the generated coverage report doesn't contain any data
Vijay Kumar Banerjee vijaykumar9597 at gmail.com
Wed Apr 18 15:49:11 UTC 2018
It's great to see it produce some data .
I have attached a screenshot of the report generated from testsuites
On 18 April 2018 at 02:07, Cillian O'Donnell <cpodonnell8 at gmail.com> wrote:
> Could be still missing something, try using the whole covoar directory
> from coverage-merge. I spent a good bit of time fixing errors like that,
> would be strange if it popped back up again but it could be right. Either
> way we're in pretty good shape now. Report looks good, try and run it with
> the full testsuite to see what happens, it takes a while, a hour-ish.
> On 17 April 2018 at 20:32, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
> wrote:
>> On 18 April 2018 at 00:57, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com
>> > wrote:
>>> The report is showing some data !!
>>> I merged a lot of changes form coverage-merge , it's showing some data
>>> now , but I'm still getting a set of errors. I'll paste them below.
>>> I have attached a screenshot of the report.html
>>> errors :
>>> INFO: DesiredSymbols::createCoverageMap - Attempt to create unified
>>> coverage maps for _Workspace_Allocate_or_fatal_error with different
>>> sizes (/home/lunatic/development/rtems/kernel/leon3/sparc-rtems5/c
>>> /leon3/testsuites/samples/capture/capture.exe/84 !=
>>> /home/lunatic/development/rtems/kernel/leon3/sparc-rtems5/c/
>>> leon3/testsuites/samples/base_sp/base_sp.exe/60)
>>> INFO: DesiredSymbols::mergeCoverageMap - Unable to merge coverage map
>>> for _Workspace_Allocate_or_fatal_error because the sizes are different
>>> Am I still possibly missing something ?
>> On 17 April 2018 at 11:59, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>> wrote:
>>>> Also if there's any file in covoar directory of coverage-merge branch
>>>> that's called symbol-set.c symbol_set_reader.h or any variation of that,
>>>> that you don't already have pull all of them into your current branch.
>>>> On Tue, 17 Apr 2018, 07:19 Cillian O'Donnell, <cpodonnell8 at gmail.com>
>>>> wrote:
>>>>> Some things are definitely missing there. Git checkout main.c
>>>>> coverage-merge. If you have that branch lying around, that definitely has
>>>>> everything in it. I must of missed of some things updating to current
>>>>> master. Fingers crossed this solves our problems
>>>>> On Mon, 16 Apr 2018, 22:52 Vijay Kumar Banerjee, <
>>>>> vijaykumar9597 at gmail.com> wrote:
>>>>>> On Tue, 17 Apr 2018, 03:19 Joel Sherrill, <joel at rtems.org> wrote:
>>>>>>> On Mon, Apr 16, 2018 at 4:47 PM, Vijay Kumar Banerjee <
>>>>>>>> On 17 April 2018 at 01:43, Cillian O'Donnell <cpodonnell8 at gmail.com
>>>>>>>> > wrote:
>>>>>>>>> On 16 April 2018 at 17:46, Joel Sherrill <joel at rtems.org> wrote:
>>>>>>>>>> On Mon, Apr 16, 2018 at 2:33 AM, Vijay Kumar Banerjee <
>>>>>>>>>>> current status :
>>>>>>>>>>> the coverage is running now with rtems-test and generating the
>>>>>>>>>>> report, however, the report doesn't show any data.
>>>>>>>>>> I've been lurking as you have been making progress. Now you have
>>>>>>>>>> crossed
>>>>>>>>>> into something you probably need some hints at. Some things to
>>>>>>>>>> check:
>>>>>>>>>> + Obviously, check output for signs that something didn't happen
>>>>>>>>>> right.
>>>>>>>>>> Anything from a path wrong, etc. The configuration has to be
>>>>>>>>>> right to
>>>>>>>>>> point to the source code, object code, executables, etc.
>>>>>>>>>> + A lot of source code has moved around since last summer. Check
>>>>>>>>>> that it is looking in the right places inside RTEMS.
>>>>>>>>>> + Does the mechanism to get debug information actually work?
>>>>>>>>>> Cillian?
>>>>>>>>> The covoar debug option just disables the cleaning of the
>>>>>>>>> tempfiles to take a look, so it's not as powerful as it might seem :)... I
>>>>>>>>> always used gdb here so that's probably the way to go.
>>>>>>>>>> + There is a utility named trace-converter. Make sure your qemu
>>>>>>>>>> traces
>>>>>>>>>> have information in them.
>>>>>>>>>> + Cillian probably has guidance on running it just on one test
>>>>>>>>>> (say ticker)
>>>>>>>>>> so you can see every step.
>>>>>>>>>> + Check that the executables have symbolic information. "file"
>>>>>>>>>> should
>>>>>>>>>> show if they are stripped or not.
>>>>>>>>>> I recall covoar has a verbose mode which should be of use.
>>>>>>>>>> Cillian .. do you have instructions on running covoar in gdb?
>>>>>>>>> Alright so run rtems-test with --no-clean option to leave the
>>>>>>>>> coverage files lying around
>>>>>>>>> $HOME/development/rtems/test/test/rtems-tools/tester/rtems-test
>>>>>>>>> --rtems-tools=$HOME/development/rtems/5
>>>>>>>>> --log=coverage-analysis.log --rtems-bsp=leon3_qemu --coverage --no-clean
>>>>>>>>> --rtems-builddir=$HOME/development/rtems/leon3
>>>>>>>>> sparc-rtems5/c/leon3/testsuites/samples
>>>>>>>>> Then run
>>>>>>>>> gdb covoar
>>>>>>>>> from gdb prompt
>>>>>>>>> run -S /home/cpod/coverage_test/leon3/coverage/score.symcfg -O
>>>>>>>>> /home/cpod/coverage_test/leon3/test/score -fQEMU -Tsparc-rtems5
>>>>>>>>> -E/home/cpod/development/rtems/test/test/vijay/rtems-tools/t
>>>>>>>>> ester/rtems/testing/coverage/Explanations.txt -c.cov -eexe
>>>>>>>>> -pRTEMS-5 /home/cpod/development/rtems/l
>>>>>>>>> eon3/sparc-rtems5/c/leon3/testsuites/samples/base_sp/base_sp.exe
>>>>>>>>> The options there are ( if you're wondering )
>>>>>>>>>  -c COVERAGEFILE_EXTENSION EXECUTABLE1 ... EXECUTABLE2
>>>>>>>>>  -v                  - verbose output
>>>>>>>>>  -T TARGET           - architecture target name
>>>>>>>>>  -f FORMAT           - simulator format
>>>>>>>>> (RTEMS, QEMU, TSIM or Skyeye)
>>>>>>>>>  -E EXPLANATIONS     - file of explanations
>>>>>>>>>  -s SYMBOLS_FILE     - symbols of interest
>>>>>>>>>  -S SYMBOL_SET_FILE  - path to symbol_sets.cfg
>>>>>>>>>  -1 EXECUTABLE       - executable to get symbols from
>>>>>>>>>  -e EXE_EXTENSION    - suffix for executables
>>>>>>>>>  -c COVERAGEFILE_EXT - coverage file suffix
>>>>>>>>>  -g GCNOS_LIST       - list of *.gcno files
>>>>>>>>>  -p PROJECT_NAME     - name of the project
>>>>>>>>>  -O Output_Directory - output directory default=.
>>>>>>>>>  -d debug            - disable cleaning of tempfiles.
>>>>>>>> maybe the problem is here . I am getting an error for the -S . Here
>>>>>>>> are the list of options that show up , capital S for symbol_set_file is not
>>>>>>>> one of them .
>>>>>>>> Usage: /home/lunatic/development/rtems/5/bin/covoar [-v] -T TARGET
>>>>>>>> -f FORMAT [-E EXPLANATIONS] -e EXE_EXTENSION -c COVERAGEFILE_EXTENSION
>>>>>>>>   -v                        - verbose at initialization
>>>>>>>>   -T TARGET                 - target name
>>>>>>>>   -f FORMAT                 - coverage file format (RTEMS, QEMU,
>>>>>>>> TSIM or Skyeye)
>>>>>>>>   -E EXPLANATIONS           - name of file with explanations
>>>>>>>>   -s SYMBOLS_FILE           - name of file with symbols of interest
>>>>>>>>   -1 EXECUTABLE             - name of executable to get symbols from
>>>>>>>>   -e EXE_EXTENSION          - extension of the executables to
>>>>>>>> analyze
>>>>>>>>   -c COVERAGEFILE_EXTENSION - extension of the coverage files to
>>>>>>>> analyze
>>>>>>>>   -g GCNOS_LIST             - name of file with list of *.gcno files
>>>>>>>>   -C ConfigurationFileName  - name of configuration file
>>>>>>>>   -O Output_Directory       - name of output directory (default=.
>>>>>>> Is it processed by the getopts switch statement in main() but not
>>>>>>> listed in the usage? That is
>>>>>>> an easy mistake to creep in.
>>>>>> It gives an "invalid option" error
>>>>>>>>> Just trying it there, it runs into segmentation fault. So trying
>>>>>>>>> to access memory it shouldn't.
>>>>>>>>> Starting program: /home/cpod/covoar -S
>>>>>>>>> Reading configuration symbol set file:
>>>>>>>>> Program received signal SIGSEGV, Segmentation fault.
>>>>>>>>> 0x00007ffff7b769bb in std::__cxx11::basic_string<char,
>>>>>>>>> std::char_traits<char>, std::allocator<char> >::basic_string(std::__cxx11::basic_string<char,
>>>>>>>>> std::char_traits<char>, std::allocator<char> > const&) ()
>>>>>>>>>    from /usr/lib/x86_64-linux-gnu/libstdc++.so.6
>>>>>>>>> Ahhh feels good to have error messages back.
>>>>>>>>> Oh also build covoar with no optimization and you'll have an
>>>>>>>>> easier time looking at stuff in gdb
>>>>>>>>> cd rtems-tools/tester/covoar
>>>>>>>>> vim wscript and change the '-O2' to '-O0' and then build again
>>>>>>>>> with waf and use that covoar to with gdb
>>>>>>>>>>> -- vijay
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180418/b21b975b/attachment-0002.html>
Name: Screenshot from 2018-04-18 20-37-04.png
Type: image/png
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180418/b21b975b/attachment-0002.png>
