[PATCH] Initial implemantation commit
Dannie Huang
danxue.huang at gmail.com
Wed Aug 1 03:50:11 UTC 2018
Hi,
This is the initial implementation commit of converting newlib markup to
rst, the example .rst file looks like this photo (see attached photo
please).
Code is pushed on my github:
https://github.com/dh0072/NewlibMarkup2SphinxConverter
Best,
Dannie
On Tue, Jul 31, 2018 at 10:42 PM, Dannie Huang <danxue.huang at gmail.com>
wrote:
> From: Danxue Huang <36866155+dh0072 at users.noreply.github.com>
> .gitignore | 2 +
> README.md | 2 +
> gen_rst_from_makedoc.py | 125 ++++++++++++++++++++++++++++++
> rst.py | 104 ++++++++++++++++++++++++++++++++++++++++
> strcmp.rst | 47 ++++++++++++++++++
> 5 files changed, 280 insertions(+)
> create mode 100644 .gitignore
> create mode 100644 README.md
> create mode 100755 gen_rst_from_makedoc.py
> create mode 100644 rst.py
> create mode 100644 strcmp.rst
> diff --git a/.gitignore b/.gitignore
> new file mode 100644
> index 0000000..9f90354
> --- /dev/null
> +++ b/.gitignore
> @@ -0,0 +1,2 @@
> +.idea/*
> +__pycache__/*
> diff --git a/README.md b/README.md
> index 0000000..8ebb224
> --- /dev/null
> +++ b/README.md
> @@ -0,0 +1,2 @@
> +# NewlibMarkup2SphinxConvertorPrivate
> +(PRIVATE) This repo contains code for NewlibMarkup2SphinxConvertorPr
> ivate.
> diff --git a/gen_rst_from_makedoc.py b/gen_rst_from_makedoc.py
> new file mode 100755
> index 0000000..da69c80
> --- /dev/null
> +++ b/gen_rst_from_makedoc.py
> @@ -0,0 +1,125 @@
> +#!/usr/bin/env python
> +# RTEMS Tools Project (http://www.rtems.org/)
> +# Copyright 2018 Danxue Huang (danxue.huang at gmail.com)
> +# All rights reserved.
> +# This file is part of the RTEMS Tools package in 'rtems-tools'.
> +# Redistribution and use in source and binary forms, with or without
> +# modification, are permitted provided that the following conditions are
> met:
> +# 1. Redistributions of source code must retain the above copyright
> notice,
> +# this list of conditions and the following disclaimer.
> +# 2. Redistributions in binary form must reproduce the above copyright
> notice,
> +# this list of conditions and the following disclaimer in the
> documentation
> +# and/or other materials provided with the distribution.
> +# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS
> IS"
> +# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
> THE
> +# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
> PURPOSE
> +# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS
> BE
> +# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> +# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> +# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> +# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> +# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> +# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF
> THE
> +# POSSIBILITY OF SUCH DAMAGE.
> +import argparse
> +import re
> +import rst
> +def is_command(s):
> + A command is a single word of at least 3 characters, all uppercase
> + :param s: input string
> + :return: True if s is a single command, otherwise False
> + return True if re.match('^[A-Z_]{3,}\s*$', s) else False
> +def extract_comments(content):
> + Extract content inside of /* */
> + :param content: input file content
> + :return: extracted comments
> + comments = ''
> + comments_match = re.match('/\*(\*(?!/)|[^*])*\*/', content)
> + if comments_match:
> + wrapped_comments = comments_match.group()
> + comments = wrapped_comments.lstrip('/*').
> rstrip('*/').lstrip().rstrip()
> + return comments
> +def extract_command_and_text(content):
> + Extract command and text from input string content
> + :param content: input string containing command and text
> + :return: a tuple containing command and text
> + command = ''
> + text = ''
> + command_text_dict = {}
> + for line in content.splitlines():
> + if is_command(line):
> + if command and text:
> + command_text_dict[command] = text
> + command = line.rstrip()
> + text = ''
> + else:
> + text += line + '\n'
> + return command_text_dict
> +def generate_rst(command_text_dict):
> + rst_str = ''
> + for command, text in command_text_dict.items():
> + rst_str += rst.get_command_processor(command)(command, text)
> + return rst_str
> +def get_parser():
> + parser = argparse.ArgumentParser(
> + description='Convert newlib style markup to rst markup'
> + parser.add_argument(
> + '-s',
> + '--source_file_dir',
> + type=str,
> + help='Source file directory with newlib style comments',
> + '-d',
> + '--dest_file_dir',
> + type=str,
> + help='Destination directory for converted rst markup file',
> + return parser
> +def main(source_file_dir, dest_file_dir):
> + with open(source_file_dir, 'r') as source_file, open(dest_file_dir,
> 'w') as dest_file:
> + file_content = source_file.read()
> + # Get comments inside of /* */
> + comments = extract_comments(file_content)
> + # Parse comments
> + command_text_dict = extract_command_and_text(comments)
> + # Process text based on command type
> + rst_str = generate_rst(command_text_dict)
> + dest_file.write(rst_str)
> +if __name__ == '__main__':
> + args = get_parser().parse_args()
> + main(args.source_file_dir, args.dest_file_dir)
> diff --git a/rst.py b/rst.py
> index 0000000..2531f46
> --- /dev/null
> +++ b/rst.py
> @@ -0,0 +1,104 @@
> met:
> notice,
> notice,
> documentation
> IS"
> THE
> PURPOSE
> BE
> THE
> +import re
> +def register_processor_command():
> + return {
> + 'FUNCTION': gen_function_summary,
> + 'SYNOPSIS': gen_code_block,
> + 'ANSI_SYNOPSIS': gen_code_block,
> + 'TRAD_SYNOPSIS': gen_code_block,
> + 'TYPEDEF': gen_code_block,
> + 'DESCRIPTION': gen_custom_directives,
> + 'INDEX': gen_custom_directives,
> + 'RETURNS': gen_custom_directives,
> + 'PORTABILITY': gen_custom_directives,
> + 'NOTES': gen_custom_directives,
> + 'ERRORS': gen_custom_directives,
> + 'BUGS': gen_custom_directives,
> + 'WARNINGS': gen_custom_directives,
> + 'QUICKREF': gen_nothing,
> + 'MATHREF': gen_nothing,
> + 'NEWPAGE': gen_nothing,
> + 'START': gen_nothing,
> + 'END': gen_nothing,
> + 'SEEALSO': gen_custom_directives,
> +def get_command_processor(command):
> + command_processor_dict = register_processor_command()
> + if command in command_processor_dict:
> + return command_processor_dict[command]
> + else:
> + print('Command {c} is not recognized, skip it'.format(c=command))
> + return gen_nothing
> +def gen_function_summary(command, text):
> + function_name = extract_function_name(text)
> + summary = extract_summary(text)
> + title = '.. {f}:\n\n{f} - {s}\n'.format(
> + f=function_name,
> + s=summary.capitalize()
> + dashes = '-' * len(text) + '\n'
> + func_name_index = '.. index:: {name}\n'.format(name=function_name)
> + summary_index = '.. index:: {summary}\n\n'.format(summary=summary)
> + return title + dashes + func_name_index + summary_index
> +def extract_function_name(text):
> + function_name = ''
> + function_name_match = re.match('\s+(<<(>(?!>)|[^>])*>>)', text)
> + if function_name_match:
> + function_name = function_name_match.group(1).
> lstrip('<<').rstrip('>>')
> + return function_name
> +def extract_summary(text):
> + return text.split('---')[-1].rstrip()
> +def gen_code_block(command, text):
> + return '**{c}:**\n\n.. code-block:: c\n\n{t}\n\n'.format(c = command,
> t=text)
> +def gen_nothing(command, text):
> + return '\n\n'
> +def gen_custom_directives(command, text):
> + return '**{c}:**\n\n{t}\n\n'.format(c=command, t=text)
> diff --git a/strcmp.rst b/strcmp.rst
> index 0000000..c1dc543
> --- /dev/null
> +++ b/strcmp.rst
> @@ -0,0 +1,47 @@
> +.. strcmp:
> +strcmp - Character string compare
> +.. index:: strcmp
> +.. index:: character string compare
> +**INDEX:**
> + strcmp
> +**SYNOPSIS:**
> +.. code-block:: c
> + #include <string.h>
> + int strcmp(const char *<[a]>, const char *<[b]>);
> +**DESCRIPTION:**
> + <<strcmp>> compares the string at <[a]> to
> + the string at <[b]>.
> +**RETURNS:**
> + If <<*<[a]>>> sorts lexicographically after <<*<[b]>>>,
> + <<strcmp>> returns a number greater than zero. If the two
> + strings match, <<strcmp>> returns zero. If <<*<[a]>>>
> + sorts lexicographically before <<*<[b]>>>, <<strcmp>> returns a
> + number less than zero.
> +**PORTABILITY:**
> +<<strcmp>> is ANSI C.
> +<<strcmp>> requires no supporting OS subroutines.
> 2.7.4
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180731/b2c2025e/attachment-0001.html>
Name: example for .rst.png
Type: image/png
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180731/b2c2025e/attachment-0001.png>
