Inlined code
Mon Aug 6 00:51:21 UTC 2018
On 05/08/2018 19:39, Christian Mauderer wrote:
> Am 05.08.2018 um 04:00 schrieb Chris Johns:
>> Hi,
>> I have been working on migrating covoar in the rtems-tools repo to DWARF. The
>> goal is remove objdump parsing and to get accurate details about the functions
>> being covered. This is an unfunded task.
>> The work has resulted in a close examination of inlined code in RTEMS and what I
>> saw alarmed me so I have added a report to the rtems-exeinfo tool in rtems-tools
>> (the change is to be posted for review once I get the coverage tests running).
>> A summary report for hello.exe on RTEMS 5 for SPARC is:
>> inlined funcs   : 1412
>>     total funcs : 1956
>>  % inline funcs : 72%
>>      total size : 174616
>>     inline size : 81668
>>   % inline size : 46%
>> This is a small application so it could be argued that skews the figures. A
>> large C/C++ application built with -O2 running on RTEMS 4.11 ARM reports the
>> inline usage as:
>> inlined funcs   : 10370
>>     total funcs : 17700
>>  % inline funcs : 58%
>>      total size : 3066240
>>     inline size : 1249514
>>   % inline size : 40%
>> This does not seem right to me.
>> The report is new and there could be issues in the DWARF handling that feeds
>> this report however I am posting this to start a discussion on the topic of
>> inlining.
>> I attach the report for hello.exe. The `-i` option generates the inline report.
>> The first section is a summary showing the total number of functions in the
>> executable that have machine code and are flagged as inline. The report lists
>> the percentage of functions that are inlined and the percentage of machine code
>> that is inlined. The values seem high to me.
>> The second table lists inline functions that are repeated sorted from the
>> largest foot print to the smallest. The first column the total size of machine
>> code in the executable and the second column the number of instances.
>> The third table is the list of inline functions sorted from largest machine code
>> footprint to smallest. The second column are flags of which there is one. A `E`
>> indicates the inline function is also external which means the compiler has
>> created an external reference to this function, ie an address-of is being taken.
>> The third column is the address in the executable so you can take a look with
>> objdump at the machine code.
>> We need to ask some important question in relation to inlining. It is cheap to
>> add and we all feel the code we add needs to be fast and needs to be inlined but
>> does it really need to be inlined?
>> Some pieces of code do need to be inlined and the overhead is just that an
>> overhead, for example in the large C/C++ application there is a low level
>> volatile hardware write routing with close to 300 instances and a code size of
>> 10K. This code needs to be inlined for performance reasons but should the size
>> on average be 40 bytes, I doubt it.
>> Can we be more judicious with our use of the inline keyword?
>> Is the performance gain we really expect or is the actual overhead of a call
>> frame not worth saving?
>> What are the real costs of inlining a piece of code? It adds size to the
>> executable and depending on the code being inlined it complicates coverage
>> analysis be adding extra branch points.
>> The metrics to determine what should be inlined is complicated and I do not
>> think we have a suitable policy in place. I believe it is time we to create one.
>> The issue is not limited to our code, gcc, newlib and libstdc++ seem to have
>> some code that should be looked at more closely. For example __udivmoddi4, and
>> __sprint_r.
>> Chris
> Hello Chris,
> I just took a look at one of the first function in your list: __sprint_r
> https://sourceware.org/git/gitweb.cgi?p=newlib-cygwin.git;a=blob;f=newlib/libc/stdio/vfprintf.c;h=c4bf2dbe31da64462ecccec97c8e901e4ffadd44;hb=HEAD#l403
> As far as I can see, there is no explicit inline key word for that
> function. So in that case, the compiler decided that it would be a good
> idea to inline that function.
Thanks and yes. At this point in time I cannot tell what is happening and I am
not sure the tool is reporting accurate data, I need to investigate.
> I'm not sure whether I might just haven't seen it but is there a
> possibility to distinguish between functions that have been inlined by
> the compiler and ones that have been inlined due to the "inline" keyword
> without looking at every definition?
I am not sure. The DWARF data is complex and detailed and I view this initial
step into the area of using DWARF to perform static analysis of RTEMS
executables as green.
DWARF does provide declaration attributes. I need to review the DWARF data and
standard to determine if we can tell what is declared inline and what has been
inlined. I think it would be good to know.
> Did you try compiling with size optimization? I would expect that the
> compiler would inline far less functions and maybe even ignore some
> "inline" keywords. As far as I know it's more of a hint to the compiler.
Not yet. A complete tool build with those options is a lot of effort and I am
still not comfortable the report is accurate. I think this is something that
should be done at some point. I think it would create an interesting data point.
> I would only worry about functions that are still inlined if size
> optimization is selected.
I think we need to review the functions we currently have tagged as inline. I
think the only way we can do this is with real data.
> That's the case when I tell the compiler to
> make the program as small as possible. In all other cases I want some
> well balanced optimum between speed and size. Inlining small functions
> is OK in that case if you ask me.
How do you define this, ie what is the inline policy we use?
How do you audit this?
