[PATCH 01/21] ramdisk: Use rtems_blkdev_create()
Mon Aug 6 07:14:33 UTC 2018
Update #3358.
 cpukit/include/rtems/ramdisk.h                 |  9 +--
 cpukit/libblock/src/ramdisk-config.c           | 11 +---
 cpukit/libblock/src/ramdisk-register.c         | 30 ++--------
 testsuites/fstests/fsdosfsname01/init.c        | 35 +----------
 testsuites/fstests/mdosfs_support/fs_support.c |  1 -
 testsuites/fstests/mrfs_support/fs_support.c   |  1 -
 testsuites/fstests/support/ramdisk_support.c   | 27 ++-------
 testsuites/libtests/block01/init.c             | 12 ++--
 testsuites/libtests/block02/init.c             | 57 +++++++++++-------
 testsuites/libtests/block03/init.c             | 49 ++++++++++-----
 testsuites/libtests/block04/init.c             | 49 ++++++++++-----
 testsuites/libtests/block07/init.c             | 53 +++++++++-------
 testsuites/samples/fileio/init.c               | 83 ++++++++------------------
 13 files changed, 181 insertions(+), 236 deletions(-)
diff --git a/cpukit/include/rtems/ramdisk.h b/cpukit/include/rtems/ramdisk.h
index 727efddbe8..dcc60483dd 100644
--- a/cpukit/include/rtems/ramdisk.h
+++ b/cpukit/include/rtems/ramdisk.h
@@ -84,8 +84,8 @@ rtems_device_driver ramdisk_initialize(
 #define RAMDISK_DRIVER_TABLE_ENTRY \
-    .initialization_entry = ramdisk_initialize, \
-    RTEMS_GENERIC_BLOCK_DEVICE_DRIVER_ENTRIES \
+    ramdisk_initialize, \
+    NULL, NULL, NULL, NULL, NULL \
 #define RAMDISK_DEVICE_BASE_NAME "/dev/rd"
@@ -137,8 +137,6 @@ typedef struct ramdisk {
   bool free_at_delete_request;
 } ramdisk;
-extern const rtems_driver_address_table ramdisk_ops;
 int ramdisk_ioctl(rtems_disk_device *dd, uint32_t req, void *argp);
@@ -212,8 +210,7 @@ rtems_status_code ramdisk_register(
   uint32_t media_block_size,
   rtems_blkdev_bnum media_block_count,
   bool trace,
-  const char *disk,
-  dev_t *dev
+  const char *disk
diff --git a/cpukit/libblock/src/ramdisk-config.c b/cpukit/libblock/src/ramdisk-config.c
index 7bd137a394..8e1b277674 100644
--- a/cpukit/libblock/src/ramdisk-config.c
+++ b/cpukit/libblock/src/ramdisk-config.c
@@ -23,7 +23,7 @@
 rtems_device_driver
 ramdisk_initialize(
-    rtems_device_major_number major,
+    rtems_device_major_number major RTEMS_UNUSED,
     rtems_device_minor_number minor RTEMS_UNUSED,
     void *arg RTEMS_UNUSED)
@@ -32,10 +32,6 @@ ramdisk_initialize(
     struct ramdisk *r;
     rtems_status_code rc;
-    rc = rtems_disk_io_initialize();
-    if (rc != RTEMS_SUCCESSFUL)
-        return rc;
      * Coverity Id 27 notes that this calloc() is a resource leak.
@@ -48,7 +44,6 @@ ramdisk_initialize(
     r->trace = false;
     for (i = 0; i < rtems_ramdisk_configuration_size; i++, c++, r++)
-        dev_t dev = rtems_filesystem_make_dev_t(major, i);
         char name [] = RAMDISK_DEVICE_BASE_NAME "a";
         name [sizeof(RAMDISK_DEVICE_BASE_NAME) - 1] += i;
         r->block_size = c->block_size;
@@ -73,8 +68,8 @@ ramdisk_initialize(
             r->initialized = true;
             r->area = c->location;
-        rc = rtems_disk_create_phys(dev, c->block_size, c->block_num,
-                                    ramdisk_ioctl, r, name);
+        rc = rtems_blkdev_create(name, c->block_size, c->block_num,
+                                 ramdisk_ioctl, r);
             if (r->malloced)
diff --git a/cpukit/libblock/src/ramdisk-register.c b/cpukit/libblock/src/ramdisk-register.c
index ec133d0c03..6b2dc2c36d 100644
--- a/cpukit/libblock/src/ramdisk-register.c
+++ b/cpukit/libblock/src/ramdisk-register.c
@@ -24,57 +24,35 @@
   #include "config.h"
 #endif
-#include <rtems.h>
 #include <rtems/ramdisk.h>
-const rtems_driver_address_table ramdisk_ops = {
-  .initialization_entry = NULL,
   bool trace,
-  const char *disk,
-  dev_t *dev_ptr
+  const char *disk
   rtems_status_code sc = RTEMS_SUCCESSFUL;
-  rtems_device_major_number major = 0;
   ramdisk *rd = NULL;
-  dev_t dev = 0;
-  sc = rtems_io_register_driver(0, &ramdisk_ops, &major);
-  if (sc != RTEMS_SUCCESSFUL) {
-    return RTEMS_UNSATISFIED;
   rd = ramdisk_allocate(NULL, media_block_size, media_block_count, trace);
   if (rd == NULL) {
-    rtems_io_unregister_driver(major);
-  dev = rtems_filesystem_make_dev_t(major, 0);
-  sc = rtems_disk_create_phys(
-    dev,
+  sc = rtems_blkdev_create(
+    disk,
     media_block_size,
     media_block_count,
     ramdisk_ioctl,
-    rd,
-    disk
+    rd
     ramdisk_free(rd);
-  *dev_ptr = dev;
   return RTEMS_SUCCESSFUL;
diff --git a/testsuites/fstests/fsdosfsname01/init.c b/testsuites/fstests/fsdosfsname01/init.c
index ce6850cfa7..90db282955 100644
--- a/testsuites/fstests/fsdosfsname01/init.c
+++ b/testsuites/fstests/fsdosfsname01/init.c
@@ -63,18 +63,6 @@ static const char UTF8_BOM[] = {0xEF, 0xBB, 0xBF};
 #define BLOCK_SIZE 512
-#define BLOCK_COUNT ( sizeof( image_bin ) / BLOCK_SIZE )
-static ramdisk                            disk_image = {
-  .block_size             = BLOCK_SIZE,
-  .block_num              = BLOCK_COUNT,
-  .area                   = &image_bin[0],
-  .initialized            = true,
-  .malloced               = false,
-  .trace                  = false,
-  .free_at_delete_request = false
 static rtems_resource_snapshot            before_mount;
 static const msdos_format_request_param_t rqdata = {
@@ -981,11 +969,8 @@ static void compare_image(
 static void test_compatibility( void )
   int                       rc;
-  rtems_status_code         sc;
-  dev_t                     dev;
-  char                      diskpath[] = "/dev/ramdisk1";
+  char                      diskpath[] = "/dev/rdd";
   rtems_dosfs_mount_options mount_opts;
-  rtems_device_major_number major;
   FILE                     *fp;
   int                       buffer;
   unsigned int              index_file = 0;
@@ -1002,20 +987,6 @@ static void test_compatibility( void )
   mount_opts.converter = rtems_dosfs_create_utf8_converter( "CP850" );
   rtems_test_assert( mount_opts.converter != NULL );
-  sc = rtems_io_register_driver( 0, &ramdisk_ops, &major );
-  rtems_test_assert( sc == RTEMS_SUCCESSFUL );
-  dev = rtems_filesystem_make_dev_t( major, 1 );
-    dev,
-    BLOCK_SIZE,
-    BLOCK_COUNT,
-    ramdisk_ioctl,
-    &disk_image,
-    diskpath );
   rc = mount_and_make_target_path(
     diskpath,
     MOUNT_DIR,
@@ -1416,7 +1387,8 @@ static void Init( rtems_task_argument arg )
 rtems_ramdisk_config rtems_ramdisk_configuration [] = {
   { .block_size = BLOCK_SIZE, .block_num = BLOCK_NUM },
   { .block_size = BLOCK_SIZE, .block_num = BLOCK_NUM, .location = &IMAGE_BIN_LE_SINGLEBYTE[0] },
-  { .block_size = BLOCK_SIZE, .block_num = BLOCK_NUM, .location = &IMAGE_BIN_LE_MULTIBYTE[0] }
+  { .block_size = BLOCK_SIZE, .block_num = BLOCK_NUM, .location = &IMAGE_BIN_LE_MULTIBYTE[0] },
+  { .block_size = BLOCK_SIZE, .block_num = sizeof( image_bin ) / BLOCK_SIZE, .location = image_bin }
 size_t rtems_ramdisk_configuration_size = RTEMS_ARRAY_SIZE(rtems_ramdisk_configuration);
@@ -1424,7 +1396,6 @@ size_t rtems_ramdisk_configuration_size = RTEMS_ARRAY_SIZE(rtems_ramdisk_configu
 #define CONFIGURE_INIT_TASK_STACK_SIZE ( 1024 * 64 )
 #define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
 #define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
-#define CONFIGURE_MAXIMUM_DRIVERS 4
 #define CONFIGURE_MAXIMUM_SEMAPHORES (2 * RTEMS_DOSFS_SEMAPHORES_PER_INSTANCE)
 #define CONFIGURE_APPLICATION_EXTRA_DRIVERS RAMDISK_DRIVER_TABLE_ENTRY
diff --git a/testsuites/fstests/mdosfs_support/fs_support.c b/testsuites/fstests/mdosfs_support/fs_support.c
index 7b73c27b84..4395182e0f 100644
--- a/testsuites/fstests/mdosfs_support/fs_support.c
+++ b/testsuites/fstests/mdosfs_support/fs_support.c
@@ -87,7 +87,6 @@ void test_shutdown_filesystem(void)
 #define CONFIGURE_MAXIMUM_SEMAPHORES RTEMS_DOSFS_SEMAPHORES_PER_INSTANCE
 #define CONFIGURE_MAXIMUM_TASKS                     10
-#define CONFIGURE_MAXIMUM_DRIVERS                   10
 #define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS    40
 #define CONFIGURE_INIT_TASK_STACK_SIZE (16 * 1024)
 #define CONFIGURE_INIT_TASK_ATTRIBUTES RTEMS_FLOATING_POINT
diff --git a/testsuites/fstests/mrfs_support/fs_support.c b/testsuites/fstests/mrfs_support/fs_support.c
index 28b7be9a03..24c82cbea1 100644
--- a/testsuites/fstests/mrfs_support/fs_support.c
+++ b/testsuites/fstests/mrfs_support/fs_support.c
@@ -66,7 +66,6 @@ test_shutdown_filesystem (void)
 #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
 #define CONFIGURE_INIT_TASK_STACK_SIZE (32 * 1024)
diff --git a/testsuites/fstests/support/ramdisk_support.c b/testsuites/fstests/support/ramdisk_support.c
index d7574b2853..0a07495c02 100644
--- a/testsuites/fstests/support/ramdisk_support.c
+++ b/testsuites/fstests/support/ramdisk_support.c
@@ -11,12 +11,9 @@
 #include "config.h"
 #endif
-#include <sys/stat.h>
-#include <fcntl.h>
+#include <unistd.h>
-#include <rtems/blkdev.h>
-#include <rtems/libio.h>
 #include "ramdisk_support.h"
 #include "fstest.h"
@@ -26,17 +23,14 @@
  * Ramdisk information
-dev_t dev = 0;
 void
 init_ramdisk (void)
   int rc = 0;
-  rc = rtems_disk_io_initialize ();
-  rtems_test_assert (rc == 0);
   rc = ramdisk_register (RAMDISK_BLOCK_SIZE, RAMDISK_BLOCK_COUNT,
-                         false, RAMDISK_PATH, &dev);
+                         false, RAMDISK_PATH);
@@ -45,20 +39,7 @@ del_ramdisk (void)
   int rc = 0;
-  rtems_device_minor_number minor = 0;
-  rc = rtems_disk_delete (dev);
+  rc = unlink (RAMDISK_PATH);
-  rtems_filesystem_split_dev_t (dev, major, minor);
-  rtems_test_assert (major >= 0);
-  rtems_test_assert (minor >= 0);
-  rc = rtems_io_unregister_driver (major);
-  rc = rtems_disk_io_done ();
diff --git a/testsuites/libtests/block01/init.c b/testsuites/libtests/block01/init.c
index 92dbfc9aba..04b2ef4986 100644
--- a/testsuites/libtests/block01/init.c
+++ b/testsuites/libtests/block01/init.c
@@ -7,10 +7,10 @@
- * Copyright (c) 2009-2012 embedded brains GmbH.  All rights reserved.
+ * Copyright (c) 2009, 2018 embedded brains GmbH.  All rights reserved.
  *  embedded brains GmbH
- *  Obere Lagerstr. 30
+ *  Dornierstr. 4
  *  82178 Puchheim
  *  Germany
  *  <rtems at embedded-brains.de>
@@ -35,9 +35,6 @@
 const char rtems_test_name[] = "BLOCK 1";
-/* forward declarations to avoid warnings */
-static rtems_task Init(rtems_task_argument argument);
 #define ASSERT_SC(sc) rtems_test_assert((sc) == RTEMS_SUCCESSFUL)
 #define ASSERT_SC_EQ(sc, sc_expected) rtems_test_assert((sc) == (sc_expected))
@@ -46,6 +43,11 @@ static rtems_task Init(rtems_task_argument argument);
 #define BLOCK_COUNT 16U
+static const rtems_driver_address_table ramdisk_ops = {
+  .initialization_entry = NULL,
+  RTEMS_GENERIC_BLOCK_DEVICE_DRIVER_ENTRIES
 static void test_block_io_control_api(dev_t dev, ramdisk *rd)
diff --git a/testsuites/libtests/block02/init.c b/testsuites/libtests/block02/init.c
index c550517e21..983f876bcd 100644
--- a/testsuites/libtests/block02/init.c
+++ b/testsuites/libtests/block02/init.c
@@ -7,10 +7,10 @@
+ *  Dornierstr. 4
  *  82178 Puchheim
  *  Germany
@@ -30,12 +30,12 @@
 #include <rtems/bspIo.h>
 #include <rtems/bdbuf.h>
-#include <rtems/diskdevs.h>
-const char rtems_test_name[] = "BLOCK 2";
+#include <sys/stat.h>
+#include <fcntl.h>
+const char rtems_test_name[] = "BLOCK 2";
@@ -130,29 +130,39 @@ static void task_high(rtems_task_argument arg)
   rtems_task_delete(RTEMS_SELF);
+static void do_ramdisk_register(
+  uint32_t media_block_size,
+  rtems_blkdev_bnum media_block_count,
+  const char *disk,
+  rtems_disk_device **dd
-  rtems_status_code sc = RTEMS_SUCCESSFUL;
-  rtems_bdbuf_buffer *bd = NULL;
-  dev_t dev_a = 0;
-  dev_t dev_b = 0;
+  rtems_status_code sc;
+  int fd;
+  int rv;
-  TEST_BEGIN();
-  sc = rtems_disk_io_initialize();
+  sc = ramdisk_register(media_block_size, media_block_count, false, disk);
   ASSERT_SC(sc);
-  sc = ramdisk_register(BLOCK_SIZE_A, BLOCK_COUNT_A, false, "/dev/rda", &dev_a);
-  ASSERT_SC(sc);
+  fd = open(disk, O_RDWR);
+  rtems_test_assert(fd >= 0);
-  sc = ramdisk_register(BLOCK_SIZE_B, BLOCK_COUNT_B, false, "/dev/rdb", &dev_b);
-  ASSERT_SC(sc);
+  rv = rtems_disk_fd_get_disk_device(fd, dd);
+  rtems_test_assert(rv == 0);
-  dd_a = rtems_disk_obtain(dev_a);
-  rtems_test_assert(dd_a != NULL);
+  rv = close(fd);
-  dd_b = rtems_disk_obtain(dev_b);
-  rtems_test_assert(dd_b != NULL);
+static rtems_task Init(rtems_task_argument argument)
+  rtems_status_code sc = RTEMS_SUCCESSFUL;
+  rtems_bdbuf_buffer *bd = NULL;
+  TEST_BEGIN();
+  do_ramdisk_register(BLOCK_SIZE_A, BLOCK_COUNT_A, "/dev/rda", &dd_a);
+  do_ramdisk_register(BLOCK_SIZE_B, BLOCK_COUNT_B, "/dev/rdb", &dd_b);
   sc = rtems_task_create(
     rtems_build_name(' ', 'L', 'O', 'W'),
@@ -200,8 +210,9 @@ static rtems_task Init(rtems_task_argument argument)
 #define CONFIGURE_APPLICATION_NEEDS_LIBBLOCK
+#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 4
 #define CONFIGURE_MAXIMUM_TASKS 3
-#define CONFIGURE_MAXIMUM_DRIVERS 3
 #define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
diff --git a/testsuites/libtests/block03/init.c b/testsuites/libtests/block03/init.c
index c66a52049f..2bab878134 100644
--- a/testsuites/libtests/block03/init.c
+++ b/testsuites/libtests/block03/init.c
@@ -7,10 +7,10 @@
+ *  Dornierstr. 4
  *  82178 Puchheim
  *  Germany
@@ -30,12 +30,12 @@
-const char rtems_test_name[] = "BLOCK 3";
+#include <fcntl.h>
+const char rtems_test_name[] = "BLOCK 3";
@@ -124,22 +124,38 @@ static void task_high(rtems_task_argument arg)
+  const char *disk,
+  int fd;
+  int rv;
+  ASSERT_SC(sc);
+  rv = close(fd);
-  dev_t dev = 0;
   TEST_BEGIN();
-  ASSERT_SC(sc);
-  sc = ramdisk_register(BLOCK_SIZE, BLOCK_COUNT, false, "/dev/rda", &dev);
-  ASSERT_SC(sc);
-  dd = rtems_disk_obtain(dev);
-  rtems_test_assert(dd != NULL);
+  do_ramdisk_register(BLOCK_SIZE, BLOCK_COUNT, "/dev/rda", &dd);
@@ -187,8 +203,9 @@ static rtems_task Init(rtems_task_argument argument)
-#define CONFIGURE_MAXIMUM_DRIVERS 2
diff --git a/testsuites/libtests/block04/init.c b/testsuites/libtests/block04/init.c
index 1b5d114029..891552d461 100644
--- a/testsuites/libtests/block04/init.c
+++ b/testsuites/libtests/block04/init.c
@@ -7,10 +7,10 @@
+ *  Dornierstr. 4
  *  82178 Puchheim
  *  Germany
@@ -30,12 +30,12 @@
-const char rtems_test_name[] = "BLOCK 4";
+#include <fcntl.h>
+const char rtems_test_name[] = "BLOCK 4";
@@ -107,21 +107,37 @@ static void task_high(rtems_task_argument arg)
   exit(0);
+  const char *disk,
+  int fd;
+  int rv;
+  ASSERT_SC(sc);
+  rv = close(fd);
-  dev_t dev = 0;
   TEST_BEGIN();
-  ASSERT_SC(sc);
-  ASSERT_SC(sc);
@@ -159,8 +175,9 @@ static rtems_task Init(rtems_task_argument argument)
diff --git a/testsuites/libtests/block07/init.c b/testsuites/libtests/block07/init.c
index 914dd35a90..e0f7ecc031 100644
--- a/testsuites/libtests/block07/init.c
+++ b/testsuites/libtests/block07/init.c
@@ -7,12 +7,13 @@
- * embedded brains GmbH
- * D-82178 Puchheim
- * Germany
- * <rtems at embedded-brains.de>
+ *  embedded brains GmbH
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+ *  <rtems at embedded-brains.de>
  * The license and distribution terms for this file may be
  * found in the file LICENSE in this distribution or at
@@ -27,19 +28,16 @@
 #include <sys/types.h>
 #include <fcntl.h>
 #include "tmacros.h"
 const char rtems_test_name[] = "BLOCK 7";
 #define PRIORITY_INIT 1
@@ -158,23 +156,39 @@ static void task_high(rtems_task_argument arg)
+  const char *disk,
+  int fd;
+  int rv;
+  ASSERT_SC(sc);
+  rv = close(fd);
   rtems_task_priority cur_prio = 0;
-  dev_t dev = 0;
   TEST_BEGIN();
-  ASSERT_SC(sc);
-  sc = ramdisk_register(BLOCK_SIZE_A, BLOCK_COUNT, false, "/dev/rda", &dev);
-  ASSERT_SC(sc);
+  do_ramdisk_register(BLOCK_SIZE_A, BLOCK_COUNT, "/dev/rda", &dd);
@@ -265,7 +279,6 @@ static rtems_task Init(rtems_task_argument argument)
 #define CONFIGURE_MAXIMUM_TASKS 4
diff --git a/testsuites/samples/fileio/init.c b/testsuites/samples/fileio/init.c
index 433266a99f..974535b83c 100644
--- a/testsuites/samples/fileio/init.c
+++ b/testsuites/samples/fileio/init.c
@@ -43,38 +43,6 @@ const char rtems_test_name[] = "FILE I/O";
 #define RTEMS_DRIVER_AUTO_MAJOR (0)
- * RAM disk driver so you can create a RAM disk from the shell prompt.
- * The RAM Disk configuration.
-rtems_ramdisk_config rtems_ramdisk_configuration[] =
-    block_size: 512,
-    block_num:  1024,
- * The number of RAM Disk configurations.
-size_t rtems_ramdisk_configuration_size = 1;
- * Create the RAM Disk Driver entry.
-rtems_driver_address_table rtems_ramdisk_io_ops = {
-  initialization_entry: ramdisk_initialize,
-  open_entry:           rtems_blkdev_generic_open,
-  close_entry:          rtems_blkdev_generic_close,
-  read_entry:           rtems_blkdev_generic_read,
-  write_entry:          rtems_blkdev_generic_write,
-  control_entry:        rtems_blkdev_generic_ioctl
  * The NV Device descriptor. For this test it is just DRAM.
@@ -404,17 +372,20 @@ disk_test_block_sizes (int argc, char *argv[])
   return disk_test_write_blocks (st.st_rdev, start, count, size);
-static size_t
+static uint32_t
 parse_size_arg (const char* arg)
-  size_t size;
-  size_t scalar = 1;
+  uint32_t size;
+  uint32_t scalar = 1;
   size = strtoul (arg, 0, 0);
   switch (arg[strlen (arg) - 1])
+    case 'b':
+      scalar = 1;
+      break;
     case 'M':
-      scalar = (size_t) 1000 * 1024;
+      scalar = 1024000;
       break;
     case 'm':
       scalar = 1000000;
@@ -426,26 +397,26 @@ parse_size_arg (const char* arg)
       scalar = 1000;
       break;
     default:
-      printf ("error: invalid scalar (M/m/K/k): %c\n", arg[strlen (arg) - 1]);
+      printf ("error: invalid scalar (b,M/m/K/k): %c\n", arg[strlen (arg) - 1]);
       return 0;
   return size * scalar;
 static int
 create_ramdisk (int argc, char *argv[])
   int                       arg;
-  size_t                    size = 0;
-  size_t                    block_size = 0;
+  uint32_t                  size = 524288;
+  uint32_t                  block_size = 512;
+  uint32_t                  block_count;
   for (arg = 0; arg < argc; ++arg)
     if (argv[arg][0] == '-')
-      switch (argv[arg][0])
+      switch (argv[arg][1])
         case 's':
           ++arg;
@@ -476,30 +447,24 @@ create_ramdisk (int argc, char *argv[])
-  if (block_size)
-    rtems_ramdisk_configuration[0].block_size = block_size;
-  if (size)
-    rtems_ramdisk_configuration[0].block_num =
-      size / rtems_ramdisk_configuration[0].block_size;
+  block_count = size / block_size;
    * Register the RAM Disk driver.
   printf ("Register RAM Disk Driver [blocks=%" PRIu32 \
-          " block-size=%" PRIu32"]:",
-          rtems_ramdisk_configuration[0].block_num,
-          rtems_ramdisk_configuration[0].block_size);
-  sc = rtems_io_register_driver (RTEMS_DRIVER_AUTO_MAJOR,
-                                 &rtems_ramdisk_io_ops,
-                                 &major);
+          " block-size=%" PRIu32 "]:",
+          block_count,
+          block_size);
+  sc = ramdisk_register(block_size, block_count, false, "/dev/rda");
     printf ("error: ramdisk driver not initialised: %s\n",
             rtems_status_text (sc));
     return 1;
   printf ("successful\n");
   return 0;
@@ -511,9 +476,9 @@ create_nvdisk (int argc, char *argv[])
   int                       arg;
-  size_t                    size = 0;
+  uint32_t                  size = 0;
 #if ADD_WHEN_NVDISK_HAS_CHANGED
+  uint32_t                  block_size = 0;
 #endif
2.13.7
