[PATCH] CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE
Tue Aug 7 06:00:22 UTC 2018
Make CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE configurable by the user.
Update #3434.
 cpukit/include/rtems/confdefs.h          |  5 +++++
 cpukit/include/rtems/posix/pthread.h     |  2 ++
 cpukit/include/rtems/posix/pthreadimpl.h |  2 +-
 testsuites/psxtests/psxconfig01/init.c   | 17 +++++++++++++++++
 4 files changed, 25 insertions(+), 1 deletion(-)
diff --git a/cpukit/include/rtems/confdefs.h b/cpukit/include/rtems/confdefs.h
index 6e7bcdf570..8119436e7c 100644
--- a/cpukit/include/rtems/confdefs.h
+++ b/cpukit/include/rtems/confdefs.h
@@ -1165,8 +1165,10 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
  * This specifies the default POSIX thread stack size. By default, it is
  * twice that recommended for the port.
+#ifndef CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE
 #define CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE \
   (2 * CONFIGURE_MINIMUM_TASK_STACK_SIZE)
+#endif
  * @brief Idle task stack size configuration.
@@ -3050,6 +3052,9 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
       CONFIGURE_POSIX_INIT_THREAD_TABLE_SIZE,
       CONFIGURE_POSIX_INIT_THREAD_TABLE_NAME
+    size_t _Configuration_POSIX_Minimum_stack_size =
+      CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE;
   #endif
diff --git a/cpukit/include/rtems/posix/pthread.h b/cpukit/include/rtems/posix/pthread.h
index 05783ff4ad..818d0f89d0 100644
--- a/cpukit/include/rtems/posix/pthread.h
+++ b/cpukit/include/rtems/posix/pthread.h
@@ -37,6 +37,8 @@ extern "C" {
+extern size_t _Configuration_POSIX_Minimum_stack_size;
  * @brief POSIX threads initialize user threads body.
diff --git a/cpukit/include/rtems/posix/pthreadimpl.h b/cpukit/include/rtems/posix/pthreadimpl.h
index e6ed1b8990..d900207fbd 100644
--- a/cpukit/include/rtems/posix/pthreadimpl.h
+++ b/cpukit/include/rtems/posix/pthreadimpl.h
@@ -40,7 +40,7 @@ extern "C" {
  * The following sets the minimum stack size for POSIX threads.
-#define PTHREAD_MINIMUM_STACK_SIZE (_Stack_Minimum() * 2)
+#define PTHREAD_MINIMUM_STACK_SIZE _Configuration_POSIX_Minimum_stack_size
  * The following defines the information control block used to manage
diff --git a/testsuites/psxtests/psxconfig01/init.c b/testsuites/psxtests/psxconfig01/init.c
index 910932a997..70e489823b 100644
--- a/testsuites/psxtests/psxconfig01/init.c
+++ b/testsuites/psxtests/psxconfig01/init.c
@@ -25,6 +25,8 @@
   #include "config.h"
 #endif
+#define _GNU_SOURCE
 #include <rtems/test.h>
 #include <tmacros.h>
@@ -65,6 +67,8 @@ const char rtems_test_name[] = "PSXCONFIG 1";
 #define CONFIGURE_MAXIMUM_POSIX_SEMAPHORES 41
 #define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#define CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE CPU_STACK_MINIMUM_SIZE
 #define CONFIGURE_MAXIMUM_POSIX_THREADS 3
 #define CONFIGURE_MAXIMUM_POSIX_TIMERS 47
@@ -462,8 +466,21 @@ static rtems_task Init(rtems_task_argument argument)
 #ifdef CONFIGURE_MAXIMUM_POSIX_THREADS
   for (i = 0; i < CONFIGURE_MAXIMUM_POSIX_THREADS; ++i) {
     pthread_t thread;
+    pthread_attr_t attr;
+    size_t stack_size;
     eno = pthread_create(&thread, NULL, posix_thread, NULL);
     rtems_test_assert(eno == 0);
+    eno = pthread_getattr_np(thread, &attr);
+    rtems_test_assert(eno == 0);
+    eno = pthread_attr_getstacksize(&attr, &stack_size);
+    rtems_test_assert(stack_size == CPU_STACK_MINIMUM_SIZE);
+    eno = pthread_attr_destroy(&attr);
   rtems_resource_snapshot_take(&snapshot);
   rtems_test_assert(
2.13.7
