BSP source re-organization status
    Chris Johns
    chrisj at rtems.org
    Mon Apr 23 01:08:22 UTC 2018
On 20/04/2018 23:23, Sebastian Huber wrote:
> PS: How can I use brackets { and } in a :file:`...{...}...` directive?
Found and tested:
 :file:`c/src/lib/libbsp/${{CPU}}/${{BSP}}/startup/bspstart.c`
worked.
Could you please fix in bsp_work_area_initialize() section:
- https://git.rtems.org/rtems-docs/tree/bsp-howto/initilization_code.rst#n204
 Space between 'in' and ':file:' in 'in:file:'
- https://git.rtems.org/rtems-docs/tree/bsp-howto/initilization_code.rst#n206
 Space between 'or' and '``bsp_...`.
Thanks
