[PATCH 01/12] crypto/sha2: Remove left over file.
Christian Mauderer christian.mauderer at embedded-brains.de
Wed Aug 1 08:04:43 UTC 2018
This file seems to be imported from a long gone version.
 freebsd/sys/crypto/sha2/sha2.h | 141 -----------------------------------------
 1 file changed, 141 deletions(-)
 delete mode 100644 freebsd/sys/crypto/sha2/sha2.h
diff --git a/freebsd/sys/crypto/sha2/sha2.h b/freebsd/sys/crypto/sha2/sha2.h
deleted file mode 100644
index 12da95c9..00000000
--- a/freebsd/sys/crypto/sha2/sha2.h
+++ /dev/null
@@ -1,141 +0,0 @@
-/*	$FreeBSD$	*/
-/*	$KAME: sha2.h,v 1.3 2001/03/12 08:27:48 itojun Exp $	*/
- * sha2.h
- * Version 1.0.0beta1
- * Written by Aaron D. Gifford <me at aarongifford.com>
- * Copyright 2000 Aaron D. Gifford.  All rights reserved.
- * Redistribution and use in source and binary forms, with or without
- * modification, are permitted provided that the following conditions
- * are met:
- * 1. Redistributions of source code must retain the above copyright
- *    notice, this list of conditions and the following disclaimer.
- * 2. Redistributions in binary form must reproduce the above copyright
- *    notice, this list of conditions and the following disclaimer in the
- *    documentation and/or other materials provided with the distribution.
- * 3. Neither the name of the copyright holder nor the names of contributors
- *    may be used to endorse or promote products derived from this software
- *    without specific prior written permission.
- * THIS SOFTWARE IS PROVIDED BY THE AUTHOR(S) AND CONTRIBUTOR(S) ``AS IS'' AND
- * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
- * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
- * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR(S) OR CONTRIBUTOR(S) BE LIABLE
- * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
- * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
- * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
- * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
- * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
- * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
- * SUCH DAMAGE.
-#ifndef __SHA2_H__
-#define __SHA2_H__
-#ifdef __cplusplus
-extern "C" {
-#endif
-/*** SHA-256/384/512 Various Length Definitions ***********************/
-#define SHA256_BLOCK_LENGTH		64
-#define SHA256_DIGEST_LENGTH		32
-#define SHA256_DIGEST_STRING_LENGTH	(SHA256_DIGEST_LENGTH * 2 + 1)
-#define SHA384_BLOCK_LENGTH		128
-#define SHA384_DIGEST_LENGTH		48
-#define SHA384_DIGEST_STRING_LENGTH	(SHA384_DIGEST_LENGTH * 2 + 1)
-#define SHA512_BLOCK_LENGTH		128
-#define SHA512_DIGEST_LENGTH		64
-#define SHA512_DIGEST_STRING_LENGTH	(SHA512_DIGEST_LENGTH * 2 + 1)
-/*** SHA-256/384/512 Context Structures *******************************/
-/* NOTE: If your architecture does not define either u_intXX_t types or
- * uintXX_t (from inttypes.h), you may need to define things by hand
- * for your system:
-#if 0
-typedef unsigned char u_int8_t;		/* 1-byte  (8-bits)  */
-typedef unsigned int u_int32_t;		/* 4-bytes (32-bits) */
-typedef unsigned long long u_int64_t;	/* 8-bytes (64-bits) */
-#endif
- * Most BSD systems already define u_intXX_t types, as does Linux.
- * Some systems, however, like Compaq's Tru64 Unix instead can use
- * uintXX_t types defined by very recent ANSI C standards and included
- * in the file:
- *   #include <inttypes.h>
- * If you choose to use <inttypes.h> then please define:
- *   #define SHA2_USE_INTTYPES_H
- * Or on the command line during compile:
- *   cc -DSHA2_USE_INTTYPES_H ...
-#if 0 /*def SHA2_USE_INTTYPES_H*/
-typedef struct _SHA256_CTX {
-	uint32_t	state[8];
-	uint64_t	bitcount;
-	uint8_t	buffer[SHA256_BLOCK_LENGTH];
-} SHA256_CTX;
-typedef struct _SHA512_CTX {
-	uint64_t	state[8];
-	uint64_t	bitcount[2];
-	uint8_t	buffer[SHA512_BLOCK_LENGTH];
-} SHA512_CTX;
-#else /* SHA2_USE_INTTYPES_H */
-	u_int32_t	state[8];
-	u_int64_t	bitcount;
-	u_int8_t	buffer[SHA256_BLOCK_LENGTH];
-} SHA256_CTX;
-	u_int64_t	state[8];
-	u_int64_t	bitcount[2];
-	u_int8_t	buffer[SHA512_BLOCK_LENGTH];
-} SHA512_CTX;
-#endif /* SHA2_USE_INTTYPES_H */
-typedef SHA512_CTX SHA384_CTX;
-/*** SHA-256/384/512 Function Prototypes ******************************/
-void SHA256_Init(SHA256_CTX *);
-void SHA256_Update(SHA256_CTX*, const u_int8_t*, size_t);
-void SHA256_Final(u_int8_t[SHA256_DIGEST_LENGTH], SHA256_CTX*);
-char* SHA256_End(SHA256_CTX*, char[SHA256_DIGEST_STRING_LENGTH]);
-char* SHA256_Data(const u_int8_t*, size_t, char[SHA256_DIGEST_STRING_LENGTH]);
-void SHA384_Init(SHA384_CTX*);
-void SHA384_Update(SHA384_CTX*, const u_int8_t*, size_t);
-void SHA384_Final(u_int8_t[SHA384_DIGEST_LENGTH], SHA384_CTX*);
-char* SHA384_End(SHA384_CTX*, char[SHA384_DIGEST_STRING_LENGTH]);
-char* SHA384_Data(const u_int8_t*, size_t, char[SHA384_DIGEST_STRING_LENGTH]);
-void SHA512_Init(SHA512_CTX*);
-void SHA512_Update(SHA512_CTX*, const u_int8_t*, size_t);
-void SHA512_Final(u_int8_t[SHA512_DIGEST_LENGTH], SHA512_CTX*);
-char* SHA512_End(SHA512_CTX*, char[SHA512_DIGEST_STRING_LENGTH]);
-char* SHA512_Data(const u_int8_t*, size_t, char[SHA512_DIGEST_STRING_LENGTH]);
-#ifdef	__cplusplus
-#endif /* __cplusplus */
-#endif /* __SHA2_H__ */
2.13.7
