[rtems commit] bsp/riscv: Initialize FPU depending on ISA
Thu Aug 2 08:36:01 UTC 2018
On 02/08/18 10:32, Chris Johns wrote:
> On 02/08/2018 17:47, Sebastian Huber wrote:
>> On 01/08/18 12:06, Hesham Almatary wrote:
>>> On Wed, Aug 1, 2018 at 10:18 AM, Sebastian Huber<sebh at rtems.org>  wrote:
>>>> Module:    rtems
>>>> Branch:    master
>>>> Commit:    529154bad207a42a6d0f03343c7e215eab97ced5
>>>> Changeset:
>>>> http://git.rtems.org/rtems/commit/?id=529154bad207a42a6d0f03343c7e215eab97ced5
>>>> Author:    Sebastian Huber<sebastian.huber at embedded-brains.de>
>>>> Date:      Tue Jul 31 09:15:00 2018 +0200
>>>> Initialize fcsr to zero for a defined rounding mode.
>>>> Update #3433.
>>>>    bsps/riscv/riscv/start/start.S | 5 ++++-
>>>>    1 file changed, 4 insertions(+), 1 deletion(-)
>>>> diff --git a/bsps/riscv/riscv/start/start.S b/bsps/riscv/riscv/start/start.S
>>>> index 290c95a..feb07fe 100644
>>>> --- a/bsps/riscv/riscv/start/start.S
>>>> +++ b/bsps/riscv/riscv/start/start.S
>>>> @@ -48,9 +48,12 @@ SYM(_start):
>>>>           LADDR   gp, __global_pointer$
>>>>           .option pop
>>>> -       /* Init FPU unit if it's there */
>>>> +       /* Init FPU */
>>>> +#ifdef __riscv_flen
>>>>           li      t0, MSTATUS_FS
>>>>           csrs    mstatus, t0
>>>> +       csrw    fcsr, zero
>>>> +#endif
>>> Do you think it makes sense to check the MISA register for checking
>>> the existence of an FPU unit or not?
>> I considered adding run-time tests here. I decided to not do it since we should
>> offer a good multilib for a particular chip. It is the duty of the user to
>> select the right multilib for its chip.
> This seems reasonable.
> Will the user get a kind landing if they select the wrong library, ie no support
> in the hardware or supported in hardware but using the wrong library? I remember
> the horrible error with the FPU on the m68k, it was often incorrect linker flags.
The RISC-V BSP name is the ISA name currently. If you select the wrong
BSP, you get an exception (e.g. use of FPU, but no FPU present on the
chip) or software FP performance instead of hardware FP performance.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
