error while running rtems-test with coverage
Cillian O'Donnell
cpodonnell8 at gmail.com
Sat Apr 14 11:12:19 UTC 2018
On 14 April 2018 at 07:11, Chris Johns <chrisj at rtems.org> wrote:
> On 14/4/18 8:02 am, Vijay Kumar Banerjee wrote:
>> Getting this error now seems like something is missing.
>> RTEMS Testing - Tester, 5 (b2ba08b0da42 modified)
>> Coverage environment prepared
>> Traceback (most recent call last):
>> File "/home/lunatic/development/rtems/test/rtems-tools/tester/rtems-test",
>> line 40, in <module>
>> rt.test.run()
>> File "/home/lunatic/development/rtems/test/rtems-tools/tester/rt/test.py",
>> line 353, in run
>> tst.reraise()
>> line 160, in reraise
>> _test_reraise(*self.result)
>> NameError: global name '_test_reraise' is not defined
> The reraise logic was moved to the rtemstoolkit last year:
> https://git.rtems.org/rtems-tools/commit/?id=fa81491764861e6
> 3785a3faa241c488469087209
> It had some issues that have been fixed and it is being reused else where
> in the tester.
>> -- vijay
>> On 13 April 2018 at 23:57, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com
>> <mailto:vijaykumar9597 at gmail.com>> wrote:
>> On 13 April 2018 at 23:51, Cillian O'Donnell <cpodonnell8 at gmail.com
>> <mailto:cpodonnell8 at gmail.com>> wrote:
>> Hmmm it's not there. Even so I can almost guarantee you, the
>> reason it's not running is that coverage_supported variable is
>> not being found as true in qemu.cfg and so the the command to
>> generated the trace files isn't run and there's no .cov files in
>> the end. So that's what you'll have to dig into.
>> Okay , I'll set it to global then.
> Changes need to be on the latest version of master before I will review
> them. The failure above indicate the code you have is not up to date.
Yes that was the plan. Just to check Vijay your starting point was using
the ini-update branch from here?
https://github.com/cillianodonnell/rtems-tools/tree/ini-update
That branch is current rtems-tools master that I started to add things back
in. The only reraise in there is the one improrted from rtemstoolkit.
> The change you have made is generating an exception in the tester thread.
> If you want to continue down this path you will need to fix what ever you
> have added.
> The tests are run as threads separate from the main thread so the
> exception is caught and re-raised in the main thread letting you know. This
> is broken in the old code base you are using.
> Why not investigate the reason as indicated and sort if out what the new
> format configuration file needs?
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180414/b7570aea/attachment-0002.html>
