[PATCH v2] Coverage: Add support to generate separate reports for each symbol-set
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Sun Aug 5 20:58:14 UTC 2018
ping :)
On 3 August 2018 at 03:15, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
wrote:
> Hello,
> If you find some time, please do a final review of this patch and provide
> suggestions if it's not mergeable yet :)
> There are only three days left, I seek some advice on the wrapup work on
> coverage
> analysis . The current status is :
> * This patch adds support to generate separate report for each symbol-sets.
> * I sent a patch a day ago with the symbol-sets and the respective
> libraray
> addresses added to the symbol-sets.ini file. I have also attached a
> screenshot of the report.
> Joel, does the report look good to you ?
> What are the next steps to get the reports published ? Is it intended to
> be a
> post GSoC work ?
> * I have completed the dumper for gcno files. There are still more
> understanding
> needed to make sense out of the data, but all the data can be dumped in
> a human
> readable format now. Please have a look at the generated txt file.
> https://github.com/thelunatic/gcno_dumper/blob/master/gcno_dump.txt
> <https://github.com/thelunatic/gcno_dumper/blob/master/gcno_dump.txt>
> * Any other suggestions ?
> Thanks
> --vijayk
> On 30 July 2018 at 22:55, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
> wrote:
>> Invoke covoar multiple times from the script to generate separate
>> reports for each symbol-set.
>> tester/rt/coverage.py | 38 ++++++++++++++++++--------------------
>> 1 file changed, 18 insertions(+), 20 deletions(-)
>> diff --git a/tester/rt/coverage.py b/tester/rt/coverage.py
>> index 7dd5002..c979332 100644
>> --- a/tester/rt/coverage.py
>> +++ b/tester/rt/coverage.py
>> @@ -99,8 +99,8 @@ class summary:
>> return line.strip().split(' ')[0]
>> class report_gen_html:
>> - def __init__(self, p_symbol_sets_list, build_dir, rtdir, bsp):
>> - self.symbol_sets_list = ['score']
>> + def __init__(self, symbol_sets, build_dir, rtdir, bsp):
>> + self.symbol_sets = symbol_sets
>> self.build_dir = build_dir
>> self.partial_reports_files = list(['index.html', 'summary.txt'])
>> self.number_of_columns = 1
>> @@ -109,7 +109,7 @@ class report_gen_html:
>> def _find_partial_reports(self):
>> partial_reports = {}
>> - for symbol_set in self.symbol_sets_list:
>> + for symbol_set in self.symbol_sets:
>> set_summary = summary(path.join(self.bsp + "-coverage",
>> symbol_set))
>> set_summary.parse()
>> @@ -204,7 +204,7 @@ class report_gen_html:
>> def add_covoar_src_path(self):
>> table_js_path = path.join(self.covoar_src_path, 'table.js')
>> covoar_css_path = path.join(self.covoar_src_path, 'covoar.css')
>> symbol_set_dir = path.join(self.build_dir,
>> self.bsp + '-coverage',
>> symbol_set)
>> html_files = os.listdir(symbol_set_dir)
>> @@ -264,27 +264,23 @@ class symbol_parser(object):
>> for sset in self.ssets:
>> lib = path.join(self.build_dir, config.get('libraries',
>> sset))
>> self.symbol_sets[sset] = lib.encode('utf-8')
>> + return self.ssets
>> except:
>> raise error.general('Symbol set parsing failed')
>> - def _write_ini(self):
>> + def write_ini(self, symbol_set):
>> config = configparser.ConfigParser()
>> try:
>> - sets = ', '.join(self.symbol_sets.keys())
>> + sset = symbol_set
>> config.add_section('symbol-sets')
>> - config.set('symbol-sets', 'sets', sets)
>> - for key in self.symbol_sets.keys():
>> - config.add_section(key)
>> - config.set(key, 'libraries', self.symbol_sets[key])
>> + config.set('symbol-sets', 'sets', sset)
>> + config.add_section(sset)
>> + config.set(sset, 'libraries', self.symbol_sets[sset])
>> with open(self.symbol_select_file, 'w') as conf:
>> config.write(conf)
>> except:
>> raise error.general('symbol parser write failed')
>> - def run(self):
>> - self.parse()
>> - self._write_ini()
>> class covoar(object):
>> Covoar runner
>> @@ -371,20 +367,22 @@ class coverage_run(object):
>> self.symbol_select_path,
>> self.symbol_set,
>> build_dir)
>> - parser.run()
>> - covoar_runner = covoar(self.test_dir,
>> + symbol_sets = parser.parse()
>> + for sset in symbol_sets:
>> + parser.write_ini(sset)
>> + covoar_runner = covoar(self.test_dir,
>> self.executables,
>> self.explanations_txt,
>> self.trace)
>> - covoar_runner.run('score', self.symbol_select_path)
>> - self._generate_reports();
>> + covoar_runner.run(sset, self.symbol_select_path)
>> + self._generate_reports(symbol_sets);
>> self._summarize();
>> finally:
>> self._cleanup();
>> - def _generate_reports(self):
>> + def _generate_reports(self, symbol_sets):
>> log.notice('Coverage generating reports')
>> if self.report_format == 'html':
>> - report = report_gen_html(self.symbol_sets,
>> + report = report_gen_html(symbol_sets,
>> self.build_dir,
>> self.rtdir,
>> self.macros['bsp'])
>> 2.14.4
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180806/c907b834/attachment-0001.html>
