[PATCH] bsp/atsam: Fix handling of slow SPI speeds.
Christian Mauderer
christian.mauderer at embedded-brains.de
Mon Aug 6 08:29:14 UTC 2018
This patch fixes an overflow in the frequency calculation of the SPI
driver for slow SPI speeds.
bsps/arm/atsam/spi/atsam_spi_bus.c | 21 ++++++++++++++++++++-
1 file changed, 20 insertions(+), 1 deletion(-)
diff --git a/bsps/arm/atsam/spi/atsam_spi_bus.c b/bsps/arm/atsam/spi/atsam_spi_bus.c
index 35f44f525d..b40fa56f7a 100644
--- a/bsps/arm/atsam/spi/atsam_spi_bus.c
+++ b/bsps/arm/atsam/spi/atsam_spi_bus.c
@@ -85,6 +85,23 @@ static uint8_t atsam_calculate_dlybcs(uint16_t delay_in_us)
(BOARD_MCK / delay_in_us) : 0xFF;
+static uint32_t atsam_calculate_scbr(uint32_t speed_hz)
+ uint32_t scbr;
+ scbr = BOARD_MCK / speed_hz;
+ if (scbr > 0x0FF) {
+ /* Best estimation we can offer with the hardware. */
+ scbr = 0x0FF;
+ if (scbr == 0) {
+ /* SCBR = 0 isn't allowed. */
+ scbr = 1;
+ return scbr;
static void atsam_set_phase_and_polarity(uint32_t mode, uint32_t *csr)
uint32_t mode_mask = mode & SPI_MODE_3;
@@ -109,11 +126,13 @@ static void atsam_set_phase_and_polarity(uint32_t mode, uint32_t *csr)
static void atsam_configure_spi(atsam_spi_bus *bus)
uint8_t delay_cs;
+ uint32_t scbr;
uint32_t csr = 0;
uint32_t mode = 0;
uint32_t cs = bus->base.cs;
delay_cs = atsam_calculate_dlybcs(bus->base.delay_usecs);
+ scbr = atsam_calculate_scbr(bus->base.speed_hz);
mode |= SPI_MR_DLYBCS(delay_cs);
mode |= SPI_MR_MSTR;
@@ -137,7 +156,7 @@ static void atsam_configure_spi(atsam_spi_bus *bus)
csr =
SPI_DLYBCT(1000, BOARD_MCK) |
SPI_DLYBS(1000, BOARD_MCK) |
- SPI_SCBR(bus->base.speed_hz, BOARD_MCK) |
+ SPI_CSR_SCBR(scbr) |
SPI_CSR_BITS(bus->base.bits_per_word - 8);
atsam_set_phase_and_polarity(bus->base.mode, &csr);
2.13.7
