[PATCH] c-user: Update partition create documentation
Sebastian Huber
Thu Aug 2 13:26:29 UTC 2018
Close #3482.
c-user/partition_manager.rst | 24 +++++++++++++-----------
1 file changed, 13 insertions(+), 11 deletions(-)
diff --git a/c-user/partition_manager.rst b/c-user/partition_manager.rst
index 68761da..61a6c7a 100644
--- a/c-user/partition_manager.rst
+++ b/c-user/partition_manager.rst
@@ -162,21 +162,23 @@ DIRECTIVE STATUS CODES:
* - ``RTEMS_SUCCESSFUL``
- partition created successfully
* - ``RTEMS_INVALID_NAME``
- - invalid partition name
+ - invalid partition ``name``
* - ``RTEMS_TOO_MANY``
- too many partitions created
* - ``RTEMS_INVALID_ADDRESS``
- - address not on four byte boundary
+ - ``starting_address`` is not on a pointer size boundary
- ``starting_address`` is NULL
- ``id`` is NULL
* - ``RTEMS_INVALID_SIZE``
- - length or buffer size is 0
+ - ``length`` or ``buffer_size`` is 0
- - length is less than the buffer size
+ - ``length`` is less than the ``buffer_size``
- - buffer size not a multiple of 4
+ - ``buffer_size`` is not an integral multiple of the pointer size
+ * - ``RTEMS_INVALID_SIZE``
+ - ``buffer_size`` is less than two times the pointer size
* - ``RTEMS_MP_NOT_CONFIGURED``
- multiprocessing not configured
@@ -194,13 +196,13 @@ DESCRIPTION:
NOTES:
This directive will not cause the calling task to be preempted.
- The ``starting_address`` must be properly aligned for the target
- architecture.
+ The ``starting_address`` must be properly aligned to naturally store target
+ architecture pointers.
- The ``buffer_size`` parameter must be a multiple of the CPU alignment
- factor. Additionally, ``buffer_size`` must be large enough to hold two
- pointers on the target architecture. This is required for RTEMS to manage
- the buffers when they are free.
+ The ``buffer_size`` parameter must be an integral multiple of the pointer
+ size on the target architecture. Additionally, ``buffer_size`` must be
+ large enough to hold two pointers on the target architecture. This is
+ required for RTEMS to manage the buffers when they are free.
Memory from the partition is not used by RTEMS to store the Partition
Control Block.
2.13.7
