[PATCH v2] coverage/symbol-sets.ini : Add symbol-sets and paths to respective libraries
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Wed Aug 1 16:17:10 UTC 2018
Hello,
I have included all the cpukit, please have a look .
I have run the tests for all these symbols.
a screenshot of the result can be found in the following link, please have
a look .
https://drive.google.com/file/d/1BtgHRwh3w4qDDI7tdMZH3xCn_NsHshKs/view?usp=sharing
2018-08-01 21:39 GMT+05:30 Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>:
> tester/rtems/testing/coverage/symbol-sets.ini | 48
> 1 file changed, 45 insertions(+), 3 deletions(-)
> diff --git a/tester/rtems/testing/coverage/symbol-sets.ini
> b/tester/rtems/testing/coverage/symbol-sets.ini
> index a2ec7bc..aac0b9b 100644
> --- a/tester/rtems/testing/coverage/symbol-sets.ini
> +++ b/tester/rtems/testing/coverage/symbol-sets.ini
> @@ -29,8 +29,50 @@
> [symbol-sets]
> -sets = score,rtems
> +sets = score,rtems,sapi,libdl,posix,libirfs,libdosfs,libdevfs,
> libimfs,libcsupport,libbspcmdline,libcpuuse,libstackchk,libfsmount,
> libstringto,libdevnull,libdumpbuf,libblock
> [libraries]
> -score = @BUILD-TARGET@/c/@BSP@/cpukit/score/libscore.a
> -rtems = @BUILD-TARGET@/c/@BSP@/cpukit/rtems/librtems.a
> +score = @BUILD-TARGET@/c/@BSP@/cpukit/score/libscore.a
> +rtems = @BUILD-TARGET@/c/@BSP@/cpukit/rtems/librtems.a
> +sapi = @BUILD-TARGET@/c/@BSP@/cpukit/sapi/libsapi.a
> +libdl = @BUILD-TARGET@/c/@BSP@/cpukit/libdl/libdl.a
> +posix = @BUILD-TARGET@/c/@BSP@/cpukit/posix/libposix.a
> +libirfs = @BUILD-TARGET@/c/@BSP@/cpukit/libfs/librfs.a
> +libdosfs = @BUILD-TARGET@/c/@BSP@/cpukit/libfs/libdosfs.a
> +libdevfs = @BUILD-TARGET@/c/@BSP@/cpukit/libfs/libdevfs.a
> +libimfs = @BUILD-TARGET@/c/@BSP@/cpukit/libfs/libimfs.a
> +#libdefaultsfs = @BUiLD-TARGET@/c/@BSP@/cpukit/libfs/libdefaultfs.a
> +#libjffs2 = @BUILD-TARGET@/c/@BSP@/cpukit/libfs/libjffs2.a
> +#dtc = @BUILD-TARGET@/c/@BSP@/cpukit/libfdt/libfdt.a
> +#libdrvmgr = @BUILD-TARGET@/c/@BSP@/cpukit/libdrvmgr/libdrvmgr.a
> +#libi2c = @BUILD-TARGET@/c/@BSP@/cpukit/libi2c/libi2c.a
> +libcsupport = @BUILD-TARGET@/c/@BSP@/cpukit/libcsupport/libcsupport.a
> +libbspcmdline = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libbspcmdline.a
> +libcpuuse = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libcpuuse.a
> +libstackchk = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libstackchk.a
> +libfsmount = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libfsmount.a
> +libstringto = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libstringto.a
> +libdevnull = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libdevnull.a
> +libdumpbuf = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libdumpbuf.a
> +#libcapture = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libcapture.a
> +#libdummy = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libdummy.a
> +#libmonitor = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libmonitor.a
> +#libmouse = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libmouse.a
> +#libmw-fb = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libmw-fb.a
> +#libredirector = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libredirector.a
> +#librtemsfdt = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/librtemsfdt.a
> +#libserdbg = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libserdbg.a
> +#libshell = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libshell.a
> +#libtestsupport= @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libtestsupport.a
> +#libuntar = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libuntar.a
> +#libutf8proc = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libutf8proc.a
> +#libuuid = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libuuid.a
> +#libxz = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libxz.a
> +libblock = @BUILD-TARGET@/c/@BSP@/cpukit/libblock/libblock.a
> +#libpci = @BUILD-TARGET@/c/@BSP@/cpukit/libpci/libpci.a
> +#librpc = @BUILD-TARGET@/c/@BSP@/cpukit/librpc/librpc.a
> +#libxdr = @BUILD-TARGET@/c/@BSP@/cpukit/librpc/libxdr.a
> +#libcrypt = @BUILD-TARGET@/c/@BSP@/cpukit/libcrypt/libcrypt.a
> +#libmd = @BUILD-TARGET@/c/@BSP@/cpukit/libmd/libmd.a
> +#libstdthreads = @BUILD-TARGET@/c/@BSP@/cpukit/
> libstdthreads/libstdthreads.a
> +#zlib = @BUILD-TARGET@/c/@BSP@/cpukit/zlib/libz.a
> 2.14.4
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180801/a6f6cce8/attachment.html>
