[PATCH] rfs: Remove erroneous call of rtems_disk_release()
Joel Sherrill
joel at rtems.org
Mon Aug 6 13:03:44 UTC 2018
On Mon, Aug 6, 2018, 3:01 AM Sebastian Huber <
> On 06/08/18 09:47, Chris Johns wrote:
> > On 06/08/2018 16:13, Sebastian Huber wrote:
> >> this needs a back port to 4.11 and 4.10.
> > I saw the ticket for 4.10 and assumed the patch was for 4.10. We separate
> > tickets for each branch.
> This makes the ticket handling a bit more complicated. Why is this
> necessary? Are different tickets for the same bug really great? I think
> the rational is that if a bug is fixed in version x, then it is also
> fixed in all versions x + i.
It is a human assumption but it doesn't work out right for using Trac to
generate release reports. Each ticket has a single milestone. So it would
be fixed in 4.10.n but we don't know where along the 4.11 series it got
fixed based on Trac 4.11 release reports.
--joel
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180806/fa468a66/attachment.html>
