[PATCH 12/21] libtests/block13: Use rtems_blkdev_create()
Mon Aug 6 07:14:44 UTC 2018
Update #3358.
 testsuites/libtests/block13/init.c | 44 ++++++++++++++++++++++----------------
 1 file changed, 25 insertions(+), 19 deletions(-)
diff --git a/testsuites/libtests/block13/init.c b/testsuites/libtests/block13/init.c
index afd7704026..0eb5d676ee 100644
--- a/testsuites/libtests/block13/init.c
+++ b/testsuites/libtests/block13/init.c
@@ -1,8 +1,8 @@
- * Copyright (c) 2012 embedded brains GmbH.  All rights reserved.
+ * Copyright (c) 2012, 2018 embedded brains GmbH.  All rights reserved.
  *  embedded brains GmbH
- *  Obere Lagerstr. 30
+ *  Dornierstr. 4
  *  82178 Puchheim
  *  Germany
  *  <rtems at embedded-brains.de>
@@ -18,10 +18,13 @@
 #include "tmacros.h"
+#include <sys/stat.h>
+#include <assert.h>
+#include <fcntl.h>
+#include <unistd.h>
-#include <rtems/blkdev.h>
 #include <rtems/bdbuf.h>
 const char rtems_test_name[] = "BLOCK 13";
@@ -29,6 +32,8 @@ const char rtems_test_name[] = "BLOCK 13";
 #define BLOCK_COUNT 11
 #define READ_COUNT 23
+#define DISK_PATH "/disk"
 static int block_access_counts [BLOCK_COUNT];
 #define RESET_CACHE (-1)
@@ -130,8 +135,7 @@ static int test_disk_ioctl(rtems_disk_device *dd, uint32_t req, void *arg)
     rtems_blkdev_request_done(breq, RTEMS_SUCCESSFUL);
   } else {
-    errno = EINVAL;
-    rv = -1;
+    rv = rtems_blkdev_ioctl(dd, req, arg);
   return rv;
@@ -181,32 +185,32 @@ static void test_read_ahead(rtems_disk_device *dd)
 static void test(void)
   rtems_status_code sc;
-  dev_t dev = 0;
   rtems_disk_device *dd;
+  int fd;
+  int rv;
-  sc = rtems_disk_io_initialize();
-  rtems_test_assert(sc == RTEMS_SUCCESSFUL);
-  sc = rtems_disk_create_phys(
-    dev,
+  sc = rtems_blkdev_create(
+    DISK_PATH,
     1,
     BLOCK_COUNT,
     test_disk_ioctl,
-    NULL,
     NULL
-  dd = rtems_disk_obtain(dev);
-  rtems_test_assert(dd != NULL);
+  fd = open(DISK_PATH, O_RDWR);
+  rtems_test_assert(fd >= 0);
-  test_read_ahead(dd);
+  rv = rtems_disk_fd_get_disk_device(fd, &dd);
+  rtems_test_assert(rv == 0);
-  sc = rtems_disk_release(dd);
+  rv = close(fd);
-  sc = rtems_disk_delete(dev);
+  test_read_ahead(dd);
+  rv = unlink(DISK_PATH);
 static void Init(rtems_task_argument arg)
@@ -224,6 +228,8 @@ static void Init(rtems_task_argument arg)
 #define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
 #define CONFIGURE_APPLICATION_NEEDS_LIBBLOCK
+#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 4
 #define CONFIGURE_BDBUF_BUFFER_MIN_SIZE 1
 #define CONFIGURE_BDBUF_BUFFER_MAX_SIZE 1
 #define CONFIGURE_BDBUF_CACHE_MEMORY_SIZE BLOCK_COUNT
2.13.7
