[PATCH 18/21] tests: Avoid deprecated rtems_disk_io_initialize()
Mon Aug 6 07:14:50 UTC 2018
Update #3358.
 testsuites/fstests/fsdosfsformat01/init.c | 3 ---
 testsuites/fstests/fsdosfssync01/init.c   | 3 ---
 testsuites/fstests/fsdosfswrite01/init.c  | 4 ----
 testsuites/libtests/block11/init.c        | 9 ---------
 testsuites/libtests/block16/init.c        | 3 ---
 testsuites/libtests/sparsedisk01/init.c   | 4 ----
 6 files changed, 26 deletions(-)
diff --git a/testsuites/fstests/fsdosfsformat01/init.c b/testsuites/fstests/fsdosfsformat01/init.c
index fb5896dca4..a8477cb61f 100644
--- a/testsuites/fstests/fsdosfsformat01/init.c
+++ b/testsuites/fstests/fsdosfsformat01/init.c
@@ -176,9 +176,6 @@ static void test( void )
   memset( &rqdata, 0, sizeof( rqdata ) );
-  sc = rtems_disk_io_initialize();
-  rtems_test_assert( sc == RTEMS_SUCCESSFUL );
   rv = mkdir( mount_dir, S_IRWXU | S_IRWXG | S_IRWXO );
   rtems_test_assert( 0 == rv );
diff --git a/testsuites/fstests/fsdosfssync01/init.c b/testsuites/fstests/fsdosfssync01/init.c
index 5aee87622c..e878e59075 100644
--- a/testsuites/fstests/fsdosfssync01/init.c
+++ b/testsuites/fstests/fsdosfssync01/init.c
@@ -100,9 +100,6 @@ static void test(const char *rda, const char *mnt, const char *file)
   int disk_fd;
   int rv;
-  rtems_test_assert(sc == RTEMS_SUCCESSFUL);
   disk_fd = open(rda, O_RDWR);
   rtems_test_assert(disk_fd >= 0);
diff --git a/testsuites/fstests/fsdosfswrite01/init.c b/testsuites/fstests/fsdosfswrite01/init.c
index 91111cc7fe..5048bdb224 100644
--- a/testsuites/fstests/fsdosfswrite01/init.c
+++ b/testsuites/fstests/fsdosfswrite01/init.c
@@ -251,10 +251,6 @@ static void test( void )
   rtems_status_code sc;
   int               rv;
diff --git a/testsuites/libtests/block11/init.c b/testsuites/libtests/block11/init.c
index f607bf515e..82e24d6548 100644
--- a/testsuites/libtests/block11/init.c
+++ b/testsuites/libtests/block11/init.c
@@ -401,22 +401,13 @@ static void test_blkdev_imfs_errors(void)
 static rtems_task Init(rtems_task_argument argument)
-  rtems_status_code sc;
   TEST_BEGIN();
-  ASSERT_SC(sc);
   test_blkdev_imfs_read_and_write();
   test_blkdev_imfs_parameters();
   test_blkdev_imfs_errors();
-  sc = rtems_disk_io_done();
-  ASSERT_SC(sc);
   TEST_END();
   exit(0);
diff --git a/testsuites/libtests/block16/init.c b/testsuites/libtests/block16/init.c
index 401a888925..64ccded9dc 100644
--- a/testsuites/libtests/block16/init.c
+++ b/testsuites/libtests/block16/init.c
@@ -48,9 +48,6 @@ static void test(void)
   rtems_bdbuf_buffer *large_bd;
   rtems_blkdev_bnum i;
-  ASSERT_SC(sc);
   for (i = 0; i < media_block_count; ++i) {
     buf [i] = i;
diff --git a/testsuites/libtests/sparsedisk01/init.c b/testsuites/libtests/sparsedisk01/init.c
index dfb87ecdd5..e0d25fa444 100644
--- a/testsuites/libtests/sparsedisk01/init.c
+++ b/testsuites/libtests/sparsedisk01/init.c
@@ -358,10 +358,6 @@ void test( void )
   int               file_descriptor;
   uint8_t           fill_pattern = 0;
   block_size       = 512;
   block_number     = 4 * 2 * 1024;
   blocks_allocated = 8;
2.13.7
