Improve coverage analysis toolset
Vijay Kumar Banerjee vijaykumar9597 at gmail.com
Tue Apr 3 19:35:38 UTC 2018
On 3 April 2018 at 03:58, Chris Johns <chrisj at rtems.org> wrote:
> On 03/04/2018 02:10, Cillian O'Donnell wrote:
> > Sure if you want to crack at it.
> > If you pull the ini-update branch again, I've included the other files
> you'll need.
> > Now if you try and run rtems-test with coverage you will get
> > cpod at cpod ~ $ $HOME/development/rtems/test/rtems-tools/tester/rtems-test
> > --rtems-tools=$HOME/development/rtems/5 --log=coverage-analysis.log
> > --rtems-bsp=leon3_qemu --coverage --rtems-builddir=$HOME/
> development/rtems/leon3
> > sparc-rtems5/c/leon3/testsuites/samples
> > RTEMS Testing - Tester, 5 (80a1e6d9607e)
> > Traceback (most recent call last):
> >   File "/home/cpod/development/rtems/test/rtems-tools/tester/rtems-test",
> line
> > 40, in <module>
> >     rt.test.run()
> >   File "/home/cpod/development/rtems/test/rtems-tools/tester/rt/test.py",
> line
> > 310, in run
> >     coverage = coverage_get_obj(opts, path_to_builddir[1])
> line
> > 230, in coverage_get_obj
> >     coverage_obj = coverage.coverage_run(opts.defaults,
> path_to_builddir)
> coverage.py",
> > line 329, in __init__
> >     self.config_map = self.macros.macros['coverage']
I managed was getting these errors yesterday after pulling the changes but
for some reason it's not working as expected , now .
It's giving the error :
 error: mandatory item not found in bsp section: bsp
where can this error be coming from ?
> I would not access the 'macros' dictionary directly like this. It
> circumvents
> the map support. There is '__getitem__' support on the class which is
> better but
> still raises an exception on an index error. You can ask if a key is
> present and
> the 'get()' interface returns 'None' if not found.
> > KeyError: 'coverage'
> Can we please create new threads for new topics?
> Thanks
> Chris
Thanks
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180404/df5802b7/attachment-0002.html>
