[PATCH] Initial implemantation commit
Wed Aug 1 13:56:08 UTC 2018
On Tue, Jul 31, 2018 at 11:50 PM, Dannie Huang <danxue.huang at gmail.com> wrote:
> Hi,
> This is the initial implementation commit of converting newlib markup to
> rst, the example .rst file looks like this photo (see attached photo
> please).
Can we see a side-by-side comparison with how newlib's documentation looks?
> Code is pushed on my github:
> https://github.com/dh0072/NewlibMarkup2SphinxConverter
> Best,
> Dannie
> On Tue, Jul 31, 2018 at 10:42 PM, Dannie Huang <danxue.huang at gmail.com>
> wrote:
>> From: Danxue Huang <36866155+dh0072 at users.noreply.github.com>
>>  .gitignore              |   2 +
>>  README.md               |   2 +
>>  gen_rst_from_makedoc.py | 125
>>  rst.py                  | 104 ++++++++++++++++++++++++++++++++++++++++
>>  strcmp.rst              |  47 ++++++++++++++++++
>>  5 files changed, 280 insertions(+)
>>  create mode 100644 .gitignore
>>  create mode 100644 README.md
>>  create mode 100755 gen_rst_from_makedoc.py
>>  create mode 100644 rst.py
>>  create mode 100644 strcmp.rst
>> diff --git a/.gitignore b/.gitignore
>> new file mode 100644
>> index 0000000..9f90354
>> --- /dev/null
>> +++ b/.gitignore
>> @@ -0,0 +1,2 @@
>> +.idea/*
>> +__pycache__/*
>> diff --git a/README.md b/README.md
>> index 0000000..8ebb224
>> --- /dev/null
>> +++ b/README.md
>> @@ -0,0 +1,2 @@
>> +# NewlibMarkup2SphinxConvertorPrivate
>> +(PRIVATE) This repo contains code for
>> NewlibMarkup2SphinxConvertorPrivate.
>> diff --git a/gen_rst_from_makedoc.py b/gen_rst_from_makedoc.py
>> new file mode 100755
>> index 0000000..da69c80
>> --- /dev/null
>> +++ b/gen_rst_from_makedoc.py
>> @@ -0,0 +1,125 @@
>> +#!/usr/bin/env python
>> +# RTEMS Tools Project (http://www.rtems.org/)
>> +# Copyright 2018 Danxue Huang (danxue.huang at gmail.com)
>> +# All rights reserved.
>> +# This file is part of the RTEMS Tools package in 'rtems-tools'.
>> +# Redistribution and use in source and binary forms, with or without
>> +# modification, are permitted provided that the following conditions are
>> met:
>> +# 1. Redistributions of source code must retain the above copyright
>> notice,
>> +# this list of conditions and the following disclaimer.
>> +# 2. Redistributions in binary form must reproduce the above copyright
>> notice,
>> +# this list of conditions and the following disclaimer in the
>> documentation
>> +# and/or other materials provided with the distribution.
>> +# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS
>> IS"
>> +# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
>> THE
>> +# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
>> PURPOSE
>> +# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS
>> BE
>> +# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
>> +# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
>> +# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
>> BUSINESS
>> +# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
>> +# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
>> +# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF
>> THE
>> +# POSSIBILITY OF SUCH DAMAGE.
>> +import argparse
>> +import re
>> +import rst
>> +def is_command(s):
>> +    A command is a single word of at least 3 characters, all uppercase
>> +    :param s: input string
>> +    :return: True if s is a single command, otherwise False
>> +    return True if re.match('^[A-Z_]{3,}\s*$', s) else False
>> +def extract_comments(content):
>> +    Extract content inside of /* */
>> +    :param content: input file content
>> +    :return: extracted comments
>> +    comments = ''
>> +    comments_match = re.match('/\*(\*(?!/)|[^*])*\*/', content)
>> +    if comments_match:
>> +        wrapped_comments = comments_match.group()
>> +        comments =
>> wrapped_comments.lstrip('/*').rstrip('*/').lstrip().rstrip()
>> +    return comments
>> +def extract_command_and_text(content):
>> +    Extract command and text from input string content
>> +    :param content: input string containing command and text
>> +    :return: a tuple containing command and text
>> +    command = ''
>> +    text = ''
>> +    command_text_dict = {}
>> +    for line in content.splitlines():
>> +        if is_command(line):
>> +            if command and text:
>> +                command_text_dict[command] = text
>> +            command = line.rstrip()
>> +            text = ''
>> +        else:
>> +            text += line + '\n'
>> +    return command_text_dict
>> +def generate_rst(command_text_dict):
>> +    rst_str = ''
>> +    for command, text in command_text_dict.items():
>> +        rst_str += rst.get_command_processor(command)(command, text)
>> +    return rst_str
>> +def get_parser():
>> +    parser = argparse.ArgumentParser(
>> +        description='Convert newlib style markup to rst markup'
>> +    parser.add_argument(
>> +        '-s',
>> +        '--source_file_dir',
>> +        type=str,
>> +        help='Source file directory with newlib style comments',
>> +        '-d',
>> +        '--dest_file_dir',
>> +        type=str,
>> +        help='Destination directory for converted rst markup file',
>> +    return parser
>> +def main(source_file_dir, dest_file_dir):
>> +    with open(source_file_dir, 'r') as source_file, open(dest_file_dir,
>> 'w') as dest_file:
>> +        file_content = source_file.read()
>> +        # Get comments inside of /* */
>> +        comments = extract_comments(file_content)
>> +        # Parse comments
>> +        command_text_dict = extract_command_and_text(comments)
>> +        # Process text based on command type
>> +        rst_str = generate_rst(command_text_dict)
>> +        dest_file.write(rst_str)
>> +if __name__ == '__main__':
>> +    args = get_parser().parse_args()
>> +    main(args.source_file_dir, args.dest_file_dir)
>> diff --git a/rst.py b/rst.py
>> index 0000000..2531f46
>> --- /dev/null
>> +++ b/rst.py
>> @@ -0,0 +1,104 @@
>> met:
>> notice,
>> notice,
>> documentation
>> IS"
>> THE
>> PURPOSE
>> BE
>> BUSINESS
>> THE
>> +import re
>> +def register_processor_command():
>> +    return {
>> +        'FUNCTION': gen_function_summary,
>> +        'SYNOPSIS': gen_code_block,
>> +        'ANSI_SYNOPSIS': gen_code_block,
>> +        'TRAD_SYNOPSIS': gen_code_block,
>> +        'TYPEDEF': gen_code_block,
>> +        'DESCRIPTION': gen_custom_directives,
>> +        'INDEX': gen_custom_directives,
>> +        'RETURNS': gen_custom_directives,
>> +        'PORTABILITY': gen_custom_directives,
>> +        'NOTES': gen_custom_directives,
>> +        'ERRORS': gen_custom_directives,
>> +        'BUGS': gen_custom_directives,
>> +        'WARNINGS': gen_custom_directives,
>> +        'QUICKREF': gen_nothing,
>> +        'MATHREF': gen_nothing,
>> +        'NEWPAGE': gen_nothing,
>> +        'START': gen_nothing,
>> +        'END': gen_nothing,
>> +        'SEEALSO': gen_custom_directives,
>> +def get_command_processor(command):
>> +    command_processor_dict = register_processor_command()
>> +    if command in command_processor_dict:
>> +        return command_processor_dict[command]
>> +    else:
>> +        print('Command {c} is not recognized, skip it'.format(c=command))
>> +        return gen_nothing
>> +def gen_function_summary(command, text):
>> +    function_name = extract_function_name(text)
>> +    summary = extract_summary(text)
>> +    title = '.. {f}:\n\n{f} - {s}\n'.format(
>> +        f=function_name,
>> +        s=summary.capitalize()
>> +    dashes = '-' * len(text) + '\n'
>> +    func_name_index = '.. index:: {name}\n'.format(name=function_name)
>> +    summary_index = '.. index:: {summary}\n\n'.format(summary=summary)
>> +    return title + dashes + func_name_index + summary_index
>> +def extract_function_name(text):
>> +    function_name = ''
>> +    function_name_match = re.match('\s+(<<(>(?!>)|[^>])*>>)', text)
>> +    if function_name_match:
>> +        function_name =
>> function_name_match.group(1).lstrip('<<').rstrip('>>')
>> +    return function_name
>> +def extract_summary(text):
>> +    return text.split('---')[-1].rstrip()
>> +def gen_code_block(command, text):
>> +    return '**{c}:**\n\n.. code-block:: c\n\n{t}\n\n'.format(c = command,
>> t=text)
>> +def gen_nothing(command, text):
>> +    return '\n\n'
>> +def gen_custom_directives(command, text):
>> +    return '**{c}:**\n\n{t}\n\n'.format(c=command, t=text)
>> diff --git a/strcmp.rst b/strcmp.rst
>> index 0000000..c1dc543
>> --- /dev/null
>> +++ b/strcmp.rst
>> @@ -0,0 +1,47 @@
>> +.. strcmp:
>> +strcmp - Character string compare
>> +.. index:: strcmp
>> +.. index:: character string compare
>> +**INDEX:**
>> +       strcmp
>> +**SYNOPSIS:**
>> +.. code-block:: c
>> +       #include <string.h>
>> +       int strcmp(const char *<[a]>, const char *<[b]>);
>> +**DESCRIPTION:**
>> +       <<strcmp>> compares the string at <[a]> to
>> +       the string at <[b]>.
>> +**RETURNS:**
>> +       If <<*<[a]>>> sorts lexicographically after <<*<[b]>>>,
>> +       <<strcmp>> returns a number greater than zero.  If the two
>> +       strings match, <<strcmp>> returns zero.  If <<*<[a]>>>
>> +       sorts lexicographically before <<*<[b]>>>, <<strcmp>> returns a
>> +       number less than zero.
>> +**PORTABILITY:**
>> +<<strcmp>> is ANSI C.
>> +<<strcmp>> requires no supporting OS subroutines.
>> 2.7.4
> devel mailing list
> devel at rtems.org
