[PATCH 14/21] libtests/block15: Use rtems_blkdev_create()
Mon Aug 6 07:14:46 UTC 2018
Update #3358.
 testsuites/libtests/block15/init.c | 42 ++++++++++++++++++++++----------------
 1 file changed, 24 insertions(+), 18 deletions(-)
diff --git a/testsuites/libtests/block15/init.c b/testsuites/libtests/block15/init.c
index cf9ec5fc0c..925a772842 100644
--- a/testsuites/libtests/block15/init.c
+++ b/testsuites/libtests/block15/init.c
@@ -18,11 +18,14 @@
 #include "tmacros.h"
+#include <sys/stat.h>
+#include <assert.h>
-#include <stdio.h>
+#include <fcntl.h>
 #include <inttypes.h>
+#include <stdlib.h>
+#include <unistd.h>
-#include <rtems/blkdev.h>
 #include <rtems/bdbuf.h>
 const char rtems_test_name[] = "BLOCK 15";
@@ -41,6 +44,8 @@ const char rtems_test_name[] = "BLOCK 15";
 #define BLOCK_SIZE 4
+#define DISK_PATH "/disk"
 static const rtems_blkdev_bnum action_sequence [ACTION_COUNT] = {
   2, 1, 0, 4, 5, 6, 7, 9
@@ -90,8 +95,7 @@ static int test_disk_ioctl(rtems_disk_device *dd, uint32_t req, void *arg)
   } else if (req == RTEMS_BLKIO_CAPABILITIES) {
     *(uint32_t *) arg = RTEMS_BLKDEV_CAP_MULTISECTOR_CONT;
   } else {
-    errno = EINVAL;
-    rv = -1;
+    rv = rtems_blkdev_ioctl(dd, req, arg);
   return rv;
@@ -126,32 +130,32 @@ static void test_write_requests(rtems_disk_device *dd)
 static void test(void)
   rtems_status_code sc;
-  dev_t dev = 0;
   rtems_disk_device *dd;
+  int fd;
+  int rv;
-  sc = rtems_disk_io_initialize();
-  rtems_test_assert(sc == RTEMS_SUCCESSFUL);
-  sc = rtems_disk_create_phys(
-    dev,
+  sc = rtems_blkdev_create(
+    DISK_PATH,
     MEDIA_BLOCK_SIZE,
     BLOCK_COUNT,
     test_disk_ioctl,
-    NULL,
     NULL
-  dd = rtems_disk_obtain(dev);
-  rtems_test_assert(dd != NULL);
+  fd = open(DISK_PATH, O_RDWR);
+  rtems_test_assert(fd >= 0);
-  test_write_requests(dd);
+  rv = rtems_disk_fd_get_disk_device(fd, &dd);
+  rtems_test_assert(rv == 0);
-  sc = rtems_disk_release(dd);
+  rv = close(fd);
-  sc = rtems_disk_delete(dev);
+  test_write_requests(dd);
+  rv = unlink(DISK_PATH);
 static void Init(rtems_task_argument arg)
@@ -169,6 +173,8 @@ static void Init(rtems_task_argument arg)
 #define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
 #define CONFIGURE_APPLICATION_NEEDS_LIBBLOCK
+#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 4
 #define CONFIGURE_BDBUF_BUFFER_MIN_SIZE 1
 #define CONFIGURE_BDBUF_BUFFER_MAX_SIZE 4
 #define CONFIGURE_BDBUF_CACHE_MEMORY_SIZE (BLOCK_COUNT * BLOCK_SIZE)
2.13.7
