[PATCH 03/21] flashdisk: Use rtems_blkdev_create()
Mon Aug 6 07:14:35 UTC 2018
Update #3358.
 cpukit/libblock/src/flashdisk.c        | 69 +++++++++++-----------------------
 testsuites/libtests/flashdisk01/init.c |  9 +----
 2 files changed, 23 insertions(+), 55 deletions(-)
diff --git a/cpukit/libblock/src/flashdisk.c b/cpukit/libblock/src/flashdisk.c
index 0543f301df..37bcd9d150 100644
--- a/cpukit/libblock/src/flashdisk.c
+++ b/cpukit/libblock/src/flashdisk.c
@@ -41,10 +41,10 @@
+#include <unistd.h>
 #include <inttypes.h>
 #include <rtems/blkdev.h>
-#include <rtems/diskdevs.h>
 #include <rtems/flashdisk.h>
 #include <rtems/thread.h>
@@ -206,16 +206,6 @@ typedef struct rtems_flashdisk
 } rtems_flashdisk;
- * The array of flash disks we support.
-static rtems_flashdisk* rtems_flashdisks;
- * The number of flash disks we have.
-static uint32_t rtems_flashdisk_count;
  * The CRC16 factor table. Created during initialisation.
 static uint16_t* rtems_fdisk_crc16_factor;
@@ -2374,19 +2364,17 @@ rtems_fdisk_print_status (rtems_flashdisk* fd)
 static int
 rtems_fdisk_ioctl (rtems_disk_device *dd, uint32_t req, void* argp)
-  dev_t                     dev = rtems_disk_get_device_identifier (dd);
-  rtems_device_minor_number minor = rtems_filesystem_dev_minor_t (dev);
-  rtems_blkdev_request*     r = argp;
+  rtems_flashdisk*      fd = rtems_disk_get_driver_data (dd);
+  rtems_blkdev_request* r = argp;
   errno = 0;
-  rtems_mutex_lock (&rtems_flashdisks[minor].lock);
+  rtems_mutex_lock (&fd->lock);
   switch (req)
     case RTEMS_BLKIO_REQUEST:
-      if ((minor >= rtems_flashdisk_count) ||
-          (rtems_flashdisks[minor].device_count == 0))
+      if (fd->device_count == 0)
         errno = ENODEV;
@@ -2395,11 +2383,11 @@ rtems_fdisk_ioctl (rtems_disk_device *dd, uint32_t req, void* argp)
         switch (r->req)
           case RTEMS_BLKDEV_REQ_READ:
-            errno = rtems_fdisk_read (&rtems_flashdisks[minor], r);
+            errno = rtems_fdisk_read (fd, r);
             break;
           case RTEMS_BLKDEV_REQ_WRITE:
-            errno = rtems_fdisk_write (&rtems_flashdisks[minor], r);
+            errno = rtems_fdisk_write (fd, r);
             break;
           default:
@@ -2410,28 +2398,28 @@ rtems_fdisk_ioctl (rtems_disk_device *dd, uint32_t req, void* argp)
       break;
     case RTEMS_FDISK_IOCTL_ERASE_DISK:
-      errno = rtems_fdisk_erase_disk (&rtems_flashdisks[minor]);
+      errno = rtems_fdisk_erase_disk (fd);
       break;
     case RTEMS_FDISK_IOCTL_COMPACT:
-      errno = rtems_fdisk_compact (&rtems_flashdisks[minor]);
+      errno = rtems_fdisk_compact (fd);
       break;
     case RTEMS_FDISK_IOCTL_ERASE_USED:
-      errno = rtems_fdisk_erase_used (&rtems_flashdisks[minor]);
+      errno = rtems_fdisk_erase_used (fd);
       break;
     case RTEMS_FDISK_IOCTL_MONITORING:
-      errno = rtems_fdisk_monitoring_data (&rtems_flashdisks[minor],
+      errno = rtems_fdisk_monitoring_data (fd,
                                            (rtems_fdisk_monitor_data*) argp);
       break;
     case RTEMS_FDISK_IOCTL_INFO_LEVEL:
-      rtems_flashdisks[minor].info_level = (uintptr_t) argp;
+      fd->info_level = (uintptr_t) argp;
       break;
     case RTEMS_FDISK_IOCTL_PRINT_STATUS:
-      errno = rtems_fdisk_print_status (&rtems_flashdisks[minor]);
+      errno = rtems_fdisk_print_status (fd);
       break;
     default:
@@ -2439,7 +2427,7 @@ rtems_fdisk_ioctl (rtems_disk_device *dd, uint32_t req, void* argp)
       break;
-  rtems_mutex_unlock (&rtems_flashdisks[minor].lock);
+  rtems_mutex_unlock (&fd->lock);
   return errno == 0 ? 0 : -1;
@@ -2462,30 +2450,21 @@ rtems_fdisk_initialize (rtems_device_major_number major,
   rtems_flashdisk*              fd;
   rtems_status_code             sc;
-  sc = rtems_disk_io_initialize ();
-  if (sc != RTEMS_SUCCESSFUL)
-    return sc;
   sc = rtems_fdisk_crc16_gen_factors (0x8408);
       return sc;
-  rtems_flashdisks = calloc (rtems_flashdisk_configuration_size,
-                             sizeof (rtems_flashdisk));
-  if (!rtems_flashdisks)
+  fd = calloc (rtems_flashdisk_configuration_size, sizeof (*fd));
+  if (!fd)
     return RTEMS_NO_MEMORY;
-  for (minor = 0; minor < rtems_flashdisk_configuration_size; minor++, c++)
+  for (minor = 0; minor < rtems_flashdisk_configuration_size; minor++, c++, fd++)
     char     name[] = RTEMS_FLASHDISK_DEVICE_BASE_NAME "a";
-    dev_t    dev = rtems_filesystem_make_dev_t (major, minor);
     uint32_t device;
     uint32_t blocks = 0;
     int      ret;
-    fd = &rtems_flashdisks[minor];
     name [sizeof(RTEMS_FLASHDISK_DEVICE_BASE_NAME)] += minor;
     fd->major              = major;
@@ -2520,13 +2499,11 @@ rtems_fdisk_initialize (rtems_device_major_number major,
     rtems_mutex_init (&fd->lock, "Flash Disk");
-    sc = rtems_disk_create_phys(dev, c->block_size,
-                                blocks - fd->unavail_blocks,
-                                rtems_fdisk_ioctl, NULL, name);
+    sc = rtems_blkdev_create(name, c->block_size, blocks - fd->unavail_blocks,
+                             rtems_fdisk_ioctl, fd);
       rtems_mutex_destroy (&fd->lock);
-      rtems_disk_delete (dev);
       free (fd->copy_buffer);
       free (fd->blocks);
       free (fd->devices);
@@ -2546,7 +2523,7 @@ rtems_fdisk_initialize (rtems_device_major_number major,
                                              sizeof (rtems_fdisk_segment_ctl));
       if (!fd->devices[device].segments)
+        unlink (name);
         free (fd->blocks);
@@ -2581,7 +2558,7 @@ rtems_fdisk_initialize (rtems_device_major_number major,
     ret = rtems_fdisk_recover_block_mappings (fd);
     if (ret)
+      unlink (name);
       free (fd->blocks);
@@ -2594,7 +2571,7 @@ rtems_fdisk_initialize (rtems_device_major_number major,
     ret = rtems_fdisk_compact (fd);
     if (ret)
+      unlink (name);
       free (fd->blocks);
@@ -2605,7 +2582,5 @@ rtems_fdisk_initialize (rtems_device_major_number major,
-  rtems_flashdisk_count = rtems_flashdisk_configuration_size;
   return RTEMS_SUCCESSFUL;
diff --git a/testsuites/libtests/flashdisk01/init.c b/testsuites/libtests/flashdisk01/init.c
index d31b4741bb..47f8c2bbeb 100644
--- a/testsuites/libtests/flashdisk01/init.c
+++ b/testsuites/libtests/flashdisk01/init.c
@@ -325,14 +325,7 @@ rtems_flashdisk_configuration [FLASHDISK_CONFIG_COUNT] = {
 uint32_t rtems_flashdisk_configuration_size = FLASHDISK_CONFIG_COUNT;
-#define FLASHDISK_DRIVER { \
-  .initialization_entry = flashdisk_initialize, \
-  .open_entry = rtems_blkdev_generic_open, \
-  .close_entry = rtems_blkdev_generic_close, \
-  .read_entry = rtems_blkdev_generic_read, \
-  .write_entry = rtems_blkdev_generic_write, \
-  .control_entry = rtems_blkdev_generic_ioctl \
+#define FLASHDISK_DRIVER { .initialization_entry = flashdisk_initialize }
 #define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
 #define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
2.13.7
