[PATCH] c-user: Sort POSIX configuration options
Tue Aug 7 06:38:58 UTC 2018
 c-user/configuring_a_system.rst | 120 ++++++++++++++++++++--------------------
 1 file changed, 60 insertions(+), 60 deletions(-)
diff --git a/c-user/configuring_a_system.rst b/c-user/configuring_a_system.rst
index 4b5fe52..a22d321 100644
--- a/c-user/configuring_a_system.rst
+++ b/c-user/configuring_a_system.rst
@@ -1055,15 +1055,15 @@ The parameters in this section are used to configure resources for the RTEMS
 POSIX API.  They are only relevant if the POSIX API is enabled at configure
 time using the ``--enable-posix`` option.
-.. index:: CONFIGURE_MAXIMUM_POSIX_THREADS
+.. index:: CONFIGURE_MAXIMUM_POSIX_KEYS
-.. _CONFIGURE_MAXIMUM_POSIX_THREADS:
+.. _CONFIGURE_MAXIMUM_POSIX_KEYS:
-CONFIGURE_MAXIMUM_POSIX_THREADS
+CONFIGURE_MAXIMUM_POSIX_KEYS
 CONSTANT:
-    ``CONFIGURE_MAXIMUM_POSIX_THREADS``
+    ``CONFIGURE_MAXIMUM_POSIX_KEYS``
 DATA TYPE:
     Unsigned integer (``uint32_t``).
@@ -1075,34 +1075,21 @@ DEFAULT VALUE:
     The default value is 0.
 DESCRIPTION:
-    ``CONFIGURE_MAXIMUM_POSIX_THREADS`` is the maximum number of POSIX API
-    Threads that can be concurrently active.
+    ``CONFIGURE_MAXIMUM_POSIX_KEYS`` is the maximum number of POSIX API Keys
+    that can be concurrently active.
 NOTES:
     This object class can be configured in unlimited allocation mode.
-    This calculations for the required memory in the RTEMS Workspace for
-    threads assume that each thread has a minimum stack size and has floating
-    point support enabled.  The configuration parameter
-    ``CONFIGURE_EXTRA_TASK_STACKS`` is used to specify thread stack
-    requirements *ABOVE* the minimum size required.  See :ref:`Reserve
-    Task/Thread Stack Memory Above Minimum` for more information about
-    ``CONFIGURE_EXTRA_TASK_STACKS``.
-    The maximum number of Classic API Tasks is specified by
-    ``CONFIGURE_MAXIMUM_TASKS``.
-    All POSIX threads have floating point enabled.
-.. index:: CONFIGURE_MAXIMUM_POSIX_KEYS
+.. index:: CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES
-.. _CONFIGURE_MAXIMUM_POSIX_KEYS:
+.. _CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES:
-CONFIGURE_MAXIMUM_POSIX_KEYS
+CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES
 CONSTANT:
-    ``CONFIGURE_MAXIMUM_POSIX_KEYS``
+    ``CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES``
 DATA TYPE:
@@ -1114,21 +1101,21 @@ DEFAULT VALUE:
 DESCRIPTION:
-    ``CONFIGURE_MAXIMUM_POSIX_KEYS`` is the maximum number of POSIX API Keys
-    that can be concurrently active.
+    ``CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES`` is the maximum number of POSIX
+    API Message Queues that can be concurrently active.
 NOTES:
-.. index:: CONFIGURE_MAXIMUM_POSIX_TIMERS
+.. index:: CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS
-.. _CONFIGURE_MAXIMUM_POSIX_TIMERS:
+.. _CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS:
-CONFIGURE_MAXIMUM_POSIX_TIMERS
+CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS
 CONSTANT:
-    ``CONFIGURE_MAXIMUM_POSIX_TIMERS``
+    ``CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS``
 DATA TYPE:
@@ -1140,21 +1127,21 @@ DEFAULT VALUE:
 DESCRIPTION:
-    ``CONFIGURE_MAXIMUM_POSIX_TIMERS`` is the maximum number of POSIX API
-    Timers that can be concurrently active.
+    ``CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS`` is the maximum number of POSIX
+    API Queued Signals that can be concurrently active.
 NOTES:
-    This object class can be configured in unlimited allocation mode.
+    None.
-.. index:: CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS
+.. index:: CONFIGURE_MAXIMUM_POSIX_SEMAPHORES
-.. _CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS:
+.. _CONFIGURE_MAXIMUM_POSIX_SEMAPHORES:
-CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS
+CONFIGURE_MAXIMUM_POSIX_SEMAPHORES
 CONSTANT:
-    ``CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS``
+    ``CONFIGURE_MAXIMUM_POSIX_SEMAPHORES``
 DATA TYPE:
@@ -1166,21 +1153,24 @@ DEFAULT VALUE:
 DESCRIPTION:
-    ``CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS`` is the maximum number of POSIX
-    API Queued Signals that can be concurrently active.
+    ``CONFIGURE_MAXIMUM_POSIX_SEMAPHORES`` is the maximum number of POSIX API
+    Named Semaphores that can be concurrently active.  Named semaphores are
+    created with ``sem_open()``.  Semaphores initialized with ``sem_init()``
+    are not affected by this configuration option since the storage space for
+    these semaphores is user-provided.
 NOTES:
     None.
-.. index:: CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES
+.. index:: CONFIGURE_MAXIMUM_POSIX_TIMERS
-.. _CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES:
+.. _CONFIGURE_MAXIMUM_POSIX_TIMERS:
-CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES
+CONFIGURE_MAXIMUM_POSIX_TIMERS
 CONSTANT:
-    ``CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES``
+    ``CONFIGURE_MAXIMUM_POSIX_TIMERS``
 DATA TYPE:
@@ -1192,21 +1182,21 @@ DEFAULT VALUE:
 DESCRIPTION:
-    ``CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES`` is the maximum number of POSIX
-    API Message Queues that can be concurrently active.
+    ``CONFIGURE_MAXIMUM_POSIX_TIMERS`` is the maximum number of POSIX API
+    Timers that can be concurrently active.
 NOTES:
-.. index:: CONFIGURE_MAXIMUM_POSIX_SEMAPHORES
+.. index:: CONFIGURE_MAXIMUM_POSIX_THREADS
-.. _CONFIGURE_MAXIMUM_POSIX_SEMAPHORES:
+.. _CONFIGURE_MAXIMUM_POSIX_THREADS:
-CONFIGURE_MAXIMUM_POSIX_SEMAPHORES
+CONFIGURE_MAXIMUM_POSIX_THREADS
 CONSTANT:
-    ``CONFIGURE_MAXIMUM_POSIX_SEMAPHORES``
+    ``CONFIGURE_MAXIMUM_POSIX_THREADS``
 DATA TYPE:
@@ -1218,14 +1208,24 @@ DEFAULT VALUE:
 DESCRIPTION:
-    ``CONFIGURE_MAXIMUM_POSIX_SEMAPHORES`` is the maximum number of POSIX API
-    Named Semaphores that can be concurrently active.  Named semaphores are
-    created with ``sem_open()``.  Semaphores initialized with ``sem_init()``
-    are not affected by this configuration option since the storage space for
-    these semaphores is user-provided.
+    ``CONFIGURE_MAXIMUM_POSIX_THREADS`` is the maximum number of POSIX API
+    Threads that can be concurrently active.
 NOTES:
-    None.
+    This object class can be configured in unlimited allocation mode.
+    This calculations for the required memory in the RTEMS Workspace for
+    threads assume that each thread has a minimum stack size and has floating
+    point support enabled.  The configuration parameter
+    ``CONFIGURE_EXTRA_TASK_STACKS`` is used to specify thread stack
+    requirements *ABOVE* the minimum size required.  See :ref:`Reserve
+    Task/Thread Stack Memory Above Minimum` for more information about
+    ``CONFIGURE_EXTRA_TASK_STACKS``.
+    The maximum number of Classic API Tasks is specified by
+    ``CONFIGURE_MAXIMUM_TASKS``.
+    All POSIX threads have floating point enabled.
 POSIX Initialization Threads Table Configuration
2.13.7
