error while running rtems-test with coverage
Vijay Kumar Banerjee vijaykumar9597 at gmail.com
Fri Apr 13 12:51:58 UTC 2018
I haven't made any local changes to qemu.cfg
-- vijay
On 13 April 2018 at 11:43, Cillian O'Donnell <cpodonnell8 at gmail.com> wrote:
> No that's the right one. I think it might be something to do with qemu.cfg
> in rtems-tools then. What's in your qemu.cfg? It's in
> rtems-tools/tester/rtems/testing
> On Fri, 13 Apr 2018, 06:39 Vijay Kumar Banerjee, <vijaykumar9597 at gmail.com>
> wrote:
>> I manually built qemu from here
>> https://github.com/AdaCore/qemu
>> I guess this is regular qemu , please send a link for couverture qemu for
>> manual build.
>> -- vijay
>> On 12 April 2018 at 22:23, Cillian O'Donnell <cpodonnell8 at gmail.com>
>> wrote:
>>> Ah that's good progress, those .cov files are supposed to be generated
>>> by couverture-qemu as the test are run. They contain the trace data. Are
>>> you definitely running couverture-qemu and not regular qemu?
>>> On Thu, 12 Apr 2018, 17:41 Vijay Kumar Banerjee, <
>>> vijaykumar9597 at gmail.com> wrote:
>>>> I got the parsing of the coverage from the ini file running , now I'm
>>>> getting the following error and warnings .
>>>> Running covoar for score
>>>> WARNING: Unable to read coverage file /home/lunatic/development/
>>>> rtems/kernel/leon3/sparc-rtems5/c/leon3/testsuites/
>>>> samples/base_sp/base_sp.exe.cov
>>>> samples/capture/capture.exe.cov
>>>> samples/cdtest/cdtest.exe.cov
>>>> samples/fileio/fileio.exe.cov
>>>> samples/hello/hello.exe.cov
>>>> samples/iostream/cxx_iostream.exe.cov
>>>> samples/loopback/loopback.exe.cov
>>>> samples/minimum/minimum.exe.cov
>>>> samples/nsecs/nsecs.exe.cov
>>>> samples/paranoia/paranoia.exe.cov
>>>> samples/pppd/pppd.exe.cov
>>>> samples/ticker/ticker.exe.cov
>>>> samples/unlimited/unlimited.exe.cov
>>>> ERROR: No information to analyze
>>>> ***Cleaning tempfiles***
>>>> error: covoar failure exit code: 1
>>>> -- vijay
>>>> On 10 April 2018 at 18:10, Vijay Kumar Banerjee <
>>>>> I managed to get the tests running with the following two patches .
>>>>> Please review them .
>>>>> -- vijay
>>>>> On 9 April 2018 at 15:28, Vijay Kumar Banerjee <
>>>>>> On Fri, 6 Apr 2018, 02:24 Vijay Kumar Banerjee, <
>>>>>>> I tried to solve the empty get in the way shown in the patch , but
>>>>>>> it doesn't seems to work, I'm getting the following error now
>>>>>>> RTEMS Testing - Tester, 5 (1ed6e2e64090)
>>>>>>> Traceback (most recent call last):
>>>>>>>   File "/home/lunatic/development/rtems/rtems-tools/tester/rtems-test",
>>>>>>> line 40, in <module>
>>>>>>>     rt.test.run()
>>>>>>>   File "/home/lunatic/development/rtems/rtems-tools/tester/rt/test.py",
>>>>>>> line 303, in run
>>>>>>>     bsp = config.load(bsp[1], opts)
>>>>>>>   File "/home/lunatic/development/rtems/rtems-tools/tester/rt/config.py",
>>>>>>> line 461, in load
>>>>>>>     return opts.defaults['bsp']
>>>>>>>   File "/home/lunatic/development/rtems/rtems-tools/rtemstoolkit/macros.py",
>>>>>>> line 190, in __getitem__
>>>>>>>     raise IndexError('key: %s' % (key))
>>>>>>> IndexError: key: bsp
>>>>>>> I still Couldn't figure out why it's happening, when I use
>>>>>> RawConfigParse , it seems to run nicely though .
>>>>>> Any Ideas on solving it without using RawConfigParser ?
>>>>>>> -- vijay
>>>>>>> On 5 April 2018 at 11:51, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>>>>> wrote:
>>>>>>>> On Wed, 4 Apr 2018, 11:18 Vijay Kumar Banerjee, <
>>>>>>>>> I got the rtems-test running
>>>>>>>>> I found that get_item_names(section, err) in configuration.py  was
>>>>>>>>> returning an empty list to the
>>>>>>>>> item_names in load(bsp,opts) for config.py this was giving out the
>>>>>>>>> error mandatory item not found .
>>>>>>>>> I have attached the patch file .
>>>>>>>>> current status :
>>>>>>>>> rtems-test is running without coverage
>>>>>>>>> running coverage gives the following error :
>>>>>>>>> RTEMS Testing - Tester, 5 (092c569e81ae)
>>>>>>>>>     rt.test.run()
>>>>>>>>> line 310, in run
>>>>>>>>>     coverage = coverage_get_obj(opts, path_to_builddir[1])
>>>>>>>>> line 230, in coverage_get_obj
>>>>>>>>>     coverage_obj = coverage.coverage_run(opts.defaults,
>>>>>>>>> path_to_builddir)
>>>>>>>>>   File "/home/lunatic/development/rtems/rtems-tools/tester/rt/coverage.py",
>>>>>>>>> line 335, in __init__
>>>>>>>>>     self.report_format = self.config_map['report_format'][2]
>>>>>>>> This is back to the difference in cfg formats. It's looking for the
>>>>>>>> last line here
>>>>>>>> https://github.com/cillianodonnell/rtems-tools/
>>>>>>>> blob/coverage/tester/rtems/testing/bsps/leon3-qemu.mc
>>>>>>>> Which is now
>>>>>>>> blob/ini-update/tester/rtems/testing/bsps/leon3_qemu.ini
>>>>>>>> It's trying to grab the 'html' text so it can trigger the right
>>>>>>>> section of code in coverage.py
>>>>>>>> It's something just to tell which format we want the report to
>>>>>>>> output
>>>>>>> Understood , I'll come to that after I manage to get the test
>>>>>>> running first .
>>>>>>>> TypeError: 'NoneType' object has no attribute '__getitem__'
>>>>>>>>> Thanks
>>>>>>>>> -- vijay
>>>>>>>>> On 4 April 2018 at 11:16, Chris Johns <chrisj at rtems.org> wrote:
>>>>>>>>>> On 04/04/2018 06:36, Vijay Kumar Banerjee wrote:
>>>>>>>>>> > after pulling the ini-update branch from
>>>>>>>>>> > https://github.com/cillianodonnell/rtems-tools/tree/ini-update
>>>>>>>>>> Any local changes?
>>>>>>>>>> > I tried running the rtems-test with the following command
>>>>>>>>>> > $HOME/development/rtems/rtems-tools/tester/rtems-test
>>>>>>>>>> > --rtems-tools=$HOME/development/rtems/5
>>>>>>>>>> --log=coverage_analysis.log
>>>>>>>>>> > --rtems-bsp=leon3_qemu --rtems-builddir=$HOME/
>>>>>>>>>> development/rtems/kernel/leon3
>>>>>>>>>> > sparc-rtems5/c/leon3/testsuites/samples
>>>>>>>>>> > was getting the KeyError for 'coverage'
>>>>>>>>>> Please paste the command and output as it appears in the terminal?
>>>>>>>>>> > current status :
>>>>>>>>>> > the same command gives the error :
>>>>>>>>>> > "mandatory item not found in bsp section : bsp,"
>>>>>>>>>> > to make sure I didn't break something , I also tried running
>>>>>>>>>> from a freshly
>>>>>>>>>> > downloaded directory as well, it gives the same error.
>>>>>>>>>> Did you try running the following command from the top of the
>>>>>>>>>> source tree:
>>>>>>>>>>  $ grep -r "mandatory item not found" *
>>>>>>>>>> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180413/506c2b6a/attachment-0002.html>
