Version of FreeBSD for libbsd
Joel Sherrill
joel at rtems.org
Sun Aug 5 22:17:55 UTC 2018
On Sun, Aug 5, 2018, 3:25 PM Christian Mauderer <list at c-mauderer.de> wrote:
> Am 05.08.2018 um 19:21 schrieb Joel Sherrill:
> > On Sun, Aug 5, 2018, 8:59 AM Christian Mauderer <list at c-mauderer.de
> > <mailto:list at c-mauderer.de>> wrote:
> > Am 03.08.2018 um 19:30 schrieb Joel Sherrill:
> > > Hi
> > > libbsd.txt says this is based on FreeBSD 9.2 but I thought it
> > > had been updated past that.
> > > Also how could I have figured this out otherwise?
> > > If it matters, there are also man pages references to FreeBSD 9.2.
> > > And is the Changes up to date? It has a date of 2017?
> > > Thanks.
> > > --joel
> > Hello Joel,
> > since we have a single release for all sources since about one year,
> the
> > simplest method to find out which release is used is to take a look
> at
> > the freebsd-org submodule. Currently that's revision 642b174da of the
> > FreeBSD git mirror which is from 2017-04-04.
> > So it should be something between 11 and 12.
> > Then what do you recommend the phrase be in the libbsd.txt since it says
> > 9 right now.
> Currently it's
> RTEMS uses FreeBSD 9.2 as the source of its TCP/IP and USB stacks.
> How about something like the following instead:
> The libbsd makes FreeBSD subsystems like TCP/IP, USB, SD and some more
> usable for RTEMS. It tries to follow the FreeBSD development as close as
> possible and therefore is updated to the latest FreeBSD HEAD revision
> from time to time.
This is much better. Before it was dated and I knew is was wrong.bu5 not
how to fix it.
Could it also provide a pointer/link to info in the FreeBSD submodule so
someone can pull it and answer the question precisely?
I was looking for a specific answer to put in the paper we have been
working on. It shouldn't be hard or require too much magic to answer this
question. :)
> It seems that we have two types of man page links:
> 1. In the "Network Stack Features" section and two other points:
> http://www.freebsd.org/cgi/man.cgi?query=unix&sektion=4&apropos=0&manpath=FreeBSD+9.2-RELEASE[UNIX(4)]
> UNIX-domain protocol family
> 2. The following style for all other links:
> http://www.freebsd.org/cgi/man.cgi?query=device
> I'm not sure whether the "Network Stack Features" is still up to date
> but if it is, maybe we should migrate to the style 2.
As long as we are tracking reasonably close to their master, would it not
make sense to just use their master docs? Which I think is the latter form.
Thanks.
--joel
> Best regards
> Christian
> > And should the man page links be updated? I know they rarely change
> but...
> > Thanks.
> > Best regards
> > Christian
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180805/c428506e/attachment.html>
