[PATCH] Initial implemantation commit
Dannie Huang
danxue.huang at gmail.com
Wed Aug 1 03:42:48 UTC 2018
From: Danxue Huang <36866155+dh0072 at users.noreply.github.com>
.gitignore | 2 +
README.md | 2 +
gen_rst_from_makedoc.py | 125 ++++++++++++++++++++++++++++++++++++++++++++++++
rst.py | 104 ++++++++++++++++++++++++++++++++++++++++
strcmp.rst | 47 ++++++++++++++++++
5 files changed, 280 insertions(+)
create mode 100644 .gitignore
create mode 100644 README.md
create mode 100755 gen_rst_from_makedoc.py
create mode 100644 rst.py
create mode 100644 strcmp.rst
diff --git a/.gitignore b/.gitignore
new file mode 100644
index 0000000..9f90354
--- /dev/null
+++ b/.gitignore
@@ -0,0 +1,2 @@
+.idea/*
+__pycache__/*
diff --git a/README.md b/README.md
index 0000000..8ebb224
--- /dev/null
+++ b/README.md
@@ -0,0 +1,2 @@
+# NewlibMarkup2SphinxConvertorPrivate
+(PRIVATE) This repo contains code for NewlibMarkup2SphinxConvertorPrivate.
diff --git a/gen_rst_from_makedoc.py b/gen_rst_from_makedoc.py
new file mode 100755
index 0000000..da69c80
--- /dev/null
+++ b/gen_rst_from_makedoc.py
@@ -0,0 +1,125 @@
+#!/usr/bin/env python
+# RTEMS Tools Project (http://www.rtems.org/)
+# Copyright 2018 Danxue Huang (danxue.huang at gmail.com)
+# All rights reserved.
+# This file is part of the RTEMS Tools package in 'rtems-tools'.
+# Redistribution and use in source and binary forms, with or without
+# modification, are permitted provided that the following conditions are met:
+# 1. Redistributions of source code must retain the above copyright notice,
+# this list of conditions and the following disclaimer.
+# 2. Redistributions in binary form must reproduce the above copyright notice,
+# this list of conditions and the following disclaimer in the documentation
+# and/or other materials provided with the distribution.
+# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
+# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+# POSSIBILITY OF SUCH DAMAGE.
+import argparse
+import re
+import rst
+def is_command(s):
+ A command is a single word of at least 3 characters, all uppercase
+ :param s: input string
+ :return: True if s is a single command, otherwise False
+ return True if re.match('^[A-Z_]{3,}\s*$', s) else False
+def extract_comments(content):
+ Extract content inside of /* */
+ :param content: input file content
+ :return: extracted comments
+ comments = ''
+ comments_match = re.match('/\*(\*(?!/)|[^*])*\*/', content)
+ if comments_match:
+ wrapped_comments = comments_match.group()
+ comments = wrapped_comments.lstrip('/*').rstrip('*/').lstrip().rstrip()
+ return comments
+def extract_command_and_text(content):
+ Extract command and text from input string content
+ :param content: input string containing command and text
+ :return: a tuple containing command and text
+ command = ''
+ text = ''
+ command_text_dict = {}
+ for line in content.splitlines():
+ if is_command(line):
+ if command and text:
+ command_text_dict[command] = text
+ command = line.rstrip()
+ text = ''
+ else:
+ text += line + '\n'
+ return command_text_dict
+def generate_rst(command_text_dict):
+ rst_str = ''
+ for command, text in command_text_dict.items():
+ rst_str += rst.get_command_processor(command)(command, text)
+ return rst_str
+def get_parser():
+ parser = argparse.ArgumentParser(
+ description='Convert newlib style markup to rst markup'
+ parser.add_argument(
+ '-s',
+ '--source_file_dir',
+ type=str,
+ help='Source file directory with newlib style comments',
+ '-d',
+ '--dest_file_dir',
+ type=str,
+ help='Destination directory for converted rst markup file',
+ return parser
+def main(source_file_dir, dest_file_dir):
+ with open(source_file_dir, 'r') as source_file, open(dest_file_dir, 'w') as dest_file:
+ file_content = source_file.read()
+ # Get comments inside of /* */
+ comments = extract_comments(file_content)
+ # Parse comments
+ command_text_dict = extract_command_and_text(comments)
+ # Process text based on command type
+ rst_str = generate_rst(command_text_dict)
+ dest_file.write(rst_str)
+if __name__ == '__main__':
+ args = get_parser().parse_args()
+ main(args.source_file_dir, args.dest_file_dir)
diff --git a/rst.py b/rst.py
index 0000000..2531f46
--- /dev/null
+++ b/rst.py
@@ -0,0 +1,104 @@
+import re
+def register_processor_command():
+ return {
+ 'FUNCTION': gen_function_summary,
+ 'SYNOPSIS': gen_code_block,
+ 'ANSI_SYNOPSIS': gen_code_block,
+ 'TRAD_SYNOPSIS': gen_code_block,
+ 'TYPEDEF': gen_code_block,
+ 'DESCRIPTION': gen_custom_directives,
+ 'INDEX': gen_custom_directives,
+ 'RETURNS': gen_custom_directives,
+ 'PORTABILITY': gen_custom_directives,
+ 'NOTES': gen_custom_directives,
+ 'ERRORS': gen_custom_directives,
+ 'BUGS': gen_custom_directives,
+ 'WARNINGS': gen_custom_directives,
+ 'QUICKREF': gen_nothing,
+ 'MATHREF': gen_nothing,
+ 'NEWPAGE': gen_nothing,
+ 'START': gen_nothing,
+ 'END': gen_nothing,
+ 'SEEALSO': gen_custom_directives,
+def get_command_processor(command):
+ command_processor_dict = register_processor_command()
+ if command in command_processor_dict:
+ return command_processor_dict[command]
+ else:
+ print('Command {c} is not recognized, skip it'.format(c=command))
+ return gen_nothing
+def gen_function_summary(command, text):
+ function_name = extract_function_name(text)
+ summary = extract_summary(text)
+ title = '.. {f}:\n\n{f} - {s}\n'.format(
+ f=function_name,
+ s=summary.capitalize()
+ dashes = '-' * len(text) + '\n'
+ func_name_index = '.. index:: {name}\n'.format(name=function_name)
+ summary_index = '.. index:: {summary}\n\n'.format(summary=summary)
+ return title + dashes + func_name_index + summary_index
+def extract_function_name(text):
+ function_name = ''
+ function_name_match = re.match('\s+(<<(>(?!>)|[^>])*>>)', text)
+ if function_name_match:
+ function_name = function_name_match.group(1).lstrip('<<').rstrip('>>')
+ return function_name
+def extract_summary(text):
+ return text.split('---')[-1].rstrip()
+def gen_code_block(command, text):
+ return '**{c}:**\n\n.. code-block:: c\n\n{t}\n\n'.format(c = command, t=text)
+def gen_nothing(command, text):
+ return '\n\n'
+def gen_custom_directives(command, text):
+ return '**{c}:**\n\n{t}\n\n'.format(c=command, t=text)
diff --git a/strcmp.rst b/strcmp.rst
index 0000000..c1dc543
--- /dev/null
+++ b/strcmp.rst
@@ -0,0 +1,47 @@
+.. strcmp:
+strcmp - Character string compare
+.. index:: strcmp
+.. index:: character string compare
+**INDEX:**
+ strcmp
+**SYNOPSIS:**
+.. code-block:: c
+ #include <string.h>
+ int strcmp(const char *<[a]>, const char *<[b]>);
+**DESCRIPTION:**
+ <<strcmp>> compares the string at <[a]> to
+ the string at <[b]>.
+**RETURNS:**
+ If <<*<[a]>>> sorts lexicographically after <<*<[b]>>>,
+ <<strcmp>> returns a number greater than zero. If the two
+ strings match, <<strcmp>> returns zero. If <<*<[a]>>>
+ sorts lexicographically before <<*<[b]>>>, <<strcmp>> returns a
+ number less than zero.
+**PORTABILITY:**
+<<strcmp>> is ANSI C.
+<<strcmp>> requires no supporting OS subroutines.
2.7.4
