multiple definition of __getreent (in newlib's crt0.c and RTEMS' confdefs.h)
Tue Apr 17 06:42:56 UTC 2018
Hello,
you found a nasty piece in the RTEMS Newlib/GCC configuration. Newlib
provides a crt0.o file which contains a bunch of global symbols suitable
enough to make the GCC link-time configure tests happy. This file must
never be used for a real RTEMS application. The default startfile of GCC
(which is this Newlib ctr0.o) must be overruled.  This is usually done
be the bsp_specs.  See also
https://lists.rtems.org/pipermail/devel/2017-December/019780.html
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
