[PATCH] Initial implemantation commit
Wed Aug 1 14:00:27 UTC 2018
On Tue, Jul 31, 2018 at 11:42 PM, Dannie Huang <danxue.huang at gmail.com> wrote:
> From: Danxue Huang <36866155+dh0072 at users.noreply.github.com>
>  .gitignore              |   2 +
>  README.md               |   2 +
>  gen_rst_from_makedoc.py | 125 ++++++++++++++++++++++++++++++++++++++++++++++++
>  rst.py                  | 104 ++++++++++++++++++++++++++++++++++++++++
>  strcmp.rst              |  47 ++++++++++++++++++
>  5 files changed, 280 insertions(+)
>  create mode 100644 .gitignore
>  create mode 100644 README.md
>  create mode 100755 gen_rst_from_makedoc.py
>  create mode 100644 rst.py
>  create mode 100644 strcmp.rst
Don't include the strcmp.rst file.
Does this code have a long-term destination in mind?
> diff --git a/.gitignore b/.gitignore
> new file mode 100644
> index 0000000..9f90354
> --- /dev/null
> +++ b/.gitignore
> @@ -0,0 +1,2 @@
> +.idea/*
> +__pycache__/*
add *.rst maybe
> diff --git a/README.md b/README.md
> index 0000000..8ebb224
> --- /dev/null
> +++ b/README.md
> @@ -0,0 +1,2 @@
> +# NewlibMarkup2SphinxConvertorPrivate
> +(PRIVATE) This repo contains code for NewlibMarkup2SphinxConvertorPrivate.
> diff --git a/gen_rst_from_makedoc.py b/gen_rst_from_makedoc.py
> new file mode 100755
> index 0000000..da69c80
> --- /dev/null
> +++ b/gen_rst_from_makedoc.py
> @@ -0,0 +1,125 @@
> +#!/usr/bin/env python
> +# RTEMS Tools Project (http://www.rtems.org/)
> +# Copyright 2018 Danxue Huang (danxue.huang at gmail.com)
> +# All rights reserved.
> +# This file is part of the RTEMS Tools package in 'rtems-tools'.
> +# Redistribution and use in source and binary forms, with or without
> +# modification, are permitted provided that the following conditions are met:
> +# 1. Redistributions of source code must retain the above copyright notice,
> +# this list of conditions and the following disclaimer.
> +# 2. Redistributions in binary form must reproduce the above copyright notice,
> +# this list of conditions and the following disclaimer in the documentation
> +# and/or other materials provided with the distribution.
> +# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> +# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> +# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> +# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
> +# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> +# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> +# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> +# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> +# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> +# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> +# POSSIBILITY OF SUCH DAMAGE.
> +import argparse
> +import re
> +import rst
> +def is_command(s):
> +    A command is a single word of at least 3 characters, all uppercase
> +    :param s: input string
> +    :return: True if s is a single command, otherwise False
> +    return True if re.match('^[A-Z_]{3,}\s*$', s) else False
I think most of the tools currently use the Python OOP style of
coding. I think this should be made more consistently class-based?
> +def extract_comments(content):
> +    Extract content inside of /* */
> +    :param content: input file content
> +    :return: extracted comments
> +    comments = ''
> +    comments_match = re.match('/\*(\*(?!/)|[^*])*\*/', content)
> +    if comments_match:
> +        wrapped_comments = comments_match.group()
> +        comments = wrapped_comments.lstrip('/*').rstrip('*/').lstrip().rstrip()
> +    return comments
> +def extract_command_and_text(content):
> +    Extract command and text from input string content
> +    :param content: input string containing command and text
> +    :return: a tuple containing command and text
> +    command = ''
> +    text = ''
> +    command_text_dict = {}
> +    for line in content.splitlines():
> +        if is_command(line):
> +            if command and text:
> +                command_text_dict[command] = text
> +            command = line.rstrip()
> +            text = ''
> +        else:
> +            text += line + '\n'
> +    return command_text_dict
> +def generate_rst(command_text_dict):
> +    rst_str = ''
> +    for command, text in command_text_dict.items():
> +        rst_str += rst.get_command_processor(command)(command, text)
> +    return rst_str
> +def get_parser():
> +    parser = argparse.ArgumentParser(
> +        description='Convert newlib style markup to rst markup'
> +    parser.add_argument(
> +        '-s',
> +        '--source_file_dir',
> +        type=str,
> +        help='Source file directory with newlib style comments',
> +        '-d',
> +        '--dest_file_dir',
> +        type=str,
> +        help='Destination directory for converted rst markup file',
> +    return parser
> +def main(source_file_dir, dest_file_dir):
> +    with open(source_file_dir, 'r') as source_file, open(dest_file_dir, 'w') as dest_file:
> +        file_content = source_file.read()
> +        # Get comments inside of /* */
> +        comments = extract_comments(file_content)
> +        # Parse comments
> +        command_text_dict = extract_command_and_text(comments)
> +        # Process text based on command type
> +        rst_str = generate_rst(command_text_dict)
> +        dest_file.write(rst_str)
The workflow of this script should be clearly defined in terms of the
requirements and interface. It seems this should have a very narrow
interface of a single input file, and a single output file?
I don't really understand this converting "_dir" names as I would
expect these to be directories, but they are treated as files. This is
confusing to me.
> +if __name__ == '__main__':
> +    args = get_parser().parse_args()
> +    main(args.source_file_dir, args.dest_file_dir)
> diff --git a/rst.py b/rst.py
> index 0000000..2531f46
> --- /dev/null
> +++ b/rst.py
> @@ -0,0 +1,104 @@
> +import re
> +def register_processor_command():
> +    return {
> +        'FUNCTION': gen_function_summary,
> +        'SYNOPSIS': gen_code_block,
> +        'ANSI_SYNOPSIS': gen_code_block,
> +        'TRAD_SYNOPSIS': gen_code_block,
> +        'TYPEDEF': gen_code_block,
> +        'DESCRIPTION': gen_custom_directives,
> +        'INDEX': gen_custom_directives,
> +        'RETURNS': gen_custom_directives,
> +        'PORTABILITY': gen_custom_directives,
> +        'NOTES': gen_custom_directives,
> +        'ERRORS': gen_custom_directives,
> +        'BUGS': gen_custom_directives,
> +        'WARNINGS': gen_custom_directives,
> +        'QUICKREF': gen_nothing,
> +        'MATHREF': gen_nothing,
> +        'NEWPAGE': gen_nothing,
> +        'START': gen_nothing,
> +        'END': gen_nothing,
> +        'SEEALSO': gen_custom_directives,
> +def get_command_processor(command):
> +    command_processor_dict = register_processor_command()
> +    if command in command_processor_dict:
> +        return command_processor_dict[command]
> +    else:
> +        print('Command {c} is not recognized, skip it'.format(c=command))
> +        return gen_nothing
> +def gen_function_summary(command, text):
> +    function_name = extract_function_name(text)
> +    summary = extract_summary(text)
> +    title = '.. {f}:\n\n{f} - {s}\n'.format(
> +        f=function_name,
> +        s=summary.capitalize()
> +    dashes = '-' * len(text) + '\n'
> +    func_name_index = '.. index:: {name}\n'.format(name=function_name)
> +    summary_index = '.. index:: {summary}\n\n'.format(summary=summary)
> +    return title + dashes + func_name_index + summary_index
> +def extract_function_name(text):
> +    function_name = ''
> +    function_name_match = re.match('\s+(<<(>(?!>)|[^>])*>>)', text)
> +    if function_name_match:
> +        function_name = function_name_match.group(1).lstrip('<<').rstrip('>>')
> +    return function_name
> +def extract_summary(text):
> +    return text.split('---')[-1].rstrip()
> +def gen_code_block(command, text):
> +    return '**{c}:**\n\n.. code-block:: c\n\n{t}\n\n'.format(c = command, t=text)
> +def gen_nothing(command, text):
> +    return '\n\n'
> +def gen_custom_directives(command, text):
> +    return '**{c}:**\n\n{t}\n\n'.format(c=command, t=text)
> diff --git a/strcmp.rst b/strcmp.rst
> index 0000000..c1dc543
> --- /dev/null
> +++ b/strcmp.rst
> @@ -0,0 +1,47 @@
> +.. strcmp:
> +strcmp - Character string compare
> +.. index:: strcmp
> +.. index:: character string compare
> +**INDEX:**
> +       strcmp
> +**SYNOPSIS:**
> +.. code-block:: c
> +       #include <string.h>
> +       int strcmp(const char *<[a]>, const char *<[b]>);
> +**DESCRIPTION:**
> +       <<strcmp>> compares the string at <[a]> to
> +       the string at <[b]>.
> +**RETURNS:**
> +       If <<*<[a]>>> sorts lexicographically after <<*<[b]>>>,
> +       <<strcmp>> returns a number greater than zero.  If the two
> +       strings match, <<strcmp>> returns zero.  If <<*<[a]>>>
> +       sorts lexicographically before <<*<[b]>>>, <<strcmp>> returns a
> +       number less than zero.
> +**PORTABILITY:**
> +<<strcmp>> is ANSI C.
> +<<strcmp>> requires no supporting OS subroutines.
> 2.7.4
> devel mailing list
> devel at rtems.org
