[PATCH v2] c-user: Update partition create documentation
Fri Aug 3 12:24:08 UTC 2018
Thanks
On Fri, Aug 3, 2018 at 1:57 AM, Sebastian Huber
> Add an example.
> Close #3482.
>  c-user/partition_manager.rst | 65 ++++++++++++++++++++++++++++++++++++--------
>  1 file changed, 54 insertions(+), 11 deletions(-)
> diff --git a/c-user/partition_manager.rst b/c-user/partition_manager.rst
> index 68761da..010f63a 100644
> --- a/c-user/partition_manager.rst
> +++ b/c-user/partition_manager.rst
> @@ -162,21 +162,23 @@ DIRECTIVE STATUS CODES:
>       * - ``RTEMS_SUCCESSFUL``
>         - partition created successfully
>       * - ``RTEMS_INVALID_NAME``
> -       - invalid partition name
> +       - invalid partition ``name``
>       * - ``RTEMS_TOO_MANY``
>         - too many partitions created
>       * - ``RTEMS_INVALID_ADDRESS``
> -       - address not on four byte boundary
> +       - ``starting_address`` is not on a pointer size boundary
>         - ``starting_address`` is NULL
>         - ``id`` is NULL
>       * - ``RTEMS_INVALID_SIZE``
> -       - length or buffer size is 0
> +       - ``length`` or ``buffer_size`` is 0
> -       - length is less than the buffer size
> +       - ``length`` is less than the ``buffer_size``
> -       - buffer size not a multiple of 4
> +       - ``buffer_size`` is not an integral multiple of the pointer size
> +     * - ``RTEMS_INVALID_SIZE``
> +       - ``buffer_size`` is less than two times the pointer size
>       * - ``RTEMS_MP_NOT_CONFIGURED``
>         - multiprocessing not configured
> @@ -194,13 +196,18 @@ DESCRIPTION:
>  NOTES:
>      This directive will not cause the calling task to be preempted.
> -    The ``starting_address`` must be properly aligned for the target
> -    architecture.
> +    The partition buffer area specified by the ``starting_address`` must be
> +    properly aligned.  It must be possible to directly store target
> +    architecture pointers and the also the user data.  For example, if the user
> +    data contains some long double or vector data types, the partition buffer
> +    area and the buffer size must take the alignment of these types into
> +    account which is usually larger than the pointer alignment.  A cache line
> +    alignment may be also a factor.
> -    The ``buffer_size`` parameter must be a multiple of the CPU alignment
> -    factor.  Additionally, ``buffer_size`` must be large enough to hold two
> -    pointers on the target architecture.  This is required for RTEMS to manage
> -    the buffers when they are free.
> +    The ``buffer_size`` parameter must be an integral multiple of the pointer
> +    size on the target architecture.  Additionally, ``buffer_size`` must be
> +    large enough to hold two pointers on the target architecture.  This is
> +    required for RTEMS to manage the buffers when they are free.
>      Memory from the partition is not used by RTEMS to store the Partition
>      Control Block.
> @@ -226,6 +233,42 @@ NOTES:
>      The total number of global objects, including partitions, is limited by the
>      maximum_global_objects field in the Configuration Table.
> +EXAMPLE:
> +    .. code-block:: c
> +        #include <rtems.h>
> +        #include <rtems/chain.h>
> +        #include <assert.h>
> +        typedef struct {
> +          char less;
> +          short more;
> +        } item;
> +        union {
> +          item             data;
> +          rtems_chain_node node;
> +        } items[ 13 ];
> +        rtems_id create_partition(void)
> +          rtems_id          id;
> +          rtems_status_code sc;
> +          sc = rtems_partition_create(
> +            rtems_build_name( 'P', 'A', 'R', 'T' ),
> +            items,
> +            sizeof( items ),
> +            sizeof( items[ 0 ] ),
> +            RTEMS_DEFAULT_ATTRIBUTES,
> +            &id
> +          assert(sc == RTEMS_SUCCESSFUL);
> +          return id;
>  .. raw:: latex
>     \clearpage
> 2.13.7
> devel mailing list
> devel at rtems.org
