[PATCH 1/1] Address comments
Dannie Huang danxue.huang at gmail.com
Thu Aug 2 04:55:06 UTC 2018
 .gitignore               |  1 +
 gen_rst_from_makedoc.py  | 71 ++++++----------------------------------
 makedoc2rst_converter.py | 85 ++++++++++++++++++++++++++++++++++++++++++++++++
 3 files changed, 96 insertions(+), 61 deletions(-)
 create mode 100644 makedoc2rst_converter.py
diff --git a/.gitignore b/.gitignore
index 9f90354..f707fbd 100644
--- a/.gitignore
+++ b/.gitignore
@@ -1,2 +1,3 @@
 .idea/*
 __pycache__/*
+*.rst
diff --git a/gen_rst_from_makedoc.py b/gen_rst_from_makedoc.py
index da69c80..4100756 100755
--- a/gen_rst_from_makedoc.py
+++ b/gen_rst_from_makedoc.py
@@ -29,60 +29,8 @@
 # POSSIBILITY OF SUCH DAMAGE.
 import argparse
-import re
-import rst
-def is_command(s):
-    A command is a single word of at least 3 characters, all uppercase
-    :param s: input string
-    :return: True if s is a single command, otherwise False
-    return True if re.match('^[A-Z_]{3,}\s*$', s) else False
-def extract_comments(content):
-    Extract content inside of /* */
-    :param content: input file content
-    :return: extracted comments
-    comments = ''
-    comments_match = re.match('/\*(\*(?!/)|[^*])*\*/', content)
-    if comments_match:
-        wrapped_comments = comments_match.group()
-        comments = wrapped_comments.lstrip('/*').rstrip('*/').lstrip().rstrip()
-    return comments
-def extract_command_and_text(content):
-    Extract command and text from input string content
-    :param content: input string containing command and text
-    :return: a tuple containing command and text
-    command = ''
-    text = ''
-    command_text_dict = {}
-    for line in content.splitlines():
-        if is_command(line):
-            if command and text:
-                command_text_dict[command] = text
-            command = line.rstrip()
-            text = ''
-        else:
-            text += line + '\n'
-    return command_text_dict
-def generate_rst(command_text_dict):
-    rst_str = ''
-    for command, text in command_text_dict.items():
-        rst_str += rst.get_command_processor(command)(command, text)
-    return rst_str
+import makedoc2rst_converter
 def get_parser():
@@ -91,15 +39,15 @@ def get_parser():
     parser.add_argument(
         '-s',
-        '--source_file_dir',
+        '--source_file_path',
         type=str,
-        help='Source file directory with newlib style comments',
+        help='Path of source file with newlib style comments',
         '-d',
-        '--dest_file_dir',
+        '--dest_file_path',
         type=str,
-        help='Destination directory for converted rst markup file',
+        help='Path of destination file with rst markup',
     return parser
@@ -108,18 +56,19 @@ def main(source_file_dir, dest_file_dir):
     with open(source_file_dir, 'r') as source_file, open(dest_file_dir, 'w') as dest_file:
         file_content = source_file.read()
+        makedoc2rst = makedoc2rst_converter.makedoc2rst_converter()
         # Get comments inside of /* */
-        comments = extract_comments(file_content)
+        comments = makedoc2rst.extract_comments(file_content)
         # Parse comments
-        command_text_dict = extract_command_and_text(comments)
+        command_text_dict = makedoc2rst.extract_command_and_text(comments)
         # Process text based on command type
-        rst_str = generate_rst(command_text_dict)
+        rst_str = makedoc2rst.generate_rst(command_text_dict)
         dest_file.write(rst_str)
 if __name__ == '__main__':
     args = get_parser().parse_args()
-    main(args.source_file_dir, args.dest_file_dir)
+    main(args.source_file_path, args.dest_file_path)
diff --git a/makedoc2rst_converter.py b/makedoc2rst_converter.py
new file mode 100644
index 0000000..e4d2d72
--- /dev/null
+++ b/makedoc2rst_converter.py
@@ -0,0 +1,85 @@
+#!/usr/bin/env python
+# RTEMS Tools Project (http://www.rtems.org/)
+# Copyright 2018 Danxue Huang (danxue.huang at gmail.com)
+# All rights reserved.
+# This file is part of the RTEMS Tools package in 'rtems-tools'.
+# Redistribution and use in source and binary forms, with or without
+# modification, are permitted provided that the following conditions are met:
+# 1. Redistributions of source code must retain the above copyright notice,
+# this list of conditions and the following disclaimer.
+# 2. Redistributions in binary form must reproduce the above copyright notice,
+# this list of conditions and the following disclaimer in the documentation
+# and/or other materials provided with the distribution.
+# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
+# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+# POSSIBILITY OF SUCH DAMAGE.
+import re
+import rst
+class makedoc2rst_converter():
+    @staticmethod
+    def is_command(s):
+        A command is a single word of at least 3 characters, all uppercase
+        :param s: input string
+        :return: True if s is a single command, otherwise False
+        return True if re.match('^[A-Z_]{3,}\s*$', s) else False
+    @staticmethod
+    def extract_comments(content):
+        Extract content inside of /* */
+        :param content: input file content
+        :return: extracted comments
+        comments = ''
+        comments_match = re.match('/\*(\*(?!/)|[^*])*\*/', content)
+        if comments_match:
+            wrapped_comments = comments_match.group()
+            comments = wrapped_comments.lstrip('/*').rstrip('*/').lstrip().rstrip()
+        return comments
+    @staticmethod
+    def extract_command_and_text(content):
+        Extract command and text from input string content
+        :param content: input string containing command and text
+        :return: a tuple containing command and text
+        command = ''
+        text = ''
+        command_text_dict = {}
+        for line in content.splitlines():
+            if makedoc2rst_converter.is_command(line):
+                if command and text:
+                    command_text_dict[command] = text
+                command = line.rstrip()
+                text = ''
+            else:
+                text += line + '\n'
+        return command_text_dict
+    @staticmethod
+    def generate_rst(command_text_dict):
+        rst_str = ''
+        for command, text in command_text_dict.items():
+            rst_str += rst.get_command_processor(command)(command, text)
+        return rst_str
2.7.4
