[PATCH 12/12] libbsd.txt: Add ipsec.
Christian Mauderer christian.mauderer at embedded-brains.de
Wed Aug 1 08:04:54 UTC 2018
 libbsd.txt | 120 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
 1 file changed, 120 insertions(+)
diff --git a/libbsd.txt b/libbsd.txt
index c7a90f64..d2bbf77c 100644
--- a/libbsd.txt
+++ b/libbsd.txt
@@ -1233,6 +1233,126 @@ workaround is to just restart it every time it exits.
 - The control interface of wpa_supplicant most likely doesn't work. The wpa_cli
   application is not ported.
+== IPSec ==
+The IPSec support is optional in libbsd. It is disabled in the default build
+set. Please make sure to use a build set with +netipsec = on+.
+To use IPSec the following modules are necessary:
+SYSINIT_MODULE_REFERENCE(if_gif);
+SYSINIT_MODULE_REFERENCE(cryptodev);
+RTEMS_BSD_DEFINE_NEXUS_DEVICE(cryptosoft, 0, 0, NULL);
+The necessary initialization steps for a IPSec connection are similar to the
+steps on a FreeBSD-System. The example assumes the following setup:
+- RTEMS external IP: 192.168.10.1/24
+- RTEMS internal IP: 10.10.1.1/24
+- remote external IP: 192.168.10.10/24
+- remote internal IP: 172.24.0.1/24
+- shared key: "mysecretkey"
+With this the following steps are necessary:
+- Create a gif0 device:
+SHLL [/] #  ifconfig gif0 create
+- Configure the gif0 device:
+SHLL [/] # ifconfig gif0 10.10.1.1 172.24.0.1
+SHLL [/] # ifconfig gif0 tunnel 192.168.10.1 192.168.10.10
+- Add a route to the remote net via the remote IP:
+SHLL [/] # route add 172.24.0.0/24 172.24.0.1
+- Call `setkey` with a correct rule set:
+SHLL [/] # cat /etc/setkey.conf
+flush;
+spdflush;
+spdadd  10.10.1.0/24 172.24.0.0/24 any -P out ipsec esp/tunnel/192.168.10.1-192.168.10.10/use;
+spdadd 172.24.0.0/24  10.10.1.0/24 any -P in  ipsec esp/tunnel/192.168.10.10-192.168.10.1/use;
+SHLL [/] # setkey -f /etc/setkey.conf
+- Start a ike-daemon (racoon) with a correct configuration.
+SHLL [/] # cat /etc/racoon.conf
+path	pre_shared_key "/etc/racoon_psk.txt";
+log	info;
+padding # options are not to be changed
+	maximum_length			20;
+	randomize			off;
+	strict_check			off;
+	exclusive_tail			off;
+listen  # address [port] that racoon will listen on
+	isakmp				192.168.10.1[500];
+remote 192.168.10.10 [500]
+	exchange_mode			main;
+	my_identifier			address 192.168.10.1;
+	peers_identifier		address 192.168.10.10;
+	proposal_check			obey;
+	proposal {
+		encryption_algorithm	3des;
+		hash_algorithm		md5;
+		authentication_method	pre_shared_key;
+		lifetime		time 3600 sec;
+		dh_group		2;
+sainfo (address 10.10.1.0/24 any address 172.24.0.0/24 any)
+	pfs_group			2;
+	lifetime			time 28800 sec;
+	authentication_algorithm	hmac_md5;
+	compression_algorithm		deflate;
+SHLL [/] # cat /etc/racoon_psk.txt
+192.168.10.10	mysecretkey
+SHLL [/] # racoon -F -f /etc/racoon.conf
+All commands can be called via the respective API functions. For racoon there is
+a `rtems_bsd_racoon_daemon()` function that forks of racoon as a task.
+Alternatively IPSec can also be configured via rc.conf entries if the
+`rc_conf_ipsec_init()` is used.:
+cloned_interfaces="gif0"
+ifconfig_gif0="10.10.1.1 172.24.0.1 tunnel 192.168.10.1 192.168.10.10"
+ike_enable="YES"
+ike_program="racoon"
+ike_flags="-F -f /etc/racoon.conf"
+ike_priority="250"
+ipsec_enable="YES"
+ipsec_file="/etc/setkey.conf"
 == Problems to report to FreeBSD ==
 The MMAP_NOT_AVAILABLE define is inverted on its usage.  When it is
2.13.7
