[PATCH] rfs: Remove erroneous call of rtems_disk_release()
Sebastian Huber
Mon Aug 6 06:12:24 UTC 2018
The function rtems_rfs_buffer_sync() erroneously calls
rtems_disk_release(). This screws up the reference counting of the disk.
Update #3484.
cpukit/libfs/src/rfs/rtems-rfs-buffer.c | 1 -
1 file changed, 1 deletion(-)
diff --git a/cpukit/libfs/src/rfs/rtems-rfs-buffer.c b/cpukit/libfs/src/rfs/rtems-rfs-buffer.c
index 33beb54700..4a66840b17 100644
--- a/cpukit/libfs/src/rfs/rtems-rfs-buffer.c
+++ b/cpukit/libfs/src/rfs/rtems-rfs-buffer.c
@@ -397,7 +397,6 @@ rtems_rfs_buffer_sync (rtems_rfs_file_system* fs)
rtems_status_text (sc));
result = EIO;
- rtems_disk_release (fs->disk);
#else
if (fsync (fs->device) < 0)
2.13.7
