[PATCH] Remove register keyword from public header files
Mon Apr 16 17:25:44 UTC 2018
I'm a bit surprised we had this many left. I thought we had
generally come to agreement not to use register and were
slowly removing it anyway. Feel free to commit
Please update the Coding Conventions to include not
using register.
https://devel.rtems.org/wiki/Developer/Coding/Conventions
--joel
On Mon, Apr 16, 2018 at 12:38 AM, Sebastian Huber <
> The following code
>   void f(void)
>     register int i;
> gives a warning with GCC and -std=c++17
>   test.cc: In function ‘void f()’:
>   test.cc:3:15: warning: ISO C++1z does not allow ‘register’ storage class
>   specifier [-Wregister]
>     register int i;
> and clang with -std=c++14
>   test.cc:3:3: warning: 'register' storage class specifier is deprecated
>   and incompatible with C++1z [-Wdeprecated-register]
>     register int i;
>   1 warning generated.
> Remove the use of the register keyword at least in the public header
> files for C++ compatibility.
> Close #3397.
>  cpukit/score/cpu/i386/include/rtems/score/cpu.h    |  4 +--
>  cpukit/score/cpu/i386/include/rtems/score/i386.h   | 42
>  .../cpu/i386/include/rtems/score/interrupts.h      |  2 +-
>  cpukit/score/cpu/lm32/include/rtems/score/lm32.h   | 10 +++---
>  cpukit/score/cpu/m68k/include/rtems/score/cpu.h    |  6 ++--
>  cpukit/score/cpu/m68k/include/rtems/score/m68k.h   |  8 ++---
>  cpukit/score/cpu/mips/include/rtems/score/mips.h   | 16 ++++-----
>  cpukit/score/cpu/powerpc/include/rtems/score/cpu.h |  4 +--
>  cpukit/score/cpu/riscv/include/rtems/score/cpu.h   |  2 +-
>  cpukit/score/cpu/sh/include/rtems/score/sh.h       |  8 ++---
>  cpukit/score/cpu/sparc/include/rtems/score/sparc.h |  2 +-
>  11 files changed, 52 insertions(+), 52 deletions(-)
> diff --git a/cpukit/score/cpu/i386/include/rtems/score/cpu.h
> b/cpukit/score/cpu/i386/include/rtems/score/cpu.h
> index 777439c6e0..42958c00f0 100644
> --- a/cpukit/score/cpu/i386/include/rtems/score/cpu.h
> +++ b/cpukit/score/cpu/i386/include/rtems/score/cpu.h
> @@ -522,8 +522,8 @@ extern void _CPU_Fatal_halt(uint32_t source, uint32_t
> error)
>  #define _CPU_Bitfield_Find_first_bit( _value, _output ) \
> -    register uint16_t __value_in_register = ( _value ); \
> -    uint16_t          __output = 0; \
> +    uint16_t __value_in_register = ( _value ); \
> +    uint16_t __output = 0; \
>      __asm__ volatile ( "bsfw    %0,%1 " \
>                      : "=r" ( __value_in_register ), "=r" ( __output ) \
>                      : "0"  ( __value_in_register ), "1"  ( __output ) \
> diff --git a/cpukit/score/cpu/i386/include/rtems/score/i386.h
> b/cpukit/score/cpu/i386/include/rtems/score/i386.h
> index 2555d13b8b..4b94e6feeb 100644
> --- a/cpukit/score/cpu/i386/include/rtems/score/i386.h
> +++ b/cpukit/score/cpu/i386/include/rtems/score/i386.h
> @@ -136,7 +136,7 @@ static inline uint16_t i386_swap_u16(
>  static inline unsigned int i386_get_cr0(void)
> -  register unsigned int segment = 0;
> +  unsigned int segment = 0;
>    __asm__ volatile ( "movl %%cr0,%0" : "=r" (segment) : "0" (segment) );
> @@ -150,7 +150,7 @@ static inline void i386_set_cr0(unsigned int segment)
>  static inline unsigned int i386_get_cr2(void)
>    __asm__ volatile ( "movl %%cr2,%0" : "=r" (segment) : "0" (segment) );
> @@ -159,7 +159,7 @@ static inline unsigned int i386_get_cr2(void)
>  static inline unsigned int i386_get_cr3(void)
>    __asm__ volatile ( "movl %%cr3,%0" : "=r" (segment) : "0" (segment) );
> @@ -243,7 +243,7 @@ int i386_Physical_to_real(
>  static __inline__ unsigned short i386_get_cs(void)
> -  register unsigned short segment = 0;
> +  unsigned short segment = 0;
>    __asm__ volatile ( "movw %%cs,%0" : "=r" (segment) : "0" (segment) );
> @@ -252,7 +252,7 @@ static __inline__ unsigned short i386_get_cs(void)
>  static __inline__ unsigned short i386_get_ds(void)
>    __asm__ volatile ( "movw %%ds,%0" : "=r" (segment) : "0" (segment) );
> @@ -261,7 +261,7 @@ static __inline__ unsigned short i386_get_ds(void)
>  static __inline__ unsigned short i386_get_es(void)
>    __asm__ volatile ( "movw %%es,%0" : "=r" (segment) : "0" (segment) );
> @@ -270,7 +270,7 @@ static __inline__ unsigned short i386_get_es(void)
>  static __inline__ unsigned short i386_get_ss(void)
>    __asm__ volatile ( "movw %%ss,%0" : "=r" (segment) : "0" (segment) );
> @@ -279,7 +279,7 @@ static __inline__ unsigned short i386_get_ss(void)
>  static __inline__ unsigned short i386_get_fs(void)
>    __asm__ volatile ( "movw %%fs,%0" : "=r" (segment) : "0" (segment) );
> @@ -288,7 +288,7 @@ static __inline__ unsigned short i386_get_fs(void)
>  static __inline__ unsigned short i386_get_gs(void)
>    __asm__ volatile ( "movw %%gs,%0" : "=r" (segment) : "0" (segment) );
> @@ -300,29 +300,29 @@ static __inline__ unsigned short i386_get_gs(void)
>  #define i386_outport_byte( _port, _value ) \
> -do { register unsigned short __port  = _port; \
> -     register unsigned char  __value = _value; \
> +do { unsigned short __port  = _port; \
> +     unsigned char  __value = _value; \
>       __asm__ volatile ( "outb %0,%1" : : "a" (__value), "d" (__port) ); \
>     } while (0)
>  #define i386_outport_word( _port, _value ) \
> -     register unsigned short __value = _value; \
> +     unsigned short __value = _value; \
>       __asm__ volatile ( "outw %0,%1" : : "a" (__value), "d" (__port) ); \
>     } while (0)
>  #define i386_outport_long( _port, _value ) \
> -     register unsigned int  __value = _value; \
> +     unsigned int  __value = _value; \
>       __asm__ volatile ( "outl %0,%1" : : "a" (__value), "d" (__port) ); \
>     } while (0)
>  #define i386_inport_byte( _port, _value ) \
> -     register unsigned char  __value = 0; \
> +     unsigned char  __value = 0; \
>       __asm__ volatile ( "inb %1,%0" : "=a" (__value) \
>                                  : "d"  (__port) \
> @@ -331,8 +331,8 @@ do { register unsigned short __port  = _port; \
>     } while (0)
>  #define i386_inport_word( _port, _value ) \
> -     register unsigned short __value = 0; \
> +     unsigned short __value = 0; \
>       __asm__ volatile ( "inw %1,%0" : "=a" (__value) \
>                                  : "d"  (__port) \
> @@ -341,8 +341,8 @@ do { register unsigned short __port  = _port; \
>     } while (0)
>  #define i386_inport_long( _port, _value ) \
> -     register unsigned int  __value = 0; \
> +     unsigned int  __value = 0; \
>       __asm__ volatile ( "inl %1,%0" : "=a" (__value) \
>                                  : "d"  (__port) \
> diff --git a/cpukit/score/cpu/i386/include/rtems/score/interrupts.h
> b/cpukit/score/cpu/i386/include/rtems/score/interrupts.h
> index 6067254509..b682772617 100644
> --- a/cpukit/score/cpu/i386/include/rtems/score/interrupts.h
> +++ b/cpukit/score/cpu/i386/include/rtems/score/interrupts.h
> @@ -62,7 +62,7 @@ typedef int  (*rtems_raw_irq_is_enabled)      (const
> struct __rtems_raw_irq_connect_d
>  #define i386_get_interrupt_level( _level ) \
>    do { \
> -    register uint32_t   _eflags; \
> +    uint32_t   _eflags; \
>      __asm__ volatile ( "pushf ; \
>                      pop %0" \
> diff --git a/cpukit/score/cpu/lm32/include/rtems/score/lm32.h
> b/cpukit/score/cpu/lm32/include/rtems/score/lm32.h
> index e8fecdf2f6..70d8bab735 100644
> --- a/cpukit/score/cpu/lm32/include/rtems/score/lm32.h
> +++ b/cpukit/score/cpu/lm32/include/rtems/score/lm32.h
> @@ -73,7 +73,7 @@ extern "C" {
>    __asm__ volatile ("rcsr %0, ip":"=r"(_ip));
>  #define lm32_disable_interrupts( _level ) \
> -  do { register uint32_t ie; \
> +  do { uint32_t ie; \
>      __asm__ volatile ("rcsr %0,ie":"=r"(ie)); \
>      (_level) = ie; \
>      ie &= (~0x0001); \
> @@ -84,28 +84,28 @@ extern "C" {
>    __asm__ volatile ("wcsr ie,%0"::"r"(_level));
>  #define lm32_flash_interrupts( _level ) \
>      __asm__ volatile ("wcsr ie,%0"::"r"(_level)); \
>      ie = (_level) & (~0x0001); \
>      __asm__ volatile ("wcsr ie,%0"::"r"(ie)); \
>    } while (0)
>  #define lm32_interrupt_unmask( _mask ) \
> -  do { register uint32_t im; \
> +  do { uint32_t im; \
>      __asm__ volatile ("rcsr %0,im":"=r"(im)); \
>      im |= _mask; \
>      __asm__ volatile ("wcsr im,%0"::"r"(im)); \
>    } while (0)
>  #define lm32_interrupt_mask( _mask ) \
>      im &= ~(_mask); \
>    } while (0)
>  #define lm32_interrupt_ack( _mask ) \
> -  do { register uint32_t ip = _mask; \
> +  do { uint32_t ip = _mask; \
>      __asm__ volatile ("wcsr ip,%0"::"r"(ip)); \
>    } while (0)
> diff --git a/cpukit/score/cpu/m68k/include/rtems/score/cpu.h
> b/cpukit/score/cpu/m68k/include/rtems/score/cpu.h
> index fc6847f37e..9b140d0da3 100644
> --- a/cpukit/score/cpu/m68k/include/rtems/score/cpu.h
> +++ b/cpukit/score/cpu/m68k/include/rtems/score/cpu.h
> @@ -501,7 +501,7 @@ extern const unsigned char _CPU_m68k_BFFFO_table[256];
> -    register int dumby; \
> +    int dumby; \
>      __asm__ volatile ( \
>         "   clr.l   %1\n"         \
> @@ -521,7 +521,7 @@ extern const unsigned char _CPU_m68k_BFFFO_table[256];
>  #elif ( M68K_HAS_EXTB_L == 1 )
> +    int dumby; \
>      __asm__ volatile ( "   move.w  %2,%1\n"        \
>         "   lsr.w   #8,%1\n"        \
> @@ -539,7 +539,7 @@ extern const unsigned char _CPU_m68k_BFFFO_table[256];
>  #else
> +    int dumby; \
>         "   lsr.w   #8,%1\n"        \
> diff --git a/cpukit/score/cpu/m68k/include/rtems/score/m68k.h
> b/cpukit/score/cpu/m68k/include/rtems/score/m68k.h
> index 818578c078..f37d978ab9 100644
> --- a/cpukit/score/cpu/m68k/include/rtems/score/m68k.h
> +++ b/cpukit/score/cpu/m68k/include/rtems/score/m68k.h
> @@ -334,7 +334,7 @@ extern "C" {
>  #if ( defined(__mcoldfire__) )
>  #define m68k_disable_interrupts( _level ) \
> -   do { register uint32_t   _tmpsr = 0x0700; \
> +   do { uint32_t   _tmpsr = 0x0700; \
>          __asm__ volatile ( "move.w %%sr,%0\n\t" \
>                        "or.l   %0,%1\n\t" \
>                        "move.w %1,%%sr" \
> @@ -354,7 +354,7 @@ extern "C" {
>  #define m68k_flash_interrupts( _level ) \
>         asm volatile ( "move.w %2,%%sr\n\t" \
>                        "or.l   %2,%1\n\t" \
>                        "move.w %1,%%sr" \
> @@ -371,7 +371,7 @@ extern "C" {
>  #define m68k_get_interrupt_level( _level ) \
>    do { \
> -    register uint32_t   _tmpsr; \
> +    uint32_t   _tmpsr; \
>      __asm__ volatile( "move.w %%sr,%0" : "=d" (_tmpsr)); \
>      _level = (_tmpsr & 0x0700) >> 8; \
> @@ -379,7 +379,7 @@ extern "C" {
>  #define m68k_set_interrupt_level( _newlevel ) \
>    do { \
>      _tmpsr = (_tmpsr & 0xf8ff) | ((_newlevel) << 8); \
> diff --git a/cpukit/score/cpu/mips/include/rtems/score/mips.h
> b/cpukit/score/cpu/mips/include/rtems/score/mips.h
> index 4c2c53fa6d..3b6115e9b6 100644
> --- a/cpukit/score/cpu/mips/include/rtems/score/mips.h
> +++ b/cpukit/score/cpu/mips/include/rtems/score/mips.h
> @@ -136,7 +136,7 @@ extern "C" {
>  #define mips_set_sr( _x ) \
>    do { \
> -    register unsigned int __x = (_x); \
> +    unsigned int __x = (_x); \
>      __asm__ volatile( "mtc0 %0, $12; nop" : : "r" (__x) ); \
>    } while (0)
> @@ -153,7 +153,7 @@ extern "C" {
>  #define mips_set_cause( _x ) \
>    do { \
>      __asm__ volatile( "mtc0 %0, $13; nop" : : "r" (__x) ); \
>    } while (0)
> @@ -172,7 +172,7 @@ extern "C" {
>  #define mips_set_dcic( _x ) \
>    do { \
>      __asm__ volatile( "mtc0 %0, $7; nop" : : "r" (__x) ); \
>    } while (0)
> @@ -193,8 +193,8 @@ extern "C" {
>  #define mips_set_bpcrm( _x, _y ) \
>    do { \
> -    register unsigned int __y = (_y); \
> +    unsigned int __y = (_y); \
>      __asm__ volatile( "mtc0 %0, $11; nop" : : "r" (__y) ); \
>      __asm__ volatile( "mtc0 %0, $3; nop" : : "r" (__x) ); \
>    } while (0)
> @@ -218,8 +218,8 @@ extern "C" {
>  #define mips_set_bdarm( _x, _y ) \
>    do { \
>      __asm__ volatile( "mtc0 %0, $9; nop" : : "r" (__y) ); \
>      __asm__ volatile( "mtc0 %0, $5; nop" : : "r" (__x) ); \
>    } while (0)
> @@ -244,7 +244,7 @@ extern "C" {
>  #define mips_set_fcr31( _x ) \
>    do { \
>      __asm__ volatile( "ctc1 %0, $31; nop" : : "r" (__x) ); \
>    } while(0)
> diff --git a/cpukit/score/cpu/powerpc/include/rtems/score/cpu.h
> b/cpukit/score/cpu/powerpc/include/rtems/score/cpu.h
> index 02560695bd..31e74aba95 100644
> --- a/cpukit/score/cpu/powerpc/include/rtems/score/cpu.h
> +++ b/cpukit/score/cpu/powerpc/include/rtems/score/cpu.h
> @@ -661,7 +661,7 @@ RTEMS_INLINE_ROUTINE bool _CPU_ISR_Is_enabled(
> uint32_t level )
>  static inline uint32_t   _CPU_ISR_Get_level( void )
> -  register unsigned int msr;
> +  uint32_t msr;
>    _CPU_MSR_GET(msr);
>    if (msr & MSR_EE) return 0;
>    else return 1;
> @@ -669,7 +669,7 @@ static inline uint32_t   _CPU_ISR_Get_level( void )
>  static inline void _CPU_ISR_Set_level( uint32_t   level )
> +  uint32_t msr;
>    _CPU_MSR_GET(msr);
>    if (!(level & CPU_MODES_INTERRUPT_MASK)) {
>      msr |= ppc_interrupt_get_disable_mask();
> diff --git a/cpukit/score/cpu/riscv/include/rtems/score/cpu.h
> b/cpukit/score/cpu/riscv/include/rtems/score/cpu.h
> index ada46ef9ee..6f286e0bd8 100644
> --- a/cpukit/score/cpu/riscv/include/rtems/score/cpu.h
> +++ b/cpukit/score/cpu/riscv/include/rtems/score/cpu.h
> @@ -158,7 +158,7 @@ Context_Control_fp  _CPU_Null_fp_context;
>  static inline unsigned long riscv_interrupt_disable( void )
> -  register unsigned long status = read_csr(mstatus);
> +  unsigned long status = read_csr(mstatus);
>    clear_csr(mstatus, MSTATUS_MIE);
>    return status;
> diff --git a/cpukit/score/cpu/sh/include/rtems/score/sh.h
> b/cpukit/score/cpu/sh/include/rtems/score/sh.h
> index 4e26478b8b..6ac5ef1382 100644
> --- a/cpukit/score/cpu/sh/include/rtems/score/sh.h
> +++ b/cpukit/score/cpu/sh/include/rtems/score/sh.h
> @@ -170,7 +170,7 @@ extern "C" {
>  #define sh_get_interrupt_level( _level ) \
> -  register uint32_t   _tmpsr ; \
> +  uint32_t   _tmpsr ; \
>    __asm__ volatile( "stc sr, %0" : "=r" (_tmpsr) ); \
>    _level = (_tmpsr & 0xf0) >> 4 ; \
> @@ -178,7 +178,7 @@ extern "C" {
>  #define sh_set_interrupt_level( _newlevel ) \
>    __asm__ volatile ( "stc sr, %0" : "=r" (_tmpsr) ); \
>    _tmpsr = ( _tmpsr & ~0xf0 ) | ((_newlevel) << 4) ; \
> @@ -194,7 +194,7 @@ static inline uint32_t sh_swap_u32(
>    uint32_t value
> -  register uint32_t swapped;
> +  uint32_t swapped;
>    __asm__ volatile (
>      "swap.b %1,%0; "
> @@ -210,7 +210,7 @@ static inline uint16_t sh_swap_u16(
>    uint16_t value
> -  register uint16_t swapped ;
> +  uint16_t swapped ;
>    __asm__ volatile ( "swap.b %1,%0" : "=r" (swapped) : "r"  (value) );
> diff --git a/cpukit/score/cpu/sparc/include/rtems/score/sparc.h
> b/cpukit/score/cpu/sparc/include/rtems/score/sparc.h
> index 47d8e6f0bd..4846520b46 100644
> --- a/cpukit/score/cpu/sparc/include/rtems/score/sparc.h
> +++ b/cpukit/score/cpu/sparc/include/rtems/score/sparc.h
> @@ -390,7 +390,7 @@ void sparc_syscall_exit(uint32_t exitcode1, uint32_t
> exitcode2)
>  #define sparc_get_interrupt_level( _level ) \
>    do { \
> -    register uint32_t   _psr_level = 0; \
> +    uint32_t _psr_level = 0; \
>      sparc_get_psr( _psr_level ); \
>      (_level) = \
> 2.12.3
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180416/a94fa4b4/attachment-0002.html>
