[PATCH] 5: Use a specific RTEMS tools version
    Sebastian Huber
    Tue Apr 17 11:18:04 UTC 2018
On 17/04/18 12:12, Chris Johns wrote:
> On 17/4/18 6:49 pm, Sebastian Huber wrote:
>> On 17/04/18 10:30, Chris Johns wrote:
>>> On 17/04/2018 18:21, Sebastian Huber wrote:
>>>> Download via HTTPS RTEMS file server.
>>>> Close 3241.
>>> Can you please explain why this solves the issue in the ticket? I do not see how
>>> they relate.
>> This solves the ticket since git is no longer involved.
>>> There can be issues with a sequence of git commands if you are switching
>>> branches. This can be resolved by improving the sequence used.
>>>>    rtems/config/tools/rtems-tools-5-1.cfg | 28 ++++++++++++++++++++++++++--
>>>>    1 file changed, 26 insertions(+), 2 deletions(-)
>>>> diff --git a/rtems/config/tools/rtems-tools-5-1.cfg
>>>> b/rtems/config/tools/rtems-tools-5-1.cfg
>>>> index 6efc4e3..e0178f0 100644
>>>> --- a/rtems/config/tools/rtems-tools-5-1.cfg
>>>> +++ b/rtems/config/tools/rtems-tools-5-1.cfg
>>>> @@ -7,9 +7,33 @@
>>>>    %if %{rsb_released}
>>>>     %define rtems_tools_version %{rsb_version}
>>>> +%else
>>>> + %define rtems_tools_version ec419a05ee52869a7d5b8712ea8e7a7d74fde096
>>>>    %endif
>>> Sorry, this is not the right place for this sort of detail. Version details need
>>> to be in the release defaults or overridden in a an arch specific file.
>> Sorry, I didn't understand the logic for the rtems_tools_version definition at
>> all. Why is it dependent on rsb_released?
> If the RSB is released the RTEMS ftp server is used for downloads and the
> version is the RTEMS release verson. The RTEMS tools do not have a separate
> release cycle from RTEMS and use the same version numbers.
>>> Why this version?
>> It is the latest commit. So, just the thing that would have been picked by the
>> current RSB.
>> The use of a random HEAD is a major problem from my point of view. It makes the
>> RSB outcome build time dependent and irreproducible.
> Releases are matched. I do not follow how this resolves any dependence issue
> that may appear such as the dl06 and rtems-ld.
For the latest test suite you need an up to date rtems-ld. If you built
the tools with RSB 703532cb04c6990fb21e97cb7347a16e9df11108 two months
ago, then it will not work. If you build with RSB
703532cb04c6990fb21e97cb7347a16e9df11108 today, then everything is fine.
This is a serious defect from my point of view.
>>> I do not follow or understand the purpose of the change and with a lack of
>>> specific detail it appears to solve a local problem. It may appear to solve the
>>> problem because it side steps an issue related to switching branches.
>> There are some reports on the mailing list related to the rtems-tools download
>> via git. It has at least two problems:
>> 1. It fails sporadically.
> The real issue in the way git is being sequenced should be fix.
>> 2. You need internet access during the build.
> If you updated RTEMS and have disconnected and not updated the RSB with a new
> hash version downloaded from your home ftp area you have stuffed anyway.
You should be able to
../source-builder/sb-set-builder --dry-run --with-download ...
and then disconnect from the internet to build the tools.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
