the generated coverage report doesn't contain any data
Vijay Kumar Banerjee vijaykumar9597 at gmail.com
Tue Apr 17 19:27:55 UTC 2018
The report is showing some data !!
I merged a lot of changes form coverage-merge , it's showing some data now
, but I'm still getting a set of errors. I'll paste them below.
I have attached a screenshot of the report.html
errors :
INFO: DesiredSymbols::createCoverageMap - Attempt to create unified
coverage maps for _Workspace_Allocate_or_fatal_error with different sizes
(/home/lunatic/development/rtems/kernel/leon3/sparc-rtems5/c/leon3/testsuites/samples/capture/capture.exe/84
/home/lunatic/development/rtems/kernel/leon3/sparc-rtems5/c/leon3/testsuites/samples/base_sp/base_sp.exe/60)
INFO: DesiredSymbols::mergeCoverageMap - Unable to merge coverage map for
_Workspace_Allocate_or_fatal_error because the sizes are different
On 17 April 2018 at 11:59, Cillian O'Donnell <cpodonnell8 at gmail.com> wrote:
> Also if there's any file in covoar directory of coverage-merge branch
> that's called symbol-set.c symbol_set_reader.h or any variation of that,
> that you don't already have pull all of them into your current branch.
> On Tue, 17 Apr 2018, 07:19 Cillian O'Donnell, <cpodonnell8 at gmail.com>
> wrote:
>> Some things are definitely missing there. Git checkout main.c
>> coverage-merge. If you have that branch lying around, that definitely has
>> everything in it. I must of missed of some things updating to current
>> master. Fingers crossed this solves our problems
>> On Mon, 16 Apr 2018, 22:52 Vijay Kumar Banerjee, <
>> vijaykumar9597 at gmail.com> wrote:
>>> On Tue, 17 Apr 2018, 03:19 Joel Sherrill, <joel at rtems.org> wrote:
>>>> On Mon, Apr 16, 2018 at 4:47 PM, Vijay Kumar Banerjee <
>>>>> On 17 April 2018 at 01:43, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>>> wrote:
>>>>>> On 16 April 2018 at 17:46, Joel Sherrill <joel at rtems.org> wrote:
>>>>>>> On Mon, Apr 16, 2018 at 2:33 AM, Vijay Kumar Banerjee <
>>>>>>>> current status :
>>>>>>>> the coverage is running now with rtems-test and generating the
>>>>>>>> report, however, the report doesn't show any data.
>>>>>>> I've been lurking as you have been making progress. Now you have
>>>>>>> crossed
>>>>>>> into something you probably need some hints at. Some things to check:
>>>>>>> + Obviously, check output for signs that something didn't happen
>>>>>>> right.
>>>>>>> Anything from a path wrong, etc. The configuration has to be right to
>>>>>>> point to the source code, object code, executables, etc.
>>>>>>> + A lot of source code has moved around since last summer. Check
>>>>>>> that it is looking in the right places inside RTEMS.
>>>>>>> + Does the mechanism to get debug information actually work? Cillian?
>>>>>> The covoar debug option just disables the cleaning of the tempfiles
>>>>>> to take a look, so it's not as powerful as it might seem :)... I always
>>>>>> used gdb here so that's probably the way to go.
>>>>>>> + There is a utility named trace-converter. Make sure your qemu
>>>>>>> traces
>>>>>>> have information in them.
>>>>>>> + Cillian probably has guidance on running it just on one test (say
>>>>>>> ticker)
>>>>>>> so you can see every step.
>>>>>>> + Check that the executables have symbolic information. "file" should
>>>>>>> show if they are stripped or not.
>>>>>>> I recall covoar has a verbose mode which should be of use.
>>>>>>> Cillian .. do you have instructions on running covoar in gdb?
>>>>>> Alright so run rtems-test with --no-clean option to leave the
>>>>>> coverage files lying around
>>>>>> $HOME/development/rtems/test/test/rtems-tools/tester/rtems-test
>>>>>> --rtems-tools=$HOME/development/rtems/5 --log=coverage-analysis.log
>>>>>> --rtems-bsp=leon3_qemu --coverage --no-clean --rtems-builddir=$HOME/development/rtems/leon3
>>>>>> Then run
>>>>>> gdb covoar
>>>>>> from gdb prompt
>>>>>> run -S /home/cpod/coverage_test/leon3/coverage/score.symcfg -O
>>>>>> /home/cpod/coverage_test/leon3/test/score -fQEMU -Tsparc-rtems5
>>>>>> -E/home/cpod/development/rtems/test/test/vijay/rtems-
>>>>>> tools/tester/rtems/testing/coverage/Explanations.txt -c.cov -eexe
>>>>>> -pRTEMS-5 /home/cpod/development/rtems/leon3/sparc-rtems5/c/leon3/
>>>>>> The options there are ( if you're wondering )
>>>>>>  -c COVERAGEFILE_EXTENSION EXECUTABLE1 ... EXECUTABLE2
>>>>>>  -v                  - verbose output
>>>>>>  -T TARGET           - architecture target name
>>>>>>  -f FORMAT           - simulator format
>>>>>> (RTEMS, QEMU, TSIM or Skyeye)
>>>>>>  -E EXPLANATIONS     - file of explanations
>>>>>>  -s SYMBOLS_FILE     - symbols of interest
>>>>>>  -S SYMBOL_SET_FILE  - path to symbol_sets.cfg
>>>>>>  -1 EXECUTABLE       - executable to get symbols from
>>>>>>  -e EXE_EXTENSION    - suffix for executables
>>>>>>  -c COVERAGEFILE_EXT - coverage file suffix
>>>>>>  -g GCNOS_LIST       - list of *.gcno files
>>>>>>  -p PROJECT_NAME     - name of the project
>>>>>>  -O Output_Directory - output directory default=.
>>>>>>  -d debug            - disable cleaning of tempfiles.
>>>>> maybe the problem is here . I am getting an error for the -S . Here
>>>>> are the list of options that show up , capital S for symbol_set_file is not
>>>>> one of them .
>>>>> Usage: /home/lunatic/development/rtems/5/bin/covoar [-v] -T TARGET -f
>>>>> FORMAT [-E EXPLANATIONS] -e EXE_EXTENSION -c COVERAGEFILE_EXTENSION
>>>>>   -v                        - verbose at initialization
>>>>>   -T TARGET                 - target name
>>>>>   -f FORMAT                 - coverage file format (RTEMS, QEMU, TSIM
>>>>> or Skyeye)
>>>>>   -E EXPLANATIONS           - name of file with explanations
>>>>>   -s SYMBOLS_FILE           - name of file with symbols of interest
>>>>>   -1 EXECUTABLE             - name of executable to get symbols from
>>>>>   -e EXE_EXTENSION          - extension of the executables to analyze
>>>>>   -c COVERAGEFILE_EXTENSION - extension of the coverage files to
>>>>> analyze
>>>>>   -g GCNOS_LIST             - name of file with list of *.gcno files
>>>>>   -C ConfigurationFileName  - name of configuration file
>>>>>   -O Output_Directory       - name of output directory (default=.
>>>> Is it processed by the getopts switch statement in main() but not
>>>> listed in the usage? That is
>>>> an easy mistake to creep in.
>>> It gives an "invalid option" error
>>>>>> Just trying it there, it runs into segmentation fault. So trying to
>>>>>> access memory it shouldn't.
>>>>>> Starting program: /home/cpod/covoar -S /home/cpod/coverage_test/leon3/coverage/score.symcfg
>>>>>> -O /home/cpod/coverage_test/leon3/test/score -fQEMU -Tsparc-rtems5
>>>>>> Reading configuration symbol set file: /home/cpod/coverage_test/
>>>>>> Program received signal SIGSEGV, Segmentation fault.
>>>>>> 0x00007ffff7b769bb in std::__cxx11::basic_string<char,
>>>>>> std::char_traits<char>, std::allocator<char> >::basic_string(std::__cxx11::basic_string<char,
>>>>>> std::char_traits<char>, std::allocator<char> > const&) ()
>>>>>>    from /usr/lib/x86_64-linux-gnu/libstdc++.so.6
>>>>>> Ahhh feels good to have error messages back.
>>>>>> Oh also build covoar with no optimization and you'll have an easier
>>>>>> time looking at stuff in gdb
>>>>>> cd rtems-tools/tester/covoar
>>>>>> vim wscript and change the '-O2' to '-O0' and then build again with
>>>>>> waf and use that covoar to with gdb
>>>>>>>> -- vijay
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180418/07c7cac5/attachment-0002.html>
Name: Screenshot from 2018-04-18 00-46-02.png
Type: image/png
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180418/07c7cac5/attachment-0002.png>
