error while running rtems-test with coverage
Vijay Kumar Banerjee vijaykumar9597 at gmail.com
Sun Apr 15 08:35:07 UTC 2018
On 15 April 2018 at 14:02, Cillian O'Donnell <cpodonnell8 at gmail.com> wrote:
> On 15 April 2018 at 06:46, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
> wrote:
>> On 15 April 2018 at 01:45, Cillian O'Donnell <cpodonnell8 at gmail.com>
>> wrote:
>>> Switch one of these lines out in qemu.cfg.
>>> #%define qemu_opts_base -no-reboot -monitor none -serial stdio
>>> -nographic
>>> #%define qemu_opts_base -no-reboot -serial null -serial mon:stdio
>>> -nographic
>>> %define qemu_opts_base -no-reboot -monitor null -serial stdio -nographic
>>> Just comment out the one that's being used and uncomment one of the
>>> others. It should cause a complaint when the tests are run and the qemu cmd
>>> should show up in the log so we can take a look at it.
>> error: qemu.cfg:71: execute failed: qemu-system-sparc -no-reboot -monitor
>> null -serial stdio -nographic -no-reboot -monitor null -serial stdio
>> -nographic -M leon3_generic -kernel /home/lunatic/development/rtem
>> s/kernel/leon3/sparc-rtems5/c/leon3/testsuites/samples/unlimited/unlimited.exe:
>> exit-code:1
>> run: qemu-system-sparc -no-reboot -monitor null -serial stdio -nographic
>> -no-reboot -mo    nitor null -serial stdio -nographic -M leon3_generic
>> -kernel /home/lunatic/development/rtem    s/kernel/leon3/sparc-rtems5/c/
>> leon3/testsuites/samples/unlimited/unlimited.exe -exec-trace
>>  /home/lunatic/development/rtems/kernel/leon3/sparc-rtems5/
>> c/leon3/testsuites/samples/unlimi    ted/unlimited.exe.cov
> Are those line breaks actually there or is it from the copy and paste.
> Like  unlimi    ted. If so that's definitely the problem. What does your
> last section in qemu.cfg look like now? The execute section.
They are from copy paste .
I'm pasting the qemu.cfg here
# RTEMS Tools Project (http://www.rtems.org/)
# Copyright 2010-2014 Chris Johns (chrisj at rtems.org)
# All rights reserved.
# This file is part of the RTEMS Tools package in 'rtems-tools'.
# Redistribution and use in source and binary forms, with or without
# modification, are permitted provided that the following conditions are
met:
# 1. Redistributions of source code must retain the above copyright notice,
# this list of conditions and the following disclaimer.
# 2. Redistributions in binary form must reproduce the above copyright
notice,
# this list of conditions and the following disclaimer in the documentation
# and/or other materials provided with the distribution.
# this software is provided by the copyright holders and contributors "as
is"
# and any express or implied warranties, including, but not limited to, the
# implied warranties of merchantability and fitness for a particular purpose
# are disclaimed. in no event shall the copyright holder or contributors be
# liable for any direct, indirect, incidental, special, exemplary, or
# consequential damages (including, but not limited to, procurement of
# substitute goods or services; loss of use, data, or profits; or business
# interruption) however caused and on any theory of liability, whether in
# contract, strict liability, or tort (including negligence or otherwise)
# arising in any way out of the use of this software, even if advised of the
# possibility of such damage.
# qemu
# use a qemu command to run the executable in the qemu simulator.
%include %{_configdir}/base.cfg
%include %{_configdir}/checks.cfg
# console.
%define console_stdio
%include %{_configdir}/console.cfg
# rtems version
%include %{_rtdir}/rtems/version.cfg
# qemu common option patterns.
%define qemu_opts_base   -no-reboot -monitor none -serial stdio -nographic
-nographic
#%define qemu_opts_base  -no-reboot -monitor null -serial stdio -nographic
%define qemu_opts_no_net -net none
# qemu executable
%ifn %{defined bsp_qemu_opts}
 %define bsp_qemu_opts %{nil}
%endif
%define qemu_cmd  qemu-system-%{bsp_arch}
%define qemu_opts %{bsp_qemu_opts}
# Coverage analysis
%define coverage_arg %{nil}
%if %{defined _coverage}
    %if %{coverage_supported}
        %define coverage_arg -exec-trace %{test_executable}.cov
    %else
        %error "Coverage analysis unsupported for %{bsp}"
    %endif
%endif
# executable
#%execute %{qemu_cmd} %{qemu_opts} -kernel %{test_executable}
%execute %{qemu_cmd} %{qemu_opts_base} %{qemu_opts} -kernel
%{test_executable} %{coverage_arg}
#%define qemu_opts_base -no-reboot -monitor none -serial stdio -nographic
#%define qemu_opts_base -no-reboot -serial null -serial mon:stdio -nographic
>>> On 14 April 2018 at 20:37, Vijay Kumar Banerjee <
>>> vijaykumar9597 at gmail.com> wrote:
>>>> -- vijay
>>>> On 15 April 2018 at 00:50, Vijay Kumar Banerjee <
>>>>> On 14 April 2018 at 16:42, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>>> wrote:
>>>>>> On 14 April 2018 at 07:11, Chris Johns <chrisj at rtems.org> wrote:
>>>>>>> On 14/4/18 8:02 am, Vijay Kumar Banerjee wrote:
>>>>>>>> Getting this error now seems like something is missing.
>>>>>>>> RTEMS Testing - Tester, 5 (b2ba08b0da42 modified)
>>>>>>>> Coverage environment prepared
>>>>>>>> Traceback (most recent call last):
>>>>>>>>    File "/home/lunatic/development/rte
>>>>>>>> ms/test/rtems-tools/tester/rtems-test", line 40, in <module>
>>>>>>>>      rt.test.run()
>>>>>>>> ms/test/rtems-tools/tester/rt/test.py", line 353, in run
>>>>>>>>      tst.reraise()
>>>>>>>> ms/test/rtems-tools/tester/rt/test.py", line 160, in reraise
>>>>>>>>      _test_reraise(*self.result)
>>>>>>>> NameError: global name '_test_reraise' is not defined
>>>>>>> The reraise logic was moved to the rtemstoolkit last year:
>>>>>>> https://git.rtems.org/rtems-tools/commit/?id=fa81491764861e6
>>>>>>> 3785a3faa241c488469087209
>>>>>>> It had some issues that have been fixed and it is being reused else
>>>>>>> where in the tester.
>>>>>>>> -- vijay
>>>>>>>> On 13 April 2018 at 23:57, Vijay Kumar Banerjee <
>>>>>>>> vijaykumar9597 at gmail.com <mailto:vijaykumar9597 at gmail.com>> wrote:
>>>>>>>>     On 13 April 2018 at 23:51, Cillian O'Donnell <
>>>>>>>>     <mailto:cpodonnell8 at gmail.com>> wrote:
>>>>>>>>         Hmmm it's not there. Even so I can almost guarantee you, the
>>>>>>>>         reason it's not running is that coverage_supported variable
>>>>>>>> is
>>>>>>>>         not being found as true in qemu.cfg and so the the command
>>>>>>>> to
>>>>>>>>         generated the trace files isn't run and there's no .cov
>>>>>>>> files in
>>>>>>>>         the end. So that's what you'll have to dig into.
>>>>>>>>     Okay , I'll set it to global then.
>>>>>>> Changes need to be on the latest version of master before I will
>>>>>>> review them. The failure above indicate the code you have is not up to date.
>>>>>> Yes that was the plan. Just to check Vijay your starting point was
>>>>>> using the ini-update branch from here?
>>>>>> https://github.com/cillianodonnell/rtems-tools/tree/ini-update
>>>>>> That branch is current rtems-tools master that I started to add
>>>>>> things back in. The only reraise in there is the one improrted from
>>>>>> rtemstoolkit.
>>>>> yes this is the branch I'm using , I checked the reraise error , not
>>>>> sure how it showed up buit I called it from the reraise module , and
>>>>> it got fixed . now I'm stuck here
>>>>> error: config error: qemu.cfg:36: No 'target' defined
>>>> okay , fixed that .
>>>> still getting the warnings of the unable to read .cov
>>>>> are we supposed to set the bsp to global as well ?
>>>>>>> The change you have made is generating an exception in the tester
>>>>>>> thread. If you want to continue down this path you will need to fix what
>>>>>>> ever you have added.
>>>>>>> The tests are run as threads separate from the main thread so the
>>>>>>> exception is caught and re-raised in the main thread letting you know. This
>>>>>>> is broken in the old code base you are using.
>>>>>>> Why not investigate the reason as indicated and sort if out what the
>>>>>>> new format configuration file needs?
>>>>>>> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180415/4c114fbc/attachment-0002.html>
