[PATCH 1/3] source-builder/config: Add couverture-qemu general config & build instructions.
Mon Apr 30 23:52:10 UTC 2018
On 28/04/2018 20:18, Cillian O'Donnell wrote:
>  source-builder/config/couverture-qemu-2-1.cfg | 104 ++++++++++++++++++++++++++
Why a new file? Could the existing qemu config be used?
I would prefer to have as few of the global configs as possible and share them
as much as possible.
>  1 file changed, 104 insertions(+)
>  create mode 100644 source-builder/config/couverture-qemu-2-1.cfg
> diff --git a/source-builder/config/couverture-qemu-2-1.cfg b/source-builder/config/couverture-qemu-2-1.cfg
> new file mode 100644
> index 0000000..b0a31bb
> --- /dev/null
> +++ b/source-builder/config/couverture-qemu-2-1.cfg
> @@ -0,0 +1,104 @@
> +# This configuration file configure's, make's and install's Couverture-QEMU.
> +%if %{release} == %{nil}
> +  %define release 1
> +%endif
> +# The description.
> +Name:      couverture-qemu-%{qemu_version}-%{_host}-%{release}
> +Summary:   Couverture-Qemu is a processor simulator with extra trace ability.
I do not mind we have just the QEMU name and summary.
> +Version:   %{qemu_version}
> +Release:   %{release}
> +URL: 	   https://github.com/AdaCore/qemu
> +BuildRoot: %{_tmppath}/%{name}-root-%(%{__id_u} -n)
> +# List of architectures to be built
> +%define qemu_archs arm-softmmu,i386-softmmu,lm32-softmmu,mips-softmmu
> +%define qemu_archs %{qemu_archs},ppc-softmmu,sparc-softmmu
Why limit the archs?
> +# Prepare the source code.
> +%prep
> +  build_top=$(pwd)
> +  source_dir_qemu="qemu-%{qemu_version}"
> +  %source setup qemu -n qemu-%{qemu_version}
Why remove the -q?
> +  %patch setup qemu -p1
> +  cd ${build_top}
> +%build
> +  build_top=$(pwd)
> +  %{build_directory}
> +  mkdir -p ${build_dir}
> +  cd ${build_dir}
> +  %if %{pkgconfig check vdeplug}
> +    VDE_CONFIG="--enable-vde"
> +    VDE_CFLAGS="%{pkgconfig cflags vdeplug}"
> +    VDE_LDFLAGS="%{pkgconfig ldflags vdeplug} %{pkgconfig libs vdeplug}"
> +  %endif
> +  %{host_build_flags}
> +  if test "%{_build}" != "%{_host}" ; then
> +    CROSS_PREFIX_OPTION="--cross-prefix=%{_host}-"
> +  fi
> +  SYSROOT=$SB_TMPPREFIX
> +  # The --extra-cflags and --extra-ldflags do not work as expected.
> +  # Hack warning: MSYS2 does not seem to convert the path to
> +  #               a shell path from Windows so we keep them
> +  #               separate and handle it in the pkgconfig tool.
> +  PKG_CONFIG_DEFAULT_PATH=${PKG_CONFIG_PATH} \
> +  PKG_CONFIG_PATH=$SYSROOT/lib/pkgconfig \
> +  PKG_CONFIG_BUILD_TOP_DIR=$SB_TMPROOT \
> +  %{_ld_library_path}=$SYSROOT/lib \
> +  LDFLAGS="-Wl,-rpath -Wl,/$SB_PREFIX_CLEAN/lib ${VDE_LDFLAGS}" \
> +  CFLAGS="${CFLAGS} ${VDE_CFLAGS}" \
> +  ../${source_dir_qemu}/configure \
> +    --prefix=%{_prefix} \
> +    ${CROSS_PREFIX_OPTION} \
> +    --make=%{__make} \
> +    --target-list=%{?with_qemu_archs:%{with_qemu_archs}}\
> +                  %{!?with_qemu_archs:%{qemu_archs}} \
> +    ${VDE_CONFIG} \
> +    --disable-smartcard-nss \
> +    --disable-tools \
> +    --disable-pie \
> +    --disable-vnc \
> +    --disable-sdl \
> +    --disable-gtk \
> +    --disable-opengl \
> +    --disable-netmap \
> +    --disable-werror \
Some of these lines have white space at the end which seems wrong.
> +    --disable-virtfs \
> +    --disable-docs
Does the standard qemu build with these added?
> +  %{__make} %{?_smp_mflags} all
> +  cd ${build_top}
> +%install
> +  build_top=$(pwd)
> +  %{__rmdir} $SB_BUILD_ROOT
> +  cd ${build_dir}
> +  %{__make} DESTDIR=$SB_BUILD_ROOT install
> +  cd ${build_top}
