[PATCH 08/21] libtests/block08: Use rtems_blkdev_create()
Mon Aug 6 07:14:40 UTC 2018
Update #3358.
 testsuites/libtests/block08/bdbuf_tests.c | 59 +++++++++----------------------
 testsuites/libtests/block08/bdbuf_tests.h |  7 +---
 testsuites/libtests/block08/system.h      |  9 ++---
 testsuites/libtests/block08/test_disk.c   | 29 +++++----------
 4 files changed, 27 insertions(+), 77 deletions(-)
diff --git a/testsuites/libtests/block08/bdbuf_tests.c b/testsuites/libtests/block08/bdbuf_tests.c
index 66e69d4fbd..8cf0111dbc 100644
--- a/testsuites/libtests/block08/bdbuf_tests.c
+++ b/testsuites/libtests/block08/bdbuf_tests.c
@@ -13,17 +13,20 @@
 #include "config.h"
 #endif
+#include <sys/stat.h>
+#include <fcntl.h>
+#include <unistd.h>
 #include <rtems/io.h>
-#include <rtems/diskdevs.h>
 #include <rtems/bdbuf.h>
 #include <rtems/inttypes.h>
 #include "bdbuf_tests.h"
+#include <tmacros.h>
 struct bdbuf_test_descr {
     void (* main)(void);
@@ -105,17 +108,10 @@ bdbuf_test_start_aux_task(rtems_name name,
 void
 run_bdbuf_tests()
-    rtems_disk_device  *disk;
-    rtems_status_code   sc;
-    dev_t               dev = -1;
-    dev_t               test_dev;
-    unsigned int        i;
-    rtems_device_major_number  major;
-    rtems_driver_address_table testdisk = {
-        test_disk_initialize,
-        RTEMS_GENERIC_BLOCK_DEVICE_DRIVER_ENTRIES
+    rtems_status_code sc;
+    unsigned int      i;
+    int               fd;
+    int               rv;
     /* Create a message queue to get events from disk driver. */
     sc = rtems_message_queue_create(TEST_TASK_RX_MQUEUE_NAME,
@@ -130,40 +126,17 @@ run_bdbuf_tests()
         return;
-    /* Register a disk device that is used in tests */
-    sc = rtems_io_register_driver(0, &testdisk, &major);
-    if (sc != RTEMS_SUCCESSFUL)
-        printf("Failed to register TEST DEVICE: %d\n", sc);
-        return;
+    sc = test_disk_initialize();
+    rtems_test_assert(sc == RTEMS_SUCCESSFUL);
-    test_dev = -1;
-    while ((disk = rtems_disk_next(dev)) != NULL)
-        printf(
-          "DEV: %s [%" PRIdrtems_blkdev_bnum "]\n",
-         disk->name,
-          disk->size
-        dev = disk->dev;
-        if (strcmp(disk->name, TEST_DISK_NAME) == 0)
-            test_dev = dev;
-        rtems_disk_release(disk);
+    fd = open(TEST_DISK_NAME, O_RDWR);
+    rtems_test_assert(fd >= 0);
-    if (test_dev == (dev_t)-1)
-        printf("Failed to find %s disk\n", TEST_DISK_NAME);
-        return;
+    rv = rtems_disk_fd_get_disk_device(fd, &test_dd);
+    rtems_test_assert(rv == 0);
-    test_dd = rtems_disk_obtain(test_dev);
-    if (test_dd == NULL)
-        printf("Failed to obtain %s disk\n", TEST_DISK_NAME);
-        return;
+    rv = close(fd);
      * On initialization test disk device driver registers
diff --git a/testsuites/libtests/block08/bdbuf_tests.h b/testsuites/libtests/block08/bdbuf_tests.h
index 72502b3e38..8924eb1f14 100644
--- a/testsuites/libtests/block08/bdbuf_tests.h
+++ b/testsuites/libtests/block08/bdbuf_tests.h
@@ -17,7 +17,6 @@
 #include <rtems/bspIo.h>
 #ifdef __cplusplus
@@ -46,11 +45,7 @@ extern void bdbuf_test4_1_main(void);
 extern void bdbuf_test4_2_main(void);
 extern void bdbuf_test4_3_main(void);
-extern rtems_device_driver
-test_disk_initialize(
-    rtems_device_major_number major,
-    rtems_device_minor_number minor,
-    void *arg);
+extern rtems_status_code test_disk_initialize(void);
 #define ARRAY_NUM(a_) (sizeof(a_) / sizeof(a_[0]))
diff --git a/testsuites/libtests/block08/system.h b/testsuites/libtests/block08/system.h
index 8ceb17e929..bb4a9a0bb1 100644
--- a/testsuites/libtests/block08/system.h
+++ b/testsuites/libtests/block08/system.h
@@ -24,6 +24,8 @@ rtems_task Init(
 #define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
 #define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 4
 #define CONFIGURE_MAXIMUM_TASKS               28
 #define CONFIGURE_MAXIMUM_TIMERS              10
 #define CONFIGURE_MAXIMUM_SEMAPHORES          20
@@ -40,13 +42,6 @@ rtems_task Init(
 #define CONFIGURE_BDBUF_BUFFER_MIN_SIZE     (512)
 #define CONFIGURE_BDBUF_BUFFER_MAX_SIZE     (512)
- * Define it here in order to be able to register
- * test driver after RTEMS initialization phase
- * (on test start-up).
-#define CONFIGURE_MAXIMUM_DRIVERS 5
 #define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
 #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
diff --git a/testsuites/libtests/block08/test_disk.c b/testsuites/libtests/block08/test_disk.c
index aa33803b23..5cc15d280a 100644
--- a/testsuites/libtests/block08/test_disk.c
+++ b/testsuites/libtests/block08/test_disk.c
@@ -21,8 +21,7 @@
 #include <inttypes.h>
-#include "rtems/blkdev.h"
-#include "rtems/diskdevs.h"
+#include <rtems/blkdev.h>
@@ -58,9 +57,7 @@ test_disk_ioctl(rtems_disk_device *dd, uint32_t req, void *argp)
         default:
-            printf("%s() Unexpected request comes %" PRIu32 "\n",
-                   __FUNCTION__, req);
-            return -1;
+            return rtems_blkdev_ioctl (dd, req, argp);
     memset(&msg, 0, sizeof(msg));
@@ -107,25 +104,15 @@ test_disk_ioctl(rtems_disk_device *dd, uint32_t req, void *argp)
     return 0;
-rtems_device_driver
-    void *arg)
+rtems_status_code
+test_disk_initialize(void)
     rtems_status_code rc;
-    dev_t             dev;
-    rc = rtems_disk_io_initialize();
-    if (rc != RTEMS_SUCCESSFUL)
-        return rc;
-    dev = rtems_filesystem_make_dev_t(major, minor);
-    rc = rtems_disk_create_phys(dev,
-                                TEST_DISK_BLOCK_SIZE, TEST_DISK_BLOCK_NUM,
-                                test_disk_ioctl,
-                                NULL,
-                                TEST_DISK_NAME);
+    rc = rtems_blkdev_create(TEST_DISK_NAME,
+                             TEST_DISK_BLOCK_SIZE, TEST_DISK_BLOCK_NUM,
+                             test_disk_ioctl,
+                             NULL);
         printf("Failed to create %s disk\n", TEST_DISK_NAME);
2.13.7
