error while running rtems-test with coverage
Vijay Kumar Banerjee vijaykumar9597 at gmail.com
Fri Apr 13 17:29:16 UTC 2018
It shows the following error
RTEMS Testing - Tester, 5 (58acb6d61ac7 modified)
Coverage environment prepared
[ 3/13] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:0  W:0  | sparc/leon3_qemu:
cdtest.exe
[ 1/13] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:0  W:0  | sparc/leon3_qemu:
base_sp.exe
[ 2/13] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:0  W:0  | sparc/leon3_qemu:
capture.exe
[ 4/13] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:0  W:0  | sparc/leon3_qemu:
fileio.exe
error: qemu.cfg:77: macro '%{coverage_supported}' not found
warning: switched to dry run due to errors
error: qemu.cfg:77: invalid if bool value:  %if %{coverage_supported}
Traceback (most recent call last):
  File
"/home/lunatic/development/rtems/test/rtems-tools/tester/rtems-test", line
40, in <module>
    rt.test.run()
  File
"/home/lunatic/development/rtems/test/rtems-tools/tester/rt/test.py", line
353, in run
    tst.reraise()
  File
160, in reraise
    _test_reraise(*self.result)
NameError: global name '_test_reraise' is not defined
-- vijay
On 13 April 2018 at 22:54, Cillian O'Donnell <cpodonnell8 at gmail.com> wrote:
> Ah yes, your missing the qemu arguments to run the coverage. Try this
> # Coverage analysis
> %define coverage_arg %{nil}
> %if %{defined _coverage}
>         %define coverage_arg -exec-trace %{test_executable}.cov
>     %else
>         %error "Coverage analysis unsupported for %{bsp}"
>     %endif
> %endif
> # Executable
> %execute %{qemu_cmd} %{qemu_opts_base} %{qemu_opts} -kernel %{test_executable} %{coverage_arg}
> On Fri, 13 Apr 2018, 18:18 Vijay Kumar Banerjee, <vijaykumar9597 at gmail.com>
> wrote:
>> sure
>> # RTEMS Tools Project (http://www.rtems.org/)
>> # Copyright 2010-2014 Chris Johns (chrisj at rtems.org)
>> # All rights reserved.
>> # This file is part of the RTEMS Tools package in 'rtems-tools'.
>> # Redistribution and use in source and binary forms, with or without
>> # modification, are permitted provided that the following conditions are
>> met:
>> # 1. Redistributions of source code must retain the above copyright
>> notice,
>> # this list of conditions and the following disclaimer.
>> # 2. Redistributions in binary form must reproduce the above copyright
>> notice,
>> # this list of conditions and the following disclaimer in the
>> documentation
>> # and/or other materials provided with the distribution.
>> # THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS
>> IS"
>> # AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
>> THE
>> # IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
>> PURPOSE
>> # ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS
>> BE
>> # LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
>> # CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
>> # SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
>> # INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
>> # CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
>> # ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF
>> THE
>> # POSSIBILITY OF SUCH DAMAGE.
>> # QEMU
>> # Use a qemu command to run the executable in the qemu simulator.
>> %include %{_configdir}/base.cfg
>> %include %{_configdir}/checks.cfg
>> # Console.
>> %define console_stdio
>> %include %{_configdir}/console.cfg
>> # RTEMS version
>> %include %{_rtdir}/rtems/version.cfg
>> # Qemu common option patterns.
>> #%define qemu_opts_base   -no-reboot -monitor none -serial stdio
>> -nographic
>> #%define qemu_opts_base   -no-reboot -serial null -serial mon:stdio
>> -nographic
>> %define qemu_opts_base  -no-reboot -monitor null -serial stdio -nographic
>> %define qemu_opts_no_net -net none
>> # Qemu executable
>> %ifn %{defined bsp_qemu_opts}
>>  %define bsp_qemu_opts %{nil}
>> %endif
>> %define qemu_cmd  qemu-system-%{bsp_arch}
>> %define qemu_opts %{bsp_qemu_opts}
>> # Executable
>> %execute %{qemu_cmd} %{qemu_opts} -kernel %{test_executable}
>> -- vijay
>> On 13 April 2018 at 22:19, Cillian O'Donnell <cpodonnell8 at gmail.com>
>> wrote:
>>> Yeah that's fine but can you just paste the contents here anyway. I'm
>>> not near a laptop and I can't remember which branch your starting from.
>>> On Fri, 13 Apr 2018, 13:51 Vijay Kumar Banerjee, <
>>> vijaykumar9597 at gmail.com> wrote:
>>>> I haven't made any local changes to qemu.cfg
>>>> -- vijay
>>>> On 13 April 2018 at 11:43, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>> wrote:
>>>>> No that's the right one. I think it might be something to do with
>>>>> qemu.cfg in rtems-tools then. What's in your qemu.cfg? It's in
>>>>> rtems-tools/tester/rtems/testing
>>>>> On Fri, 13 Apr 2018, 06:39 Vijay Kumar Banerjee, <
>>>>>> I manually built qemu from here
>>>>>> https://github.com/AdaCore/qemu
>>>>>> I guess this is regular qemu , please send a link for couverture
>>>>>> qemu for manual build.
>>>>>> -- vijay
>>>>>> On 12 April 2018 at 22:23, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>>>> wrote:
>>>>>>> Ah that's good progress, those .cov files are supposed to be
>>>>>>> generated by couverture-qemu as the test are run. They contain the trace
>>>>>>> data. Are you definitely running couverture-qemu and not regular qemu?
>>>>>>> On Thu, 12 Apr 2018, 17:41 Vijay Kumar Banerjee, <
>>>>>>>> I got the parsing of the coverage from the ini file running , now
>>>>>>>> I'm getting the following error and warnings .
>>>>>>>> Running covoar for score
>>>>>>>> WARNING: Unable to read coverage file /home/lunatic/development/
>>>>>>>> rtems/kernel/leon3/sparc-rtems5/c/leon3/testsuites/
>>>>>>>> samples/base_sp/base_sp.exe.cov
>>>>>>>> samples/capture/capture.exe.cov
>>>>>>>> samples/cdtest/cdtest.exe.cov
>>>>>>>> samples/fileio/fileio.exe.cov
>>>>>>>> samples/hello/hello.exe.cov
>>>>>>>> samples/iostream/cxx_iostream.exe.cov
>>>>>>>> samples/loopback/loopback.exe.cov
>>>>>>>> samples/minimum/minimum.exe.cov
>>>>>>>> samples/nsecs/nsecs.exe.cov
>>>>>>>> samples/paranoia/paranoia.exe.cov
>>>>>>>> samples/pppd/pppd.exe.cov
>>>>>>>> samples/ticker/ticker.exe.cov
>>>>>>>> samples/unlimited/unlimited.exe.cov
>>>>>>>> ERROR: No information to analyze
>>>>>>>> ***Cleaning tempfiles***
>>>>>>>> error: covoar failure exit code: 1
>>>>>>>> -- vijay
>>>>>>>> On 10 April 2018 at 18:10, Vijay Kumar Banerjee <
>>>>>>>>> I managed to get the tests running with the following two patches .
>>>>>>>>> Please review them .
>>>>>>>>> -- vijay
>>>>>>>>> On 9 April 2018 at 15:28, Vijay Kumar Banerjee <
>>>>>>>>>> On Fri, 6 Apr 2018, 02:24 Vijay Kumar Banerjee, <
>>>>>>>>>>> I tried to solve the empty get in the way shown in the patch ,
>>>>>>>>>>> but it doesn't seems to work, I'm getting the following error now
>>>>>>>>>>> RTEMS Testing - Tester, 5 (1ed6e2e64090)
>>>>>>>>>>>   File "/home/lunatic/development/rtems/rtems-tools/tester/rtems-test",
>>>>>>>>>>> line 40, in <module>
>>>>>>>>>>>     rt.test.run()
>>>>>>>>>>>   File "/home/lunatic/development/rtems/rtems-tools/tester/rt/test.py",
>>>>>>>>>>> line 303, in run
>>>>>>>>>>>     bsp = config.load(bsp[1], opts)
>>>>>>>>>>>   File "/home/lunatic/development/rtems/rtems-tools/tester/rt/config.py",
>>>>>>>>>>> line 461, in load
>>>>>>>>>>>     return opts.defaults['bsp']
>>>>>>>>>>>   File "/home/lunatic/development/rtems/rtems-tools/rtemstoolkit/macros.py",
>>>>>>>>>>> line 190, in __getitem__
>>>>>>>>>>>     raise IndexError('key: %s' % (key))
>>>>>>>>>>> IndexError: key: bsp
>>>>>>>>>>> I still Couldn't figure out why it's happening, when I use
>>>>>>>>>> RawConfigParse , it seems to run nicely though .
>>>>>>>>>> Any Ideas on solving it without using RawConfigParser ?
>>>>>>>>>>> -- vijay
>>>>>>>>>>> On 5 April 2018 at 11:51, Cillian O'Donnell <
>>>>>>>>>>>> On Wed, 4 Apr 2018, 11:18 Vijay Kumar Banerjee, <
>>>>>>>>>>>>> I got the rtems-test running
>>>>>>>>>>>>> I found that get_item_names(section, err) in configuration.py
>>>>>>>>>>>>> was returning an empty list to the
>>>>>>>>>>>>> item_names in load(bsp,opts) for config.py this was giving out
>>>>>>>>>>>>> the error mandatory item not found .
>>>>>>>>>>>>> I have attached the patch file .
>>>>>>>>>>>>> current status :
>>>>>>>>>>>>> rtems-test is running without coverage
>>>>>>>>>>>>> running coverage gives the following error :
>>>>>>>>>>>>> RTEMS Testing - Tester, 5 (092c569e81ae)
>>>>>>>>>>>>>     rt.test.run()
>>>>>>>>>>>>> line 310, in run
>>>>>>>>>>>>>     coverage = coverage_get_obj(opts, path_to_builddir[1])
>>>>>>>>>>>>> line 230, in coverage_get_obj
>>>>>>>>>>>>>     coverage_obj = coverage.coverage_run(opts.defaults,
>>>>>>>>>>>>> path_to_builddir)
>>>>>>>>>>>>>   File "/home/lunatic/development/rtems/rtems-tools/tester/rt/coverage.py",
>>>>>>>>>>>>> line 335, in __init__
>>>>>>>>>>>>>     self.report_format = self.config_map['report_format'][2]
>>>>>>>>>>>> This is back to the difference in cfg formats. It's looking for
>>>>>>>>>>>> the last line here
>>>>>>>>>>>> https://github.com/cillianodonnell/rtems-tools/
>>>>>>>>>>>> blob/coverage/tester/rtems/testing/bsps/leon3-qemu.mc
>>>>>>>>>>>> Which is now
>>>>>>>>>>>> blob/ini-update/tester/rtems/testing/bsps/leon3_qemu.ini
>>>>>>>>>>>> It's trying to grab the 'html' text so it can trigger the right
>>>>>>>>>>>> section of code in coverage.py
>>>>>>>>>>>> It's something just to tell which format we want the report to
>>>>>>>>>>>> output
>>>>>>>>>>> Understood , I'll come to that after I manage to get the test
>>>>>>>>>>> running first .
>>>>>>>>>>>> TypeError: 'NoneType' object has no attribute '__getitem__'
>>>>>>>>>>>>> Thanks
>>>>>>>>>>>>> -- vijay
>>>>>>>>>>>>> On 4 April 2018 at 11:16, Chris Johns <chrisj at rtems.org>
>>>>>>>>>>>>> wrote:
>>>>>>>>>>>>>> On 04/04/2018 06:36, Vijay Kumar Banerjee wrote:
>>>>>>>>>>>>>> > after pulling the ini-update branch from
>>>>>>>>>>>>>> tree/ini-update
>>>>>>>>>>>>>> Any local changes?
>>>>>>>>>>>>>> > I tried running the rtems-test with the following command
>>>>>>>>>>>>>> > $HOME/development/rtems/rtems-tools/tester/rtems-test
>>>>>>>>>>>>>> > --rtems-tools=$HOME/development/rtems/5
>>>>>>>>>>>>>> --log=coverage_analysis.log
>>>>>>>>>>>>>> > --rtems-bsp=leon3_qemu --rtems-builddir=$HOME/
>>>>>>>>>>>>>> development/rtems/kernel/leon3
>>>>>>>>>>>>>> > sparc-rtems5/c/leon3/testsuites/samples
>>>>>>>>>>>>>> > was getting the KeyError for 'coverage'
>>>>>>>>>>>>>> Please paste the command and output as it appears in the
>>>>>>>>>>>>>> terminal?
>>>>>>>>>>>>>> > current status :
>>>>>>>>>>>>>> > the same command gives the error :
>>>>>>>>>>>>>> > "mandatory item not found in bsp section : bsp,"
>>>>>>>>>>>>>> > to make sure I didn't break something , I also tried
>>>>>>>>>>>>>> running from a freshly
>>>>>>>>>>>>>> > downloaded directory as well, it gives the same error.
>>>>>>>>>>>>>> Did you try running the following command from the top of the
>>>>>>>>>>>>>> source tree:
>>>>>>>>>>>>>>  $ grep -r "mandatory item not found" *
>>>>>>>>>>>>>> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180413/0b864a2e/attachment-0002.html>
