[PATCH] setting raw in get_items
Vijay Kumar Banerjee vijaykumar9597 at gmail.com
Wed Apr 11 05:04:27 UTC 2018
I was using Python 3, I just checked that it works fine with Python2.7
without the changes mentioned in the patch.
On 11 April 2018 at 06:20, Chris Johns <chrisj at rtems.org> wrote:
> On 11/04/2018 07:04, vijaykumar9597 at gmail.com wrote:
> > From: thelunatic <vijaykumar9597 at gmail.com>
> >  rtemstoolkit/configuration.py | 4 ++--
> >  2 files changed, 3 insertions(+), 2 deletions(-)
> > diff --git a/rtemstoolkit/configuration.py b/rtemstoolkit/configuration.
> py
> > index 10d97e5..53ad79b 100644
> > --- a/rtemstoolkit/configuration.py
> > +++ b/rtemstoolkit/configuration.py
> > @@ -98,7 +98,7 @@ class configuration:
> >      def get_items(self, section, err = True, flatten = True):
> >          try:
> >              items = []
> > -            for name, key in self.config.items(section):
> > +            for name, key in self.config.items(section,raw=True):
> As stated in another email, this breaks Python 2.7 users where
> interpolation is
> being used. It is a requirement for this module to support interpolation
> and to
> support it to the level Python 3 has. This is why this module has
> functionality
> specific to Python 2.7.
> I suspect there is a problem else where in the code. I have not looked to
> see
> what the problem is you are having.
> >                  if flatten:
> >                      items += [(name, key.replace(os.linesep, ' '))]
> >                  else:
> > @@ -117,7 +117,7 @@ class configuration:
> >      def get_item_names(self, section, err = True):
> >          try:
> > -            return [item[0] for item in self.config.items(section)]
> > +            return [item[0] for item in self.config.items(section,raw=
> True)]
> Sorry, this change is not going to be accepted in the rtems-tools repo.
> FYI all the Python code we have has spaces after the ',' and between '='.
> You
> will find it easier to get patches accept by following the coding standard
> that
> is already present.
> I will keep this in mind .
> Thanks
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180411/f41bd933/attachment-0002.html>
