error while running rtems-test with coverage
Vijay Kumar Banerjee vijaykumar9597 at gmail.com
Fri Apr 13 05:39:29 UTC 2018
I manually built qemu from here
https://github.com/AdaCore/qemu
I guess this is regular qemu , please send a link for couverture qemu for
manual build.
-- vijay
On 12 April 2018 at 22:23, Cillian O'Donnell <cpodonnell8 at gmail.com> wrote:
> Ah that's good progress, those .cov files are supposed to be generated by
> couverture-qemu as the test are run. They contain the trace data. Are you
> definitely running couverture-qemu and not regular qemu?
> On Thu, 12 Apr 2018, 17:41 Vijay Kumar Banerjee, <vijaykumar9597 at gmail.com>
> wrote:
>> I got the parsing of the coverage from the ini file running , now I'm
>> getting the following error and warnings .
>> Running covoar for score
>> WARNING: Unable to read coverage file /home/lunatic/development/
>> rtems/kernel/leon3/sparc-rtems5/c/leon3/testsuites/
>> samples/base_sp/base_sp.exe.cov
>> samples/capture/capture.exe.cov
>> samples/cdtest/cdtest.exe.cov
>> samples/fileio/fileio.exe.cov
>> samples/hello/hello.exe.cov
>> samples/iostream/cxx_iostream.exe.cov
>> samples/loopback/loopback.exe.cov
>> samples/minimum/minimum.exe.cov
>> samples/nsecs/nsecs.exe.cov
>> samples/paranoia/paranoia.exe.cov
>> samples/pppd/pppd.exe.cov
>> samples/ticker/ticker.exe.cov
>> samples/unlimited/unlimited.exe.cov
>> ERROR: No information to analyze
>> ***Cleaning tempfiles***
>> error: covoar failure exit code: 1
>> -- vijay
>> On 10 April 2018 at 18:10, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com
>> > wrote:
>>> I managed to get the tests running with the following two patches .
>>> Please review them .
>>> -- vijay
>>> On 9 April 2018 at 15:28, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com
>>> > wrote:
>>>> On Fri, 6 Apr 2018, 02:24 Vijay Kumar Banerjee, <
>>>> vijaykumar9597 at gmail.com> wrote:
>>>>> I tried to solve the empty get in the way shown in the patch , but it
>>>>> doesn't seems to work, I'm getting the following error now
>>>>> RTEMS Testing - Tester, 5 (1ed6e2e64090)
>>>>> Traceback (most recent call last):
>>>>>   File "/home/lunatic/development/rtems/rtems-tools/tester/rtems-test",
>>>>> line 40, in <module>
>>>>>     rt.test.run()
>>>>>   File "/home/lunatic/development/rtems/rtems-tools/tester/rt/test.py",
>>>>> line 303, in run
>>>>>     bsp = config.load(bsp[1], opts)
>>>>>   File "/home/lunatic/development/rtems/rtems-tools/tester/rt/config.py",
>>>>> line 461, in load
>>>>>     return opts.defaults['bsp']
>>>>>   File "/home/lunatic/development/rtems/rtems-tools/rtemstoolkit/macros.py",
>>>>> line 190, in __getitem__
>>>>>     raise IndexError('key: %s' % (key))
>>>>> IndexError: key: bsp
>>>>> I still Couldn't figure out why it's happening, when I use
>>>> RawConfigParse , it seems to run nicely though .
>>>> Any Ideas on solving it without using RawConfigParser ?
>>>>> -- vijay
>>>>> On 5 April 2018 at 11:51, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>>> wrote:
>>>>>> On Wed, 4 Apr 2018, 11:18 Vijay Kumar Banerjee, <
>>>>>>> I got the rtems-test running
>>>>>>> I found that get_item_names(section, err) in configuration.py  was
>>>>>>> returning an empty list to the
>>>>>>> item_names in load(bsp,opts) for config.py this was giving out the
>>>>>>> error mandatory item not found .
>>>>>>> I have attached the patch file .
>>>>>>> current status :
>>>>>>> rtems-test is running without coverage
>>>>>>> running coverage gives the following error :
>>>>>>> RTEMS Testing - Tester, 5 (092c569e81ae)
>>>>>>>     rt.test.run()
>>>>>>> line 310, in run
>>>>>>>     coverage = coverage_get_obj(opts, path_to_builddir[1])
>>>>>>> line 230, in coverage_get_obj
>>>>>>>     coverage_obj = coverage.coverage_run(opts.defaults,
>>>>>>> path_to_builddir)
>>>>>>>   File "/home/lunatic/development/rtems/rtems-tools/tester/rt/coverage.py",
>>>>>>> line 335, in __init__
>>>>>>>     self.report_format = self.config_map['report_format'][2]
>>>>>> This is back to the difference in cfg formats. It's looking for the
>>>>>> last line here
>>>>>> https://github.com/cillianodonnell/rtems-tools/
>>>>>> blob/coverage/tester/rtems/testing/bsps/leon3-qemu.mc
>>>>>> Which is now
>>>>>> blob/ini-update/tester/rtems/testing/bsps/leon3_qemu.ini
>>>>>> It's trying to grab the 'html' text so it can trigger the right
>>>>>> section of code in coverage.py
>>>>>> It's something just to tell which format we want the report to output
>>>>> Understood , I'll come to that after I manage to get the test running
>>>>> first .
>>>>>> TypeError: 'NoneType' object has no attribute '__getitem__'
>>>>>>> Thanks
>>>>>>> -- vijay
>>>>>>> On 4 April 2018 at 11:16, Chris Johns <chrisj at rtems.org> wrote:
>>>>>>>> On 04/04/2018 06:36, Vijay Kumar Banerjee wrote:
>>>>>>>> > after pulling the ini-update branch from
>>>>>>>> > https://github.com/cillianodonnell/rtems-tools/tree/ini-update
>>>>>>>> Any local changes?
>>>>>>>> > I tried running the rtems-test with the following command
>>>>>>>> > $HOME/development/rtems/rtems-tools/tester/rtems-test
>>>>>>>> > --rtems-tools=$HOME/development/rtems/5
>>>>>>>> --log=coverage_analysis.log
>>>>>>>> > --rtems-bsp=leon3_qemu --rtems-builddir=$HOME/
>>>>>>>> development/rtems/kernel/leon3
>>>>>>>> > sparc-rtems5/c/leon3/testsuites/samples
>>>>>>>> > was getting the KeyError for 'coverage'
>>>>>>>> Please paste the command and output as it appears in the terminal?
>>>>>>>> > current status :
>>>>>>>> > the same command gives the error :
>>>>>>>> > "mandatory item not found in bsp section : bsp,"
>>>>>>>> > to make sure I didn't break something , I also tried running from
>>>>>>>> a freshly
>>>>>>>> > downloaded directory as well, it gives the same error.
>>>>>>>> Did you try running the following command from the top of the
>>>>>>>> source tree:
>>>>>>>>  $ grep -r "mandatory item not found" *
>>>>>>>> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180413/6bf08b48/attachment-0002.html>
