[PATCH 1/1] Refactor class and main module per comments
Fri Aug 3 12:22:34 UTC 2018
Hi Dannie,
Please send this as a squashed patch showing only your original
changes now, and provide with -v2
https://devel.rtems.org/wiki/Developer/Git/Users#CreatingaPatch
At this point we will need to see what Chris thinks about the Python.
I think it looks much better now.
Gedare
On Thu, Aug 2, 2018 at 10:48 PM, Dannie Huang <danxue.huang at gmail.com> wrote:
> Address multiple comments:
> 1. Refactored makedoc2rst class.
> 2. Refactored main module
> 3. Removed strcmp.rst
> On Thu, Aug 2, 2018 at 9:44 PM, Dannie Huang <danxue.huang at gmail.com> wrote:
>>  README.md                |  4 +-
>>  gen_rst_from_makedoc.py  | 31 +++++----------
>>  makedoc2rst.py           | 99
>>  makedoc2rst_converter.py | 85 -----------------------------------------
>>  strcmp.rst               | 47 -----------------------
>>  5 files changed, 110 insertions(+), 156 deletions(-)
>>  create mode 100644 makedoc2rst.py
>>  delete mode 100644 makedoc2rst_converter.py
>>  delete mode 100644 strcmp.rst
>> diff --git a/README.md b/README.md
>> index 8ebb224..64a3ba9 100644
>> --- a/README.md
>> +++ b/README.md
>> @@ -1,2 +1,2 @@
>> -# NewlibMarkup2SphinxConvertorPrivate
>> -(PRIVATE) This repo contains code for
>> NewlibMarkup2SphinxConvertorPrivate.
>> +# NewlibMarkup2SphinxConverter
>> +This repo contains code for NewlibMarkup2SphinxConverter
>> diff --git a/gen_rst_from_makedoc.py b/gen_rst_from_makedoc.py
>> index 4100756..8e4d9b0 100755
>> --- a/gen_rst_from_makedoc.py
>> +++ b/gen_rst_from_makedoc.py
>> @@ -30,7 +30,7 @@
>>  import argparse
>> -import makedoc2rst_converter
>> +import makedoc2rst
>>  def get_parser():
>> @@ -38,37 +38,24 @@ def get_parser():
>>          description='Convert newlib style markup to rst markup'
>>      parser.add_argument(
>> -        '-s',
>> -        '--source_file_path',
>> +        '-c',
>> +        '--c_file_path',
>>          type=str,
>> -        help='Path of source file with newlib style comments',
>> +        help='Path of c source file with newlib style comments',
>> -        '-d',
>> -        '--dest_file_path',
>> +        '-r',
>> +        '--rst_file_path',
>>          type=str,
>>          help='Path of destination file with rst markup',
>>      return parser
>> -def main(source_file_dir, dest_file_dir):
>> -    with open(source_file_dir, 'r') as source_file, open(dest_file_dir,
>> 'w') as dest_file:
>> -        file_content = source_file.read()
>> -        makedoc2rst = makedoc2rst_converter.makedoc2rst_converter()
>> -        # Get comments inside of /* */
>> -        comments = makedoc2rst.extract_comments(file_content)
>> -        # Parse comments
>> -        command_text_dict =
>> makedoc2rst.extract_command_and_text(comments)
>> -        # Process text based on command type
>> -        rst_str = makedoc2rst.generate_rst(command_text_dict)
>> -        dest_file.write(rst_str)
>> +def main(c_file, rst_file):
>> +    makedoc2rst.makedoc2rst(c_file, rst_file).convert()
>>  if __name__ == '__main__':
>>      args = get_parser().parse_args()
>> -    main(args.source_file_path, args.dest_file_path)
>> +    main(args.c_file_path, args.rst_file_path)
>> diff --git a/makedoc2rst.py b/makedoc2rst.py
>> new file mode 100644
>> index 0000000..d887323
>> --- /dev/null
>> +++ b/makedoc2rst.py
>> @@ -0,0 +1,99 @@
>> +#!/usr/bin/env python
>> +# RTEMS Tools Project (http://www.rtems.org/)
>> +# Copyright 2018 Danxue Huang (danxue.huang at gmail.com)
>> +# All rights reserved.
>> +# This file is part of the RTEMS Tools package in 'rtems-tools'.
>> +# Redistribution and use in source and binary forms, with or without
>> +# modification, are permitted provided that the following conditions are
>> met:
>> +# 1. Redistributions of source code must retain the above copyright
>> notice,
>> +# this list of conditions and the following disclaimer.
>> +# 2. Redistributions in binary form must reproduce the above copyright
>> notice,
>> +# this list of conditions and the following disclaimer in the
>> documentation
>> +# and/or other materials provided with the distribution.
>> +# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS
>> IS"
>> +# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
>> THE
>> +# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
>> PURPOSE
>> +# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS
>> BE
>> +# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
>> +# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
>> +# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
>> BUSINESS
>> +# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
>> +# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
>> +# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF
>> THE
>> +# POSSIBILITY OF SUCH DAMAGE.
>> +import re
>> +import rst
>> +class makedoc2rst():
>> +    """ Convert c source file with makedoc markup to rst markup file
>> +    c_file: c source file containing block comments (/* */) at the
>> beginning
>> +    rst_file: destination file with rst markup
>> +    def __init__(self, c_file, rst_file):
>> +        self.c_file = c_file
>> +        self.rst_file = rst_file
>> +    def convert(self):
>> +        """ Implementation of converting c file to rst file """
>> +        rst_str = ''
>> +        with open(self.c_file, 'r') as c_file:
>> +            # Get comments inside of /* */
>> +            comments = self._extract_comments(c_file.read())
>> +            # Parse comments
>> +            command_text_dict = self._extract_command_and_text(comments)
>> +            # Process text based on command type
>> +            for command, text in command_text_dict.items():
>> +                rst_str += rst.get_command_processor(command)(command,
>> text)
>> +        with open(self.rst_file, 'w') as rst_file:
>> +            rst_file.write(rst_str)
>> +        return rst_str
>> +    def _is_command(self, s):
>> +        A command is a single word of at least 3 characters, all
>> uppercase
>> +        :param s: input string
>> +        :return: True if s is a single command, otherwise False
>> +        return True if re.match('^[A-Z_]{3,}\s*$', s) else False
>> +    def _extract_comments(self, content):
>> +        Extract content inside of /* */
>> +        :param content: input file content
>> +        :return: extracted comments
>> +        comments = ''
>> +        comments_match = re.match('/\*(\*(?!/)|[^*])*\*/', content)
>> +        if comments_match:
>> +            wrapped_comments = comments_match.group()
>> +            comments =
>> wrapped_comments.lstrip('/*').rstrip('*/').lstrip().rstrip()
>> +        return comments
>> +    def _extract_command_and_text(self, comments):
>> +        Extract command and text from input string content
>> +        :param comments: input string containing command and text
>> +        :return: a tuple containing command and text
>> +        command = ''
>> +        text = ''
>> +        command_text_dict = {}
>> +        for line in comments.splitlines():
>> +            if self._is_command(line):
>> +                if command and text:
>> +                    command_text_dict[command] = text
>> +                command = line.rstrip()
>> +                text = ''
>> +            else:
>> +                text += line + '\n'
>> +        return command_text_dict
>> diff --git a/makedoc2rst_converter.py b/makedoc2rst_converter.py
>> deleted file mode 100644
>> index e4d2d72..0000000
>> --- a/makedoc2rst_converter.py
>> +++ /dev/null
>> @@ -1,85 +0,0 @@
>> -#!/usr/bin/env python
>> -# RTEMS Tools Project (http://www.rtems.org/)
>> -# Copyright 2018 Danxue Huang (danxue.huang at gmail.com)
>> -# All rights reserved.
>> -# This file is part of the RTEMS Tools package in 'rtems-tools'.
>> -# Redistribution and use in source and binary forms, with or without
>> -# modification, are permitted provided that the following conditions are
>> met:
>> -# 1. Redistributions of source code must retain the above copyright
>> notice,
>> -# this list of conditions and the following disclaimer.
>> -# 2. Redistributions in binary form must reproduce the above copyright
>> notice,
>> -# this list of conditions and the following disclaimer in the
>> documentation
>> -# and/or other materials provided with the distribution.
>> -# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS
>> IS"
>> -# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
>> THE
>> -# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
>> PURPOSE
>> -# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS
>> BE
>> -# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
>> -# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
>> -# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
>> BUSINESS
>> -# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
>> -# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
>> -# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF
>> THE
>> -# POSSIBILITY OF SUCH DAMAGE.
>> -import re
>> -import rst
>> -class makedoc2rst_converter():
>> -    @staticmethod
>> -    def is_command(s):
>> -        A command is a single word of at least 3 characters, all
>> uppercase
>> -        :param s: input string
>> -        :return: True if s is a single command, otherwise False
>> -        return True if re.match('^[A-Z_]{3,}\s*$', s) else False
>> -    @staticmethod
>> -    def extract_comments(content):
>> -        Extract content inside of /* */
>> -        :param content: input file content
>> -        :return: extracted comments
>> -        comments = ''
>> -        comments_match = re.match('/\*(\*(?!/)|[^*])*\*/', content)
>> -        if comments_match:
>> -            wrapped_comments = comments_match.group()
>> -            comments =
>> -        return comments
>> -    @staticmethod
>> -    def extract_command_and_text(content):
>> -        Extract command and text from input string content
>> -        :param content: input string containing command and text
>> -        :return: a tuple containing command and text
>> -        command = ''
>> -        text = ''
>> -        command_text_dict = {}
>> -        for line in content.splitlines():
>> -            if makedoc2rst_converter.is_command(line):
>> -                if command and text:
>> -                    command_text_dict[command] = text
>> -                command = line.rstrip()
>> -                text = ''
>> -            else:
>> -                text += line + '\n'
>> -        return command_text_dict
>> -    @staticmethod
>> -    def generate_rst(command_text_dict):
>> -        rst_str = ''
>> -        for command, text in command_text_dict.items():
>> -            rst_str += rst.get_command_processor(command)(command, text)
>> -        return rst_str
>> diff --git a/strcmp.rst b/strcmp.rst
>> index c1dc543..0000000
>> --- a/strcmp.rst
>> +++ /dev/null
>> @@ -1,47 +0,0 @@
>> -.. strcmp:
>> -strcmp - Character string compare
>> -.. index:: strcmp
>> -.. index:: character string compare
>> -**INDEX:**
>> -       strcmp
>> -**SYNOPSIS:**
>> -.. code-block:: c
>> -       #include <string.h>
>> -       int strcmp(const char *<[a]>, const char *<[b]>);
>> -**DESCRIPTION:**
>> -       <<strcmp>> compares the string at <[a]> to
>> -       the string at <[b]>.
>> -**RETURNS:**
>> -       If <<*<[a]>>> sorts lexicographically after <<*<[b]>>>,
>> -       <<strcmp>> returns a number greater than zero.  If the two
>> -       strings match, <<strcmp>> returns zero.  If <<*<[a]>>>
>> -       sorts lexicographically before <<*<[b]>>>, <<strcmp>> returns a
>> -       number less than zero.
>> -**PORTABILITY:**
>> -<<strcmp>> is ANSI C.
>> -<<strcmp>> requires no supporting OS subroutines.
>> 2.7.4
> devel mailing list
> devel at rtems.org
