[PATCH] CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE
Joel Sherrill
joel at rtems.org
Tue Aug 7 15:21:45 UTC 2018
This seems reasonable.
On Tue, Aug 7, 2018 at 1:00 AM, Sebastian Huber <
> Make CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE configurable by the user.
> Update #3434.
> cpukit/include/rtems/confdefs.h | 5 +++++
> cpukit/include/rtems/posix/pthread.h | 2 ++
> cpukit/include/rtems/posix/pthreadimpl.h | 2 +-
> testsuites/psxtests/psxconfig01/init.c | 17 +++++++++++++++++
> 4 files changed, 25 insertions(+), 1 deletion(-)
> diff --git a/cpukit/include/rtems/confdefs.h b/cpukit/include/rtems/
> confdefs.h
> index 6e7bcdf570..8119436e7c 100644
> --- a/cpukit/include/rtems/confdefs.h
> +++ b/cpukit/include/rtems/confdefs.h
> @@ -1165,8 +1165,10 @@ extern rtems_initialization_tasks_table
> Initialization_tasks[];
> * This specifies the default POSIX thread stack size. By default, it is
> * twice that recommended for the port.
> +#ifndef CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE
> #define CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE \
> (2 * CONFIGURE_MINIMUM_TASK_STACK_SIZE)
> +#endif
> * @brief Idle task stack size configuration.
> @@ -3050,6 +3052,9 @@ extern rtems_initialization_tasks_table
> CONFIGURE_POSIX_INIT_THREAD_TABLE_SIZE,
> CONFIGURE_POSIX_INIT_THREAD_TABLE_NAME
> + size_t _Configuration_POSIX_Minimum_stack_size =
> + CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE;
> #endif
> diff --git a/cpukit/include/rtems/posix/pthread.h
> b/cpukit/include/rtems/posix/pthread.h
> index 05783ff4ad..818d0f89d0 100644
> --- a/cpukit/include/rtems/posix/pthread.h
> +++ b/cpukit/include/rtems/posix/pthread.h
> @@ -37,6 +37,8 @@ extern "C" {
> +extern size_t _Configuration_POSIX_Minimum_stack_size;
> * @brief POSIX threads initialize user threads body.
> diff --git a/cpukit/include/rtems/posix/pthreadimpl.h
> b/cpukit/include/rtems/posix/pthreadimpl.h
> index e6ed1b8990..d900207fbd 100644
> --- a/cpukit/include/rtems/posix/pthreadimpl.h
> +++ b/cpukit/include/rtems/posix/pthreadimpl.h
> @@ -40,7 +40,7 @@ extern "C" {
> * The following sets the minimum stack size for POSIX threads.
> -#define PTHREAD_MINIMUM_STACK_SIZE (_Stack_Minimum() * 2)
> +#define PTHREAD_MINIMUM_STACK_SIZE _Configuration_POSIX_Minimum_
> stack_size
> * The following defines the information control block used to manage
> diff --git a/testsuites/psxtests/psxconfig01/init.c b/testsuites/psxtests/
> psxconfig01/init.c
> index 910932a997..70e489823b 100644
> --- a/testsuites/psxtests/psxconfig01/init.c
> +++ b/testsuites/psxtests/psxconfig01/init.c
> @@ -25,6 +25,8 @@
> #include "config.h"
> #endif
> +#define _GNU_SOURCE
> #include <rtems/test.h>
> #include <tmacros.h>
> @@ -65,6 +67,8 @@ const char rtems_test_name[] = "PSXCONFIG 1";
> #define CONFIGURE_MAXIMUM_POSIX_SEMAPHORES 41
> #define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
> +#define CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE CPU_STACK_MINIMUM_SIZE
> #define CONFIGURE_MAXIMUM_POSIX_THREADS 3
> #define CONFIGURE_MAXIMUM_POSIX_TIMERS 47
> @@ -462,8 +466,21 @@ static rtems_task Init(rtems_task_argument argument)
> #ifdef CONFIGURE_MAXIMUM_POSIX_THREADS
> for (i = 0; i < CONFIGURE_MAXIMUM_POSIX_THREADS; ++i) {
> pthread_t thread;
> + pthread_attr_t attr;
> + size_t stack_size;
> eno = pthread_create(&thread, NULL, posix_thread, NULL);
> rtems_test_assert(eno == 0);
> + eno = pthread_getattr_np(thread, &attr);
> + rtems_test_assert(eno == 0);
> + eno = pthread_attr_getstacksize(&attr, &stack_size);
> + rtems_test_assert(stack_size == CPU_STACK_MINIMUM_SIZE);
> + eno = pthread_attr_destroy(&attr);
> rtems_resource_snapshot_take(&snapshot);
> rtems_test_assert(
> 2.13.7
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180807/53af6194/attachment.html>
