[PATCH] Initial implemantation commit
Thu Aug 2 13:01:50 UTC 2018
I think these << >> blocks ought to be typeset as inline code blocks?
On Thu, Aug 2, 2018 at 1:03 AM, Dannie Huang <danxue.huang at gmail.com> wrote:
> On Wed, Aug 1, 2018 at 8:56 AM, Gedare Bloom <gedare at rtems.org> wrote:
>> On Tue, Jul 31, 2018 at 11:50 PM, Dannie Huang <danxue.huang at gmail.com>
>> wrote:
>> > Hi,
>> > This is the initial implementation commit of converting newlib markup to
>> > rst, the example .rst file looks like this photo (see attached photo
>> > please).
>> Can we see a side-by-side comparison with how newlib's documentation
>> looks?
> Sure, see attached photo please. Newlib's documentation is on the left and
> the rst output is on the right.
>> > Code is pushed on my github:
>> > https://github.com/dh0072/NewlibMarkup2SphinxConverter
>> > Best,
>> > Dannie
>> > On Tue, Jul 31, 2018 at 10:42 PM, Dannie Huang <danxue.huang at gmail.com>
>> > wrote:
>> >> From: Danxue Huang <36866155+dh0072 at users.noreply.github.com>
>> >>  .gitignore              |   2 +
>> >>  README.md               |   2 +
>> >>  gen_rst_from_makedoc.py | 125
>> >>  rst.py                  | 104 ++++++++++++++++++++++++++++++++++++++++
>> >>  strcmp.rst              |  47 ++++++++++++++++++
>> >>  5 files changed, 280 insertions(+)
>> >>  create mode 100644 .gitignore
>> >>  create mode 100644 README.md
>> >>  create mode 100755 gen_rst_from_makedoc.py
>> >>  create mode 100644 rst.py
>> >>  create mode 100644 strcmp.rst
>> >> diff --git a/.gitignore b/.gitignore
>> >> new file mode 100644
>> >> index 0000000..9f90354
>> >> --- /dev/null
>> >> +++ b/.gitignore
>> >> @@ -0,0 +1,2 @@
>> >> +.idea/*
>> >> +__pycache__/*
>> >> diff --git a/README.md b/README.md
>> >> index 0000000..8ebb224
>> >> --- /dev/null
>> >> +++ b/README.md
>> >> @@ -0,0 +1,2 @@
>> >> +# NewlibMarkup2SphinxConvertorPrivate
>> >> +(PRIVATE) This repo contains code for
>> >> NewlibMarkup2SphinxConvertorPrivate.
>> >> diff --git a/gen_rst_from_makedoc.py b/gen_rst_from_makedoc.py
>> >> new file mode 100755
>> >> index 0000000..da69c80
>> >> --- /dev/null
>> >> +++ b/gen_rst_from_makedoc.py
>> >> @@ -0,0 +1,125 @@
>> >> +#!/usr/bin/env python
>> >> +# RTEMS Tools Project (http://www.rtems.org/)
>> >> +# Copyright 2018 Danxue Huang (danxue.huang at gmail.com)
>> >> +# All rights reserved.
>> >> +# This file is part of the RTEMS Tools package in 'rtems-tools'.
>> >> +# Redistribution and use in source and binary forms, with or without
>> >> +# modification, are permitted provided that the following conditions
>> >> are
>> >> met:
>> >> +# 1. Redistributions of source code must retain the above copyright
>> >> notice,
>> >> +# this list of conditions and the following disclaimer.
>> >> +# 2. Redistributions in binary form must reproduce the above copyright
>> >> notice,
>> >> +# this list of conditions and the following disclaimer in the
>> >> documentation
>> >> +# and/or other materials provided with the distribution.
>> >> +# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
>> >> "AS
>> >> IS"
>> >> +# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
>> >> TO,
>> >> THE
>> >> +# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
>> >> PURPOSE
>> >> +# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR
>> >> CONTRIBUTORS
>> >> BE
>> >> +# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
>> >> +# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
>> >> +# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
>> >> BUSINESS
>> >> +# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER
>> >> IN
>> >> +# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
>> >> OTHERWISE)
>> >> +# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED
>> >> OF
>> >> THE
>> >> +# POSSIBILITY OF SUCH DAMAGE.
>> >> +import argparse
>> >> +import re
>> >> +import rst
>> >> +def is_command(s):
>> >> +    A command is a single word of at least 3 characters, all uppercase
>> >> +    :param s: input string
>> >> +    :return: True if s is a single command, otherwise False
>> >> +    return True if re.match('^[A-Z_]{3,}\s*$', s) else False
>> >> +def extract_comments(content):
>> >> +    Extract content inside of /* */
>> >> +    :param content: input file content
>> >> +    :return: extracted comments
>> >> +    comments = ''
>> >> +    comments_match = re.match('/\*(\*(?!/)|[^*])*\*/', content)
>> >> +    if comments_match:
>> >> +        wrapped_comments = comments_match.group()
>> >> +        comments =
>> >> wrapped_comments.lstrip('/*').rstrip('*/').lstrip().rstrip()
>> >> +    return comments
>> >> +def extract_command_and_text(content):
>> >> +    Extract command and text from input string content
>> >> +    :param content: input string containing command and text
>> >> +    :return: a tuple containing command and text
>> >> +    command = ''
>> >> +    text = ''
>> >> +    command_text_dict = {}
>> >> +    for line in content.splitlines():
>> >> +        if is_command(line):
>> >> +            if command and text:
>> >> +                command_text_dict[command] = text
>> >> +            command = line.rstrip()
>> >> +            text = ''
>> >> +        else:
>> >> +            text += line + '\n'
>> >> +    return command_text_dict
>> >> +def generate_rst(command_text_dict):
>> >> +    rst_str = ''
>> >> +    for command, text in command_text_dict.items():
>> >> +        rst_str += rst.get_command_processor(command)(command, text)
>> >> +    return rst_str
>> >> +def get_parser():
>> >> +    parser = argparse.ArgumentParser(
>> >> +        description='Convert newlib style markup to rst markup'
>> >> +    parser.add_argument(
>> >> +        '-s',
>> >> +        '--source_file_dir',
>> >> +        type=str,
>> >> +        help='Source file directory with newlib style comments',
>> >> +        '-d',
>> >> +        '--dest_file_dir',
>> >> +        type=str,
>> >> +        help='Destination directory for converted rst markup file',
>> >> +    return parser
>> >> +def main(source_file_dir, dest_file_dir):
>> >> +    with open(source_file_dir, 'r') as source_file,
>> >> open(dest_file_dir,
>> >> 'w') as dest_file:
>> >> +        file_content = source_file.read()
>> >> +        # Get comments inside of /* */
>> >> +        comments = extract_comments(file_content)
>> >> +        # Parse comments
>> >> +        command_text_dict = extract_command_and_text(comments)
>> >> +        # Process text based on command type
>> >> +        rst_str = generate_rst(command_text_dict)
>> >> +        dest_file.write(rst_str)
>> >> +if __name__ == '__main__':
>> >> +    args = get_parser().parse_args()
>> >> +    main(args.source_file_dir, args.dest_file_dir)
>> >> diff --git a/rst.py b/rst.py
>> >> index 0000000..2531f46
>> >> --- /dev/null
>> >> +++ b/rst.py
>> >> @@ -0,0 +1,104 @@
>> >> are
>> >> met:
>> >> notice,
>> >> notice,
>> >> documentation
>> >> "AS
>> >> IS"
>> >> TO,
>> >> THE
>> >> PURPOSE
>> >> CONTRIBUTORS
>> >> BE
>> >> BUSINESS
>> >> IN
>> >> OTHERWISE)
>> >> OF
>> >> THE
>> >> +import re
>> >> +def register_processor_command():
>> >> +    return {
>> >> +        'FUNCTION': gen_function_summary,
>> >> +        'SYNOPSIS': gen_code_block,
>> >> +        'ANSI_SYNOPSIS': gen_code_block,
>> >> +        'TRAD_SYNOPSIS': gen_code_block,
>> >> +        'TYPEDEF': gen_code_block,
>> >> +        'DESCRIPTION': gen_custom_directives,
>> >> +        'INDEX': gen_custom_directives,
>> >> +        'RETURNS': gen_custom_directives,
>> >> +        'PORTABILITY': gen_custom_directives,
>> >> +        'NOTES': gen_custom_directives,
>> >> +        'ERRORS': gen_custom_directives,
>> >> +        'BUGS': gen_custom_directives,
>> >> +        'WARNINGS': gen_custom_directives,
>> >> +        'QUICKREF': gen_nothing,
>> >> +        'MATHREF': gen_nothing,
>> >> +        'NEWPAGE': gen_nothing,
>> >> +        'START': gen_nothing,
>> >> +        'END': gen_nothing,
>> >> +        'SEEALSO': gen_custom_directives,
>> >> +def get_command_processor(command):
>> >> +    command_processor_dict = register_processor_command()
>> >> +    if command in command_processor_dict:
>> >> +        return command_processor_dict[command]
>> >> +    else:
>> >> +        print('Command {c} is not recognized, skip
>> >> it'.format(c=command))
>> >> +        return gen_nothing
>> >> +def gen_function_summary(command, text):
>> >> +    function_name = extract_function_name(text)
>> >> +    summary = extract_summary(text)
>> >> +    title = '.. {f}:\n\n{f} - {s}\n'.format(
>> >> +        f=function_name,
>> >> +        s=summary.capitalize()
>> >> +    dashes = '-' * len(text) + '\n'
>> >> +    func_name_index = '.. index:: {name}\n'.format(name=function_name)
>> >> +    summary_index = '.. index:: {summary}\n\n'.format(summary=summary)
>> >> +    return title + dashes + func_name_index + summary_index
>> >> +def extract_function_name(text):
>> >> +    function_name = ''
>> >> +    function_name_match = re.match('\s+(<<(>(?!>)|[^>])*>>)', text)
>> >> +    if function_name_match:
>> >> +        function_name =
>> >> function_name_match.group(1).lstrip('<<').rstrip('>>')
>> >> +    return function_name
>> >> +def extract_summary(text):
>> >> +    return text.split('---')[-1].rstrip()
>> >> +def gen_code_block(command, text):
>> >> +    return '**{c}:**\n\n.. code-block:: c\n\n{t}\n\n'.format(c =
>> >> command,
>> >> t=text)
>> >> +def gen_nothing(command, text):
>> >> +    return '\n\n'
>> >> +def gen_custom_directives(command, text):
>> >> +    return '**{c}:**\n\n{t}\n\n'.format(c=command, t=text)
>> >> diff --git a/strcmp.rst b/strcmp.rst
>> >> index 0000000..c1dc543
>> >> --- /dev/null
>> >> +++ b/strcmp.rst
>> >> @@ -0,0 +1,47 @@
>> >> +.. strcmp:
>> >> +strcmp - Character string compare
>> >> +.. index:: strcmp
>> >> +.. index:: character string compare
>> >> +**INDEX:**
>> >> +       strcmp
>> >> +**SYNOPSIS:**
>> >> +.. code-block:: c
>> >> +       #include <string.h>
>> >> +       int strcmp(const char *<[a]>, const char *<[b]>);
>> >> +**DESCRIPTION:**
>> >> +       <<strcmp>> compares the string at <[a]> to
>> >> +       the string at <[b]>.
>> >> +**RETURNS:**
>> >> +       If <<*<[a]>>> sorts lexicographically after <<*<[b]>>>,
>> >> +       <<strcmp>> returns a number greater than zero.  If the two
>> >> +       strings match, <<strcmp>> returns zero.  If <<*<[a]>>>
>> >> +       sorts lexicographically before <<*<[b]>>>, <<strcmp>> returns a
>> >> +       number less than zero.
>> >> +**PORTABILITY:**
>> >> +<<strcmp>> is ANSI C.
>> >> +<<strcmp>> requires no supporting OS subroutines.
>> >> 2.7.4
>> > _______________________________________________
>> > devel mailing list
>> > devel at rtems.org
>> > http://lists.rtems.org/mailman/listinfo/devel
