multiple definition of __getreent (in newlib's crt0.c and RTEMS' confdefs.h)
Tue Apr 17 08:57:12 UTC 2018
On 17/04/18 10:35, Amaan Cheval wrote:
> - https://docs.rtems.org/branches/master/bsp-howto/linker_script.html
You have to be careful with the BSP guilde. It is a bit out of date. For
a reference linker command file I would use this:
https://git.rtems.org/rtems/tree/c/src/lib/libbsp/arm/shared/startup/linkcmds.base
Use this to get the default linker command file:
x86_64-rtems5-ld --verbose
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
