return -1;
-    if (RTEMS_SUCCESSFUL != rtems_io_unregister_driver(pty_major)) {
-        fprintf(stderr,"Unable to remove this driver\n");
-        return -1;
-        /* rtems_io_register_name() actually creates a node in the filesystem
-         * (mknod())
-        status = (rtems_status_code)unlink(telnet_ptys[ndx].devname);
-          perror("removing pty device node from file system");
-        else
-          free(telnet_ptys[ndx].devname);
-    free ( telnet_ptys );
-    fprintf(stderr,"PTY driver unloaded successfully\n");
-    telnet_pty_inited=FALSE;
-    return 0;
- *  Open entry point
-static
-rtems_device_driver my_pty_open(
-  void                    * arg
-  rtems_status_code sc;
-  sc = rtems_termios_open(major,minor,arg,pty_get_termios_handlers(FALSE));
-  return sc;
- *  Close entry point
-static
-rtems_device_driver my_pty_close(
-  void                    * arg
-  return rtems_termios_close(arg);
- * read bytes from the pty
-static
-rtems_device_driver my_pty_read(
-  void                    * arg
-  return rtems_termios_read(arg);
- * write bytes to the pty
-static
-rtems_device_driver my_pty_write(
-  void                    * arg
-  return rtems_termios_write(arg);
- *  IO Control entry point
-static
-rtems_device_driver my_pty_control(
-  void                    * arg
-  rtems_libio_ioctl_args_t *args = (rtems_libio_ioctl_args_t*)arg;
-  struct winsize           *wp = (struct winsize*)args->buffer;
-  pty_t                    *p = &telnet_ptys[minor];
-  switch (args->command) {
-    case TIOCGWINSZ:
-      wp->ws_row = p->height;
-      wp->ws_col = p->width;
-      args->ioctl_return=0;
-      fprintf(stderr,
-          "ioctl(TIOCGWINSZ), returning %ix%i\n",
-          wp->ws_col,
-          wp->ws_row);
-#endif
-    case TIOCSWINSZ:
-      fprintf(stderr,
-          "ioctl(TIOCGWINSZ), setting %ix%i\n",
-          wp->ws_col,
-          wp->ws_row);
-#endif
-      p->height = wp->ws_row;
-      p->width  = wp->ws_col;
-    default:
-     break;
-  return rtems_termios_ioctl(arg);
-static rtems_driver_address_table drvPty = {
-    my_pty_initialize,
-    my_pty_open,
-    my_pty_close,
-    my_pty_read,
-    my_pty_write,
-    my_pty_control
-static const rtems_termios_callbacks pty_poll_callbacks = {
-  ptyPollInitialize,  /* FirstOpen */
-  ptyShutdown,        /* LastClose */
-  ptyPollRead,        /* PollRead  */
-  ptyPollWrite,       /* Write */
-  ptySetAttributes,   /* setAttributes */
-  NULL,               /* stopRemoteTX */
-  NULL,               /* StartRemoteTX */
-  0                   /* outputUsesInterrupts */
-static const rtems_termios_callbacks * pty_get_termios_handlers(int polled) {
-  return &pty_poll_callbacks;
-static int pty_do_initialize(void)
-  if ( !telnet_pty_inited ) {
-    if (RTEMS_SUCCESSFUL==rtems_io_register_driver(0, &drvPty, &pty_major))
-      telnet_pty_inited=TRUE;
-    else
-      fprintf(stderr,"WARNING: registering the PTY driver FAILED\n");
-  return telnet_pty_inited;
-int telnet_pty_initialize(void)
-  return pty_do_initialize();
-int telnet_pty_finalize(void)
-  return pty_do_finalize();
diff --git a/rtemsbsd/telnetd/telnetd-init.c b/rtemsbsd/telnetd/telnetd-init.c
index e723def07..000000000
--- a/rtemsbsd/telnetd/telnetd-init.c
+++ /dev/null
@@ -1,33 +0,0 @@
- *  The telnet DAEMON
- *  Author: 17,may 2001
- *   WORK: fernando.ruiz at ctv.es
- *   HOME: correo at fernando-ruiz.com
- * embedded brains GmbH
- * Obere Lagerstr. 30
- * Germany
- * <rtems at embedded-brains.de>
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
-#ifdef HAVE_CONFIG_H
-#endif
-  return rtems_telnetd_start(&rtems_telnetd_config);
diff --git a/rtemsbsd/telnetd/telnetd.c b/rtemsbsd/telnetd/telnetd.c
index 7fe603fa5..000000000
--- a/rtemsbsd/telnetd/telnetd.c
+++ /dev/null
@@ -1,517 +0,0 @@
- * After start the net you can start this daemon.
- * It uses the previously inited pseudo-terminales (pty.c)
- * getting a new terminal with getpty(). This function
- * gives a terminal name passing a opened socket like parameter.
- * With register_telnetd() you add a new command in the shell to start
- * this daemon interactively. (Login in /dev/console of course)
- * Sorry but OOB is not still implemented. (This is the first version)
- *  - made the 'shell' interface more generic, i.e. it is now
- *    possible to have 'telnetd' run an arbitrary 'shell'
- *    program.
- * Germany
-#endif
-#include <rtems.h>
-#include <rtems/error.h>
-#include <rtems/pty.h>
-#include <arpa/inet.h>
-#include <stdio.h>
-#include <rtems/userenv.h>
-#include <rtems/rtems_bsdnet.h>
-#define PARANOIA
-extern char *telnet_get_pty(int socket);
-extern int   telnet_pty_initialize(void);
-struct shell_args {
-  char *devname;
-  void *arg;
-  char  peername[16];
-  char  delete_myself;
-typedef union uni_sa {
-  struct sockaddr_in sin;
-  struct sockaddr     sa;
-} uni_sa;
-static int sockpeername(int sock, char *buf, int bufsz);
-rtems_id telnetd_dflt_spawn(
-  const char *name,
-  unsigned priority,
-  unsigned stackSize,
-  void (*fn)(void*),
-  void *fnarg
-static rtems_telnetd_config_table* telnetd_config;
-static rtems_id                    telnetd_task_id;
- * chrisj: this variable was global and with no declared interface in a header
- *         file and with no means to set it so I have stopped it being global;
- *         if this breaks any user they will have be to provide a formal
- *         interface to get this change reverted.
-static const rtems_id (*telnetd_spawn_task)(
-  const char *,
-  unsigned,
-  unsigned,
-  void (*)(void*),
-  void *
-) = telnetd_dflt_spawn;
-static char *grab_a_Connection(
-  int des_socket,
-  uni_sa *srv,
-  char *peername,
-  int sz
-  char *rval = 0;
-  socklen_t size_adr = sizeof(srv->sin);
-  int acp_sock;
-  acp_sock = accept(des_socket,&srv->sa,&size_adr);
-  if (acp_sock<0) {
-    perror("telnetd:accept");
-    goto bailout;
-  if ( !(rval=telnet_get_pty(acp_sock)) ) {
-    syslog( LOG_DAEMON | LOG_ERR, "telnetd: unable to obtain PTY");
-    /* NOTE: failing 'do_get_pty()' closed the socket */
-    goto bailout;
-  if (sockpeername(acp_sock, peername, sz))
-    strncpy(peername, "<UNKNOWN>", sz);
-#ifdef PARANOIA
-  syslog(LOG_DAEMON | LOG_INFO,
-      "telnetd: accepted connection from %s on %s",
-      peername,
-      rval);
-#endif
-bailout:
-  return rval;
-static void release_a_Connection(char *devname, char *peername, FILE **pstd, int n)
-#ifdef PARANOIA
-  syslog( LOG_DAEMON | LOG_INFO,
-      "telnetd: releasing connection from %s on %s",
-      peername,
-      devname );
-#endif
-  while (--n>=0)
-    if (pstd[n]) fclose(pstd[n]);
-  uni_sa peer;
-  int    rval = sock < 0;
-  socklen_t len  = sizeof(peer.sin);
-  if ( !rval )
-    rval = getpeername(sock, &peer.sa, &len);
-  if ( !rval )
-    rval = !inet_ntop( AF_INET, &peer.sin.sin_addr, buf, bufsz );
-  return rval;
-static void
-spawned_shell(void *arg);
-static void
-rtems_task_telnetd(void *task_argument)
-  int                des_socket;
-  uni_sa             srv;
-  char              *devname;
-  int                i=1;
-  int                size_adr;
-  struct shell_args *arg = NULL;
-  if ((des_socket=socket(PF_INET,SOCK_STREAM,0))<0) {
-    perror("telnetd:socket");
-    telnetd_task_id = RTEMS_ID_NONE;
-    rtems_task_delete(RTEMS_SELF);
-  setsockopt(des_socket,SOL_SOCKET,SO_KEEPALIVE,&i,sizeof(i));
-  memset(&srv,0,sizeof(srv));
-  srv.sin.sin_family=AF_INET;
-  srv.sin.sin_port=htons(23);
-  size_adr=sizeof(srv.sin);
-  if ((bind(des_socket,&srv.sa,size_adr))<0) {
-    perror("telnetd:bind");
-    close(des_socket);
-  if ((listen(des_socket,5))<0) {
-    perror("telnetd:listen");
-  /* we don't redirect stdio as this probably
-   * was started from the console anyway ..
-  do {
-    if (telnetd_config->keep_stdio) {
-      bool start = true;
-      char device_name [32];
-      ttyname_r( 1, device_name, sizeof( device_name));
-      if (telnetd_config->login_check != NULL) {
-        start = rtems_shell_login_prompt(
-          stdin,
-          stderr,
-          device_name,
-          telnetd_config->login_check
-      if (start) {
-        telnetd_config->command( device_name, arg->arg);
-      } else {
-        syslog(
-          LOG_AUTHPRIV | LOG_WARNING,
-          "telnetd: to many wrong passwords entered from %s",
-          device_name
-    } else {
-      devname = grab_a_Connection(des_socket, &srv, peername, sizeof(peername));
-      if ( !devname ) {
-        /* if something went wrong, sleep for some time */
-        sleep(10);
-        continue;
-      arg = malloc( sizeof(*arg) );
-      arg->devname = devname;
-      arg->arg = telnetd_config->arg;
-      strncpy(arg->peername, peername, sizeof(arg->peername));
-      telnetd_task_id = telnetd_spawn_task(
-        devname,
-        telnetd_config->priority,
-        telnetd_config->stack_size,
-        spawned_shell,
-        arg
-      if (telnetd_task_id == RTEMS_ID_NONE) {
-        FILE *dummy;
-        if ( telnetd_spawn_task != telnetd_dflt_spawn ) {
-          fprintf(stderr,"Telnetd: Unable to spawn child task\n");
-        /* hmm - the pty driver slot can only be
-         * released by opening and subsequently
-         * closing the PTY - this also closes
-         * the underlying socket. So we mock up
-         * a stream...
-        if ( !(dummy=fopen(devname,"r+")) )
-          perror("Unable to dummy open the pty, losing a slot :-(");
-        release_a_Connection(devname, peername, &dummy, 1);
-        free(arg);
-        sleep(2); /* don't accept connections too fast */
-  } while(1);
-  /* TODO: how to free the connection semaphore? But then -
-   *       stopping the daemon is probably only needed during
-   *       development/debugging.
-   *       Finalizer code should collect all the connection semaphore
-   *       counts and eventually clean up...
-  if (telnetd_config != NULL) {
-    fprintf(stderr, "telnetd already started\n");
-    return RTEMS_RESOURCE_IN_USE;
-  if (config->command == NULL) {
-    fprintf(stderr, "telnetd setup with invalid command\n");
-    return RTEMS_IO_ERROR;
-  telnetd_config = calloc(1, sizeof(*telnetd_config));
-  if (telnetd_config == NULL) {
-    fprintf(stderr, "telnetd cannot alloc telnetd config table\n");
-    return RTEMS_NO_MEMORY;
-  if ( !telnet_pty_initialize() ) {
-    fprintf(stderr, "telnetd cannot initialize PTY driver\n");
-    free(telnetd_config);
-    telnetd_config = NULL;
-  *telnetd_config = *config;
-  /* Check priority */
-  if (telnetd_config->priority < 2) {
-    telnetd_config->priority = 100;
-  /* Check stack size */
-  if (telnetd_config->stack_size <= 0) {
-    telnetd_config->stack_size = (size_t)32 * 1024;
-  /* Spawn task */
-    "TNTD",
-    rtems_task_telnetd,
-    0
-  /* Print status */
-  if (!telnetd_config->keep_stdio) {
-    fprintf(
-      stderr,
-      "telnetd started with stacksize = %u and priority = %d\n",
-      (unsigned) telnetd_config->stack_size,
-      (unsigned) telnetd_config->priority
-/* utility wrapper */
-static void
-spawned_shell(void *targ)
-  FILE                *nstd[3]={0};
-  FILE                *ostd[3]={ stdin, stdout, stderr };
-  int                  i=0;
-  struct shell_args  *arg = targ;
-  bool login_failed = false;
-  sc=rtems_libio_set_private_env();
-  /* newlib hack/workaround. Before we change stdin/out/err we must make
-         * sure the internal data are initialized (fileno(stdout) has this sideeffect).
-   * This should probably be done from RTEMS' libc support layer...
-   * (T.S., newlibc-1.13; 2005/10)
-  fileno(stdout);
-  if (RTEMS_SUCCESSFUL != sc) {
-    rtems_error(sc,"rtems_libio_set_private_env");
-    goto cleanup;
-  /* redirect stdio */
-  for (i=0; i<3; i++) {
-    if ( !(nstd[i]=fopen(arg->devname,"r+")) ) {
-      perror("unable to open stdio");
-      goto cleanup;
-  stdin  = nstd[0];
-  stdout = nstd[1];
-  stderr = nstd[2];
-  #if 0
-    printk("STDOUT is now %x (%x) (FD %i/%i)\n",
-           stdout,nstd[1],fileno(stdout),fileno(nstd[1]));
-    printf("hello\n");
-    write(fileno(stdout),"hellofd\n",8);
-  #endif
-  /* call their routine */
-      stdin,
-      stderr,
-      arg->devname,
-    login_failed = !start;
-  if (start) {
-    telnetd_config->command( arg->devname, arg->arg);
-  stdin  = ostd[0];
-  stdout = ostd[1];
-  stderr = ostd[2];
-  if (login_failed) {
-    syslog(
-      arg->peername
-cleanup:
-  release_a_Connection(arg->devname, arg->peername, nstd, i);
-  free(arg);
-struct wrap_delete_args {
-  void (*t)(void *);
-  void           *a;
-static rtems_task
-wrap_delete(rtems_task_argument arg)
-  struct wrap_delete_args     *pwa = (struct wrap_delete_args *)arg;
-  register void              (*t)(void *) = pwa->t;
-  register void               *a   = pwa->a;
-  /* free argument before calling function (which may never return if
-   * they choose to delete themselves)
-  free(pwa);
-  t(a);
-rtems_id
-telnetd_dflt_spawn(const char *name, unsigned int priority, unsigned int stackSize, void (*fn)(void *), void* fnarg)
-  rtems_id                 task_id = RTEMS_ID_NONE;
-  char                     nm[4] = {'X','X','X','X' };
-  struct wrap_delete_args *pwa = malloc(sizeof(*pwa));
-  strncpy(nm, name, 4);
-  if ( !pwa ) {
-    perror("Telnetd: no memory\n");
-    return RTEMS_ID_NONE;
-  pwa->t = fn;
-  pwa->a = fnarg;
-  if ((sc=rtems_task_create(
-    rtems_build_name(nm[0], nm[1], nm[2], nm[3]),
-      (rtems_task_priority)priority,
-      stackSize,
-      RTEMS_DEFAULT_MODES,
-      RTEMS_DEFAULT_ATTRIBUTES | RTEMS_FLOATING_POINT,
-      &task_id)) ||
-    (sc=rtems_task_start(
-      task_id,
-      wrap_delete,
-      (rtems_task_argument)pwa))) {
-        free(pwa);
-        rtems_error(sc,"Telnetd: spawning task failed");
-  return task_id;
-/* convenience routines for CEXP (retrieve stdio descriptors
- * from reent structure)
-#ifdef stdin
-static __inline__ FILE *
-_stdin(void)  { return stdin; }
-#undef stdin
-FILE *stdin(void)  { return _stdin(); }
-#endif
-#ifdef stdout
-_stdout(void) { return stdout; }
-#undef stdout
-FILE *stdout(void) { return _stdout(); }
-#endif
-#ifdef stderr
-_stderr(void) { return stderr; }
-#undef stderr
-FILE *stderr(void) { return _stderr(); }
-#endif
-/* MUST NOT USE stdin & friends below here !!!!!!!!!!!!! */
diff --git a/waf_libbsd.py b/waf_libbsd.py
index 54a60a78a..fd89c3947 100644
--- a/waf_libbsd.py
+++ b/waf_libbsd.py
@@ -477,5 +477,5 @@ class Builder(builder.ModuleManager):
                             includes = includes,
                             source = test_sources,
                             use = ['bsd'],
-                            lib = ['m', 'z'],
+                            lib = ['ftpfs', 'ftpd', 'telnetd', 'bsd', 'm', 'z'],
                             install_path = None)
2.12.3
